Blue screen for over 6 months
Discussion in 'Windows 7 Blue Screen of Death (BSOD)' started by abd121699, Aug 2, 2013.
Thread Status:
Not open for further replies.
  1. abd121699
    abd121699 New Member
    May 28, 2013
    12
    0
    Hello, I've been getting BSOD for over 6 months but very rarely until now, I get them quite frequently. I seem to be getting them when I load something, like upon a new browser, or a new website. Now I get them well playing a game, and it's very irritating. Any help would be appreciated.
    Here is my computer specs and Diagnostic tool file.
    • W7F.zip
      File size:
      921.7 KB
      146
  2. Josephur
    Josephur Windows Forum Admin
    Staff Member Premium Supporter
    Aug 3, 2010
    1,054
    136
    Can you zip and post the last few dump files (C:\windows\minidump) so someone can analyze them? Thanks!
  3. abd121699
    May 28, 2013
    12
    0
    I thought that was the zip I attatched? I can't find this directory.
  4. Josephur
    Aug 3, 2010
    1,054
    136
    The zip is attached however I do not see any dump files in it, make sure your system is configured to write dump files so that when it blue screens we have some debug information to work with.
    1) Click on Start
    2) Run
    3) sysdm.cpl
    4) Advanced Tab
    5) Startup and Recovery Settings Button
    6) Write Debugging Information - Small Memory Dump
    If you enable this option the next time your machine BSOD's it should generate a corresponding .dmp file in the location specified under the "small dump directory" location seen in Step 6 (this defaults to %SystemRoot%\Minidump which on most machines should be C:\windows\Minidump).
  5. abd121699
    May 28, 2013
    12
    0
    Thanks for the help. I did what you said and once I bluescreen I will edit this and upload the files.
  6. abd121699
    May 28, 2013
    12
    0
    Ok so weird problem. I did what you said, and when I usually get a bluescreen my computer goes black like a bluescreen but a bluescreen never apears, and my computer just restarts like a bluescreen, and no files are put into minidump.
    When I use the program and press grab all it says "No Dump Found"
  7. Josephur
    Aug 3, 2010
    1,054
    136
    What happens if you uncheck the "Automatically Restart" option in the above mentioned configuration dialog?
  8. abd121699
    May 28, 2013
    12
    0
    I unchecked it, and I get a bluescreen again. But I'm still not getting any dump files.
  9. abd121699
    May 28, 2013
    12
    0
    Reeally want to fix this
  10. Trouble
    Trouble Noob Whisperer
    Nov 30, 2009
    13,848
    836
    First make sure your machine is configured properly to facilitate the collection of .dmp files.
    Then install this hotfix http://support.microsoft.com/kb/2716542
    if applicable or
    Perhaps this patch http://support.microsoft.com/kb/2541014
    your choice
    And stop bumping your thread, it's just annoying and as a result will likely produce less help instead of more. We can't do much without a dump file.
    #10 Trouble, Aug 10, 2013
  11. abd121699
    May 28, 2013
    12
    0
    Hello I downloaded the patch not the hotfix because I already tried the hotfix, and it still doesn't give me any dump files. I won't bump again
    Thanks for the help
  12. Mike
    Mike Windows Forum Admin
    Jul 22, 2005
    8,503
    791
    The thread is closed from abuse by the original poster for bumping the message over a dozen times. This is considered post counting and spam.
Thread Status:
Share This Page
Loading...
