Windows 7 been getting IRQL_NOT_LESS_OR_EQUAL for about 3 months now...
Filipe Cunha
I've been getting an irritating IRQL_NOT_LESS_OR_EQUAL BSoD for a long time now... I've tried almost everything short of formatting and reinstalling everything (it started crashing a few days after I've put the thing together...)
specs:
Core i7 2600K
Gigabyte Z77X-D3H
2x8gb value RAM
Running on onboard GPU (my Radeon 6950 HD keeps crashing... probably defective), which is a Intel HD Graphics 3000 (GT2+)
If anybody could help, it would be really appreciated...
The crashes/BSoDs are quite random, but one thing I noticed is that it happens more frequently when I'm viewing YouTube videos, or have 'em loading.
And from what I recall, it never crashed while playing.
Yes I was having problems with BSOD. I uninstalled Firefox and it's Flash plugin amd haven't had problems in about 4 weeks. I also uninstalled Avast and switched to MSE.
Joe
Only 102 updates since SP1 - most systems have 130 to 140. Please visit Windows Update and get all available updates
Drive D:
Size 465,75 GB (500.096.991.232 bytes)
Free Space 5,79 GB (6.215.413.760 bytes)
Drives need 15% free space for Windows to operate in - so I'd suggest that you free up 65 gB of space on this drive (for a total of 70+ gB free)
I suspect video issues (from the WER Section of MSINFO32) - more on that later
BSOD's involve DirectX and memory corruption
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] Link Removed [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): Link Removed (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Link Removed - Invalid URL
Please un-install Gigabyte EasySaver and EasyTune6 - they cause BSOD's in some Win7 systems.
USB XBox controller is known to cause BSOD's on some Win7 systems. Un-install the software and remove the device from the system. Don't reinstall until the manufacturer releases new drivers (these date from 2009).
Install a new version of Avira - yours dates from 2011
If this doesn't fix things, try these free diagnostics (particularly those for the video): Link Removed
Analysis:
[font=lucida console]**************************Wed Sep 26 06:07:54.961 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092612-19734-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 0:14:19.789[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e55d00, 2, 1, fffff80002eac830}[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VIDMM_SEGMENT::SafeProbeAndLockPages+229 )[/B]
BugCheck Info: [B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]firefox.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_dxgmms1!VIDMM_SEGMENT::SafeProbeAndLockPages+229[/B]
**************************Mon Sep 24 23:27:48.116 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092512-15428-01.dmp]
System Uptime:[B]0 days 0:52:18.318[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e55d00, 2, 1, fffff80002eb0830}[/B]
Probably caused by :[B]memory_corruption ( nt!MiReplenishPageSlist+c0 )[/B]
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]AcroRd32.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_nt!MiReplenishPageSlist+c0[/B]
**************************Mon Sep 24 21:41:45.910 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092412-15974-01.dmp]
System Uptime:[B]0 days 0:14:33.112[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e55d00, 2, 1, fffff80002eb4830}[/B]
BUGCHECK_STR:  0xA
**************************Mon Sep 24 21:26:23.924 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092412-14320-01.dmp]
System Uptime:[B]0 days 7:22:58.126[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e55d00, 2, 1, fffff80002efb830}[/B]
BUGCHECK_STR:  0xA
**************************Mon Sep 24 14:02:53.845 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092412-16380-01.dmp]
System Uptime:[B]0 days 0:20:04.672[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e52d00, 2, 1, fffff80002f0c830}[/B]
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]FlashPlayerPlu[/B]
**************************Mon Sep 24 13:42:16.056 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092412-18033-01.dmp]
System Uptime:[B]0 days 0:55:57.884[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e54500, 2, 1, fffff80002eb6830}[/B]
BUGCHECK_STR:  0xA
**************************Mon Sep 24 12:45:17.466 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092412-15818-01.dmp]
System Uptime:[B]0 days 0:36:54.668[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e55d00, 2, 1, fffff80002f08830}[/B]
BUGCHECK_STR:  0xA
**************************Mon Sep 24 12:07:15.602 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092412-16910-01.dmp]
System Uptime:[B]0 days 2:01:30.804[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e7b4f8, 2, 1, fffff80002efe8c0}[/B]
BUGCHECK_STR:  0xA
**************************Mon Sep 24 09:49:51.660 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092412-48516-01.dmp]
System Uptime:[B]0 days 0:08:10.163[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e54500, 2, 1, fffff80002eae830}[/B]
