!!! Blue error screen problem !!!
Hi, I am using Dell XPS M1530 and upgraded vista to windows 7. Anyway, the blue screen error details are here:
Problem signature:
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1061
Additional information about the problem:
BCCode: a
BCP1: 82177B80
BCP2: 00000002
BCP3: 00000000
BCP4: 828BB5C7
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\120609-26098-01.dmp
C:\Users\Hans\AppData\Local\Temp\WER-62244-0.sysdata.xml
Thanks if someone can help me!
nobody? :frown:
Actually it has two different errors.
1) check if you have adequate disk space (which i think i have)
2) bad_pool_header
ickymay
2) bad_pool_header
first suggestion is please post the minidump file for people to analyze, just zip it and upload it then link in your post ;)
blue screens are mostly driver errors so every device needs to be checked to make sure they are running the latest :)
second suggestion which you won't like is to be honest you are likely to get this and more issues because you have done an upgrade rather than a fresh install :frown: , sorry but my best advice is save your data then wipe the drive and do a complete fresh install :cool:
Is this the fresh install when windows automatically creates winodws.old file for the previous windows?
I think i dont have nothing else to do, than a fresh install..
