ATI Catalyst unistall problem
Hi!
I can't install the upgrade to Windows7 because a message on compatibility issues apears saying that ATI Catalyst Control Center must be uninstalled.
I removed it with windows unistall tool.
But still no improvement.
Windows7 instalations aborts just when it is almost finished the instalation procedure.
What can I do to solve this?
Thank you for your time.
Marco
Windows Forum Admin
Microsoft MVP
You could try using this app found here: Guru3D - Driver Sweeper or try booting from the disk itself (this means you'll have to change the boot menu via the bios)
May I also suggest that you do a clean install instead of upgrading.. We have had many posts from users experiencing problems after upgrading. The solution usually being to do a clean install..
