Windows 7 Bad Pool Header, Driver IRQL Not Less Or Equal, Random crashes
Adrius
Please look at post #5 for full details (CPUZ Screens, RAMMon, and more minidumps)
Hi all,
My PC has been randomly crashing, and usually it's about 2 or 3 weeks between crashes so I've never really looked into it. But now it is happening much more frequently especially after I've installed a Battlefield Bad Company 2 which is notorious for crashes. But again, the crashes have been happening way before I ever tried installing the game, which leads me to think there is a deeper issue.
I'm really at a loss, I've updated all the drivers I know of and can't seem to pin point the problem.
Minidump is attached. Thanks for any help!
  • dumpcheck.zip
I just had another BSOD crash after a reboot, opened up chrome, started a flash video. The message at the top read: MEMORY MANAGEMENT.
I've attached the minidump for this one crash.
Any help would be greatly appreciated! Thanks.
  • memory_management_minidump.zip
You may want to take this to the BSOD forum. Perhaps someone from there will come by, but it may take some time.
Until then, you seem to have and EVGA Precision driver from 2005. Could you look for a newer version of that utility, or keep it from starting if you can?
RTCore64 RTCore64.sys Wed May 25 01:39:12 2005
Thanks saltgrass, i'll give that a try. That utility doesn't usually start unless I've started it manually, and I've been experiencing the crashes even when it is off. Nevertheless i'll try to find a newer version.
I'll post this in BSOD forum as well. Thanks.
A Mix of Crashes: Driver IRQL Not Less or Equal, Bad Pool Header/Caller, System Service Exception
Hi all,
My PC has been randomly crashing and each time the message on the blue screen is different. Usually it's about 2 or 3 weeks between crashes so I've never really looked into it. But now it is happening much more frequently irrespective of what I am doing, which leads me to think there is a deeper issue.
I also updated my motherboard BIOS as well today hoping it would fix something.
Minidumps are attached. CPUZ and Rammon info attached.
CPUZ_memory.JPGCPUZ_SPD_slot1.JPGCPUZ_SPD_slot2.JPGCPUZ_SPD_slot3.JPGCPUZ_SPD_slot4.JPG
  • dumpcheck.zip
  • RAMMon - SPD Info.txt
  • 051011-37112-01.dmp
Re: A Mix of Crashes: Driver IRQL Not Less or Equal, Bad Pool Header/Caller, System Service Exception
Moved and merged two threads to save confusion.
051011-37112-01.dmp
BugCheck 3B, {c0000005, fffff80002cc76c2, fffff8800761fe50, 0}
PROCESS_NAME: svchost.exe
Probably caused by : memory_corruption
1. GSKILL F2-8500CL5-2GBPK is rated as 800Mhz 5-5-5-15 1.8v.
Overclocking tools as MSI Afterburner is likely why you have it currently overstock 1066Mhz 5-7-7-20.
2. Update drivers:
Creative (June 2009)
Wacom Mouse (February 2007)
3. Should crashes ever re-occur after you set the memory right and update drivers, uninstall Daemon Tools and AVG. Replace AVG with MSE.
CRASH DUMPS
Loading Dump File [F:\DMP\051011-37112-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`02c15000 PsLoadedModuleList = 0xfffff800`02e5ae90
Debug session time: Tue May 10 16:31:53.642 2011 (UTC - 4:00)
System Uptime: 0 days 0:04:29.453
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: memory_corruption
2: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002cc76c2, Address of the instruction which caused the bugcheck
Arg3: fffff8800761fe50, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
nt!MiDeleteVirtualAddresses+4ba
fffff800`02cc76c2 8b00            mov     eax,dword ptr [rax]
CONTEXT:  fffff8800761fe50 -- (.cxr 0xfffff8800761fe50)
rax=f8a00f1210000001 rbx=fffffa8001516b30 rcx=fffffa8003d2b048
rdx=0000000000000000 rsi=da70000070791025 rdi=fffff6800007e300
rip=fffff80002cc76c2 rsp=fffff88007620830 rbp=000000000fc60000
 r8=0000000000001000  r9=fffffa8007b5ab30 r10=00000000000000f4
r11=0000000000000000 r12=fffff6800007eff8 r13=0000000000005da7
r14=0000000000000000 r15=fffffa8000ac2a20
iopl=0         nv up ei ng nz ac po cy
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010297
nt!MiDeleteVirtualAddresses+0x4ba:
fffff800`02cc76c2 8b00            mov     eax,dword ptr [rax] ds:002b:f8a00f12`10000001=????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  CODE_CORRUPTION
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff80002cc76c2
STACK_TEXT:
fffff880`07620830 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MiDeleteVirtualAddresses+0x4ba
CHKIMG_EXTENSION: !chkimg -lo 50 -db !nt
11 errors : !nt (fffff80002cc74cb-fffff80002cc76fb)
fffff80002cc74c0  20  00  00  00  48  8b  47  08  48  8b  50 *00  44  0f  b7  82  ...H.G.H.P.D...
