Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\WhoEver\Desktop\New folder\021910-16052-01.dmp]
Symbol search path is: SRV*c:\symbols*
Symbol information Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02c59000 PsLoadedModuleList = 0xfffff800`02e96e50
Debug session time: Fri Feb 19 18:12:26.567 2010 (GMT-6)
System Uptime: 0 days 2:10:37.611
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck D1, {8005d0ea8e, 2, 0, fffff88003a850e1}
Unable to load image \SystemRoot\system32\DRIVERS\athrxusb.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for athrxusb.sys
*** ERROR: Module load completed but symbols could not be loaded for athrxusb.sys
Probably caused by : athrxusb.sys ( athrxusb+760e1 )
Followup: MachineOwner
3: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
interrupt request level (IRQL) that is too high. This is usually
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000008005d0ea8e, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88003a850e1, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002f010e0
0000008005d0ea8e
CURRENT_IRQL: 2
FAULTING_IP:
athrxusb+760e1
fffff880`03a850e1 8b402c mov eax,dword ptr [rax+2Ch]
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xD1
PROCESS_NAME: DOW2.exe
TRAP_FRAME: fffff880009b06f0 -- (.trap 0xfffff880009b06f0)
rax=0000008005d0ea62 rbx=0000000000000000 rcx=0000000000000001
rdx=fffffa8005cf1030 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88003a850e1 rsp=fffff880009b0880 rbp=0000000000000000
r8=fffffa800599c290 r9=0000000000000000 r10=fffff88002fd3e20
r11=0000000000000002 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl nz na pe nc
athrxusb+0x760e1:
fffff880`03a850e1 8b402c mov eax,dword ptr [rax+2Ch] ds:00000080`05d0ea8e=????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002cca469 to fffff80002ccaf00
STACK_TEXT:
fffff880`009b05a8 fffff800`02cca469 : 00000000`0000000a 00000080`05d0ea8e 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`009b05b0 fffff800`02cc90e0 : fffffa80`00000000 fffffa80`04bcbcc0 fffffa80`05b519a0 fffff800`02dfe2dd : nt!KiBugCheckDispatch+0x69
fffff880`009b06f0 fffff880`03a850e1 : fffff880`01559110 fffffa80`03de6050 00000000`00000286 fffff880`03a206b0 : nt!KiPageFault+0x260
fffff880`009b0880 fffff880`01559110 : fffffa80`03de6050 00000000`00000286 fffff880`03a206b0 00000000`00000000 : athrxusb+0x760e1
fffff880`009b0888 fffffa80`03de6050 : 00000000`00000286 fffff880`03a206b0 00000000`00000000 fffffa80`03de6050 : ndis!WPP_GLOBAL_Control
fffff880`009b0890 00000000`00000286 : fffff880`03a206b0 00000000`00000000 fffffa80`03de6050 00000000`00000000 : 0xfffffa80`03de6050
fffff880`009b0898 fffff880`03a206b0 : 00000000`00000000 fffffa80`03de6050 00000000`00000000 fffff880`03a4bca1 : 0x286
fffff880`009b08a0 00000000`00000000 : fffffa80`03de6050 00000000`00000000 fffff880`03a4bca1 00000001`060af810 : athrxusb+0x116b0
STACK_COMMAND: kb
FOLLOWUP_IP:
athrxusb+760e1
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: athrxusb+760e1
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: athrxusb
IMAGE_NAME: athrxusb.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 488f1151
FAILURE_BUCKET_ID: X64_0xD1_athrxusb+760e1
3: kd> lmvm athrxusb
start end module name
fffff880`03a0f000 fffff880`03b1c000 athrxusb T (no symbols)
Loaded symbol image file: athrxusb.sys
Image path: \SystemRoot\system32\DRIVERS\athrxusb.sys
Image name: athrxusb.sys
Timestamp: Tue Jul 29 07:47:13 2008 (488F1151)
CheckSum: 00107E18
ImageSize: 0010D000
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
