Windows 7 Blue Screen MEMORY_MANAGEMENT + Screen faliure + CPU overheat
Warming
Hi there,
I have a couple of errors listed here since I don't know if they are connected or not.
System:
Windows 7 Home Premium
Intel Core i7 2600k @ 3.4GHz
ASUS Sabertooth P67
EVGA nVIDIA GTX560Ti
All these problems have happened since I builded the computer a week ago:
1) When my pc starts, it makes a bip and shortly comes up with the message that no harddisk is deteced.
2) The computer randomly shut down with the BSOD message "memory_mangement" or "system_service_exception" (or somthing like that). Can i fix that by siwthing the RAM around, som ram 1 is in slot 2 and ram 2 is in slot 1?
3) When I start Battelfield 3, my CPU overheat to 70-80 degree Celcius, but it's less than 50 degrees as soon I shut down the game.
4) My screen have twice "shutted down" due to an error with the driver it says.
It's not a lot of info, but I appreciate all the help I can get, since this is my first costum builkd PC. I will upload the DMP files a soon as I can!
EDIT: CPU-Z and DMP-files now uploaded.
Regards,
Warming
  • DMP files - Warming.zip
Hi Warming and Welcome to The Forum.
We really need to see the DMP file as it contains the only record of the sequence of events leading up to the crash, what drivers were loaded, and what was responsible.
To ensure minidumps are enabled:
Go to Start, in the Search Box type: sysdm.cpl, press Enter.
Under the Advanced tab, click on the Startup and Recovery Settings... button.
Ensure that Automatically restart is unchecked.
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box (the 256kb varies).
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump.
OK your way out.
Reboot if changes have been made.
The .dmp files are located at C:\Windows\Minidump. Until a .dmp file is generated, the Minidump folder may not exist.
Go to your C:\Windows\Minidump folder. Copy the .dmp files to a new folder on your desktop. Zip up that folder and attach to a post.
Please see: How to ask for help with a BSOD problem Following Method 2:
Download
and run the SF Diagnostics Tool. Right click the SF Diag tool and select Run as Administrator before running. When the reports have been created, zip them up and attach to a post.
Download and run CPU-Z. Take screenshots**/snips of the CPU tab, Mainboard tab, Memory tab and all the slot #'s under the SPD tab.
Go to Post Reply, click on the Go Advanced button and attach the screenshots**/snips to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
If screenshots, please crop.
Also see: http://windows7forums.com/blue-scre...lp-us-help-you-filling-your-system-specs.html
When attaching dmp files, PLEASE put them in a single zipped folder
DMP files and CPU-Z is now in post zero. Note that I did not take a screenshot of slot 1 and 3 since there isn't any RAM in them and therefore no info.
STOP 0x0000003B: SYSTEM_SERVICE_EXCEPTION
Usual causes:
System service, Device driver, graphics driver, ?memory.
Your latest dump file lists ntkrnlmp.exe as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
The ASUS HM Com Service was in use at the time of your crash. Personally, I'd recommend removing all the Asus utilities (programs), otherwise commonly known as bloatware. The Asus Probe Utility has a chequered history with Windows 7.
As you have the capability to use the XMP ram setting in your BIOS, I'd suggest that you check that it is in fact being used.
Drivers that pre-date Windows 7. Update:
MtiCtwl.sys Tue Nov 04 07:40:50 2008 MagicTunePremium or PortTalk Driver by Samsung Electronics or Beyond Logic.
XENfiltv.sys Fri Jul 31 04:40:32 2009 Link Removed due to 404 Error
Drivers with Updates:
e1c62x64.sys Tue Sep 21 22:34:15 2010 Intel(R) 82579V Gigabit Network Connection driver
jraid.sys Tue Aug 10 10:28:44 2010 JMicron Raid Driver June '11
mv91xx.sys Mon Nov 22 07:00:45 2010
mvxxmm.sys Mon Nov 22 07:00:18 2010
nusb3hub.sys Fri Dec 10 04:50:35 2010
nusb3xhc.sys Fri Dec 10 04:50:35 2010
Go to your Motherboard Mfr. Support website (or Link Removed - Invalid URL) and update your USB 3.0 drivers. A June 2011 set are available Here.