fffff80002cc74d0  88  00  00  00  0f  b7  82  8a  00  00  00 *00  44  89  84  24 ............D..$
fffff80002cc74f0  73  25  45 *00  b7  c0  48  8d  8c  24  98  00  00  00  48  81 s%E...H..$....H.
fffff80002cc76c0  03  00  8b *00  24  c0  01  00  00  85  c9 *04  85  3d  01  00 ....$........=..
fffff80002cc76d0  00  4d  8d *00  98  03  00  00  45  8b  c5 *00  8b  cd  49  8b .M......E.....I.
fffff80002cc76e0  5c  24  68 *00  8b  d4  48  89  5c  24  78 *00  80  d8  fd  ff \$h...H.\$x.....
fffff80002cc76f0  48  8b  4b *00  44  8b  f8  49  b8  ff  ff *00  ff  0f  00  00 H.K.D..I........
MODULE_NAME: memory_corruption
IMAGE_NAME:  memory_corruption
FOLLOWUP_NAME:  memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MEMORY_CORRUPTOR:  STRIDE
STACK_COMMAND:  .cxr 0xfffff8800761fe50 ; kb
FAILURE_BUCKET_ID:  X64_MEMORY_CORRUPTION_STRIDE
DRIVERS
fffff880`04334000 fffff880`04372000   1394ohci 1394ohci.sys Sat Nov 20 05:44:56 2010 (4CE7A6A8)
fffff880`04372000 fffff880`043b7000   a7lb2er3 a7lb2er3.SYS Tue Jul 14 17:12:55 2009 (4A5CF4D7)
fffff880`0102f000 fffff880`01086000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`02ee4000 fffff880`02f6d000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`043c0000 fffff880`043d6000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00fef000 fffff880`00ffa000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`0befd000 fffff880`0bf08000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00fe6000 fffff880`00fef000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00dd3000 fffff880`00dfd000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff960`00950000 fffff960`009b1000   ATMFD    ATMFD.DLL    Sat Feb 19 04:00:32 2011 (4D5F86B0)
fffff880`045aa000 fffff880`045f1000   avgldx64 avgldx64.sys Thu Jun 03 17:06:48 2010 (4C081968)
fffff880`045a2000 fffff880`045a9080   avgmfx64 avgmfx64.sys Sun Apr 25 17:06:15 2010 (4BD4AEC7)
fffff880`02e4e000 fffff880`02e9f000   avgtdia  avgtdia.sys  Wed Apr 27 03:34:54 2011 (4DB7C71E)
fffff880`01833000 fffff880`0183a000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`04591000 fffff880`045a2000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`06dc2000 fffff880`06de0000   bowser   bowser.sys   Tue Feb 22 23:55:04 2011 (4D649328)
fffff960`006a0000 fffff960`006c7000   cdd      cdd.dll      unavailable (00000000)
fffff880`01800000 fffff880`0182a000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`00cd7000 fffff880`00d97000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`00e00000 fffff880`00e30000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00c79000 fffff880`00cd7000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01615000 fffff880`01687000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`04a51000 fffff880`04a61000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`063e0000 fffff880`063ee000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`044f0000 fffff880`04573000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`04da8000 fffff880`04ddd000   CT20XUT  CT20XUT.DLL  Wed Jun 17 01:00:53 2009 (4A387885)
fffff880`04a82000 fffff880`04b28580   ctaud2k  ctaud2k.sys  Wed Jun 17 00:59:35 2009 (4A387837)
fffff880`06283000 fffff880`063e0000   CTEXFIFX CTEXFIFX.DLL Wed Jun 17 01:00:48 2009 (4A387880)
fffff880`04d8d000 fffff880`04da8000   CTHWIUT  CTHWIUT.DLL  Wed Jun 17 01:00:57 2009 (4A387889)
fffff880`04bcb000 fffff880`04bfc000   ctoss2k  ctoss2k.sys  Wed Jun 17 00:57:34 2009 (4A3877BE)
fffff880`04a00000 fffff880`04a08000   ctprxy2k ctprxy2k.sys Wed Jun 17 00:59:38 2009 (4A38783A)
fffff880`04c92000 fffff880`04cca000   ctsfm2k  ctsfm2k.sys  Wed Jun 17 00:57:21 2009 (4A3877B1)
fffff880`04573000 fffff880`04591000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`044e1000 fffff880`044f0000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01b94000 fffff880`01baa000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04b66000 fffff880`04b88000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06200000 fffff880`06209000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`063ee000 fffff880`063fa000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06209000 fffff880`0621c000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0621c000 fffff880`06228000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0feb4000 fffff880`0ffa8000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`0ffa8000 fffff880`0ffee000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`06196000 fffff880`061e0000   emupia2k emupia2k.sys Wed Jun 17 00:57:13 2009 (4A3877A9)
