Could you give the model number of the Conexant driver?
Hello, it's CONEXANT HD2 Smartaudio (this one ftp://ftp.hp.com/pub/softpaq/sp40001-40500/sp40170.exe ) after the WINDOWS UPDATE, but now it's this one automatically run by Windows ilote c:\windows\system32\drivers\hdaudio.sys (6.1.7100.0, 342,00 Ko (350 208 octets), 22/04/2009 06:15) Sorry for all the questions, but........
thank you for your help in advance !!! In order to troubleshoot your problem we need to know more detailed specs of your system hardware.
1. Go to Start > Run, and type msinfo32, look under the
Components section for hardware identification
2. Go to Control Panel > Device Manager and look for any entry that has a
yellow flag beside it
The exact make and model of your motherboard would be of great help also.
Quanta 30DA, all other info in my profile Are you using the 32-bit or 64-bit version?
64 bits Was it a \"clean\" install or an upgrade?
Install w/o formating, before was Vista x64 Are you dual-booting?
nope Are you suing the official RC directly from Microsoft?
yes, official French RC 7100 release Did this occur immediately after install?
Yes, it was found by system and installed as it is now, my Conexant drivers worked only 1 day, before Windows decides to reinstall MS driver again. Do you recall installing any software that may have caused the problem?
not at all, in fact quite all sounds work propely, but I have the scratch on every switch on and off and tactile touchpad doesn' react when you make mute the sounds..
