Szymon Welgus
- Joined
- Mar 24, 2012
- Messages
- 4
- Thread Author
- #1
Hi guys.
I'd like to request your urgent help in helping me solve a blue screen uncorrectable hardware error on a laptop.
I was playing Mass Effect 2 when the crash happened and then the blue screen error came up and it lingered for about 10 seconds before the entire screen went black but the computer was still running and everything but the screen was black and there was no interaction, even the power button didn't work! I then took out the battery and started it again, and this time it sort of switches on but the screen is completely blank, it doesn't even load the BIOS at all. It just switches on and hangs there until I take out the battery out to switch it off.
Please guys, anything you'd recommend I should do to fix this problem? Thanks guys!