fffff880`04d18000 fffff880`04d4e000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`0791a000 fffff880`07927000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`01390000 fffff880`013a4000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0799f000 fffff880`079aa000   flpydisk flpydisk.sys Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`01344000 fffff880`01390000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`01698000 fffff880`016a2000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01b5a000 fffff880`01b94000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`01a57000 fffff880`01aa1000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff880`04a44000 fffff880`04a51000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff880`0600a000 fffff880`0618b000   ha20x2k  ha20x2k.sys  Wed Jun 17 00:58:58 2009 (4A387812)
fffff800`031ff000 fffff800`03248000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`078f6000 fffff880`0791a000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`07932000 fffff880`0798e000   HdAudio  HdAudio.sys  Sat Nov 20 05:44:23 2010 (4CE7A687)
fffff880`04a64000 fffff880`04a7d000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`043b7000 fffff880`043bf080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`06228000 fffff880`06236000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`06cf9000 fffff880`06dc2000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01b51000 fffff880`01b5a000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`04426000 fffff880`0443c000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`045f1000 fffff880`04600000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04ddd000 fffff880`04deb000   kbdhid   kbdhid.sys   Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff800`00bb4000 fffff800`00bbe000   kdcom    kdcom.dll    Sat Feb 05 11:52:49 2011 (4D4D8061)
fffff880`04b88000 fffff880`04bcb000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`015c6000 fffff880`015e1000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`0125e000 fffff880`01289000   ksecpkg  ksecpkg.sys  Sat Nov 20 05:10:34 2010 (4CE79E9A)
fffff880`04a08000 fffff880`04a0d200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`04ceb000 fffff880`04d00000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04c00000 fffff880`04c23000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c16000 fffff880`00c65000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 08:03:51 2010 (4CE7C737)
fffff880`06253000 fffff880`06261000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`02e1a000 fffff880`02e29000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`061e0000 fffff880`061ed000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00f90000 fffff880`00faa000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`06de0000 fffff880`06df8000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`06c00000 fffff880`06c2d000   mrxsmb   mrxsmb.sys   Tue Feb 22 23:56:22 2011 (4D649376)
fffff880`06c2d000 fffff880`06c7a000   mrxsmb10 mrxsmb10.sys Tue Feb 22 23:55:12 2011 (4D649330)
fffff880`06c7a000 fffff880`06c9e000   mrxsmb20 mrxsmb20.sys Tue Feb 22 23:55:12 2011 (4D649330)
fffff880`01600000 fffff880`0160b000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01086000 fffff880`01090000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01200000 fffff880`0125e000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`044d6000 fffff880`044e1000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01b3f000 fffff880`01b51000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`016a2000 fffff880`01795000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`04200000 fffff880`0420c000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0420c000 fffff880`0423b000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`04d78000 fffff880`04d8d000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`02f9c000 fffff880`02fab000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02e9f000 fffff880`02ee4000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`01795000 fffff880`017f5000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`015e1000 fffff880`015f2000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`044ca000 fffff880`044d6000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c15000 fffff800`031ff000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`01423000 fffff880`015c6000   Ntfs     Ntfs.sys     Thu Mar 10 22:39:39 2011 (4D79997B)
fffff880`0182a000 fffff880`01833000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`0feb2000 fffff880`0feb3180   nvBridge nvBridge.kmd Thu Apr 07 23:14:49 2011 (4D9E7DA9)
fffff880`0f20d000 fffff880`0feb1300   nvlddmkm nvlddmkm.sys Thu Apr 07 23:22:12 2011 (4D9E7F64)
fffff880`00faa000 fffff880`00fd2000   nvraid   nvraid.sys   Fri Mar 19 16:59:20 2010 (4BA3E5A8)
