Thanks sir Please See Details of my system
Motherboard -Intel D102GGC2
Processer -Pentium 4 524 (Prescott) 3.06GHz [G1]
CPU-Intel(R) Pentium(R) 4 CPU 3.06GHz
Graphic controller -ATI Raedon Graphic Controller
Realtek 8139 Ethernet Device
ATI Azalia Audio Device
Board AAD42789-203-D102GGC2-BTGC629002DR-Intel Corporation
System Information Viewer V4.04 PRATIK-LAD:
RATIK
SMBios V2.4 DMI V2.4 MPS V1.4 Count 29 Size 1312 Description BIOS Intel
CPU-0 Intel® Corporation 3.0 volts Pentium® 4 Other Intel® Pentium® 4 CPU 3.06GHz 3.07GHz Max 4.00GHz Ext 133MHz
L1 Cache Unknown Cur: 16KB Max: 16KB Write Back 8-Way Set-Associative
L2 Cache Unknown Cur: 1MB Max: 1MB Write Back 8-Way Set-Associative
BIOS GC11020M.86A.1065.2006.0502.1638 Date: 05/02/2006 [ Options 1 ] Intel Corp. ROM Base 0xF000 Size 512KB
Board AAD42789-203 D102GGC2 BTGC629002DR Intel Corporation
Port PRIMARY Other Internal on-board IDE
Port SECONDARY Other Internal on-board IDE
Port ATX_PWR Other Internal ATX_PWR
Slot PCIE X16 SLOT ID 5 x16 PCI Express [ 0 - 17 - 0 ] ATI 437A SATA Controller (GC2)
Slot PCIE X1 SLOT 1 ID 9 x1 PCI Express | 0 - 09 - 0 | Available
Slot PCI SLOT 1 ID 7 32-bit PCI [ 0 - 19 - 0 ] ATI SB400 USB OHCI Controller
Slot PCI SLOT 2 ID 8 32-bit PCI | 0 - 08 - 0 | Available
Onboard 1 [Y] Video Device 1 ATI Raedon Graphic Controller
Onboard 1 [Y] Ethernet Device 1 Realtek 8139 Ethernet Device
Onboard 1 [Y] Sound Device 1 ATI Azalia Audio Device
Active Language enUS Available 1
System Boot Length 10 00 00 00 00 00 00 00 00 00 00
Strings 1 String 1 ETK_VER_02.00
Memory on Motherboard System Memory Handle 0xFFFE Maximum capacity 1.00GB, 4 devices with No correction
Memory BANK0 DIMM0 Not Installed DDR RAM DIMM Tag Unknown
Memory BANK0 DIMM1 Not Installed DDR RAM DIMM Tag Unknown
Memory BANK1 DIMM2 Not Installed DDR RAM DIMM Tag Unknown
Memory BANK1 DIMM3 Size 1.00GB Bits 64 DDR RAM DIMM Speed 667MHz Man 0000000000000000 Ser 0000-0000 Tag Unknown Part DNHMAU1GC8FER2-A6.
[System] <- SIV - System Information Viewer V4.04 PRATIK-LAD:
RATIK
Product Windows 7 Ultimate V6.1 Build 7600 Build 1
Type: Multiprocessor Free
Owner PRATIK Edition ID Ultimate SystemRoot D:\Windows
InstallDate 2010-01-24 07:48:51 Sunday (1264319331)
Product Type WinNT Product Suite Terminal Server
Windows Desktop Display WinSta0\Default
Windows Directory D:\Windows
System Directory D:\Windows\system32
[CPU-0 GenuineIntel Patch 03 A08F3FFF] Intel Pentium 4 524 (Prescott) [G1] 3.07GHz Socket T LGA-775 (Intel(R) Pentium(R) 4 CPU 3.06GHz) (x86 Family 15 Model 4 Stepping 9) <SIIP64>
[CPU-1 GenuineIntel Patch 03 A08F3FFF] Intel Pentium 4 524 (Prescott) [G1] 3.07GHz Socket T LGA-775 (Intel(R) Pentium(R) 4 CPU 3.06GHz) (x86 Family 15 Model 4 Stepping 9) <SIIP64>
Mains Power, no Battery Time Zone India Standard Time (India Daylight Time) Adjustment 15,625µs
[Physical Memory 896MB in 4 Areas] Current Profile Undocked Profile, Portable System, currently Undocked HAL ACPI x86 platform
Identifier AT/AT COMPATIBLE
System Bios Date 05/02/06 System Bios Version DELL - 429
Video Bios Date 05/09/08
Primary Desktop Display #1 Generic PnP Monitor (GSM4B05) (
\\.\DISPLAY1\Monitor0)
ATI RADEON XPRESS 200 Series cdd 1440 x 900 @0.0 60 Hz 32 bit colour
Video Description ATI RADEON XPRESS 200 Series 128 MB memory
Video Adapter ATI Radeon XPRESS 200 Series (ATI RADEON XPRESS 200 Series)
Video DAC Internal DAC(400MHz) Video Chip Radeon Xpress Series (0x5A61) Bios BK-ATI VER008.046I.003.000
Display #2 Unknown (
\\.\DISPLAYV1)
Video Description RDPDD Chained DD
Display #3 Unknown (
\\.\DISPLAYV2)
Video Description RDP Encoder Mirror Driver
Display #4 Unknown (
\\.\DISPLAYV3)
Video Description RDP Reflector Display Driver
Monitor names from C:\Downloads\siv\MONDEVS.txt Date 2009-11-19 Version 045 (8,254)
