Windows 7 Blue screen appearances and physical memory dump :( please help
smritiaeon
Hey guys,
I recently upgraded to windows ultimate and since then I have been getting blue screens...saying physical memory dump...my error details are this
Problem signature:
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 2057
Additional information about the problem:
BCCode: d1
BCP1: 00000064
BCP2: 00000002
BCP3: 00000000
BCP4: 95099D54
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\020611-19702-01.dmp
C:\Users\smriti\AppData\Local\Temp\WER-34632-0.sysdata.xml
any help will do :(
smritiaeon:
Please refer to and do your best to comply with the following three links to the sticky posts in the root of the BSOD forum.
SF Diagnostic Tool
Important! Every thread starter please see.
How to ask for help with a BSOD problem
You may be able to use safemode with networking to help make this easier.
If you have any problem with these please post back and we will attempt to advise you further. Make sure you pay particular attention to the instructions regarding compressing these file before uploading as well as taking ownership of the dump folder if you have problems accessing these files.
Hi there..
Ok I will explain the situation better... I recently upgraded from Windows Vista home premium to Windows 7 professional... since the install i have been getting occasional blue screens.
I tried running SF diagnostic tool but it wouldnt work except the system info... for MS info 32 it says access denied and says cannot find file MS INFO 32 and with others it says the same... i have attached the dump files and watever i cud get from SF diagnostic tool..
here are my CPU Z captures
[/url] Capture spd by smritirocks, on Flickr[/IMG]
[/url] capture-memory by smritirocks, on Flickr[/IMG]
Apparently i did run a registry booster check in order to check whether there are any registery issues apparently it detected several issues regarding the registry... can u suggest me some help?
  • dumpfiles.rar
  • Seven Forums.rar
RAM causes your blue screens as it's set wrong.
Enter bios setup and load setup defaults. Save and reboot.
1066 Mhz 7-7-7-20 1.5 v
1. Hit 'Del' on POST when you start the PC
2. Look for the option "Setup defaults" / "Optimizable defaults"
Or if you can't find setup defaults, then set all the DRAM options to "Auto".
See how to do that in your bios manual.
Hi I did that... everything seemed to work well until today when my computer crashed twice...
But the strange thing I noticed was the BSODs actually started occurring whenever I install Adobe Reader to read my PDFs... : /
It might be my imagination i guess but here's the dmp file..
  • temp.rar
I am not surprised at all as you have some very obsolete drivers needing updates. Both your crashes were caused by the Intel Wi Fi driver.
--> Update Intel WiFi:
netw5v32.sys Thu Mar 26 12:10:37 2009
--> Update Broadcom NetLink Gigabit Ethernet:
k57nd60x.sys Sun Apr 26 07:23:19 2009
--> Update Fingerprint Sensor WDF USB:
ATSwpWDF.sys Tue Nov 24 09:01:43 2009
--> Update NVIDIA:
nvlddmkm.sys Tue Jul 28 10:21:09 2009
nvBridge.kmd Tue Jul 28 10:05:43 2009
--> Update or disable PenTablet:
PTSimHid.sys Mon Apr 23 03:28:54 2007
PTSimBus.sys Thu Jun 07 05:16:26 2007
TClass2k.sys Mon Apr 23 03:28:54 2007
UCTblHid.sys Thu May 31 05:33:43 2007
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\020911-40061-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
Built by: 7600.16617.x86fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0x82a47000 PsLoadedModuleList = 0x82b8f810
Debug session time: Wed Feb  9 16:58:53.541 2011 (UTC - 5:00)
System Uptime: 0 days 10:17:24.351
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck D1, {64, 2, 0, 820a5d54}
Unable to load image \SystemRoot\system32\DRIVERS\netw5v32.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for netw5v32.sys
*** ERROR: Module load completed but symbols could not be loaded for netw5v32.sys
Probably caused by : netw5v32.sys ( netw5v32+6bd54 )
Followup: MachineOwner
Loading Dump File [F:\a\Minidump\D M P\DMP\020911-17238-01.dmp]
Machine Name:
Kernel base = 0x82a02000 PsLoadedModuleList = 0x82b4a810
Debug session time: Wed Feb  9 18:12:26.404 2011 (UTC - 5:00)
System Uptime: 0 days 1:04:11.215
BugCheck D1, {64, 2, 0, 94c9ed54}
1: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000064, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: 94c9ed54, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 82b6a718
Unable to read MiSystemVaType memory at 82b4a160
 00000064
CURRENT_IRQL:  2
FAULTING_IP:
netw5v32+6bd54
94c9ed54 80786400        cmp     byte ptr [eax+64h],0
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xD1
PROCESS_NAME:  chrome.exe
TRAP_FRAME:  807e28b4 -- (.trap 0xffffffff807e28b4)
ErrCode = 00000000
eax=00000000 ebx=8790b000 ecx=00000001 edx=807e2934 esi=807e29f0 edi=00000000
eip=94c9ed54 esp=807e2928 ebp=807e297c iopl=0         nv up ei pl zr na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00210246
netw5v32+0x6bd54:
94c9ed54 80786400        cmp     byte ptr [eax+64h],0       ds:0023:00000064=??
