Bitlocker without TPM
Hello, I am currently running the beta version and wondering how do I enabled Bitlocker without TPM chip. I tried the local system policy but couldn't find any options to disabled TPM.
Thanks.
I had the same problem - no TPM on the motherboard. Check your BIOS to see if you can enable it - otherwise, the alternative is to use a thumb drive to store the key. The "Help" section will tell you what the process is to set up Bitlocker using a thumd drive or SD card...
