Windows 7 Blue Screen of Death, Please Help
KJQuadro
I was on the web, watching a youtube video, halfway through it blue screened, the internet browser that I am using is Google Chrome, Steam was downloading something in the background, and the anti virus is AVG Free Edition.
Hope this stuff helps, unfortunately I am unable to upload the W7F Diagnostics Tools File, the forum is saying error when I try to upload the file, so I have uploaded the files individually, the only ones that said error when doing the files separately are; "EventApp.txt" and "EventSys.txt".
Thanks.
  • 052713-29062-01.dmp
  • DriverList.txt
  • dxdiag.txt
  • Hosts.txt
  • SystemInfo.txt
usasma
Fantastic Member
Still need the MSINF32.nfo file - here's alternate instructions for getting it:
MSINFO32:
Please go to Start and type in "msinfo32.exe" (without the quotes) and press Enter
Save the report as an .nfo file, then zip up the .nfo file and upload/attach the .zip file with your next post.
Also, save a copy as a .txt file and include it also (it's much more difficult to read, but we have greater success in getting the info from it).
If you're having difficulties with the format, please open an elevated (Run as administrator) Command Prompt and type (or copy/paste) "msinfo32 /nfo %USERPROFILE%\Desktop\TEST.NFO" (without the quotes) and press Enter. Then navigate to Desktop to retrieve the TEST.NFO file. If you have difficulties with making this work, please post back. Then zip up the .nfo file and upload/attach the .zip file with your next post.
Elevated Command Prompt:
Win7/Vista: Click on the Start button and type "cmd" (without the quotes). At the top of the search box you'll see cmd.exe appear. Right click on it and select "Run as administrator".
Win8: Press the Win key and the X key at the same time. When the Power User menu pops up in the lower left corner of the screen, press the A key.
Check to be sure you have ALL Windows Updates - visit it a couple of times in order to be sure.
You have a Corsair Gaming Keyboard - do you use Corsair Link2? If so, please uninstall it to see if it'll help (it's known to cause BSOD's on some Windows systems)
If all of this doesn't stop the BSOD's, please run Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Mon May 27 08:30:25.889 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\052713-29062-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].18113.amd64fre.win7sp1_gdr.130318-1533
System Uptime:[B]0 days 2:53:07.591[/B]
Probably caused by :[B]memory_corruption ( nt!MiMapPageInHyperSpaceWorker+1b )[/B]
BugCheck [B]A, {680019209da, 2, 0, fffff8000351306b}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000000A]IRQL_NOT_LESS_OR_EQUAL (a)[/url]
Arguments:
Arg1: 00000680019209da, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff8000351306b, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME:  avgnsa.exe
FAILURE_BUCKET_ID: [B]X64_0xA_nt!MiMapPageInHyperSpaceWorker+1b[/B]
CPUID:        "Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz"
MaxSpeed:     3500
CurrentSpeed: [B]3510[/B]
  BIOS Version                  1206
  BIOS Release Date             06/05/2012
[/font]
3rd Party Drivers:
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
LGBusEnum.sys               Mon Nov 23 20:36:48 2009 (4B0B38B0)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
AsUpIO.sys                  Mon Aug  2 22:47:59 2010 (4C57835F)
ICCWDT.sys                  Wed Aug 18 04:27:45 2010 (4C6B9981)