Resetting default scope
LAST_CONTROL_TRANSFER:  from 94c9ed54 to 82a4882b
STACK_TEXT:
807e28b4 94c9ed54 badb0d00 807e2934 8670be02 nt!KiTrap0E+0x2cf
WARNING: Stack unwind information not available. Following frames may be wrong.
807e297c 94ca27c3 8790b000 00000000 807e29ac netw5v32+0x6bd54
807e29c8 94ca386a 8790b000 807e29e8 807e29ec netw5v32+0x6f7c3
807e29f4 94ca3f13 8790b000 00000003 807e2a64 netw5v32+0x7086a
807e2a6c 94ca4290 8790b001 850e56d0 85315fb8 netw5v32+0x70f13
807e2a88 94c3f38e 8790b000 850e56d0 85315fb8 netw5v32+0x71290
807e2ab4 94c3f6d3 85315fb8 85315fd8 850e56d0 netw5v32+0xc38e
807e2acc 94c3eb35 850e56d0 85315fb8 00000000 netw5v32+0xc6d3
807e2ae8 94c55e96 867010f0 00000157 00000001 netw5v32+0xbb35
807e2b34 94d5119f 867010b0 ff000808 807e2bb0 netw5v32+0x22e96
807e2b54 94d7ac57 86b11988 ff000808 807e2bb0 netw5v32+0x11e19f
807e2bb4 94d7b6b6 86b76000 00000001 00000007 netw5v32+0x147c57
807e2c1c 94d7a55f 86b76000 0000012d 8959c6f4 netw5v32+0x1486b6
807e2c84 94d6ec4e 00000001 0000000e 89e66c80 netw5v32+0x14755f
807e2ce0 94c3f38e 86b76000 89e66c80 00000000 netw5v32+0x13bc4e
807e2d0c 94c3f6d3 8530cfa8 8530cff0 89e66c80 netw5v32+0xc38e
807e2d24 94c3eb35 89e66c80 8530cfd0 00000008 netw5v32+0xc6d3
807e2d40 94d51007 86b119c8 000000ba 00000000 netw5v32+0xbb35
807e2d84 94c55d57 86b11988 20030011 807e2db8 netw5v32+0x11e007
807e2d9c 94c60298 867010b0 20030011 807e2db8 netw5v32+0x22d57
807e2dc0 94c4ecb8 875b1b58 872ba004 87545c70 netw5v32+0x2d298
807e2de8 94c4fbd4 872ba004 00000000 872ba004 netw5v32+0x1bcb8
807e2dfc 94c530c9 87545e18 872ba004 00000000 netw5v32+0x1cbd4
807e2e38 94c532a7 867032b0 86b82bd8 872ba040 netw5v32+0x200c9
807e2e88 94c4aa27 00000001 86b82bd8 000000ff netw5v32+0x202a7
807e2ec4 94c4731c 00703e58 80000000 807e2ee0 netw5v32+0x17a27
807e2ed4 94c347a5 86b82bd8 807e2f20 8b07c301 netw5v32+0x1431c
807e2ee0 8b07c301 866d5ec0 00000000 00000000 netw5v32+0x17a5
807e2f20 8b0279f4 8670517c 00705068 00000000 ndis!ndisMiniportDpc+0xda
807e2f48 82a6a3b5 8670517c 86705068 00000000 ndis!ndisInterruptDpc+0xaf
807e2fa4 82a6a218 807c2120 851a38b0 00000000 nt!KiExecuteAllDpcs+0xf9
807e2ff4 82a699dc a2305ce4 00000000 00000000 nt!KiRetireDpcList+0xd5
807e2ff8 a2305ce4 00000000 00000000 00000000 nt!KiDispatchInterrupt+0x2c
82a699dc 00000000 0000001a 00d6850f bb830000 0xa2305ce4
STACK_COMMAND:  kb
FOLLOWUP_IP:
netw5v32+6bd54
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  netw5v32+6bd54
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: netw5v32
IMAGE_NAME:  netw5v32.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  49cba8fd
FAILURE_BUCKET_ID:  0xD1_netw5v32+6bd54
Drivers:
start    end        module name
8acb1000 8acf9000   ACPI     ACPI.sys     Mon Jul 13 19:11:11 2009 (4A5BBF0F)
90085000 900df000   afd      afd.sys      Mon Jul 13 19:12:34 2009 (4A5BBF62)
950a4000 950b6000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
822c6000 823cc000   AGRSM    AGRSM.sys    Mon Nov 10 09:56:37 2008 (49184BA5)
8ac18000 8ac21000   amdxata  amdxata.sys  Tue May 19 13:57:35 2009 (4A12F30F)
9b944000 9b94d000   asyncmac asyncmac.sys Mon Jul 13 19:54:46 2009 (4A5BC946)
8add4000 8addd000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
8addd000 8ae00000   ataport  ataport.SYS  Mon Jul 13 19:11:18 2009 (4A5BBF16)
82015000 820b2000   ATSwpWDF ATSwpWDF.sys Tue Nov 24 09:01:43 2009 (4B0BE747)
8ad58000 8ad63000   BATTC    BATTC.SYS    Mon Jul 13 19:19:15 2009 (4A5BC0F3)
8b1f3000 8b1fa000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
8f690000 8f69e000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
8aa9f000 8aaa7000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
9a4ae000 9a4c7000   bowser   bowser.sys   Mon Jul 13 19:14:21 2009 (4A5BBFCD)
