scotty1105 - I'm running the last 11 memory dumps from your system.
The advice is based upon the report you gave that stated "BCCode: fe"
Since that's the only info we had, it's basically just a shot in the dark (although it's a bit more focused than that).
The additional info and the additional memory dumps let us dig a bit deeper.
In this case the first problem noted is the use of Daemon Tools/Alcohol % software.
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program,
then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration):
[DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012):
DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link:
Disc-Tools.com Manual procedure here:
Link Removed - Invalid URL
Next, the dump files are suggestive of problems with your mouse. And most Dell computers use USB mice. I'd suggest updating yoru mouse drivers from the Dell website (if there are any) - and also trying another mouse to see if that stops the problems.
You have Evo mouse drivers - could that be the USB device?
Please ensure that you have all available Windows Updates.
RimSerial.sys Mon Nov 24 12:02:13 2008 (492ADE15) RIM Virtual Driver (probably associated with a Blackberry)
Link Removed - Invalid URL Rt86win7.sys Thu Feb 26 04:04:22 2009 (49A65B16) Realtek NIC
Link Removed - Invalid URL btwl2cap.sys Fri Apr 3 20:28:45 2009 (49D6A9BD) Broadcom Bluetooth L2CAP Servicen
Link Removed - Invalid URL btusbflt.sys Tue Jun 9 17:46:26 2009 (4A2ED832) Widcomm Bluetooth USB Filter by Broadcom
Link Removed - Invalid URL nvhda64v.sys Fri Jun 26 18:54:59 2009 (4A4551C3) nVidia HDMI Audio Device (nForce chipset driver)
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114) Intel IDE storage driver
Link Removed - Invalid URL btwavdt.sys Tue Aug 25 16:35:17 2009 (4A944B05)
Broadcom Bluetooth AVDT Service
Link Removed - Invalid URL btwrchid.sys Tue Aug 25 16:36:32 2009 (4A944B50)
Bluetooth Remote Control HID Minidriver
Link Removed - Invalid URL netr28u.sys Tue Sep 15 00:36:25 2009 (4AAF19C9)
Ralink RT2870 series USB802.11n Wireless Adapter Driver (you may have a different manufacturer)
Link Removed - Invalid URL HECIx64.sys Thu Sep 17 15:54:16 2009 (4AB293E8)
Intel Management Engine Interface
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys btwaudio.sys Mon Sep 28 11:47:34 2009 (4AC0DA96)
Broadcom Bluetooth Audio Device
Link Removed - Invalid URL PxHlpa64.sys Tue Oct 20 14:08:42 2009 (4ADDFCAA)
Sonic CD/DVD driver (used by many different CD/DVD programs)
http://www.carrona.org/drivers/driver.php?id=PxHlpa64.sys Not usually a problem and difficult to find out what it belongs to. Leave this one until last :0)
cmudax3.sys Mon Nov 30 22:31:07 2009 (4B148DFB)
C-Media Audio Driver (WDM) by C-Media
Link Removed - Invalid URL Lot's of Norton in the memory dumps. If the above doesn't fix it, please try un-installing Norton to see if that helps.
You can find a free anti
-virus here:
Link Removed - Invalid URL Don't forget to turn the Windows Firewall on also.
I'm ignoring the video stuff for right now - but that's something we may want to consider later on.
