Windows 7 blue screens and computer hangs
Matthew Birch
Hey guys
Ive been experiencing for about a month now computer slow downs and random blue screens whether im browsing the internet, listening to music, playing a game anything really i open an app or a webpage and my audio goes all glitchy as well really confused as I haven't come across this before. I have read around and figured most people have different answers regarding the different errors im getting so i compiled a zip with all my .dmp files. If someone could help me would be much appreciated as I don't wish to buy new hardware anytime soon.
Hardware
ASUS P5G41T-M LX socket 775
Q9400 Core2Quad 2.66Ghz
4 GB RAM
Gigabyte 560ti GPU
1TB HDD
2TB HDD
I am running Bitdefender Total Security 2013
I have run memtest+86 for 12 hours total no errors
Cheers in advanced!
Matt,
  • W7F_11-07-2013.zip
usasma
Fantastic Member
Please provide this information so we can provide a complete analysis: http://windows7forums.com/blue-screen-death-bsod/38837-how-ask-help-bsod-problem.html
If you've already run the app, please re-run it and let it run for at least 15 minutes (or until the app itself tells you that it's done). Then zip it up and upload it with your next post.
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Windows systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
BrPar64a.sys Tue Jun 29 10:37:06 2004 (40E17E92)
Brother parallel class printer driver
BrPar64a.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
vcsvad.sys Sun Nov 16 04:51:18 2008 (491FED16)
Avnex Ltd. Virtual Audio Device
http://www.carrona.org/drivers/driver.php?id=vcsvad.sys
hamachi.sys Thu Feb 19 05:36:41 2009 (499D3639)
LogMeIn Hamachi Virtual network interface driver
http://www.carrona.org/drivers/driver.php?id=hamachi.sys
intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
Intel IDE storage driver
http://www.carrona.org/drivers/driver.php?id=intelide.sys
If all of this doesn't stop the BSOD's, please run these free hardware diagnostics: Hardware Diagnostics. Let us know the results and we can move on from there.
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Wed Jul 10 19:47:44.330 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\071113-47502-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18113.amd64fre.win7sp1_gdr.130318-1533
System Uptime:[B]0 days 0:05:22.156[/B]
*** WARNING: Unable to verify timestamp for gzflt.sys
*** ERROR: Module load completed but symbols could not be loaded for gzflt.sys
Probably caused by :[B]gzflt.sys ( gzflt+4d0d )[/B]
BugCheck [B]D5, {fffff9802b91efd8, 0, fffff88001384d0d, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]DRIVER_PAGE_FAULT_IN_FREED_SPECIAL_POOL (d5)[/URL]
Arguments:
Arg1: fffff9802b91efd8, memory referenced
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation
Arg3: fffff88001384d0d, if non-zero, the address which referenced memory.
Arg4: 0000000000000000, (reserved)
BUGCHECK_STR:  0xD5
DEFAULT_BUCKET_ID: [B][COLOR=RED]VERIFIER_ENABLED_VISTA_MINIDUMP[/COLOR][/B]
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID: [B]X64_0xD5_VRF_gzflt+4d0d[/B]
CPUID:        "Intel(R) Core(TM)2 Quad CPU    Q9400  @ 2.66GHz"
MaxSpeed:     2660
CurrentSpeed: [B]2667[/B]
  BIOS Version                  0902
  BIOS Release Date             07/27/2011
**************************Wed Jul 10 10:59:08.465 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\071113-99684-01.dmp]
System Uptime:[B]1 days 5:46:40.917[/B]
*** WARNING: Unable to verify timestamp for L1C62x64.sys
*** ERROR: Module load completed but symbols could not be loaded for L1C62x64.sys
Probably caused by :[B]L1C62x64.sys ( L1C62x64+c03a )[/B]
BugCheck [B]D1, {fffff98011c7af50, 2, 0, fffff8800583003a}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/URL]
Arguments:
Arg1: fffff98011c7af50, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff8800583003a, address which referenced memory
BUGCHECK_STR:  0xD1
PROCESS_NAME:  BitTorrent.exe
FAILURE_BUCKET_ID: [B]X64_0xD1_VRF_L1C62x64+c03a[/B]
**************************Mon Jul  8 07:13:02.002 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070813-28766-01.dmp]
System Uptime:[B]0 days 0:00:10.453[/B]
Probably caused by :[B]GenuineIntel[/B]
BugCheck [B]124, {0, fffffa80052088f8, 0, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]WHEA_UNCORRECTABLE_ERROR (124)[/URL]
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa80052088f8, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
BUGCHECK_STR:  0x124_GenuineIntel
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]X64_0x124_GenuineIntel_PROCESSOR_BUS_PRV[/B]
**************************Mon Jul  8 05:36:32.832 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070813-19406-01.dmp]
System Uptime:[B]0 days 0:00:08.673[/B]
BugCheck [B]124, {0, fffffa80047d18f8, 0, 0}[/B]
Arguments:
Arg2: fffffa80047d18f8, Address of the WHEA_ERROR_RECORD structure.
