Blue Screen of Death (with dump log) Any Help Appreciated
Started continously getting this error today, this is the log.. If anyone has any idea how I can fix this let me know!
Problem signature:
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 4105
Additional information about the problem:
BCCode: a
BCP1: FFFFFA8027E71180
BCP2: 0000000000000002
BCP3: 0000000000000001
BCP4: FFFFF80002AC3839
OS Version: 6_1_7600
Service Pack: 0_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\062710-16785-01.dmp
C:\Users\Rick\AppData\Local\Temp\WER-28735-0.sysdata.xml
Hi.
Please navigate to C:\Windows\Minidump to copy the files in there to any other folder. Then rar or zip them and attach the compressed file to a post using the paperclip above where you type, in advanced mode reply.
Neiter program will let me zip these files, saying I don't have access which shouln't be the case, I've changed all the access restrictions but still no luck, is there a common issue with this??
Yes, you have to copy the files to another folder first and then access will be allowed to zip them.
You're getting driver errors, which we can attempt to alleviate.
Please update this driver,
Rt64win7 Rt64win7.sys Thu Feb 26 04:04:13 2009
which is your network driver.
You can check the device manager under network section for which type of lan you have of Realtek's. Then search the number for the driver software on the left side of this link:
Realtek
This Razer Death Adder driver, because of it's 2007 date, always causes problems. Please install the latest driver for the mouse from the following link:
dadder   dadder.sys   Thu Aug 02 05:33:03 2007
Razer DeathAdder Driver v3.01
This iTunes driver is a known problem causer. You can uninstall iTunes as a test if needed to see if it helps.
GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009
But ya, going by experience, I really think it's the mouse driver causing problems. Let us know how it goes after updating these drivers and post a new crash dump if needed. Good luck.
#7
Thanks a TON , will do!