Analysis: The following is for information purposes only. Code:
[FONT=lucida console]**************************Fri Aug 10 14:20:15.946 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\081012-6489-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17514.amd64fre.win7sp1_rtm.101119-1850
System Uptime:[B]0 days 0:00:05.725[/B]
BugCheck Code: [B]BugCheck 124, {0, fffffa80048a7028, bf800000, 100125}[/B]
Probably caused by :[B]GenuineIntel[/B]
BugCheck Info: [B]WHEA_UNCORRECTABLE_ERROR (124)[/B]
BUGCHECK_STR: 0x124_GenuineIntel
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x124_GenuineIntel__UNKNOWN[/B]
CPUID: "Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz"
MaxSpeed: 2500
CurrentSpeed: [B]2492[/B]
**************************Fri Jul 20 04:44:52.794 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\072012-28657-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 0:08:07.622[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffff80003301830, 0, ffffffffffffffff}[/B]
Probably caused by :[B]memory_corruption ( nt!MiReplenishPageSlist+c0 )[/B]
BugCheck Info: [B]KMODE_EXCEPTION_NOT_HANDLED (1e)[/B]
BUGCHECK_STR: 0x1E_c0000005_R
DEFAULT_BUCKET_ID: [B][COLOR=RED]VERIFIER_ENABLED_VISTA_MINIDUMP[/COLOR][/B]
PROCESS_NAME: [B]iexplore.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_VRF_nt!MiReplenishPageSlist+c0[/B]
CPUID: "Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz"
MaxSpeed: 3400
CurrentSpeed: [B]3400[/B]
BIOS Version 0501
BIOS Release Date 05/09/2011
Manufacturer System manufacturer
Product Name System Product Name
**************************Sun Jun 17 09:26:39.485 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\061712-23119-01.dmp]
System Uptime:[B]0 days 0:36:27.968[/B]
*** ERROR: Module load completed but symbols could not be loaded for usbhub.sys
BugCheck Code: [B]BugCheck FE, {8, 6, 5, fffffa8004ed2000}[/B]
Probably caused by :[B]usbhub.sys ( usbhub+12a60 )[/B]
BugCheck Info: [B]BUGCODE_USB_DRIVER (fe)[/B]
BUGCHECK_STR: 0xFE
FAILURE_BUCKET_ID: [B]X64_0xFE_usbhub+12a60[/B]
CPUID: "Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz"
MaxSpeed: 2400
CurrentSpeed: [B]2393[/B]
BIOS Version 04JB.M014.20091221.hkk
BIOS Release Date 12/21/2009
Manufacturer SAMSUNG ELECTRONICS CO., LTD.
Product Name R580
**************************Mon May 28 15:40:45.205 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\052812-63492-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (2 procs) Free x86 compatible
Built by: [B]7601[/B].17803.x86fre.win7sp1_gdr.120330-1504
System Uptime:[B]12 days 19:22:55.521[/B]
BugCheck Code: [B]BugCheck 1000007E, {c0000005, 82c94039, c1d1cb44, c1d1c720}[/B]
*** ERROR: Module load completed but symbols could not be loaded for srv2.sys
Probably caused by :[B]srv2.sys ( srv2+1b465 )[/B]
BugCheck Info: [B]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/B]
BUGCHECK_STR: 0x7E
FAILURE_BUCKET_ID: [B]0x7E_srv2+1b465[/B]
CPUID: "Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz"
MaxSpeed: 3000
CurrentSpeed: [B]2992[/B]
BIOS Version 1.2.4
BIOS Release Date 12/30/2009
Manufacturer Dell Inc.
Product Name Vostro 420 Series
**************************Mon Jul 23 20:17:10.934 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\072312-18125-01.dmp]
Windows 7 Kernel Version [B]7600 [/B]MP (4 procs) Free x64
Built by: [B]7600[/B].16385.amd64fre.win7_rtm.090713-1255
System Uptime:[B]0 days 0:39:27.543[/B]