AsIO.sys                    Mon Aug 23 21:53:02 2010 (4C7325FE)
rikvm_38F51D56.sys          Fri Oct 29 06:52:09 2010 (4CCAA759)
bcmvwl64.sys                Mon Nov 22 08:58:19 2010 (4CEA76FB)
btwl2cap.sys                Fri Feb 11 20:06:04 2011 (4D55DCFC)
btwdpan.sys                 Mon May 16 10:58:06 2011 (4DD13B7E)
CORSGKB.sys                 Mon Jun 20 22:38:24 2011 (4E000420)
btwavdt.sys                 Thu Jun 23 10:53:33 2011 (4E03536D)
btwrchid.sys                Thu Jun 23 10:56:51 2011 (4E035433)
btwaudio.sys                Wed Jul  6 18:39:13 2011 (4E14E411)
BCM42RLY.sys                Tue Jul 19 23:22:48 2011 (4E264A08)
btwampfl.sys                Tue Sep 20 13:14:26 2011 (4E78C9F2)
Rt64win7.sys                Tue Sep 27 10:50:33 2011 (4E81E2B9)
PxHlpa64.sys                Mon Oct 17 10:29:34 2011 (4E9C3BCE)
bcbtums.sys                 Tue Oct 18 14:37:25 2011 (4E9DC765)
bcmwl664.sys                Wed Oct 26 22:45:09 2011 (4EA8C5B5)
asmtxhci.sys                Wed Nov  2 23:00:22 2011 (4EB203C6)
asmthub3.sys                Wed Nov  2 23:00:32 2011 (4EB203D0)
mv91cons.sys                Mon Nov  7 03:51:20 2011 (4EB79C08)
mvxxmm.sys                  Mon Nov  7 03:58:34 2011 (4EB79DBA)
mvs91xx.sys                 Mon Nov  7 03:58:49 2011 (4EB79DC9)
asahci64.sys                Thu Jan  5 00:08:19 2012 (4F053043)
iusb3hub.sys                Thu Jan  5 06:54:43 2012 (4F058F83)
iusb3xhc.sys                Thu Jan  5 06:54:45 2012 (4F058F85)
iusb3hcs.sys                Thu Jan  5 06:56:40 2012 (4F058FF8)
iaStor.sys                  Wed Feb  1 19:15:24 2012 (4F29D59C)
LGSHidFilt.Sys              Tue Feb  7 08:12:39 2012 (4F312347)
cbfs3.sys                   Mon Apr  9 09:21:46 2012 (4F82E26A)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
RTKVHD64.sys                Tue Jun 19 04:50:56 2012 (4FE03D70)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
nvhda64v.sys                Tue Jul  3 11:25:04 2012 (4FF30ED0)
e1c62x64.sys                Fri Aug 10 18:44:15 2012 (50258EBF)
nvlddmkm.sys                Fri Jan 18 08:22:15 2013 (50F94C87)
avgrkx64.sys                Thu Feb  7 22:14:05 2013 (51146D7D)
avgldx64.sys                Thu Feb  7 22:14:24 2013 (51146D90)
avgloga.sys                 Thu Feb  7 22:14:29 2013 (51146D95)
avgidsha.sys                Thu Feb  7 22:14:48 2013 (51146DA8)
avgmfx64.sys                Thu Feb  7 22:14:48 2013 (51146DA8)
avgtdia.sys                 Wed Mar 20 21:50:47 2013 (514A6777)
avgidsdrivera.sys           Thu Mar 28 21:40:56 2013 (5154F128)
[/font]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=LGBusEnum.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=AsUpIO.sys
http://www.carrona.org/drivers/driver.php?id=ICCWDT.sys
http://www.carrona.org/drivers/driver.php?id=AsIO.sys
http://www.carrona.org/drivers/driver.php?id=rikvm_38F51D56.sys
http://www.carrona.org/drivers/driver.php?id=bcmvwl64.sys
http://www.carrona.org/drivers/driver.php?id=btwl2cap.sys
http://www.carrona.org/drivers/driver.php?id=btwdpan.sys
http://www.carrona.org/drivers/driver.php?id=CORSGKB.sys
http://www.carrona.org/drivers/driver.php?id=btwavdt.sys
http://www.carrona.org/drivers/driver.php?id=btwrchid.sys
http://www.carrona.org/drivers/driver.php?id=btwaudio.sys
http://www.carrona.org/drivers/driver.php?id=BCM42RLY.sys
http://www.carrona.org/drivers/driver.php?id=btwampfl.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=PxHlpa64.sys
