Windows 7 Blue Screen after cleaning computer
Trikotnik
HI !
Yesterday I opened my computer and cleaned the inside because it was full of dust.
After I started it I have gotten a Blue Screen Error quite alot (every 15-30 mins)
This is not the first time I've cleaned the inside of this computer and have cleaned a few others too but nothing like that ever happend.
I have also tried reinstalling windows and formatting everything but it still happens (a little less often though)
RAMMon 2.PNGRAMMon.PNGView attachment 012813-34062-01.zip
I have just got this one again
Crash dump file: C:\Windows\Minidump\012813-22546-01.dmp
Date/time: 28.1.2013 12:10:49 GMT
Uptime: 00:06:54
Machine:
Bug check name: VIDEO_SCHEDULER_INTERNAL_ERROR
Bug check code: 0x119
Bug check parm 1: 0x1
Bug check parm 2: 0xF10000
Bug check parm 3: 0x0
Bug check parm 4: 0x0
Probably caused by: watchdog.sys
Driver description: Watchdog Driver
Driver product: Microsoft® Windows® Operating System
Driver company: Microsoft Corporation
OS build: Built by: 7600.17118.amd64fre.win7_gdr.120830-0334
Architecture: x64 (64 bit)
CPU count: 2
Page size: 4096
Bug check description:
This indicates that the video scheduler has detected a fatal violation.
Comments:
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
usasma
Fantastic Member
Please provide this information so we can provide a complete analysis: http://windows7forums.com/blue-screen-death-bsod/38837-how-ask-help-bsod-problem.html
The memory dump that you posted is a STOP 0x119 error, please follow these troubleshooting steps (this error is similar to the STOP 0x116 and STOP 0x117 errors): Video TDR Timeout - 0x116 + 0x117
Your BIOS dates from 2009. Please check at the manufacturer's website to see if there are any BIOS updates available for your system. Also check the readme file to see if they apply to the problems that you are having. Please be advised that flashing the BIOS is a very unforgiving process - and one mistake can physically damage your motherboard. This is not normally as big an issue for Win7 as it is for Win8 - but I just wanted to make you aware of it.
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions). I strongly suspect that this hold true for Win8 systems also.
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
Razer Abyssus driver dates from 2009. Known BSOD issues with the older version. Either update to a new, Win7 compatible version or remove the device and it's software.
intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
Intel IDE storage driver
http://www.carrona.org/drivers/driver.php?id=intelide.sys
dtsoftbus01.sys Fri Jan 13 08:45:46 2012 (4F10358A)
Daemon Tools driver [br] Possible BSOD issues in Win7
http://www.carrona.org/drivers/driver.php?id=dtsoftbus01.sys
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Mon Jan 28 08:33:30.377 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012813-34062-01.dmp]
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
[B][COLOR=RED]Missing Windows 7 Service Pack 1[/COLOR][/B]
Built by: [B]7600[/B].17118.amd64fre.win7_gdr.120830-0334
System Uptime:[B]0 days 1:21:42.143[/B]
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VidSchiVerifyDriverReportedFenceId+ad )[/B]
BugCheck [B]119, {1, 9e0000, 0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000119]VIDEO_SCHEDULER_INTERNAL_ERROR (119)[/url]
Arguments:
Arg1: 0000000000000001, The driver has reported an invalid fence ID.
Arg2: 00000000009e0000
Arg3: 0000000000000000
Arg4: 0000000000000000
BUGCHECK_STR:  0x119
PROCESS_NAME: [B]chrome.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x119_dxgmms1!VidSchiVerifyDriverReportedFenceId+ad[/B]
CPUID:        "Intel(R) Core(TM)2 Duo CPU     E7500  @ 2.93GHz"
MaxSpeed:     2930
CurrentSpeed: [B]2926[/B]
  BIOS Version                  P1.00
  BIOS Release Date             12/09/2009
  Manufacturer                  To Be Filled By O.E.M.
  Product Name                  To Be Filled By O.E.M.
