Windows 7 audio services don't auto- start on startup
gauloises
Honorable Member
Hi for all
pls. need help,
audio services wont start automatically on start up, so I have to restart manually every time at startup.any solution for this issue???
thanks
hi welcome to the forums
you can try the followin
go to start
control panel
system and security
admin tools
services
right click the service
click propterties
in the middle of the box it says
startup type : "what ever "
change the startup type to automatic
close thte box , restart pc and see if it works
I assume you are probably talking about the Windows native audio services, so....
type
services.msc
into the search or run dialog box and hit enter.
Scoll as needed and find
Multimedia Class Scheduler
Windows Audio
Windows Audio Endpoint Builder
Double click them and make sure their respective "Startup Type" is set to Automatic
Additonally you may want to search the event viewer to see if there are any error logs being reported pertaining to audio. Expand Windows Logs, check application and system. A quick and dirty right click and find "audio" might get you started. Perhaps a third party audio service from another vendor might be conflicting.
Thanks for answering,I checked all native windows audio services, all are setted to "automatic",any way i'll reboot and see.
Thanks again and again.
I would think if it takes two boots to get the audio to work it is not recognizing the driver on the first attempt. If the other suggestions are not the fix, maybe check the Device Manager to see what you show for sound. You may have one or more sound devices, but at least one should probably be an HD Audio and they should not have any yellow marks.
On my system, I load the Realtek drivers which also have their own control panel. If yours is not working correctly, you might want to check your manufacturer to see if any Windows 7 drivers are available.
Top Bottom