http://www.carrona.org/drivers/driver.php?id=bcbtums.sys
http://www.carrona.org/drivers/driver.php?id=bcmwl664.sys
http://www.carrona.org/drivers/driver.php?id=asmtxhci.sys
http://www.carrona.org/drivers/driver.php?id=asmthub3.sys
http://www.carrona.org/drivers/driver.php?id=mv91cons.sys
http://www.carrona.org/drivers/driver.php?id=mvxxmm.sys
http://www.carrona.org/drivers/driver.php?id=mvs91xx.sys
http://www.carrona.org/drivers/driver.php?id=asahci64.sys
http://www.carrona.org/drivers/driver.php?id=iusb3hub.sys
http://www.carrona.org/drivers/driver.php?id=iusb3xhc.sys
http://www.carrona.org/drivers/driver.php?id=iusb3hcs.sys
http://www.carrona.org/drivers/driver.php?id=iaStor.sys
http://www.carrona.org/drivers/driver.php?id=LGSHidFilt.Sys
http://www.carrona.org/drivers/driver.php?id=cbfs3.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=e1c62x64.sys
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
http://www.carrona.org/drivers/driver.php?id=avgrkx64.sys
http://www.carrona.org/drivers/driver.php?id=avgldx64.sys
http://www.carrona.org/drivers/driver.php?id=avgloga.sys
http://www.carrona.org/drivers/driver.php?id=avgidsha.sys
http://www.carrona.org/drivers/driver.php?id=avgmfx64.sys
http://www.carrona.org/drivers/driver.php?id=avgtdia.sys
http://www.carrona.org/drivers/driver.php?id=avgidsdrivera.sys
KJQuadro
Ok, it blue screened again, it was a driver fault as the blue screen had this on it; [h=2]IRQL_NOT_LESS_OR_EQUAL[/h]
If you could tell me the drivers and devices causing the issue it would help a lot, I have uploaed a new crash dump, with all the files needed.
Thanks.
  • W7F_29-05-2013.zip
KJQuadro
Also thought I should give you as much info on the system's components as possible;
Motherboard: Asus P8Z77-V Deluxe
Processor: Intel Core I7 3770K Ivy Bridge
Graphics Card: EVGA GTX 570 Classified
Memory/RAM: 8GB (2 sticks) Corsair Vengeance
Hard Drive: WD Black 1TB
Power Supply: Hiper S625 (625W) NOTE: Power Supply is around 7 or 6 years old
CPU Cooler: Corsair H80
Mouse: Logitech G300
Keyboard: Corsair K90
usasma
Fantastic Member
Although sometimes looking at a dump file will tell you what driver is causing it - it's never sure that that is the actual problem.
In it's simplest form, the problem with the driver could actually be caused by a hardware problem with the device (in other words, if it's a video driver, it's possible that the video driver is broken).
But more typically, there are different things interacting with the system that are causing the BSOD's. We know of some of the more common BSOD causes ( Driver Reference Table - Common BSOD related drivers ), but there are also issues with older drivers, and with drivers that become corrupted.
I recently learned that even errors typically thought of as driver issues can be actually due to hardware problems (see this article: Bit Flips - Sysnative Forums )
There's nothing of significance (related to the BSOD issues) that I could see in the MSINFO32 report.
No mention of BSOD's in the WER section of MSINFO32 either.
Have you run Driver Verifier as I requested earlier? If not, please do so according to these instructions: Driver Verifier Settings
If Driver Verifier doesn't give us anything to go on, then I'll suspect a hardware problem. You can get a head start on that by running these free diagnostics: Hardware Diagnostics
Good luck!
KJQuadro
Ok, the computer blue screened, hopefully the driver verifier worked.
Got the file.