BugCheck Code: [B]BugCheck 1E, {0, 0, 0, 0}[/B]
*** ERROR: Module load completed but symbols could not be loaded for mouclass.sys
*** ERROR: Module load completed but symbols could not be loaded for mouhid.sys
Probably caused by :[B]mouclass.sys ( mouclass+2cd6 )[/B]
BUGCHECK_STR: 0x1E
PROCESS_NAME: [B]wmplayer.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_mouclass+2cd6[/B]
CPUID: "Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz"
MaxSpeed: 2330
CurrentSpeed: [B]2341[/B]
BIOS Version V2.5
BIOS Release Date 06/02/2009
Manufacturer MICRO-STAR INTERNATIONAL CO.,LTD
Product Name MS-7529
**************************Sun Sep 23 22:31:47.070 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092312-30716-01.dmp]
Windows 7 Kernel Version [B]7600 [/B](Service Pack 3) MP (4 procs) Free x64
Built by: [B]7600[/B].16792.amd64fre.win7_gdr.110408-1633
System Uptime:[B]0 days 8:24:26.225[/B]
*** WARNING: Unable to verify timestamp for usbhub.sys
BugCheck Code: [B]BugCheck FE, {8, 6, 5, fffffa800be7a7a0}[/B]
BUGCHECK_STR: 0xFE
CPUID: "Intel(R) Core(TM) i5 CPU M 460 @ 2.53GHz"
MaxSpeed: 2530
CurrentSpeed: [B]2527[/B]
BIOS Version F.13
BIOS Release Date 08/27/2010
Manufacturer Hewlett-Packard
Product Name HP ENVY 14 Notebook PC
**************************Fri Sep 21 10:22:04.644 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092112-29328-01.dmp]
System Uptime:[B]0 days 2:12:50.799[/B]
BugCheck Code: [B]BugCheck FE, {8, 6, 5, fffffa800bde97a0}[/B]
BUGCHECK_STR: 0xFE
MaxSpeed: 2530
BIOS Version F.13
**************************Thu Sep 20 11:29:17.155 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092012-35022-01.dmp]
System Uptime:[B]0 days 4:17:50.311[/B]
BugCheck Code: [B]BugCheck FE, {8, 6, 5, fffffa800be6e7a0}[/B]
*** ERROR: Module load completed but symbols could not be loaded for Wdf01000.sys
BUGCHECK_STR: 0xFE
MaxSpeed: 2530
BIOS Version F.13
**************************Mon Sep 10 13:20:19.556 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091012-30700-01.dmp]
System Uptime:[B]0 days 2:56:45.086[/B]
BugCheck Code: [B]BugCheck FE, {8, 6, 5, fffffa800abf77a0}[/B]
BUGCHECK_STR: 0xFE
MaxSpeed: 2530
BIOS Version F.13
**************************Fri Sep 7 01:00:09.778 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090712-32151-01.dmp]
System Uptime:[B]0 days 3:13:20.307[/B]
BugCheck Code: [B]BugCheck FE, {8, 6, 5, fffffa800bd957a0}[/B]
BUGCHECK_STR: 0xFE
MaxSpeed: 2530
BIOS Version F.13
**************************Tue Sep 4 08:04:16.244 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090412-30607-01.dmp]
System Uptime:[B]0 days 0:56:00.773[/B]
BugCheck Code: [B]BugCheck FE, {8, 6, 5, fffffa800bef97a0}[/B]
BUGCHECK_STR: 0xFE
MaxSpeed: 2530
BIOS Version F.13
**************************Sun Sep 2 22:32:19.977 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090212-31309-01.dmp]
System Uptime:[B]0 days 0:09:33.506[/B]
BugCheck Code: [B]BugCheck FE, {8, 6, 5, fffffa800beda7a0}[/B]
BUGCHECK_STR: 0xFE
MaxSpeed: 2530
BIOS Version F.13
**************************Sun Sep 2 22:22:08.308 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090212-31122-01.dmp]
System Uptime:[B]0 days 1:33:48.838[/B]
BugCheck Code: [B]BugCheck FE, {8, 6, 5, fffffa800bd9a7a0}[/B]
BUGCHECK_STR: 0xFE
MaxSpeed: 2530
BIOS Version F.13
**************************Sun Sep 2 19:15:54.092 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090212-31746-01.dmp]
System Uptime:[B]0 days 8:12:43.371[/B]
