asus laptop cursor problem
my typing cursor moves around when i type. not always, but often enough for it to be annoying (it did it twice this message for example).
the typing bar moves back a seemingly random amount of places for no reason.
I have no problems with Vista.Just with windows 7. Had it with ver. 7000 and 7100. Anyone else having this problem? I use a mouse not touch pad.
funky cursor
Hi, Scubadog,
Have you received a reply? I am having the same problem except my cursor snaps across the active window like it was shot with a rubberband. Also, when I try to do something easy, like putting a check in a box, it takes maybe 30 to 45 seconds to do it because the cursor won't stay put!. I don't know if if it makes any difference, but I am using my touchpad. This is driving me nuts! I can't find anything anywhere that relates to this type of problem. I would be very interested if you have figured this out.
Thanks,
judiko
Nan
cursor jumps all over the place
I am having the same problem. The frequency is high and FRUSTRATING! I am about ready to give up. Has anyone responded and identified a way to fix this? This problem exists when I am working on documents, email, etc. I am also having problems with my internet connection, specifically aol.
Google Touchfreeze it does a pretty good job of fixing that problem.
oh.. and give me some rep points... ... you are welcome.