  • W7F_31-05-2013.zip
usasma
Fantastic Member
This is a Verifier Enabled memory dump - yet it does not blame a 3rd party driver (which we were testing for). As such it's most likely a hardware problem - although a Windows problem is also a possibility (but is much less likely)
Please run these free hardware diagnostics: Hardware Diagnostics
Microsoft (R) Windows Debugger Version 6.2.9200.16384 AMD64
Loading Dump File [C:\Users\Owner\Downloads\053113-31699-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols;srv*c:\SymcachePublic*http://ctxsym.citrix.com/symbolsad/symbols
Executable search path is:
Built by: 7601.18113.amd64fre.win7sp1_gdr.130318-1533
Machine Name:
Kernel base = 0xfffff800`0305f000 PsLoadedModuleList = 0xfffff800`032a2670
Debug session time: Fri May 31 09:21:37.907 2013 (UTC - 4:00)
System Uptime: 0 days 1:51:35.750
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck A, {680007fd5a8, 2, 0, fffff800031637e5}
Probably caused by : memory_corruption ( nt!MiGetTopLevelPfn+65 )
Followup: MachineOwner
6: kd> !analyze -v; !sysinfo cpuspeed; !sysinfo SMBIOS; lmtsmn
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 00000680007fd5a8, memory referenced
Arg4: fffff800031637e5, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff8000330c100
GetUlongFromAddress: unable to read from fffff8000330c1c0
 00000680007fd5a8 Nonpaged pool
CURRENT_IRQL:  2
FAULTING_IP:
fffff800`031637e5 4c8b4928        mov     r9,qword ptr [rcx+28h]
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP
BUGCHECK_STR:  0xA
PROCESS_NAME:  svchost.exe
TRAP_FRAME:  fffff8800ac43390 -- (.trap 0xfffff8800ac43390)
rax=000000400002a9c8 rbx=0000000000000000 rcx=00000680007fd580
rdx=fffffff5558ec11d rsi=0000000000000000 rdi=0000000000000000
rip=fffff800031637e5 rsp=fffff8800ac43528 rbp=0000000000000005
 r8=fffffe000ac43560  r9=000000400002a9c8 r10=fffff8800ac435d8
r11=0000000000000001 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na pe nc
nt!MiGetTopLevelPfn+0x65:
fffff800`031637e5 4c8b4928        mov     r9,qword ptr [rcx+28h] ds:00000680`007fd5a8=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800030d41a9 to fffff800030d4c00
STACK_TEXT:
fffff880`0ac43248 fffff800`030d41a9 : 00000000`0000000a 00000680`007fd5a8 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`0ac43250 fffff800`030d2e20 : 00000000`00000000 fffffa80`08663000 00000000`42506650 000fffff`ffffffff : nt!KiBugCheckDispatch+0x69
fffff880`0ac43390 fffff800`031637e5 : fffff800`03186142 00000040`0002a9c8 fffffa80`08664210 00000000`42506600 : nt!KiPageFault+0x260
fffff880`0ac43528 fffff800`03186142 : 00000040`0002a9c8 fffffa80`08664210 00000000`42506600 fffff800`033c1603 : nt!MiGetTopLevelPfn+0x65
fffff880`0ac43530 fffff800`0318693b : 00000000`00000000 00000000`00000004 fffffa80`08664210 fffffa80`08663000 : nt!MiIdentifyPfn+0x722
fffff880`0ac435d0 fffff800`034e8ee5 : fffffa80`08663000 fffff880`0ac43b60 fffff880`0ac436a8 00000000`00000000 : nt!MmQueryPfnList+0xbb
fffff880`0ac43610 fffff800`0342c888 : 00000000`00000006 00000000`00000000 fffffa80`08663000 00000000`00000001 : nt!PfpPfnPrioRequest+0x115
fffff880`0ac43660 fffff800`033e16d3 : 00000000`00000000 00000000`00000000 fffffa80`08664000 00000000`00000801 : nt! ?? ::NNGAKEGL::`string'+0x42efd
fffff880`0ac436f0 fffff800`033e1f4d : 00000000`0149bcc8 fffff800`0354e500 00000000`0149bd20 00000000`0149bce8 : nt!ExpQuerySystemInformation+0x1193
fffff880`0ac43aa0 fffff800`030d3e93 : fffffa80`0e42f700 00000000`04268480 00000000`09c05d10 00000000`0001fcb0 : nt!NtQuerySystemInformation+0x4d
fffff880`0ac43ae0 00000000`7730167a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0149bbe8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7730167a
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!MiGetTopLevelPfn+65
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  5147d9c6
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0xA_VRF_nt!MiGetTopLevelPfn+65
sysinfo: could not find necessary interfaces.
sysinfo: note that mssmbios.sys must be loaded (XPSP2+).
