Kyle Mccullough
ok so i built this computer about a year and a half ago and i have been dealing with this same blue screen almost from the start. it used to only happen rarely when i played video games and i was also getting graphical artifacts so last christmas i upgraded my failing graphics card thinking this would solve the issue but it did not. it started blue screening while playing diablo 3 recently so i reinstalled windows 7 tonight thinking this would fix the issue but it has not. now it has started to blue screen while im doing normal tasks right after installing windows 7.
im sure its not my graphics card and im pretty sure its not the ram because i have tested each stick individually and it blue screened on each stick
the only things i can think that might be causing this are either my motherboard, cpu, or hard drive. it might also be a voltage issue if that can cause a blue screen.
i have attached the latest dmp file
thanks!
thanks!
