ATTEMPTED_WRITE_TO_READONLY_MEMORY (be)
An attempt was made to write to readonly memory. The guilty driver is on the
stack trace (and is typically the current instruction pointer).
When possible, the guilty driver's name (Unicode string) is printed on
the bugcheck screen and saved in KiBugCheckDriver.
Arguments:
Arg1: fffff88004c0d0a7, Virtual address for the attempted write.
Arg2: 32d00000751a2121, PTE contents.
Arg3: fffff88008b9f740, (reserved)
Arg4: 000000000000000b, (reserved)
Debugging Details:
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xBE
PROCESS_NAME: audiodg.exe
CURRENT_IRQL: 0
TRAP_FRAME: fffff88008b9f740 -- (.trap 0xfffff88008b9f740)
rax=fffffa80063a0540 rbx=0000000000000000 rcx=fffffa80073a0960
rdx=fffff88004c09eb0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88004c18354 rsp=fffff88008b9f8d0 rbp=fffffa8004666c10
r8=fffff88004c0d11c r9=0000000000000000 r10=0000000000000000
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl nz ac pe cy
usbaudio!USBType1RenderClosePin+0x8:
fffff880`04c18354 4110488b adc byte ptr [r8-75h],cl ds:fffff880`04c0d0a7=4c
Resetting default scope
MISALIGNED_IP:
usbaudio!USBType1RenderClosePin+8
LAST_CONTROL_TRANSFER: from fffff8000323f5e2 to fffff80003293d00
STACK_TEXT:
fffff880`08b9f5d8 fffff800`0323f5e2 : 00000000`000000be fffff880`04c0d0a7 32d00000`751a2121 fffff880`08b9f740 : nt!KeBugCheckEx
fffff880`08b9f5e0 fffff800`03291e2e : 00000000`00000001 fffff880`04c0d0a7 fffffa80`06ada400 fffffa80`04666c10 : nt! ?? ::FNODOBFM::`string'+0x45d6e
fffff880`08b9f740 fffff880`04c18354 : fffffa80`04666c10 fffff880`04c0d148 fffffa80`073a0948 fffffa80`04244f20 : nt!KiPageFault+0x16e
fffff880`08b9f8d0 fffffa80`04666c10 : fffffa80`04666e90 fffff880`0421ba14 fffffa80`04666c10 fffffa80`00000000 : usbaudio!USBType1RenderClosePin+0x8
fffff880`08b9f900 fffffa80`04666e90 : fffff880`0421ba14 fffffa80`04666c10 fffffa80`00000000 fffff880`04213100 : 0xfffffa80`04666c10
fffff880`08b9f908 fffff880`0421ba14 : fffffa80`04666c10 fffffa80`00000000 fffff880`04213100 fffffa80`04666c00 : 0xfffffa80`04666e90
fffff880`08b9f910 fffff880`0421cce4 : 00000000`00000000 fffffa80`073a0860 fffffa80`04666c10 fffffa80`04283480 : ks!KspClose+0xfc
fffff880`08b9f950 fffff880`0421b52d : 00000000`00000000 fffffa80`04666ed8 fffffa80`06363520 fffffa80`04666c10 : ks!CKsPin::DispatchClose+0x2f4
fffff880`08b9f9c0 fffff880`04daf825 : 00000000`00000001 fffffa80`06363520 fffffa80`04244ef0 00000000`00000000 : ks!DispatchClose+0x4d
fffff880`08b9f9f0 fffff800`0358fa1e : fffffa80`04244f20 00000000`00000001 fffffa80`00000000 fffffa80`04666c10 : ksthunk!CKernelFilterDevice::DispatchIrp+0x11d
fffff880`08b9fa50 fffff800`0329db14 : 00000000`00000008 fffffa80`04688830 fffffa80`03a327b0 fffffa80`03ae0011 : nt!IopDeleteFile+0x11e
fffff880`08b9fae0 fffff800`0358a614 : fffffa80`04688830 00000000`00000000 fffffa80`03bf5b60 00000000`00000000 : nt!ObfDereferenceObject+0xd4
fffff880`08b9fb40 fffff800`0358abc4 : 00000000`000002fc fffffa80`04688830 fffff8a0`10919510 00000000`000002fc : nt!ObpCloseHandleTableEntry+0xc4
fffff880`08b9fbd0 fffff800`03292f93 : fffffa80`03bf5b60 fffff880`08b9fca0 000007fe`f5c4d2a0 fffffa80`03f0ee90 : nt!ObpCloseHandle+0x94
fffff880`08b9fc20 00000000`779b140a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`00ecdce8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x779b140a
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: usbaudio!USBType1RenderClosePin+8
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_IP_MISALIGNED_usbaudio.sys
Followup: MachineOwner