fffff880`00e00000 fffff880`00e57000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`042ec000 fffff880`04375000   afd      afd.sys      Tue Dec 27 22:59:20 2011 (4EFA9418)
fffff880`065bc000 fffff880`065d2000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`015b9000 fffff880`015c4000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`015a1000 fffff880`015b1000   asahci64 asahci64.sys Mon Sep 17 07:36:13 2012 (50570B2D)
fffff880`042e4000 fffff880`042ea000   AsIO     AsIO.sys     Wed Aug 22 05:54:47 2012 (5034AC67)
fffff880`0956a000 fffff880`0958e000   asmthub3 asmthub3.sys Wed Nov 02 23:00:32 2011 (4EB203D0)
fffff880`05eee000 fffff880`05f52000   asmtxhci asmtxhci.sys Wed Nov 02 23:00:22 2011 (4EB203C6)
fffff880`042dd000 fffff880`042e4000   AsUpIO   AsUpIO.sys   Mon Aug 02 22:47:59 2010 (4C57835F)
fffff880`0b38f000 fffff880`0b39a000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00feb000 fffff880`00ff4000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01060000 fffff880`0108a000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff880`01db7000 fffff880`01dfa000   avgidsdrivera avgidsdrivera.sys Thu Mar 28 21:40:56 2013 (5154F128)
fffff880`01d06000 fffff880`01d1b000   avgidsha avgidsha.sys Thu Feb 07 22:14:48 2013 (51146DA8)
fffff880`042a6000 fffff880`042dd000   avgldx64 avgldx64.sys Thu Feb 07 22:14:24 2013 (51146D90)
fffff880`01c98000 fffff880`01ce7000   avgloga  avgloga.sys  Thu Feb 07 22:14:29 2013 (51146D95)
fffff880`01ce7000 fffff880`01d06000   avgmfx64 avgmfx64.sys Thu Feb 07 22:14:48 2013 (51146DA8)
fffff880`01c8b000 fffff880`01c98000   avgrkx64 avgrkx64.sys Thu Feb 07 22:14:05 2013 (51146D7D)
fffff880`01d33000 fffff880`01d72000   avgtdia  avgtdia.sys  Wed Mar 20 21:50:47 2013 (514A6777)
fffff880`0958e000 fffff880`095c1000   bcbtums  bcbtums.sys  Fri Aug 24 17:21:36 2012 (5037F060)
fffff880`0b315000 fffff880`0b31e000   BCM42RLY BCM42RLY.sys Tue Jul 19 23:22:48 2011 (4E264A08)
fffff880`06027000 fffff880`06030000   bcmvwl64 bcmvwl64.sys Mon Nov 22 08:58:19 2010 (4CEA76FB)
fffff880`06030000 fffff880`064ba000   bcmwl664 bcmwl664.sys Wed Oct 26 22:45:09 2011 (4EA8C5B5)
fffff880`05d53000 fffff880`05d5a000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`04295000 fffff880`042a6000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`059cb000 fffff880`059e9000   bowser   bowser.sys   Tue Feb 22 23:55:04 2011 (4D649328)
fffff880`08cee000 fffff880`08cfe000   BthEnum  BthEnum.sys  Mon Jul 13 20:06:52 2009 (4A5BCC1C)
fffff880`08cfe000 fffff880`08d1e000   bthpan   bthpan.sys   Mon Jul 13 20:07:00 2009 (4A5BCC24)
fffff880`08c36000 fffff880`08cc2000   bthport  bthport.sys  Fri Jul 06 16:07:41 2012 (4FF7458D)
fffff880`08f77000 fffff880`08f8f000   BTHUSB   BTHUSB.sys   Wed Apr 27 23:54:56 2011 (4DB8E510)
fffff880`08e63000 fffff880`08f77000   btwampfl btwampfl.sys Sat Dec 01 16:50:24 2012 (50BA7BA0)
fffff880`08d86000 fffff880`08de3000   btwaudio btwaudio.sys Fri Apr 27 16:54:05 2012 (4F9B076D)
fffff880`08d1e000 fffff880`08d86000   btwavdt  btwavdt.sys  Thu Mar 01 16:45:18 2012 (4F4FEDEE)
fffff880`08de3000 fffff880`08df1000   btwl2cap btwl2cap.sys Sat Aug 27 18:58:52 2011 (4E5976AC)
fffff880`08df1000 fffff880`08df4a00   btwrchid btwrchid.sys Thu Mar 01 16:46:08 2012 (4F4FEE20)
fffff960`00710000 fffff960`00737000   cdd      cdd.dll      unavailable (00000000)
fffff880`05d20000 fffff880`05d4a000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`00d31000 fffff880`00df1000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`01c5b000 fffff880`01c8b000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00cd3000 fffff880`00d31000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0181f000 fffff880`01891000   cng      cng.sys      Fri Jun 01 23:25:51 2012 (4FC987BF)
fffff880`065ac000 fffff880`065bc000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`08fb8000 fffff880`08fc6000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04277000 fffff880`04295000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`04268000 fffff880`04277000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01c45000 fffff880`01c5b000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`07d2b000 fffff880`07d4d000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`08df5000 fffff880`08dff000   dump_diskdump dump_diskdump.sys Fri Apr 22 16:04:32 2011 (4DB1DF50)