BugCheck Code: [B]BugCheck FE, {8, 6, 5, fffffa800bc0a7a0}[/B]
BUGCHECK_STR: 0xFE
MaxSpeed: 2530
BIOS Version F.13
**************************Tue Sep 20 00:28:28.226 2011 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092011-32292-01.dmp]
System Uptime:[B]0 days 0:05:53.756[/B]
BugCheck Code: [B]BugCheck 116, {fffffa8009b7c4e0, fffff88002ef7c58, 0, 2}[/B]
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by :[B]atikmpag.sys ( atikmpag+6c58 )[/B]
BugCheck Info: [B]VIDEO_TDR_FAILURE (116)[/B]
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
BUGCHECK_STR: 0x116
FAILURE_BUCKET_ID: [B]X64_0x116_IMAGE_atikmpag.sys[/B]
MaxSpeed: 2530
BIOS Version F.13
**************************Tue Sep 20 00:22:01.960 2011 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092011-33025-01.dmp]
System Uptime:[B]7 days 6:50:26.332[/B]
BugCheck Code: [B]BugCheck 116, {fffffa80099291e0, fffff88002ed8c58, 0, 2}[/B]
BUGCHECK_STR: 0x116
MaxSpeed: 2530
BIOS Version F.13
[/FONT]
3rd Party Drivers: The following is for information purposes only. Any drivers in red should be updated or removed from your system. And should have been discussed in the body of my post. Code:
intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
NETwNs64.sys Mon Oct 31 18:57:43 2011 (4EAF27E7)
psadd.sys Mon Dec 26 20:09:28 2011 (4EF91AC8)
MpFilter.sys Fri Mar 9 06:05:26 2012 (4F59E3F6)
vpcvmm.sys Sat Nov 20 06:35:48 2010 (4CE7B294)
RTKVHD64.sys Tue Nov 23 05:14:08 2010 (4CEB93F0)
iaStor.sys Tue Mar 22 21:53:28 2011 (4D895298)
jraid.sys Thu May 19 03:55:18 2011 (4DD4CCE6)
e1c62x64.sys Wed Jul 20 12:37:53 2011 (4E270461)
igdkmd64.sys Mon Mar 19 19:31:54 2012 (4F67C1EA)
atikmpag.sys Thu Apr 5 21:10:44 2012 (4F7E4294)
atikmdag.sys Thu Apr 5 21:48:25 2012 (4F7E4B69)
[COLOR=RED][B]btwl2cap.sys Fri Apr 3 20:28:45 2009 (49D6A9BD)[/B][/COLOR]
[COLOR=RED][B]btusbflt.sys Tue Jun 9 17:46:26 2009 (4A2ED832)[/B][/COLOR]
[COLOR=RED][B]nvhda64v.sys Fri Jun 26 18:54:59 2009 (4A4551C3)[/B][/COLOR]
nvBridge.kmd Wed Feb 10 08:15:51 2010 (4B72B187)
nvlddmkm.sys Wed Feb 10 08:57:28 2010 (4B72BB48)
SynTP.sys Fri Feb 25 13:13:32 2011 (4D67F14C)
yk62x64.sys Fri May 6 06:11:27 2011 (4DC3C94F)
SYMDS64.SYS Mon May 16 18:15:03 2011 (4DD1A1E7)
RTKVHD64.sys Tue May 24 08:32:39 2011 (4DDBA567)
ccSetx64.sys Fri Nov 4 18:05:25 2011 (4EB461A5)
SYMNETS.SYS Sat Nov 12 16:11:53 2011 (4EBEE119)
Ironx64.SYS Mon Nov 14 21:00:53 2011 (4EC1C7D5)
SYMEVENT64x86.SYS Tue Nov 22 13:30:48 2011 (4ECBEA58)
SYMEFA64.SYS Tue Nov 22 19:49:28 2011 (4ECC4318)
athrx.sys Mon Dec 12 08:02:13 2011 (4EE5FB55)
eeCtrl64.sys Fri Jan 20 18:39:48 2012 (4F19FB44)
EraserUtilRebootDrv.sys Fri Jan 20 18:39:49 2012 (4F19FB45)
dump_truecrypt.sys Tue Feb 7 04:09:36 2012 (4F30EA50)
IDSvia64.sys Fri Mar 9 16:57:02 2012 (4F5A7CAE)
BHDrvx64.sys Tue Mar 13 16:02:37 2012 (4F5FA7DD)
SRTSPX64.SYS Thu Mar 15 14:09:21 2012 (4F623051)
VBoxNetFlt.sys Tue Apr 3 08:19:04 2012 (4F7AEAB8)
VBoxUSBMon.sys Tue Apr 3 08:19:05 2012 (4F7AEAB9)
VBoxDrv.sys Tue Apr 3 08:19:05 2012 (4F7AEAB9)
VBoxNetAdp.sys Tue Apr 3 08:19:06 2012 (4F7AEABA)
[COLOR=RED][B]RimSerial.sys Mon Nov 24 12:02:13 2008 (492ADE15)[/B][/COLOR]
[COLOR=RED][B]Rt86win7.sys Thu Feb 26 04:04:22 2009 (49A65B16)[/B][/COLOR]
GEARAspiWDM.sys Mon May 18 08:16:53 2009 (4A1151B5)
intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07)
amdxata.sys Fri Mar 19 12:19:01 2010 (4BA3A3F5)
EvoMouseDriverMini.sys Wed Jun 16 04:03:56 2010 (4C18856C)