fffff880`012b6000 fffff880`012e1000   nvstor   nvstor.sys   Fri Mar 19 16:45:11 2010 (4BA3E257)
fffff880`02f76000 fffff880`02f9c000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`04a27000 fffff880`04a44000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`0109d000 fffff880`010b2000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`00eea000 fffff880`00f1d000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`00f79000 fffff880`00f80000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00f80000 fffff880`00f90000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01687000 fffff880`01698000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`07069000 fffff880`0710f000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04b29000 fffff880`04b66000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c65000 fffff880`00c79000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`013a4000 fffff880`013afe00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
fffff880`043d6000 fffff880`043fa000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`0443c000 fffff880`04457000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04457000 fffff880`04478000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`02e00000 fffff880`02e1a000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04479000 fffff880`044ca000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`0423b000 fffff880`04246000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01bf0000 fffff880`01bf9000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01848000 fffff880`01851000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`017f5000 fffff880`017fe000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01b05000 fffff880`01b3f000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`04d00000 fffff880`04d18000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`042de000 fffff880`04334000   Rt64win7 Rt64win7.sys Wed Jun 23 05:10:45 2010 (4C21CF95)
fffff880`0bf08000 fffff880`0bf0e000   RTCore64 RTCore64.sys Wed May 25 02:39:12 2005 (42941D90)
fffff880`01000000 fffff880`0102f000   SCSIPORT SCSIPORT.SYS Sat Nov 20 05:34:01 2010 (4CE7A419)
fffff880`0710f000 fffff880`0711a000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`04a1b000 fffff880`04a27000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02fab000 fffff880`02fc8000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01afd000 fffff880`01b05000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0be8c000 fffff880`0befd000   spsys    spsys.sys    Mon May 11 13:20:58 2009 (4A085E7A)
fffff880`010cd000 fffff880`011f3000   sptd     sptd.sys     Sun Oct 11 16:55:14 2009 (4AD24632)
fffff880`0782d000 fffff880`078c5000   srv      srv.sys      Tue Feb 22 23:56:21 2011 (4D649375)
fffff880`0715d000 fffff880`071c7000   srv2     srv2.sys     Tue Feb 22 23:56:00 2011 (4D649360)
fffff880`0711a000 fffff880`0714b000   srvnet   srvnet.sys   Tue Feb 22 23:55:44 2011 (4D649350)
fffff880`012e1000 fffff880`01344000   storport storport.sys Thu Mar 10 23:30:23 2011 (4D79A55F)
fffff880`04a7d000 fffff880`04a7e480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01853000 fffff880`01a57000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`0714b000 fffff880`0715d000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`015f2000 fffff880`015ff000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`01400000 fffff880`01422000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`02fe3000 fffff880`02ff7000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`00430000 fffff960`0043a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`04400000 fffff880`04426000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`02e29000 fffff880`02e3b000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`06261000 fffff880`0627e000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`06236000 fffff880`06237f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`042a9000 fffff880`042ba000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04c38000 fffff880`04c92000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`04253000 fffff880`042a9000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0ffee000 fffff880`0fffb000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`01090000 fffff880`0109d000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0183a000 fffff880`01848000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01289000 fffff880`012ae000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00d97000 fffff880`00dd3000   vmbus    vmbus.sys    Sat Nov 20 04:57:29 2010 (4CE79B89)