fffff880`08fc6000 fffff880`08fd9000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`05a33000 fffff880`05d04000   dump_iaStorA dump_iaStorA.sys Mon Apr 22 15:38:05 2013 (5175919D)
fffff880`08fd9000 fffff880`08fe5000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`072eb000 fffff880`073df000   dxgkrnl  dxgkrnl.sys  Tue Apr 09 23:28:09 2013 (5164DC49)
fffff880`048c5000 fffff880`0490b000   dxgmms1  dxgmms1.sys  Tue Apr 09 23:27:15 2013 (5164DC13)
fffff880`0481c000 fffff880`04898000   e1c62x64 e1c62x64.sys Thu Feb 21 00:14:02 2013 (5125AD1A)
fffff880`0124c000 fffff880`01260000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01200000 fffff880`0124c000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`018a2000 fffff880`018ac000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`01c0b000 fffff880`01c45000   fvevol   fvevol.sys   Wed Jan 23 22:11:24 2013 (5100A65C)
fffff880`01195000 fffff880`011de000   fwpkclnt fwpkclnt.sys Wed Jan 02 22:06:48 2013 (50E4F5C8)
fffff880`06586000 fffff880`0658cc00   GEARAspiWDM GEARAspiWDM.sys Thu May 03 15:56:17 2012 (4FA2E2E1)
fffff800`03016000 fffff800`0305f000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`0490b000 fffff880`0492f000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`08c00000 fffff880`08c19000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`095c1000 fffff880`095c9080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`08f8f000 fffff880`08f9d000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`05902000 fffff880`059cb000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01600000 fffff880`01609000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`0126d000 fffff880`0153e000   iaStorA  iaStorA.sys  Mon Apr 22 15:38:05 2013 (5175919D)
fffff880`017f4000 fffff880`017ff000   iaStorF  iaStorF.sys  Mon Apr 22 15:38:07 2013 (5175919F)
fffff880`0657a000 fffff880`06586000   ICCWDT   ICCWDT.sys   Wed Aug 18 04:27:45 2010 (4C6B9981)
fffff880`06596000 fffff880`065ac000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00eaa000 fffff880`00eb4000   iusb3hcs iusb3hcs.sys Mon May 21 03:23:42 2012 (4FB9ED7E)
fffff880`07d53000 fffff880`07db0000   iusb3hub iusb3hub.sys Mon May 21 03:21:36 2012 (4FB9ED00)
fffff880`0492f000 fffff880`049f4000   iusb3xhc iusb3xhc.sys Mon May 21 03:21:40 2012 (4FB9ED04)
fffff880`05fbc000 fffff880`05fcb000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`08faa000 fffff880`08fb8000   kbdhid   kbdhid.sys   Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff800`00ba5000 fffff800`00baf000   kdcom    kdcom.dll    Sat Feb 05 11:52:49 2011 (4D4D8061)
fffff880`05e00000 fffff880`05e43000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`017af000 fffff880`017ca000   ksecdd   ksecdd.sys   Fri Jun 01 22:50:23 2012 (4FC97F6F)
fffff880`017ca000 fffff880`017f4000   ksecpkg  ksecpkg.sys  Fri Jun 01 23:27:11 2012 (4FC9880F)
fffff880`07d4d000 fffff880`07d52200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`08e23000 fffff880`08e38000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`08e00000 fffff880`08e23000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c70000 fffff880`00cbf000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 08:03:51 2010 (4CE7C737)
fffff880`08fe5000 fffff880`08ff3000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`05fcb000 fffff880`05fda000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`08f9d000 fffff880`08faa000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00fd1000 fffff880`00feb000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`05800000 fffff880`05818000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`05818000 fffff880`05845000   mrxsmb   mrxsmb.sys   Tue Apr 26 22:40:38 2011 (4DB78226)
fffff880`07db0000 fffff880`07dfe000   mrxsmb10 mrxsmb10.sys Fri Jul 08 22:46:28 2011 (4E17C104)
fffff880`05845000 fffff880`05869000   mrxsmb20 mrxsmb20.sys Tue Apr 26 22:39:37 2011 (4DB781E9)