RTKVHD64.sys Tue Nov 02 11:25:59 2010 Realtek HD Audio R2.67
Bugcheck Analysis:
BugCheck 3B, {c0000005, fffff80003105bca, fffff88006447df0, 0}
Probably caused by : ntkrnlmp.exe ( nt!KiUnlinkWaitBlocks+1a )
Followup: MachineOwner
7: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80003105bca, Address of the instruction which caused the bugcheck
Arg3: fffff88006447df0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff800`03105bca 0fb6432b        movzx   eax,byte ptr [rbx+2Bh]
CONTEXT:  fffff88006447df0 -- (.cxr 0xfffff88006447df0)
rax=fffffa8009c79740 rbx=0000000009c79740 rcx=0000000009c79740
rdx=0000000000000001 rsi=0000000009c79740 rdi=fffff88003189180
rip=fffff80003105bca rsp=fffff880064487d0 rbp=fffffa800a4623c0
 r8=fffff80003054000  r9=0000000000000000 r10=ffffffffffffff7f
r11=00000000002f5b01 r12=0000000000000000 r13=0000000009c79740
r14=0000000000000001 r15=fffffa8006cbec68
iopl=0         nv up ei ng nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010282
nt!KiUnlinkWaitBlocks+0x1a:
fffff800`03105bca 0fb6432b        movzx   eax,byte ptr [rbx+2Bh] ds:002b:00000000`09c7976b=??
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x3B
PROCESS_NAME:  aaHMSvc.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff80003105bca
STACK_TEXT:
fffff880`064487d0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiUnlinkWaitBlocks+0x1a
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!KiUnlinkWaitBlocks+1a
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4e02aaa3
STACK_COMMAND:  .cxr 0xfffff88006447df0 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!KiUnlinkWaitBlocks+1a
Drivers:
fffff880`0fdbd000 fffff880`0fdfb000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00d57000 fffff880`00dae000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`03cca000 fffff880`03d53000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`0f026000 fffff880`0f03c000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`01139000 fffff880`01144000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`0456e000 fffff880`04574000   AsIO     AsIO.sys     Tue Aug 24 02:53:02 2010 (4C7325FE)
fffff880`04567000 fffff880`0456e000   AsUpIO   AsUpIO.sys   Tue Aug 03 03:47:59 2010 (4C57835F)
fffff880`06f73000 fffff880`06f7e000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00df7000 fffff880`00e00000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0106f000 fffff880`01099000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff960`00920000 fffff960`00981000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`019e5000 fffff880`019ec000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`04556000 fffff880`04567000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`05e49000 fffff880`05e67000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00640000 fffff960`00667000   cdd      cdd.dll      unavailable (00000000)
fffff880`016b8000 fffff880`016e2000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00e38000 fffff880`00ef8000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01650000 fffff880`01680000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00cf9000 fffff880`00d57000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0140b000 fffff880`0147d000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`0f016000 fffff880`0f026000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`060ff000 fffff880`0610d000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`04538000 fffff880`04556000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`04529000 fffff880`04538000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`0163a000 fffff880`01650000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`05c78000 fffff880`05c9a000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`0610d000 fffff880`06119000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`06124000 fffff880`06137000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`06119000 fffff880`06124000   dump_msahci dump_msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`060f3000 fffff880`060ff000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`052c0000 fffff880`053b4000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`053b4000 fffff880`053fa000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`05235000 fffff880`05284000   e1c62x64 e1c62x64.sys Tue Sep 21 22:34:15 2010 (4C9924D7)
fffff880`01190000 fffff880`011a4000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01144000 fffff880`01190000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`0148e000 fffff880`01498000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01600000 fffff880`0163a000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`018f2000 fffff880`0193c000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`0300b000 fffff800`03054000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`05200000 fffff880`05224000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`05224000 fffff880`05235000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`06153000 fffff880`0616c000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0616c000 fffff880`06174080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`06145000 fffff880`06153000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`05ca0000 fffff880`05d69000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`019dc000 fffff880`019e5000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`052a3000 fffff880`052af000   ICCWDT   ICCWDT.sys   Wed Aug 18 09:27:45 2010 (4C6B9981)
fffff880`0f000000 fffff880`0f016000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`00c6c000 fffff880`00c8d000   jraid    jraid.sys    Tue Aug 10 10:28:44 2010 (4C611BCC)
fffff880`045d5000 fffff880`045e4000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05e0e000 fffff880`05e1c000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00bcc000 fffff800`00bd6000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`04400000 fffff880`04443000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`01200000 fffff880`0121b000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`0121b000 fffff880`01246000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`05c9a000 fffff880`05c9f200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`05e1c000 fffff880`05e31000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`06182000 fffff880`061a5000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c96000 fffff880`00ce5000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`06137000 fffff880`06145000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`045e4000 fffff880`045f3000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`06175000 fffff880`06182000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00ddd000 fffff880`00df7000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`011a4000 fffff880`011d5000   MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`05e67000 fffff880`05e7f000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`05d69000 fffff880`05d96000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`05d96000 fffff880`05de4000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`01680000 fffff880`016a4000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`01099000 fffff880`010a4000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`03c7f000 fffff880`03c8a000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fb4000 fffff880`00fbe000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01000000 fffff880`0105e000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`0451e000 fffff880`04529000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`019ec000 fffff880`019f5000   MtiCtwl  MtiCtwl.sys  Tue Nov 04 07:40:50 2008 (490FFC82)
