Hi killstrelok and Welcome to the Forum.
STOP 0x0000001E: KMODE_EXCEPTION_NOT_HANDLED
Usual causes: Device driver, hardware, System service, compatibility, Remote control programs, memory, BIOS
Your latest dump file lists
ntkrnlmp.exe as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
As a Priority: AVG is known to be a cause of BSOD's on Windows 7 systems. I suggest that you uninstall it. Download the correct
AVG Remover for your system
(32 or 64 bit).
If you have AVG ID protection installed, download the
AVGID Protection Remover from the above link as well (it wouldn't hurt to download and run it anyway). Download
Link Removed due to 404 Error as AVG's replacement. Re-boot to Safe Mode. In Safe Mode run the
AVG Removal tools. Re-boot to normal mode and
install MSE. Make sure your Windows firewall is enabled!
Once your BSOD issues are resolved, you may wish to try AVG again, although personally I wouldn't recommend it at this point in time.
Outdated Drivers. Update: atksgt.sys Sun May 17 14:36:34 2009 Part of a Copy Protection platform dveloped by
Tages SA ctac32k.sys Wed Jul 02 09:38:22 2008 Creative Audio Driver gdrv.sys Fri Mar 13 03:22:29 2009 Gigabyte Easy Saver. If you cannot update this then
uninstall it. LGPBTDD.sys Wed Jul 01 19:47:52 2009 LG CDMA USB Multi function Driver Drivers with Updates: jraid.sys Wed Jan 27 08:58:17 2010 JMicron Raid Driver nusb3hub.sys Fri Nov 20 10:15:57 2009
nusb3xhc.sys Fri Nov 20 10:16:01 2009 Go to your
Motherboard Mfr. Support website and update your USB 3.0 drivers.
Rt64win7.sys Thu Mar 04 13:42:52 2010 Realtek PCIe GBE Family Controller v7.046 RTKVHD64.sys Fri Mar 26 10:30:50 2010 Realtek HD Audio R2.62 Bugcheck Analysis: Code:
* Bugcheck Analysis *
BugCheck 1E, {ffffffffc0000096, fffff800032f3dd5, 0, 0}
Probably caused by : ntkrnlmp.exe ( nt!KiSecondaryClockInterrupt+1c5 )
Followup: MachineOwner
7: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000096, The exception code that was not handled
Arg2: fffff800032f3dd5, The address that the exception occurred at
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000096 - {EXCEPTION} Privileged instruction.
FAULTING_IP:
fffff800`032f3dd5 440f22c1 mov cr8,rcx
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 0000000000000000
ERROR_CODE: (NTSTATUS) 0xc0000096 - {EXCEPTION} Privileged instruction.
BUGCHECK_STR: 0x1E_c0000096
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
CURRENT_IRQL: d
LAST_CONTROL_TRANSFER: from fffff800033335d8 to fffff800032e7d00
STACK_TEXT:
fffff880`033920e8 fffff800`033335d8 : 00000000`0000001e ffffffff`c0000096 fffff800`032f3dd5 00000000`00000000 : nt!KeBugCheckEx
fffff880`033920f0 fffff800`032e7382 : fffff880`033928c8 fffff880`0336a180 fffff880`03392970 fffff880`0336a180 : nt! ?? ::FNODOBFM::`string'+0x4987d
fffff880`03392790 fffff800`032e5c8a : fffffa80`08324340 fffff880`0478fe28 00000000`00000000 fffffa80`08315320 : nt!KiExceptionDispatch+0xc2
fffff880`03392970 fffff800`032f3dd5 : 00000000`00000000 fffff880`03392b80 fffff880`0336a180 00000000`00000001 : nt!KiGeneralProtectionFault+0x10a
fffff880`03392b00 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSecondaryClockInterrupt+0x1c5
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: nt!KiSecondaryClockInterrupt+1c5
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4d9fdd5b
FAILURE_BUCKET_ID: X64_0x1E_c0000096_nt!KiSecondaryClockInterrupt+1c5
Drivers: Code:
fffff880`04a06000 fffff880`04a44000 1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00e00000 fffff880`00e57000 ACPI ACPI.sys Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`02ea5000 fffff880`02f2e000 afd afd.sys Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`04a5d000 fffff880`04a73000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`011bb000 fffff880`011c6000 amdxata amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`0454f000 fffff880`04557000 AppleCharger AppleCharger.sys Thu Apr 22 08:05:49 2010 (4BCFF54D)
fffff880`08993000 fffff880`0899e000 asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`01188000 fffff880`01191000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01191000 fffff880`011bb000 ataport ataport.SYS Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`06800000 fffff880`0684f000 atksgt atksgt.sys Sun May 17 14:36:34 2009 (4A1012E2)