96020000 9603e000   cdd      cdd.dll      Mon Jul 13 21:04:18 2009 (4A5BD992)
8aae9000 8ab94000   CI       CI.dll       Mon Jul 13 21:09:28 2009 (4A5BDAC8)
8b19b000 8b1c0000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
8aaa7000 8aae9000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
95046000 95049700   CmBatt   CmBatt.sys   Mon Jul 13 19:19:18 2009 (4A5BC0F6)
8af6e000 8afcb000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
8ad50000 8ad58000   compbatt compbatt.sys Mon Jul 13 19:19:18 2009 (4A5BC0F6)
95097000 950a4000   CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
820b2000 820bf000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
8f614000 8f678000   csc      csc.sys      Mon Jul 13 19:15:08 2009 (4A5BBFFC)
8f678000 8f690000   dfsc     dfsc.sys     Mon Jul 13 19:14:16 2009 (4A5BBFC8)
901bd000 901c9000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
8b18a000 8b19b000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
822ad000 822c6000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
820bf000 820ca000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:11:16 2009 (4A5BBF14)
820d4000 820e5000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
820ca000 820d4000   dump_msahci dump_msahci.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
823db000 823e5000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
8f6bf000 8f776000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 20:48:33 2009 (4AC54DE1)
90f83000 90fbc000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:25:25 2009 (4A5BC265)
8ac21000 8ac32000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
8ab94000 8abc8000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
8afd9000 8afe2000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:11:14 2009 (4A5BBF12)
8b158000 8b18a000   fvevol   fvevol.sys   Fri Sep 25 22:24:21 2009 (4ABD7B55)
8b34d000 8b37e000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
82e12000 82e49000   hal      halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
90fd6000 90ff5000   HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
8222e000 8227e000   HdAudio  HdAudio.sys  Mon Jul 13 19:51:46 2009 (4A5BC892)
8214d000 82160000   HIDCLASS HIDCLASS.SYS Mon Jul 13 19:51:01 2009 (4A5BC865)
82160000 82166480   HIDPARSE HIDPARSE.SYS Mon Jul 13 19:50:59 2009 (4A5BC863)
82142000 8214d000   hidusb   hidusb.sys   Mon Jul 13 19:51:04 2009 (4A5BC868)
9a429000 9a4ae000   HTTP     HTTP.sys     Mon Jul 13 19:12:53 2009 (4A5BBF75)
8b150000 8b158000   hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
9504a000 95062000   i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B)
95085000 95097000   intelppm intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07)
8f7c1000 8f7fd000   k57nd60x k57nd60x.sys Sun Apr 26 07:23:19 2009 (49F44427)
95062000 9506f000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
80bb3000 80bbb000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
9514d000 95181000   ks       ks.sys       Wed Mar 03 22:57:52 2010 (4B8F2FC0)
8af5b000 8af6e000   ksecdd   ksecdd.sys   Mon Jul 13 19:11:56 2009 (4A5BBF3C)
8b11b000 8b140000   ksecpkg  ksecpkg.sys  Thu Dec 10 23:04:22 2009 (4B21C4C6)
821a6000 821b6000   lltdio   lltdio.sys   Mon Jul 13 19:53:18 2009 (4A5BC8EE)
8218b000 821a6000   luafv    luafv.sys    Mon Jul 13 19:15:44 2009 (4A5BC020)
8aa16000 8aa8e000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:06:41 2009 (4A5BDA21)
823ce000 823db000   modem    modem.sys    Mon Jul 13 19:55:24 2009 (4A5BC96C)
82137000 82142000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
9506f000 9507c000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
82178000 82183000   mouhid   mouhid.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
8adbe000 8add4000   mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