EvoMouseDriverFilterHidUsb.sys Fri Jun 18 03:03:31 2010 (4C1B1A43)
truecrypt.sys Sun Sep 5 10:23:03 2010 (4C83A7C7)
atikmpag.sys Tue Apr 19 21:22:09 2011 (4DAE3541)
atikmdag.sys Tue Apr 19 21:48:00 2011 (4DAE3B50)
SYMDS.SYS Mon May 16 18:14:26 2011 (4DD1A1C2)
SASKUTIL.SYS Tue Jul 12 16:24:48 2011 (4E1CAD90)
SASDIFSV.SYS Thu Jul 21 19:03:16 2011 (4E28B034)
mozy.sys Mon Sep 12 10:55:35 2011 (4E6E1D67)
SymIMv.sys Sat Nov 12 15:55:14 2011 (4EBEDD32)
SYMNETS.SYS Sat Nov 12 15:58:19 2011 (4EBEDDEB)
Ironx86.SYS Mon Nov 14 21:00:13 2011 (4EC1C7AD)
SYMEFA.SYS Tue Nov 22 19:48:14 2011 (4ECC42CE)
keyscrambler.sys Wed Dec 14 19:39:19 2011 (4EE941B7)
eeCtrl.sys Fri Jan 20 18:33:15 2012 (4F19F9BB)
EraserUtilRebootDrv.sys Fri Jan 20 18:33:18 2012 (4F19F9BE)
SYMEVENT.SYS Mon Jan 23 13:57:32 2012 (4F1DAD9C)
IDSvix86.sys Fri Mar 9 16:55:47 2012 (4F5A7C63)
BHDrvx86.sys Tue Mar 13 15:30:22 2012 (4F5FA04E)
SRTSP.SYS Thu Mar 15 14:05:33 2012 (4F622F6D)
SRTSPX.SYS Thu Mar 15 14:05:40 2012 (4F622F74)
NAVEX15.SYS Wed Apr 25 04:36:43 2012 (4F97B79B)
NAVENG.SYS Wed Apr 25 04:38:43 2012 (4F97B813)
[COLOR=RED][B]amdxata.sys Tue May 19 13:56:59 2009 (4A12F2EB)[/B][/COLOR]
[COLOR=RED][B]intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)[/B][/COLOR]
atikmpag.sys Tue May 24 22:25:42 2011 (4DDC68A6)
atikmdag.sys Tue May 24 22:40:32 2011 (4DDC6C20)
Rt64win7.sys Thu Feb 16 00:39:50 2012 (4F3C96A6)
stwrt64.sys Thu Jan 14 00:44:05 2010 (4B4EAF25)
Impcd.sys Fri Feb 26 18:32:11 2010 (4B8859FB)
iaStor.sys Wed Mar 24 16:55:45 2010 (4BAA7C51)
SCDEmu.SYS Mon Apr 12 04:52:25 2010 (4BC2DF49)
clwvd.sys Tue May 25 23:06:46 2010 (4BFC9046)
Accelerometer.sys Fri Jul 16 11:02:38 2010 (4C40748E)
hpdskflt.sys Fri Jul 16 11:02:38 2010 (4C40748E)
igdpmd64.sys Wed Jul 28 17:10:36 2010 (4C509CCC)
SynTP.sys Fri Sep 10 21:09:32 2010 (4C8AD6CC)
Sftvollh.sys Mon Sep 13 18:02:56 2010 (4C8E9F90)
Sftfslh.sys Mon Sep 13 18:03:14 2010 (4C8E9FA2)
Sftplaylh.sys Mon Sep 13 18:03:15 2010 (4C8E9FA3)
Sftredirlh.sys Mon Sep 13 18:03:26 2010 (4C8E9FAE)
aqs3n19s.SYS Sun Nov 28 05:38:44 2010 (4CF23134)
[COLOR=RED][B]dtsoftbus01.sys Thu Jan 13 03:27:08 2011 (4D2EB75C)[/B][/COLOR]
AtihdW76.sys Tue Jun 7 06:34:39 2011 (4DEDFEBF)
NETwNs64.sys Wed Aug 3 20:28:26 2011 (4E39E7AA)
atikmpag.sys Mon Oct 3 11:22:40 2011 (4E89D340)
atikmdag.sys Mon Oct 3 11:55:28 2011 (4E89DAF0)
ayay23dq.SYS Wed Dec 28 04:10:52 2011 (4EFADD1C)
[COLOR=RED][B]sptd.sys Sat Mar 3 11:45:52 2012 (4F524AC0)[/B][/COLOR]
asj0265v.SYS Sun Nov 28 05:38:44 2010 (4CF23134)
arybm0d9.SYS Wed Dec 28 04:10:52 2011 (4EFADD1C)
ak1s1ep6.SYS Sun Nov 28 05:38:44 2010 (4CF23134)
ays0shhh.SYS Wed Dec 28 04:10:52 2011 (4EFADD1C)
a6glwv6x.SYS Sun Nov 28 05:38:44 2010 (4CF23134)
axw7jnz7.SYS Wed Dec 28 04:10:52 2011 (4EFADD1C)
acowwy1v.SYS Sun Nov 28 05:38:44 2010 (4CF23134)
ale5luqa.SYS Wed Dec 28 04:10:52 2011 (4EFADD1C)
ae5b6ezv.SYS Sun Nov 28 05:38:44 2010 (4CF23134)
aakllfvk.SYS Wed Dec 28 04:10:52 2011 (4EFADD1C)
axm31tvf.SYS Sun Nov 28 05:38:44 2010 (4CF23134)
ahnriaon.SYS Wed Dec 28 04:10:52 2011 (4EFADD1C)
apberpqk.SYS Sun Nov 28 05:38:44 2010 (4CF23134)
a8eo194j.SYS Wed Dec 28 04:10:52 2011 (4EFADD1C)
akyje9vz.SYS Sun Nov 28 05:38:44 2010 (4CF23134)
awo7k11v.SYS Wed Dec 28 04:10:52 2011 (4EFADD1C)
btwl2cap.sys Mon Mar 1 21:25:23 2010 (4B8C7713)
NETw5s64.sys Thu Mar 18 01:21:53 2010 (4BA1B871)
Sftvollh.sys Fri Apr 23 15:20:08 2010 (4BD1F2E8)
Sftplaylh.sys Fri Apr 23 15:20:28 2010 (4BD1F2FC)