fffff880`0838f000 fffff880`083ba000 AVGIDSDriver AVGIDSDriver.Sys Thu Apr 14 18:11:05 2011 (4DA72AA9)
fffff880`01b98000 fffff880`01ba2000 AVGIDSEH AVGIDSEH.Sys Tue Feb 22 05:23:04 2011 (4D634838)
fffff880`07415000 fffff880`07420000 AVGIDSFilter AVGIDSFilter.Sys Thu Feb 10 04:59:37 2011 (4D5370B9)
fffff880`04500000 fffff880`0454f000 avgldx64 avgldx64.sys Fri Jan 07 04:36:39 2011 (4D269857)
fffff880`01bd8000 fffff880`01be7000 avgmfx64 avgmfx64.sys Tue Mar 01 12:25:15 2011 (4D6CE5AB)
fffff880`01b8c000 fffff880`01b98000 avgrkx64 avgrkx64.sys Wed Mar 16 14:06:34 2011 (4D80C3EA)
fffff880`01200000 fffff880`01260000 avgtdia avgtdia.sys Mon Apr 04 22:54:35 2011 (4D9A3E1B)
fffff880`01bf0000 fffff880`01bf7000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`044ef000 fffff880`04500000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`06f4d000 fffff880`06f6b000 bowser bowser.sys Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`007b0000 fffff960`007d7000 cdd cdd.dll unavailable (00000000)
fffff880`017bc000 fffff880`017e6000 cdrom cdrom.sys Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00e76000 fffff880`00f36000 CI CI.dll Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`04bc0000 fffff880`04bd2000 circlass circlass.sys Tue Jul 14 01:06:34 2009 (4A5BCC0A)
fffff880`01b5c000 fffff880`01b8c000 CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00ce5000 fffff880`00d43000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01332000 fffff880`013a4000 cng cng.sys Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`04a4d000 fffff880`04a5d000 CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`07420000 fffff880`07429000 cpuz135_x64 cpuz135_x64.sys Tue Nov 09 13:33:36 2010 (4CD94DB0)
fffff880`0899e000 fffff880`089ac000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0444e000 fffff880`044d1000 csc csc.sys Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`069af000 fffff880`069e4000 CT20XUT CT20XUT.SYS Wed May 05 14:01:28 2010 (4BE16C28)
fffff880`068e6000 fffff880`06994000 ctac32k ctac32k.sys Wed Jul 02 09:38:22 2008 (486B3E7E)
fffff880`0f200000 fffff880`0f2a5700 ctaud2k ctaud2k.sys Wed May 05 13:59:48 2010 (4BE16BC4)
fffff880`06a39000 fffff880`06b96000 CTEXFIFX CTEXFIFX.SYS Wed May 05 14:01:21 2010 (4BE16C21)
fffff880`06994000 fffff880`069af000 CTHWIUT CTHWIUT.SYS Wed May 05 14:01:32 2010 (4BE16C2C)
fffff880`02e1a000 fffff880`02e4b000 ctoss2k ctoss2k.sys Wed May 05 13:57:46 2010 (4BE16B4A)
fffff880`04674000 fffff880`0467c000 ctprxy2k ctprxy2k.sys Wed May 05 13:59:51 2010 (4BE16BC7)
fffff880`011c6000 fffff880`011fe000 ctsfm2k ctsfm2k.sys Wed May 05 13:57:33 2010 (4BE16B3D)
fffff880`044d1000 fffff880`044ef000 dfsc dfsc.sys Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`02e0b000 fffff880`02e1a000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01b46000 fffff880`01b5c000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`045c5000 fffff880`045e7000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`089b8000 fffff880`089c1000 dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`089ac000 fffff880`089b8000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`089c1000 fffff880`089d4000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`07ad4000 fffff880`07ae0000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`04693000 fffff880`04787000 dxgkrnl dxgkrnl.sys Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04787000 fffff880`047cd000 dxgmms1 dxgmms1.sys Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0678d000 fffff880`067d7000 emupia2k emupia2k.sys Wed May 05 13:57:27 2010 (4BE16B37)
fffff880`012c0000 fffff880`012d4000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01274000 fffff880`012c0000 fltmgr fltmgr.sys Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01411000 fffff880`0141b000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01b0c000 fffff880`01b46000 fvevol fvevol.sys Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01a09000 fffff880`01a53000 fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`08902000 fffff880`0890b000 gdrv gdrv.sys Fri Mar 13 03:22:29 2009 (49B9D175)