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]avguard.exe[/B]
**************************Sat Sep 22 11:04:19.178 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092212-15537-01.dmp]
System Uptime:[B]0 days 18:20:57.005[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e31d00, 2, 1, fffff80002eaa830}[/B]
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]dllhost.exe[/B]
**************************Fri Sep 21 16:42:00.417 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092112-43493-01.dmp]
System Uptime:[B]1 days 1:01:30.245[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e5777b, 2, 0, fffff80002f8a7df}[/B]
*** WARNING: Unable to verify checksum for win32k.sys
Probably caused by :[B]memory_corruption ( nt!MiRelinkStandbyPage+8f )[/B]
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]svchost.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_nt!MiRelinkStandbyPage+8f[/B]
**************************Thu Sep 20 15:39:17.546 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092012-15584-01.dmp]
System Uptime:[B]1 days 2:46:03.748[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e59dbb, 2, 0, fffff80002f737df}[/B]
BUGCHECK_STR:  0xA
**************************Fri Sep 14 05:07:45.626 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091412-14196-01.dmp]
System Uptime:[B]0 days 2:42:20.828[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e4fd00, 2, 1, fffff80002f02830}[/B]
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]SearchFilterHo[/B]
**************************Thu Sep 13 21:47:11.221 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091312-17971-01.dmp]
System Uptime:[B]0 days 15:22:26.423[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c047a9d3b, 2, 0, fffff80002f807df}[/B]
BUGCHECK_STR:  0xA
**************************Wed Sep 12 00:07:27.462 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091212-16270-01.dmp]
System Uptime:[B]0 days 7:25:18.664[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e49d00, 2, 1, fffff80002f08830}[/B]
BUGCHECK_STR:  0xA
**************************Mon Sep 10 23:00:25.883 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091112-16629-01.dmp]
System Uptime:[B]0 days 7:19:22.711[/B]
BugCheck Code: [B]BugCheck 1E, {0, 0, 0, 0}[/B]
*** WARNING: Unable to verify timestamp for igdkmd64.sys
*** ERROR: Module load completed but symbols could not be loaded for igdkmd64.sys
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VidSchiProcessDpcCompletedPacket+3a5 )[/B]
BugCheck Info: [B]KMODE_EXCEPTION_NOT_HANDLED (1e)[/B]
BUGCHECK_STR:  0x1E
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_dxgmms1!VidSchiProcessDpcCompletedPacket+3a5[/B]
[/font]
3rd Party Drivers:
[B]gdrv.sys                    Thu Mar 12 23:22:29 2009 (49B9D175)[/B]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
[B]xusb21.sys                  Thu Aug 13 18:10:17 2009 (4A848F49)[/B]
PxHlpa64.sys                Tue Oct 20 14:08:42 2009 (4ADDFCAA)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
mv_process.sys              Tue Feb 22 04:22:20 2011 (4D63804C)
avkmgr.sys                  Thu Sep 15 09:36:11 2011 (4E71FF4B)
IntcDAud.sys                Tue Dec  6 06:23:07 2011 (4EDDFB1B)
[B]dtsoftbus01.sys             Fri Jan 13 08:45:46 2012 (4F10358A)[/B]
xhcdrv.sys                  Thu Jan 19 23:39:02 2012 (4F18EFE6)
ViaHub3.sys                 Thu Jan 19 23:39:13 2012 (4F18EFF1)
iaStor.sys                  Wed Feb  1 19:15:24 2012 (4F29D59C)
[B]sptd.sys                    Sat Mar  3 11:45:52 2012 (4F524AC0)[/B]
athrx.sys                   Fri Mar  9 06:30:56 2012 (4F59E9F0)
igdkmd64.sys                Mon Mar 26 22:09:46 2012 (4F71216A)
iusb3hub.sys                Tue Mar 27 04:09:29 2012 (4F7175B9)
iusb3xhc.sys                Tue Mar 27 04:09:32 2012 (4F7175BC)
iusb3hcs.sys                Tue Mar 27 04:11:21 2012 (4F717629)
avgntflt.sys                Tue Apr 24 02:14:35 2012 (4F9644CB)
avipbb.sys                  Thu Apr 26 06:12:40 2012 (4F991F98)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
L1C62x64.sys                Wed Jul 18 22:55:34 2012 (50077726)
viahduaa.sys                Thu Aug  2 21:31:13 2012 (501B29E1)
viahduaa.sys                Tue Jul 12 02:53:21 2011 (4E1BEF61)
L1C62x64.sys                Wed Aug  3 02:21:09 2011 (4E38E8D5)
HECIx64.sys                 Wed Nov  9 19:52:25 2011 (4EBB2049)
iaStor.sys                  Tue Nov 29 22:39:19 2011 (4ED5A567)
aiz934hx.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
iusb3hub.sys                Fri Jan 27 04:35:25 2012 (4F226FDD)
iusb3xhc.sys                Fri Jan 27 04:35:28 2012 (4F226FE0)
iusb3hcs.sys                Fri Jan 27 04:37:23 2012 (4F227053)
igdkmd64.sys                Mon Mar 19 19:31:54 2012 (4F67C1EA)
GEARAspiWDM.sys             Mon May 18 08:17:04 2009 (4A1151C0)
[/font]
mv_process.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
I usually keep it updated. I ran it again and it shows that there isn't any updates to be made. Only the language-specific optional ones (which I don't really need).