fffff880`019ca000 fffff880`019dc000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`010a4000 fffff880`01131000   mv91xx   mv91xx.sys   Mon Nov 22 07:00:45 2010 (4CEA151D)
fffff880`01131000 fffff880`01139000   mvxxmm   mvxxmm.sys   Mon Nov 22 07:00:18 2010 (4CEA1502)
fffff880`01498000 fffff880`0158b000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`0f060000 fffff880`0f06c000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`0f06c000 fffff880`0f09b000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`03c48000 fffff880`03c5d000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`03dc7000 fffff880`03dd6000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03d53000 fffff880`03d98000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`0158b000 fffff880`015eb000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`06eea000 fffff880`06f02000   NisDrvWFP NisDrvWFP.sys Wed Apr 06 21:08:53 2011 (4D9CC855)
fffff880`03c8a000 fffff880`03c9b000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`04512000 fffff880`0451e000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03054000 fffff800`0363d000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01248000 fffff880`013eb000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`016e2000 fffff880`016eb000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`03c2f000 fffff880`03c48000   nusb3hub nusb3hub.sys Fri Dec 10 04:50:35 2010 (4D01B19B)
fffff880`0fd8c000 fffff880`0fdbd000   nusb3xhc nusb3xhc.sys Fri Dec 10 04:50:35 2010 (4D01B19B)
fffff880`0fd34000 fffff880`0fd35180   nvBridge nvBridge.kmd Mon Dec 27 16:29:39 2010 (4D18BEF3)
fffff880`05c0e000 fffff880`05c3b000   nvhda64v nvhda64v.sys Thu Jul 07 17:21:14 2011 (4E15DCFA)
fffff880`0f0bd000 fffff880`0fd34000   nvlddmkm nvlddmkm.sys Sat Oct 15 07:07:55 2011 (4E99233B)
fffff880`03da1000 fffff880`03dc7000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00e00000 fffff880`00e15000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00fbe000 fffff880`00ff1000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00e2a000 fffff880`00e31000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00c5c000 fffff880`00c6c000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0147d000 fffff880`0148e000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`06cde000 fffff880`06d84000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`05c3b000 fffff880`05c78000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00ce5000 fffff880`00cf9000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`0f03c000 fffff880`0f060000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`0f09b000 fffff880`0f0b6000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0459a000 fffff880`045bb000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`045bb000 fffff880`045d5000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`044c1000 fffff880`04512000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`019f5000 fffff880`019fe000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01400000 fffff880`01409000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0105e000 fffff880`01067000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01990000 fffff880`019ca000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`05e31000 fffff880`05e49000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05e89000 fffff880`060f2800   RTKVHD64 RTKVHD64.sys Tue Nov 02 11:25:59 2010 (4CCFF547)
fffff880`00dae000 fffff880`00ddd000   SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`06d84000 fffff880`06d8f000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`05297000 fffff880`052a3000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`03dd6000 fffff880`03df3000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`01988000 fffff880`01990000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`06e52000 fffff880`06eea000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`06c00000 fffff880`06c69000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`06d8f000 fffff880`06dc0000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`052b8000 fffff880`052b9480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`016ee000 fffff880`018f2000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`06dc0000 fffff880`06dd2000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`03cbd000 fffff880`03cca000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`03c9b000 fffff880`03cbd000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`03c1b000 fffff880`03c2f000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`004f0000 fffff960`004fa000   TSDDD    TSDDD.dll    Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`04574000 fffff880`0459a000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`04443000 fffff880`04455000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`061e3000 fffff880`061fdc80   usbaudio usbaudio.sys Sat Nov 20 10:43:52 2010 (4CE7A668)
fffff880`061c6000 fffff880`061e3000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`05295000 fffff880`05296f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`05284000 fffff880`05295000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04455000 fffff880`044af000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`0fd36000 fffff880`0fd8c000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`00ff1000 fffff880`00ffe000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`015eb000 fffff880`015f9000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`011d5000 fffff880`011fa000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00e15000 fffff880`00e2a000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`0193c000 fffff880`01988000   volsnap  volsnap.sys  Fri Feb 25 03:38:18 2011 (4D67242A)
fffff880`03c00000 fffff880`03c1b000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`013eb000 fffff880`013fb000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00ef8000 fffff880`00f9c000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f9c000 fffff880`00fab000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`03d98000 fffff880`03da1000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00040000 fffff960`00354000   win32k   win32k.sys   Thu Nov 24 04:51:38 2011 (4ECDCD5A)
fffff880`052af000 fffff880`052b8000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00fab000 fffff880`00fb4000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`061a5000 fffff880`061c6000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`05e00000 fffff880`05e0e000   XENfiltv XENfiltv.sys Fri Jul 31 04:40:32 2009 (4A7267B0)
Unloaded modules:
fffff880`06f02000 fffff880`06f73000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`06f7e000 fffff880`06fef000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01680000 fffff880`0168e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0168e000 fffff880`0169a000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0169a000 fffff880`016a5000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`016a5000 fffff880`016b8000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