fffff880`04667000 fffff880`04674000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff880`0660c000 fffff880`0678d000 ha20x2k ha20x2k.sys Wed May 05 13:59:10 2010 (4BE16B9E)
fffff800`0321f000 fffff800`03268000 hal hal.dll Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`047cd000 fffff880`047f1000 HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`045e7000 fffff880`04600000 HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`067f0000 fffff880`067f8080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`07abb000 fffff880`07ac9000 hidusb hidusb.sys Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`06c00000 fffff880`06cc9000 HTTP HTTP.sys Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01b03000 fffff880`01b0c000 hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`0106a000 fffff880`01188000 iaStorV iaStorV.sys Fri Jun 11 01:46:19 2010 (4C11875B)
fffff880`0457d000 fffff880`04593000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`00c10000 fffff880`00c30000 jraid jraid.sys Wed Jan 27 08:58:17 2010 (4B600029)
fffff880`04b3e000 fffff880`04b4d000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`06f1a000 fffff880`06f28000 kbdhid kbdhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00bb7000 fffff800`00bc1000 kdcom kdcom.dll Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`08918000 fffff880`08922000 kerneld kerneld.amd64 Tue Oct 05 09:21:07 2010 (4CAADFF3)
fffff880`04400000 fffff880`04443000 ks ks.sys Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`015d6000 fffff880`015f1000 ksecdd ksecdd.sys Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01791000 fffff880`017bc000 ksecpkg ksecpkg.sys Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`0467c000 fffff880`04681200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`04bd2000 fffff880`04bd5d80 LGBusEnum LGBusEnum.sys Tue Nov 24 01:36:48 2009 (4B0B38B0)
fffff880`07ac9000 fffff880`07ad4000 LGPBTDD LGPBTDD.sys Wed Jul 01 19:47:52 2009 (4A4BAF58)
fffff880`08915000 fffff880`08917480 LGVirHid LGVirHid.sys Tue Nov 24 01:36:48 2009 (4B0B38B0)
fffff880`07bee000 fffff880`07bfb000 lirsgt lirsgt.sys Sun May 17 14:06:57 2009 (4A100BF1)
fffff880`07400000 fffff880`07415000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`07b79000 fffff880`07b9c000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`0890b000 fffff880`08915000 LVPr2M64 LVPr2M64.sys Wed Oct 07 09:26:50 2009 (4ACC50CA)
fffff880`07a59000 fffff880`07aa7600 lvrs64 lvrs64.sys Wed Oct 07 09:27:59 2009 (4ACC510F)
fffff880`0742a000 fffff880`07a3dd00 lvuvc64 lvuvc64.sys Wed Oct 07 09:28:44 2009 (4ACC513C)
fffff880`00c82000 fffff880`00cd1000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`07ae0000 fffff880`07aee000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`04b4d000 fffff880`04b5c000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`06f28000 fffff880`06f35000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00c5f000 fffff880`00c79000 mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`06f6b000 fffff880`06f83000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`06f83000 fffff880`06fb0000 mrxsmb mrxsmb.sys Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`06fb0000 fffff880`06ffe000 mrxsmb10 mrxsmb10.sys Wed Apr 27 03:39:40 2011 (4DB781EC)
fffff880`06bc3000 fffff880`06be7000 mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`0141b000 fffff880`01426000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e60000 fffff880`00e6a000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`012d4000 fffff880`01332000 msrpc msrpc.sys Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`02e00000 fffff880`02e0b000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01af1000 fffff880`01b03000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0163e000 fffff880`01731000 ndis ndis.sys Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`04a97000 fffff880`04aa3000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`04aa3000 fffff880`04ad2000 ndiswan