fffff880`0108a000 fffff880`01095000   msahci   msahci.sys   Sat Nov 20 05:33:58 2010 (4CE7A416)
fffff880`05db8000 fffff880`05dc3000   Msfs     Msfs.SYS     unavailable (00000000)
fffff880`00e60000 fffff880`00e6a000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01137000 fffff880`01195000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`0425d000 fffff880`04268000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01808000 fffff880`0181a000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`00ede000 fffff880`00ee9000   mv91cons mv91cons.sys Tue Oct 09 04:48:50 2012 (5073E4F2)
fffff880`010a5000 fffff880`01137000   mvs91xx  mvs91xx.sys  Tue Oct 09 04:50:58 2012 (5073E572)
fffff880`015b1000 fffff880`015b9000   mvxxmm   mvxxmm.sys   Tue Oct 09 04:50:43 2012 (5073E563)
fffff880`018ac000 fffff880`0199e000   ndis     ndis.sys     Wed Aug 22 11:11:46 2012 (5034F6B2)
fffff880`06000000 fffff880`0600c000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`058d7000 fffff880`058ea000   ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`05f52000 fffff880`05f81000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`07ca6000 fffff880`07cbb000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`043ba000 fffff880`043c9000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`01d72000 fffff880`01db7000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`0199e000 fffff880`019fe000   NETIO    NETIO.SYS    Wed Aug 22 11:11:28 2012 (5034F6A0)
fffff880`05dc3000 fffff880`05dd4000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04251000 fffff880`0425d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0305f000 fffff800`03645000   nt       ntkrnlmp.exe Mon Mar 18 23:21:42 2013 (5147D9C6)
fffff880`0160d000 fffff880`017af000   Ntfs     Ntfs.sys     Fri Apr 12 07:54:36 2013 (5167F5FC)
fffff880`05d4a000 fffff880`05d53000   Null     Null.SYS     unavailable (00000000)
fffff880`07cbb000 fffff880`07cee000   nvhda64v nvhda64v.sys Mon Feb 25 00:27:35 2013 (512AF647)
fffff880`0680a000 fffff880`072eb000   nvlddmkm nvlddmkm.sys Sun May 12 15:09:45 2013 (518FE8F9)
fffff880`05884000 fffff880`058d7000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`0437e000 fffff880`043a4000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`00eb4000 fffff880`00ec9000   partmgr  partmgr.sys  Sat Mar 17 01:06:09 2012 (4F641BC1)
fffff880`00e6a000 fffff880`00e9d000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`01095000 fffff880`010a5000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01891000 fffff880`018a2000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`0ae17000 fffff880`0aebd000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`07cee000 fffff880`07d2b000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cbf000 fffff880`00cd3000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`065d2000 fffff880`065f6000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`0600c000 fffff880`06027000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`05f81000 fffff880`05fa2000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`05fa2000 fffff880`05fbc000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04200000 fffff880`04251000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`05d9d000 fffff880`05da6000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`05da6000 fffff880`05daf000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`05daf000 fffff880`05db8000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`015c4000 fffff880`015fe000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`08cc2000 fffff880`08cee000   rfcomm   rfcomm.sys   Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`058ea000 fffff880`05902000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`064c7000 fffff880`0657a000   Rt64win7 Rt64win7.sys Tue Jun 12 10:00:29 2012 (4FD74B7D)
fffff880`09232000 fffff880`09569f00   RTKVHD64 RTKVHD64.sys Tue Apr 23 10:24:25 2013 (51769999)
fffff880`0aebd000 fffff880`0aec8000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`01800000 fffff880`01808000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0b27d000 fffff880`0b315000   srv      srv.sys      Thu Apr 28 23:06:06 2011 (4DBA2B1E)