Drive D:
Done.
Alright. I hope the changes fix it before it gets to that...
Done as well.
I removed EasyTune6 (I never installed EasySaver nor it shows up on the uninstallation control panel), but those were recently installed (last week) and the problem has been happening way prior to their installation.
I removed it, but as with the EasyTune6 above, those were recently installed (last week) and the problem has been happening way prior to their installation.
Done as well, but it's weird, since I did a fresh installation of Win7 (and downloaded the newest version of avira from their website) when I got a new MoBo and CPU earlier this year (right before the BSoDs started)
OK, will do that. :)
Well... let's see how things goes. Hopefully, it'll stop with the random crashes.
And again, thanks SO much for your time and patience, sir. :)
Driver dates aren't the best way of determining problems - but often they're the only way that we have. That's why we use them.
If this was specifically related to a certain incident that happened on your computer - then it'd be easy to fix. Unfortunately, a computer is a dynamic collection of hardware and software (it changes frequently). While it's less likely that the newer installations are a part of the problem - it's also possible that the older problems are either also related to the newer stuff - or that the newer stuff is also causing some of the problems that you're experiencing now.
In short, here's what we do:
- we look for 3rd party (non-Microsoft) problems (regardless of when they occurred)
- if we take care of all those and you still have BSOD's, then we move on to hardware diagnostics
The 3rd party stuff is part guesswork, part looking for older drivers (which may/may not be bad), part looking for stuff that we've seen cause problems elsewhere, and part reading reports for hints on what might be wrong.
So, what we do next is we wait....
If you don't get another BSOD in a while (in most cases it's a week or two) then we can figure it's possibly solved.
If you don't get another BSOD in a longer while (in most cases it's up to a month) then we can figure that it's probably solved.
But this also depends on how often you were getting the BSOD's originally.
Well, from the time I posted that reply to now, it just crashed twice. :/
I guess it didn't solve it then... I'll check that additional diagnosis link.
The timing between BSODs is really unreliable... sometimes it crashes twice in 10min, sometimes it goes almost a week without ever crashing.
edit.: and just got another BSoD right now... /sigh
One thing I remembered just now... Could it be related to Adobe Flash somehow? 'Cause flash keeps crashing on Firefox while I'm browsing and if I remember correctly, the BSoDs only happen while Firefox is open (but that, I'm not really sure)
Joe
Please zip up and upload the memory dumps so we can have a look at them. They're located in C:\Windows\Minidump
Just a quick update...
I've installed Chrome and started using it... For a while, I thought it wouldn't crash, but it did a few minutes ago, so, it's not Firefox's fault (but it can still be the damned flash plugin... who knows... :frown:)
USB Link Removed controller is known to cause BSOD's on some Win7 systems. Un-install the software and remove the device from the system. Don't reinstall until the manufacturer releases new drivers (these date from 2009).
Please un-install Gigabyte On/Off (Applecharger.sys) as recently we've seen some BSOD's due to it. Feel free to reinstall it (if needed) after the BSOD's have stopped.