ndiswan.sys Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`067d7000 fffff880`067ec000 NDProxy NDProxy.SYS Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`02f5d000 fffff880`02f6c000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02e60000 fffff880`02ea5000 netbt netbt.sys Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01731000 fffff880`01791000 NETIO NETIO.SYS Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`013a4000 fffff880`013b5000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`02fec000 fffff880`02ff8000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03268000 fffff800`03851000 nt ntkrnlmp.exe Sat Apr 09 05:15:23 2011 (4D9FDD5B)
fffff880`01433000 fffff880`015d6000 Ntfs Ntfs.sys Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`01be7000 fffff880`01bf0000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`04be8000 fffff880`04bff000 nusb3hub nusb3hub.sys Fri Nov 20 10:15:57 2009 (4B066C5D)
fffff880`04593000 fffff880`045c3000 nusb3xhc nusb3xhc.sys Fri Nov 20 10:16:01 2009 (4B066C61)
fffff880`0ff55000 fffff880`0ff5a000 nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`06b96000 fffff880`06bc3000 nvhda64v nvhda64v.sys Tue May 10 10:41:18 2011 (4DC9083E)
fffff880`0f2a7000 fffff880`0ff55000 nvlddmkm nvlddmkm.sys Sat May 21 05:07:04 2011 (4DD73A68)
fffff880`02f37000 fffff880`02f5d000 pacer pacer.sys Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00d76000 fffff880`00d8b000 partmgr partmgr.sys Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00d43000 fffff880`00d76000 pci pci.sys Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00ff6000 fffff880`00ffd000 pciide pciide.sys Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00c00000 fffff880`00c10000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01400000 fffff880`01411000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0829b000 fffff880`08341000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0ffb1000 fffff880`0ffee000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cd1000 fffff880`00ce5000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`04a73000 fffff880`04a97000 rasl2tp rasl2tp.sys Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`04ad2000 fffff880`04aed000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04aed000 fffff880`04b0e000 raspptp raspptp.sys Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`04b0e000 fffff880`04b28000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`02f9b000 fffff880`02fec000 rdbss rdbss.sys Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`04b33000 fffff880`04b3e000 rdpbus rdpbus.sys Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`01bf7000 fffff880`01c00000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01635000 fffff880`0163e000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`017f4000 fffff880`017fd000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01ab7000 fffff880`01af1000 rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`06f35000 fffff880`06f4d000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0ff5a000 fffff880`0ffb1000 Rt64win7 Rt64win7.sys Thu Mar 04 13:42:52 2010 (4B8FB8DC)
fffff880`06ccb000 fffff880`06efcc00 RTKVHD64 RTKVHD64.sys Fri Mar 26 10:30:50 2010 (4BAC8CDA)
fffff880`04b28000 fffff880`04b32900 SaiBus SaiBus.sys Wed Apr 21 17:58:20 2010 (4BCF2EAC)
fffff880`067ec000 fffff880`067efe80 SaiMini SaiMini.sys Wed Apr 21 17:58:19 2010 (4BCF2EAB)
fffff880`00c30000 fffff880`00c5f000 SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`08341000 fffff880`0834c000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01aaf000 fffff880`01ab7000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0886a000 fffff880`08902000 srv srv.sys Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`08200000 fffff880`08269000 srv2 srv2.sys Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0834c000 fffff880`0837d000 srvnet srvnet.sys Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`04bbe000 fffff880`04bbf480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01805000 fffff880`01a09000 tcpip tcpip.sys Mon Apr 25 03:37:30 2011 (4DB4DE6A)