Sftfslh.sys Fri Apr 23 15:20:30 2010 (4BD1F2FE)
Sftredirlh.sys Fri Apr 23 15:20:39 2010 (4BD1F307)
AtiHdmi.sys Thu May 6 05:20:39 2010 (4BE289E7)
igdpmd64.sys Wed Jun 2 12:43:16 2010 (4C068A24)
btwavdt.sys Thu Jun 3 15:34:57 2010 (4C0803E1)
btwaudio.sys Thu Jun 3 15:36:00 2010 (4C080420)
btwrchid.sys Thu Jun 3 15:36:17 2010 (4C080431)
btwampfl.sys Thu Jun 3 15:37:28 2010 (4C080478)
stwrt64.sys Thu Jun 17 22:16:06 2010 (4C1AD6E6)
atikmpag.sys Mon Jun 21 21:24:10 2010 (4C2010BA)
atikmdag.sys Mon Jun 21 21:49:15 2010 (4C20169B)
MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
MpNWMon.sys Tue Sep 14 20:19:30 2010 (4C901112)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys http://www.carrona.org/drivers/driver.php?id=amdxata.sys http://www.carrona.org/drivers/driver.php?id=NETwNs64.sys Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=MpFilter.sys http://www.carrona.org/drivers/driver.php?id=vpcvmm.sys http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys http://www.carrona.org/drivers/driver.php?id=iaStor.sys Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=e1c62x64.sys http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys Link Removed - Invalid URL Link Removed - Invalid URL Link Removed - Invalid URL Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys Link Removed - Invalid URL Link Removed - Invalid URL Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=nvBridge.kmd http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys http://www.carrona.org/drivers/driver.php?id=SynTP.sys Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=SYMDS64.SYS http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=SYMNETS.SYS http://www.carrona.org/drivers/driver.php?id=Ironx64.SYS http://www.carrona.org/drivers/driver.php?id=SYMEVENT64x86.SYS http://www.carrona.org/drivers/driver.php?id=SYMEFA64.SYS http://www.carrona.org/drivers/driver.php?id=athrx.sys http://www.carrona.org/drivers/driver.php?id=eeCtrl64.sys http://www.carrona.org/drivers/driver.php?id=EraserUtilRebootDrv.sys dump_truecrypt.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=IDSvia64.sys http://www.carrona.org/drivers/driver.php?id=BHDrvx64.sys http://www.carrona.org/drivers/driver.php?id=SRTSPX64.SYS http://www.carrona.org/drivers/driver.php?id=VBoxNetFlt.sys http://www.carrona.org/drivers/driver.php?id=VBoxUSBMon.sys http://www.carrona.org/drivers/driver.php?id=VBoxDrv.sys http://www.carrona.org/drivers/driver.php?id=VBoxNetAdp.sys Link Removed - Invalid URL Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys http://www.carrona.org/drivers/driver.php?id=intelppm.sys Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=amdxata.sys EvoMouseDriverMini.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
EvoMouseDriverFilterHidUsb.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
Link Removed - Invalid URL Link Removed - Invalid URL Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=SYMDS.SYS Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=SASDIFSV.SYS http://www.carrona.org/drivers/driver.php?id=mozy.sys Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=SYMNETS.SYS http://www.carrona.org/drivers/driver.php?id=Ironx86.SYS Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=keyscrambler.sys http://www.carrona.org/drivers/driver.php?id=eeCtrl.sys http://www.carrona.org/drivers/driver.php?id=EraserUtilRebootDrv.sys http://www.carrona.org/drivers/driver.php?id=SYMEVENT.SYS