As predicted, SSDs in DIMM slots now becoming reality
Mike
Windows Forum Admin
Designing faster and more efficient enterprise server & storage solutions is now possible with Viking Modular Solutions™ SATADIMM. The SATADIMM is a high-performance, high-availability Enterprise Class Solid State Drive (SSD) in an industry-standard JEDEC 240-pin DDR3 DIMM form factor (JEDEC MO-269). Viking Modular’s SATADIMM is designed to take advantage of available DDR3 DIMM sockets, deriving power from the 1.5V supply to the DIMM socket; eliminating the need for a power cable. Simply insert SATADIMM into any available DIMM socket, connect a SATA data cable and begin enjoying all the benefits of high performance SATA SSD.
For new designs, system architects will appreciate that the SATA data signals can be routed directly to the socket thus eliminating the need for any cables. Furthermore, a socket can be easily and cost-effectively designed to be used for either DDR3 DRAM modules or SATADIMM operation.
Adding SATADIMM to any available 240-pin DIMM socket delivers the performance and power savings you want from a SSD at a fraction of the space required to house a typical 2.5” SSD.
Break free from traditional hard drive form factors with SATADIMM and explore a whole new world of design possibilities.
Features
  • Best in class sequential and random performance
  • Enterprise MLC (eMLC) NAND flash supported
  • Advanced SSD-specific SMART command support
  • Intelligent write management techniques for optimized endurance
  • Protection against catastrophic flash sector/page/block failures
  • Patented power fail data protection (super capacitor)
  • Optional performance-throttling to guarantee service life
  • Built-in AES-128 encryption for secure data protection
  • Compatible with SAS host systems and infrastructure
  • Compatible with standard operating systems, TRIM command support
  • Industry standard JEDEC MO-269 form factor
Viking Modular SATADIMM
[H]ard|OCP - SATADIMM: Enterprise SSD in a DIMM Form Factor