fffff880`0837d000 fffff880`0838f000 tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01426000 fffff880`01433000 TDI TDI.SYS Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`013b5000 fffff880`013d7000 tdx tdx.sys Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`02f87000 fffff880`02f9b000 termdd termdd.sys Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00560000 fffff960`0056a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`04557000 fffff880`0457d000 tunnel tunnel.sys Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`07aee000 fffff880`07b43000 udfs udfs.sys Sat Nov 20 09:26:11 2010 (4CE79433)
fffff880`04bd6000 fffff880`04be8000 umbus umbus.sys Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`07a3e000 fffff880`07a58c80 usbaudio usbaudio.sys Sat Nov 20 10:43:52 2010 (4CE7A668)
fffff880`06efd000 fffff880`06f1a000 usbccgp usbccgp.sys Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`045c3000 fffff880`045c4f00 USBD USBD.SYS Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`04656000 fffff880`04667000 usbehci usbehci.sys Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04b5c000 fffff880`04bb6000 usbhub usbhub.sys Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`04600000 fffff880`04656000 USBPORT USBPORT.SYS Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`047f1000 fffff880`047fe000 usbuhci usbuhci.sys Fri Mar 25 03:29:03 2011 (4D8C0BFF)
fffff880`00fe9000 fffff880`00ff6000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`017e6000 fffff880`017f4000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01600000 fffff880`01625000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`0101a000 fffff880`01056000 vmbus vmbus.sys Sat Nov 20 09:57:29 2010 (4CE79B89)
fffff880`01a53000 fffff880`01a63000 vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00d8b000 fffff880`00da0000 volmgr volmgr.sys Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00da0000 fffff880`00dfc000 volmgrx volmgrx.sys Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01a63000 fffff880`01aaf000 volsnap volsnap.sys Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`02f6c000 fffff880`02f87000 wanarp wanarp.sys Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01625000 fffff880`01635000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00f36000 fffff880`00fda000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00fda000 fffff880`00fe9000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02f2e000 fffff880`02f37000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00020000 fffff960`00332000 win32k win32k.sys unavailable (00000000)
fffff880`01056000 fffff880`0106a000 winhv winhv.sys Sat Nov 20 09:20:02 2010 (4CE792C2)
fffff880`04a44000 fffff880`04a4d000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00e57000 fffff880`00e60000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`07b9c000 fffff880`07bbd000 WudfPf WudfPf.sys Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`07bbd000 fffff880`07bee000 WUDFRd WUDFRd.sys Sat Nov 20 10:43:32 2010 (4CE7A654)
fffff880`07aa8000 fffff880`07aba100 xusb21 xusb21.sys Thu Aug 13 23:10:17 2009 (4A848F49)
Unloaded modules:
fffff880`08922000 fffff880`08993000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`07b43000 fffff880`07b51000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`07b51000 fffff880`07b5d000 dump_ataport
Checksum: 00000000
ImageSize: 0000C000
fffff880`07b5d000 fffff880`07b66000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
fffff880`07b66000 fffff880`07b79000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
Checksum: 00000000
ImageSize: 00071000
fffff880`01ba2000 fffff880`01bb0000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`01bb0000 fffff880`01bbc000 dump_ataport
Checksum: 00000000
ImageSize: 0000C000
fffff880`01bbc000 fffff880`01bc5000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
fffff880`01bc5000 fffff880`01bd8000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
fffff880`04b8d000 fffff880`04bbe000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00031000
fffff880`04b5c000 fffff880`04b8d000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00031000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