**************************Mon Jan 28 07:10:49.238 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012813-22546-01.dmp]
System Uptime:[B]0 days 0:06:54.988[/B]
BugCheck [B]119, {1, f10000, 0, 0}[/B]
Arguments:
Arg2: 0000000000f10000
BUGCHECK_STR:  0x119
MaxSpeed:     2930
  BIOS Version                  P1.00
**************************Mon Jan 28 06:04:04.945 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012813-25140-01.dmp]
System Uptime:[B]0 days 0:01:48.662[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiSystemServiceExit+245 )[/B]
BugCheck [B]1, {77c5f72a, 0, ffff, fffff88007107c60}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000001]APC_INDEX_MISMATCH (1)[/url]
Arguments:
Arg1: 0000000077c5f72a, Address of system call function or worker routine
Arg2: 0000000000000000, Thread->ApcStateIndex
Arg3: 000000000000ffff, (Thread->SpecialApcDisable << 16) | Thread->KernelApcDisable
Arg4: fffff88007107c60, Call type (0 - system call, 1 - worker routine)
BUGCHECK_STR:  0x1
PROCESS_NAME: [B]svchost.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1_SysCallNum_4_nt!KiSystemServiceExit+245[/B]
MaxSpeed:     2930
CurrentSpeed: [B]2938[/B]
  BIOS Version                  P1.00
**************************Mon Jan 28 05:42:22.862 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012813-23875-01.dmp]
System Uptime:[B]0 days 0:05:29.643[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ExpInterlockedPopEntrySListFault16+0 )[/B]
BugCheck [B]3B, {c0000005, fffff80002ec47a5, fffff8800a15e890, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002ec47a5, Address of the instruction which caused the bugcheck
Arg3: fffff8800a15e890, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]Traktor.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!ExpInterlockedPopEntrySListFault16+0[/B]
MaxSpeed:     2930
  BIOS Version                  P1.00
**************************Sun Jan 27 15:25:38.301 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012713-40281-01.dmp]
System Uptime:[B]0 days 1:10:24.083[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiKernelCalloutExceptionHandler+e )[/B]
BugCheck [B]1E, {0, 0, 0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000001E]KMODE_EXCEPTION_NOT_HANDLED (1e)[/url]
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
BUGCHECK_STR:  0x1E
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_nt!KiKernelCalloutExceptionHandler+e[/B]
MaxSpeed:     2930
  BIOS Version                  P1.00
**************************Sun Jan 27 07:14:07.541 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012713-39640-01.dmp]
System Uptime:[B]0 days 0:51:05.338[/B]
*** WARNING: Unable to verify timestamp for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
BugCheck [B]119, {1, ff0000, 0, 0}[/B]
Arguments:
Arg2: 0000000000ff0000
BUGCHECK_STR:  0x119
MaxSpeed:     2930
  BIOS Version                  P1.00
[/font]
3rd Party Drivers:
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
[COLOR=RED][B]intelide.sys                Mon Jul 13 19:19:48 2009 (4A5BC114)[/B][/COLOR]
vHidDev.sys                 Mon Dec 21 08:49:58 2009 (4B2F7D06)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
Tpkd.sys                    Fri Mar 25 01:09:33 2011 (4D8C238D)
[COLOR=RED][B]dtsoftbus01.sys             Fri Jan 13 08:45:46 2012 (4F10358A)[/B][/COLOR]
DirectIo64.sys              Mon Aug 13 00:30:24 2012 (502882E0)
aswrdr2.sys                 Mon Oct  8 04:23:43 2012 (50728D8F)
viahduaa.sys                Mon Oct 22 04:11:15 2012 (5084FFA3)
Rt64win7.sys                Thu Oct 25 05:20:09 2012 (50890449)
aswFsBlk.SYS                Tue Oct 30 18:43:04 2012 (509057F8)
aswMonFlt.sys               Tue Oct 30 18:43:09 2012 (509057FD)
aswTdi.SYS                  Tue Oct 30 18:43:16 2012 (50905804)
aswSP.SYS                   Tue Oct 30 18:44:06 2012 (50905836)
aswSnx.SYS                  Tue Oct 30 18:44:08 2012 (50905838)
AtihdW76.sys                Tue Nov  6 16:41:51 2012 (5099841F)
atikmpag.sys                Wed Dec 19 14:32:55 2012 (50D21667)
atikmdag.sys                Wed Dec 19 15:38:55 2012 (50D225DF)
Abyssus.sys                 Thu Oct 29 22:53:48 2009 (4AEA553C)
LHidFilt.Sys                Tue Sep 18 05:26:53 2012 (50583E5D)
LUsbFilt.Sys                Tue Sep 18 05:27:01 2012 (50583E65)
amdxata.sys                 Tue May 19 13:56:59 2009 (4A12F2EB)
RtHDMIVX.sys                Tue Jun  5 01:45:14 2012 (4FCD9CEA)
[/font]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=vHidDev.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=Tpkd.sys
DirectIo64.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
aswrdr2.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=viahduaa.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=aswFsBlk.SYS
http://www.carrona.org/drivers/driver.php?id=aswMonFlt.sys
http://www.carrona.org/drivers/driver.php?id=aswTdi.SYS
http://www.carrona.org/drivers/driver.php?id=aswSP.SYS
http://www.carrona.org/drivers/driver.php?id=aswSnx.SYS
http://www.carrona.org/drivers/driver.php?id=AtihdW76.sys
http://www.carrona.org/drivers/driver.php?id=atikmpag.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
http://www.carrona.org/drivers/driver.php?id=Abyssus.sys
http://www.carrona.org/drivers/driver.php?id=LHidFilt.Sys
http://www.carrona.org/drivers/driver.php?id=LUsbFilt.Sys
http://www.carrona.org/drivers/driver.php?id=RtHDMIVX.sys
Top Bottom