http://www.carrona.org/drivers/driver.php?id=IDSvix86.sys http://www.carrona.org/drivers/driver.php?id=BHDrvx86.sys http://www.carrona.org/drivers/driver.php?id=SRTSP.SYS http://www.carrona.org/drivers/driver.php?id=SRTSPX.SYS http://www.carrona.org/drivers/driver.php?id=NAVEX15.SYS http://www.carrona.org/drivers/driver.php?id=NAVENG.SYS http://www.carrona.org/drivers/driver.php?id=amdxata.sys Link Removed - Invalid URL Link Removed - Invalid URL Link Removed - Invalid URL Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys http://www.carrona.org/drivers/driver.php?id=HECIx64.sys http://www.carrona.org/drivers/driver.php?id=stwrt64.sys http://www.carrona.org/drivers/driver.php?id=Impcd.sys http://www.carrona.org/drivers/driver.php?id=iaStor.sys Link Removed - Invalid URL Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=Accelerometer.sys http://www.carrona.org/drivers/driver.php?id=hpdskflt.sys http://www.carrona.org/drivers/driver.php?id=igdpmd64.sys http://www.carrona.org/drivers/driver.php?id=SynTP.sys http://www.carrona.org/drivers/driver.php?id=Sftvollh.sys http://www.carrona.org/drivers/driver.php?id=Sftfslh.sys http://www.carrona.org/drivers/driver.php?id=Sftplaylh.sys http://www.carrona.org/drivers/driver.php?id=Sftredirlh.sys aqs3n19s.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
http://www.carrona.org/drivers/driver.php?id=dtsoftbus01.sys Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=NETwNs64.sys Link Removed - Invalid URL Link Removed - Invalid URL ayay23dq.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
http://www.carrona.org/drivers/driver.php?id=sptd.sys asj0265v.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
arybm0d9.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
ak1s1ep6.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
ays0shhh.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
a6glwv6x.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
axw7jnz7.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
acowwy1v.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
ale5luqa.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
ae5b6ezv.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
aakllfvk.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
axm31tvf.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
ahnriaon.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
apberpqk.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
a8eo194j.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
akyje9vz.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
awo7k11v.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically generated driver name.
http://www.carrona.org/drivers/driver.php?id=PxHlpa64.sys Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=NETw5s64.sys http://www.carrona.org/drivers/driver.php?id=Sftvollh.sys http://www.carrona.org/drivers/driver.php?id=Sftplaylh.sys http://www.carrona.org/drivers/driver.php?id=Sftfslh.sys http://www.carrona.org/drivers/driver.php?id=Sftredirlh.sys http://www.carrona.org/drivers/driver.php?id=AtiHdmi.sys http://www.carrona.org/drivers/driver.php?id=igdpmd64.sys Link Removed - Invalid URL Link Removed - Invalid URL Link Removed - Invalid URL Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=stwrt64.sys Link Removed - Invalid URL Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=MpFilter.sys http://www.carrona.org/drivers/driver.php?id=MpNWMon.sys