fffff880`0af0b000 fffff880`0af74000   srv2     srv2.sys     Thu Apr 28 23:05:46 2011 (4DBA2B0A)
fffff880`0aec8000 fffff880`0aef9000   srvnet   srvnet.sys   Thu Apr 28 23:05:35 2011 (4DBA2AFF)
fffff880`0153e000 fffff880`015a1000   storport storport.sys Thu Mar 10 23:30:23 2011 (4D79A55F)
fffff880`065f6000 fffff880`065f7480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01a00000 fffff880`01c00000   tcpip    tcpip.sys    Wed Jan 02 22:11:48 2013 (50E4F6F4)
fffff880`0aef9000 fffff880`0af0b000   tcpipreg tcpipreg.sys Wed Oct 03 12:07:26 2012 (506C62BE)
fffff880`05a00000 fffff880`05a0d000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`05dd4000 fffff880`05df6000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`04800000 fffff880`0481c000   TeeDriverx64 TeeDriverx64.sys Mon Feb 25 15:25:04 2013 (512BC8A0)
fffff880`043e4000 fffff880`043f8000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`00540000 fffff960`0054a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`05a0d000 fffff880`05a33000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`05e43000 fffff880`05e55000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`08c19000 fffff880`08c36000   usbccgp  usbccgp.sys  Thu Mar 24 23:29:14 2011 (4D8C0C0A)
fffff880`049f4000 fffff880`049f5f00   USBD     USBD.SYS     Thu Mar 24 23:28:59 2011 (4D8C0BFB)
fffff880`04898000 fffff880`048a9000   usbehci  usbehci.sys  Thu Mar 24 23:29:04 2011 (4D8C0C00)
fffff880`07c4c000 fffff880`07ca6000   usbhub   usbhub.sys   Thu Mar 24 23:29:25 2011 (4D8C0C15)
fffff880`05e98000 fffff880`05eee000   USBPORT  USBPORT.SYS  Thu Mar 24 23:29:12 2011 (4D8C0C08)
fffff880`00e9d000 fffff880`00eaa000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`05d5a000 fffff880`05d68000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`05d68000 fffff880`05d8d000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00ec9000 fffff880`00ede000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`064ba000 fffff880`064c7000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`043a4000 fffff880`043ba000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`043c9000 fffff880`043e4000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`05d8d000 fffff880`05d9d000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00eff000 fffff880`00fc1000   Wdf01000 Wdf01000.sys Wed Jul 25 22:25:13 2012 (5010AA89)
fffff880`00fc1000 fffff880`00fd1000   WDFLDR   WDFLDR.SYS   Wed Jul 25 22:29:04 2012 (5010AB70)
fffff880`04375000 fffff880`0437e000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00020000 fffff960`00337000   win32k   win32k.sys   Tue Apr 09 23:30:19 2013 (5164DCCB)
fffff880`0658d000 fffff880`06596000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00e57000 fffff880`00e60000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
Unloaded modules:
fffff880`0b39a000 fffff880`0b3ad000   xusb21.sys
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0b31e000 fffff880`0b38f000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01d1b000 fffff880`01d29000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01d29000 fffff880`01d33000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`05a3c000 fffff880`05d0d000   dump_iaStorA
    Checksum:  00000000
    ImageSize:  002D1000
fffff880`05d0d000 fffff880`05d20000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
KJQuadro
Thank you very much for the help so far, I shall run the hardware diagnostics, and report back with the results as soon as possible.
Thanks.
KJQuadro
Hi Usasma,
Managed to find some time to do the Graphics Card stress test and MemTest, the results are as follows;
The GPU maxed out at 87 Degrees Celsius, and didn't go higher than that, the fan speed maxed out at 67%.
The Memory had NO errors, the test was run for around 12 hours.
All that's left now it a 24 hours stress test on the CPU.
KJQuadro
Ok, done the final hardware test, the CPU test was run for roughly 12 hours, and had no problems.
Can't think of anything else to fix the problem, should I replace the motherboard?