8abc8000 8abee680   MpFilter MpFilter.sys Tue Sep 14 17:23:59 2010 (4C8FE7EF)
9b8c8000 9b8cd900   MpKsl5f3ee821 MpKsl5f3ee821.sys Tue Mar 30 22:06:14 2010 (4BB2AE16)
9a4c7000 9a4d9000   mpsdrv   mpsdrv.sys   Mon Jul 13 19:52:52 2009 (4A5BC8D4)
9a4d9000 9a4fc000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:32:02 2010 (4B88CA72)
9a4fc000 9a537000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:32:21 2010 (4B88CA85)
9a537000 9a552000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:32:11 2010 (4B88CA7B)
8ac00000 8ac0a000   msahci   msahci.sys   Mon Jul 13 19:45:50 2009 (4A5BC72E)
9004a000 90055000   Msfs     Msfs.SYS     Mon Jul 13 19:11:26 2009 (4A5BBF1E)
8ad02000 8ad0a000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
8af30000 8af5b000   msrpc    msrpc.sys    Mon Jul 13 19:11:59 2009 (4A5BBF3F)
901b3000 901bd000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
8b140000 8b150000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
8b026000 8b0dd000   ndis     ndis.sys     Mon Jul 13 19:12:24 2009 (4A5BBF58)
950ce000 950d9000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
82000000 82010000   ndisuio  ndisuio.sys  Mon Jul 13 19:53:51 2009 (4A5BC90F)
950d9000 950fb000   ndiswan  ndiswan.sys  Mon Jul 13 19:54:34 2009 (4A5BC93A)
951dc000 951ed000   NDProxy  NDProxy.SYS  Mon Jul 13 19:54:27 2009 (4A5BC933)
90137000 90145000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
900df000 90111000   netbt    netbt.sys    Mon Jul 13 19:12:18 2009 (4A5BBF52)
8b0dd000 8b11b000   NETIO    NETIO.SYS    Thu Apr 08 22:32:21 2010 (4BBE91B5)
94c33000 95046000   netw5v32 netw5v32.sys Thu Mar 26 12:10:37 2009 (49CBA8FD)
9b8ce000 9b8d9c00   NisDrvWFP NisDrvWFP.sys Tue Sep 14 17:24:12 2010 (4C8FE7FC)
90055000 90063000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
901a9000 901b3000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
82a02000 82e12000   nt       ntkrpamp.exe Fri Jun 18 23:55:24 2010 (4C1C3FAC)
8ae01000 8af30000   Ntfs     Ntfs.sys     Mon Jul 13 19:12:05 2009 (4A5BBF45)
8b01f000 8b026000   Null     Null.SYS     Mon Jul 13 19:11:12 2009 (4A5BBF10)
90f81000 90f82080   nvBridge nvBridge.kmd Tue Jul 28 10:05:43 2009 (4A6F05B7)
9062a000 90f80840   nvlddmkm nvlddmkm.sys Tue Jul 28 10:21:09 2009 (4A6F0955)
821b6000 821fc000   nwifi    nwifi.sys    Mon Jul 13 19:51:59 2009 (4A5BC89F)
90118000 90137000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
8ad3f000 8ad50000   partmgr  partmgr.sys  Mon Jul 13 19:11:35 2009 (4A5BBF27)
8ad0a000 8ad34000   pci      pci.sys      Mon Jul 13 19:11:16 2009 (4A5BBF14)
8ac0a000 8ac18000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
8afcb000 8afd9000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
9a552000 9a5e9000   peauth   peauth.sys   Mon Jul 13 20:35:44 2009 (4A5BD2E0)
8227e000 822ad000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
8aa8e000 8aa9f000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
95181000 9518a000   PTSimBus PTSimBus.sys Thu Jun 07 05:16:26 2007 (4667CCEA)
82183000 8218b000   PTSimHid PTSimHid.sys Mon Apr 23 03:28:54 2007 (462C6036)
950b6000 950ce000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
950fb000 95113000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
95113000 9512a000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
9512a000 95141000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
90168000 901a9000   rdbss    rdbss.sys    Mon Jul 13 19:14:26 2009 (4A5BBFD2)
95141000 9514b000   rdpbus   rdpbus.sys   Mon Jul 13 20:02:40 2009 (4A5BCB20)
90032000 9003a000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:01:40 2009 (4A5BCAE4)
9003a000 90042000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