fffff880`01aa1000 fffff880`01ab1000   vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`010b2000 fffff880`010c7000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00f1d000 fffff880`00f79000   volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`01ab1000 fffff880`01afd000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`061f5000 fffff880`061fe000   wacmoumonitor wacmoumonitor.sys Fri Jan 22 20:33:34 2010 (4B5A51EE)
fffff880`061ed000 fffff880`061f5000   wacommousefilter wacommousefilter.sys Fri Feb 16 13:12:17 2007 (45D5F401)
fffff880`04a61000 fffff880`04a63a00   wacomvhid wacomvhid.sys Mon Sep 21 19:29:14 2009 (4AB80C4A)
fffff880`02fc8000 fffff880`02fe3000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`01be0000 fffff880`01bf0000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e37000 fffff880`00edb000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00edb000 fffff880`00eea000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02f6d000 fffff880`02f76000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00050000 fffff960`00362000   win32k   win32k.sys   Wed Mar 02 22:51:40 2011 (4D6F104C)
fffff880`00fd2000 fffff880`00fe6000   winhv    winhv.sys    Sat Nov 20 04:20:02 2010 (4CE792C2)
fffff880`011f3000 fffff880`011fc000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`04cca000 fffff880`04ceb000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`078c5000 fffff880`078f6000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`06238000 fffff880`06253000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`07997000 fffff880`0799f000   drmkaud.sys
    Checksum:  00000000
    ImageSize:  00008000
fffff880`07995000 fffff880`07997000   MSPQM.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`07993000 fffff880`07995000   MSTEE.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`07990000 fffff880`07993000   MSKSSRV.sys
    Checksum:  00000000
    ImageSize:  00003000
fffff880`0798e000 fffff880`07990000   MSPCLOCK.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`07927000 fffff880`07932000   flpydisk.sys
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`04a0e000 fffff880`04a1b000   fdc.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`0618b000 fffff880`06196000   flpydisk.sys
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`042ba000 fffff880`042de000   HDAudBus.sys
    Checksum:  00000000
    ImageSize:  00024000
fffff880`01baa000 fffff880`01bb8000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01bb8000 fffff880`01bc4000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01bc4000 fffff880`01bcd000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01bcd000 fffff880`01be0000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`04cca000 fffff880`04d78000   ctac32k.sys
    Checksum:  00000000
    ImageSize:  000AE000
Wow cybercore, thank you! I made the changes to the ram and so far so good, programs that usually crash are now fine it seems. All my bios settings were set to Auto, so it confuses me as to why the they were overclocked. One question, is MSE, Microsoft Security Essentials? Thanks again.
To answer for Cybercore, if I may, yes it is. That with a weekly scan of Malwarebytes' Free. after you've updated its database should cover your security needs. AVG is well known for causng BSOD's on many Windows 7 systems. If this includes you, then:
Download the correct AVG Remover for your system (32 or 64 bit).
If you have AVG ID protection installed, download the AVGID Protection Remover from the above link as well (it wouldn't hurt to download and run it anyway). Download Link Removed due to 404 Error as AVG's replacement. Re-boot to Safe Mode. In Safe Mode run the AVG Removal tools. Re-boot to normal mode and install MSE. Make sure your Windows firewall is enabled!
You're welcome. Yes, MSE is Microsoft Security Essentials. However, if so far so good than no need to uninstall AVG. Only if blue screens re-occur.
Be sure to update Creative and Wacom.
cybercore, Elmer, thanks for such clear and concise instructions and help.
I have one last question which might be a little outside the scope of the thread but is RAM related. Before I bought the current RAM I'm using now I had a set of 4x1gb Crucial Ballistix PC8500 1066Mhz (serial: BL12864AA1065.16FD5), google tells me the stock timings are 5-5-5-15 at 2.2V. If i stick 2 sticks of Crucial RAM in with my Gskill RAM and kept the timings for the Gskill pair would it cause problems? If so is there any way to get them to work together or is it better to just leave them separate?
Cheers, and thanks!
Not necessarily but quite possible that it will cause blue screens. It may work well but as a simple rule it is recommended to buy ram kit of identical sticks. So if you pair different brands and it gives you blue screens -- you know why. You may wanna try though.