If the BSOD's keep coming after you've removed this stuff, then please run Driver Verifier according to these instructions: Link Removed
Analysis:
[font=lucida console]**************************Wed Oct  3 13:52:39.525 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100312-12589-01.dmp]
System Uptime:[B]0 days 0:52:28.727[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e58d00, 2, 1, fffff80002eba830}[/B]
BUGCHECK_STR:  0xA
**************************Wed Oct  3 12:59:37.434 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100312-13306-01.dmp]
System Uptime:[B]0 days 0:19:51.652[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e54500, 2, 1, fffff80002f00830}[/B]
BUGCHECK_STR:  0xA
**************************Wed Oct  3 12:37:26.078 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100312-16161-01.dmp]
System Uptime:[B]0 days 0:19:00.280[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e55d00, 2, 1, fffff80002ef0830}[/B]
BUGCHECK_STR:  0xA
**************************Wed Oct  3 12:17:16.644 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100312-18735-01.dmp]
System Uptime:[B]0 days 2:40:17.846[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00ecf500, 2, 1, fffff80002eaf830}[/B]
BUGCHECK_STR:  0xA
**************************Wed Oct  3 08:32:26.225 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100312-17362-01.dmp]
System Uptime:[B]0 days 19:24:11.427[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e5762b, 2, 0, fffff80002f877df}[/B]
BUGCHECK_STR:  0xA
**************************Tue Oct  2 13:07:03.296 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100212-15553-01.dmp]
System Uptime:[B]0 days 3:25:23.124[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00b0dd00, 2, 1, fffff80002eab830}[/B]
BUGCHECK_STR:  0xA
**************************Tue Oct  2 09:41:06.052 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100212-24850-01.dmp]
System Uptime:[B]0 days 0:12:03.880[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e55d00, 2, 1, fffff80002ef4830}[/B]
BUGCHECK_STR:  0xA
**************************Tue Oct  2 02:51:13.167 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100212-20342-01.dmp]
System Uptime:[B]0 days 0:23:12.369[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e55d00, 2, 1, fffff80002ef8830}[/B]
BUGCHECK_STR:  0xA
**************************Tue Oct  2 02:27:24.682 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100212-16130-01.dmp]
System Uptime:[B]0 days 2:03:36.509[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e90500, 2, 1, fffff80002eee830}[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VIDMM_PROCESS_HEAP::Rotate+2d0 )[/B]
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_dxgmms1!VIDMM_PROCESS_HEAP::Rotate+2d0[/B]
**************************Fri Sep 28 23:56:49.071 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092912-24585-01.dmp]
System Uptime:[B]0 days 3:00:31.273[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c037e8500, 2, 1, fffff80002ef4830}[/B]
BUGCHECK_STR:  0xA
[/font]
3rd Party Drivers:
[B]AppleCharger.sys            Tue Nov  1 22:46:00 2011 (4EB0AEE8)[/B]
avgntflt.sys                Thu Sep 13 01:47:38 2012 (5051737A)
avipbb.sys                  Thu Sep 13 01:47:44 2012 (50517380)
avkmgr.sys                  Wed Sep 19 04:31:52 2012 (505982F8)
avkmgr.sys                  Thu Sep 15 09:36:11 2011 (4E71FF4B)  Daemon Tools dynamically assigned driver names
avjgjf00.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)  Daemon Tools dynamically assigned driver names
axpftypl.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)  Daemon Tools dynamically assigned driver names
a36t8bxx.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)  Daemon Tools dynamically assigned driver names
aj3ftxah.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)  Daemon Tools dynamically assigned driver names
awznlfa7.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)  Daemon Tools dynamically assigned driver names
[B]GVTDrv64.sys                Tue Sep  5 03:10:02 2006 (44FD22CA)[/B]
atwrd7k0.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
[/font]
avjgjf00.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver names
axpftypl.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver names
a36t8bxx.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver names
aj3ftxah.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver names
awznlfa7.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver names
atwrd7k0.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver names
after about 14 days without a single BSoD while running Driver Verifier, I got the following:Link Removed
I lost power yesterday due to Hurricane Sandy. Don't have any idea when it will be restored. I will post back as soon as power is restored. Meanwhile, I only have my phone to post with.
No problem... I hope everything is OK there.
Link Removed - Invalid URLLink Removed - Invalid URLLink Removed - Invalid URLLink Removed - Invalid URL
Daemon Tools is still showing up in the memory dumps.
Have you uninstalled it?
Please turn off Driver Verifier
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Tue Oct 30 11:25:44.219 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\103012-17846-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 0:06:13.437[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e58d00, 2, 1, fffff80002ebc4f0}[/B]
Arguments:
Arg1: fffffa8c00e58d00, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff80002ebc4f0, address which referenced memory
DEFAULT_BUCKET_ID: [B]VERIFIER_ENABLED_VISTA_MINIDUMP[/B]
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_VRF_nt!MiReplenishPageSlist+c0[/B]
**************************Tue Oct 30 11:18:37.763 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\103012-20716-01.dmp]
System Uptime:[B]0 days 0:09:01.981[/B]
BugCheck Code: [B]BugCheck A, {fffffa8c00e57500, 2, 1, fffff80002ea84f0}[/B]
Arguments:
Arg1: fffffa8c00e57500, memory referenced
Arg4: fffff80002ea84f0, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_VRF_dxgmms1!VIDMM_PROCESS_HEAP::Rotate+2d0[/B]
[/font]
3rd Party Drivers:
avipbb.sys                  Fri Sep 28 07:58:45 2012 (506590F5)
[/font]