90042000 9004a000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
8b3ce000 8b3fb000   rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
823e5000 823f8000   rspndr   rspndr.sys   Mon Jul 13 19:53:20 2009 (4A5BC8F0)
9a5e9000 9a5f3000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
8b3c6000 8b3ce000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
9b877000 9b8c8000   srv      srv.sys      Thu Aug 26 23:31:26 2010 (4C77318E)
9b828000 9b877000   srv2     srv2.sys     Thu Aug 26 23:30:45 2010 (4C773165)
9a400000 9a421000   srvnet   srvnet.sys   Thu Aug 26 23:30:39 2010 (4C77315F)
9514b000 9514c380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
8216f000 82178000   TClass2k TClass2k.sys Mon Apr 23 03:28:54 2007 (462C6036)
8b204000 8b34d000   tcpip    tcpip.sys    Sun Jun 13 23:36:59 2010 (4C15A3DB)
9a5f3000 9a600000   tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
9007a000 90085000   TDI      TDI.SYS      Mon Jul 13 19:12:12 2009 (4A5BBF4C)
90063000 9007a000   tdx      tdx.sys      Mon Jul 13 19:12:10 2009 (4A5BBF4A)
90158000 90168000   termdd   termdd.sys   Mon Jul 13 20:01:35 2009 (4A5BCADF)
963e0000 963e9000   TSDDD    TSDDD.dll    unavailable (00000000)
8f69e000 8f6bf000   tunnel   tunnel.sys   Mon Jul 13 19:54:03 2009 (4A5BC91B)
82167000 8216f000   UCTblHid UCTblHid.sys Thu May 31 05:33:43 2007 (465E9677)
9518a000 95198000   umbus    umbus.sys    Mon Jul 13 19:51:38 2009 (4A5BC88A)
820fc000 82113000   usbccgp  usbccgp.sys  Mon Jul 13 19:51:31 2009 (4A5BC883)
823cc000 823cd700   USBD     USBD.SYS     Mon Jul 13 19:51:05 2009 (4A5BC869)
90fc7000 90fd6000   usbehci  usbehci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
95198000 951dc000   usbhub   usbhub.sys   Mon Jul 13 19:52:06 2009 (4A5BC8A6)
8f776000 8f7c1000   USBPORT  USBPORT.SYS  Mon Jul 13 19:51:13 2009 (4A5BC871)
820e5000 820fc000   USBSTOR  USBSTOR.SYS  Mon Jul 13 19:51:19 2009 (4A5BC877)
90fbc000 90fc7000   usbuhci  usbuhci.sys  Mon Jul 13 19:51:10 2009 (4A5BC86E)
82113000 82136b80   usbvideo usbvideo.sys Wed Mar 03 23:04:40 2010 (4B8F3158)
8ad34000 8ad3f000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
8b000000 8b00c000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
90004000 90025000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
8b37e000 8b386380   vmstorfl vmstorfl.sys Mon Jul 13 19:28:44 2009 (4A5BC32C)
8ad63000 8ad73000   volmgr   volmgr.sys   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8ad73000 8adbe000   volmgrx  volmgrx.sys  Mon Jul 13 19:11:41 2009 (4A5BBF2D)
8b387000 8b3c6000   volsnap  volsnap.sys  Mon Jul 13 19:11:34 2009 (4A5BBF26)
90145000 90158000   wanarp   wanarp.sys   Mon Jul 13 19:55:02 2009 (4A5BC956)
90025000 90032000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
8ac32000 8aca3000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
8aca3000 8acb1000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
90111000 90118000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
96180000 963cb000   win32k   win32k.sys   Tue Oct 19 23:00:01 2010 (4CBE5B31)
9507c000 95085000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:19:16 2009 (4A5BC0F4)
8acf9000 8ad02000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
Unloaded modules:
9b8da000 9b944000   spsys.sys
    Checksum:  00000000
    ImageSize:  0006A000
9a552000 9a56a000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
8b1c0000 8b1cd000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
8b1cd000 8b1d8000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000B000
8b1d8000 8b1e2000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000A000
8b1e2000 8b1f3000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
8b000000 8b01f000   cdrom.sys
    Checksum:  00000000
    ImageSize:  0001F000
Top Bottom