**************************Sun Jul  7 21:21:39.281 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070813-23134-01.dmp]
System Uptime:[B]0 days 0:00:11.122[/B]
BugCheck [B]124, {0, fffffa80047998f8, 0, 0}[/B]
Arguments:
Arg2: fffffa80047998f8, Address of the WHEA_ERROR_RECORD structure.
**************************Sun Jul  7 08:36:22.332 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070713-23821-01.dmp]
System Uptime:[B]0 days 0:00:08.800[/B]
BugCheck [B]124, {0, fffffa80047a08f8, 0, 0}[/B]
Arguments:
Arg2: fffffa80047a08f8, Address of the WHEA_ERROR_RECORD structure.
**************************Sun Jul  7 07:27:05.988 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070713-24913-01.dmp]
System Uptime:[B]0 days 0:00:09.439[/B]
BugCheck [B]124, {0, fffffa80047358f8, 0, 0}[/B]
Arguments:
Arg2: fffffa80047358f8, Address of the WHEA_ERROR_RECORD structure.
**************************Fri Jul  5 05:29:26.691 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070513-18751-01.dmp]
System Uptime:[B]0 days 0:00:08.517[/B]
BugCheck [B]124, {0, fffffa80047c18f8, 0, 0}[/B]
Arguments:
Arg2: fffffa80047c18f8, Address of the WHEA_ERROR_RECORD structure.
**************************Wed Jul  3 00:13:11.364 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070313-23025-01.dmp]
System Uptime:[B]0 days 0:00:08.205[/B]
BugCheck [B]124, {0, fffffa800473e8f8, 0, 0}[/B]
Arguments:
Arg2: fffffa800473e8f8, Address of the WHEA_ERROR_RECORD structure.
**************************Tue Jul  2 02:04:36.048 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070213-18657-01.dmp]
System Uptime:[B]0 days 0:00:09.874[/B]
BugCheck [B]124, {0, fffffa8004ae48f8, 0, 0}[/B]
Arguments:
Arg2: fffffa8004ae48f8, Address of the WHEA_ERROR_RECORD structure.
**************************Fri Jun 28 01:46:47.019 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\062813-23275-01.dmp]
System Uptime:[B]0 days 0:00:09.470[/B]
BugCheck [B]124, {0, fffffa800479d8f8, 0, 0}[/B]
Arguments:
Arg2: fffffa800479d8f8, Address of the WHEA_ERROR_RECORD structure.
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]BrPar64a.sys                Tue Jun 29 10:37:06 2004 (40E17E92)[/B][/COLOR]
[COLOR=RED][B]vcsvad.sys                  Sun Nov 16 04:51:18 2008 (491FED16)[/B][/COLOR]
[COLOR=RED][B]hamachi.sys                 Thu Feb 19 05:36:41 2009 (499D3639)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
[COLOR=RED][B]intelide.sys                Mon Jul 13 19:19:48 2009 (4A5BC114)[/B][/COLOR]
[COLOR=RED][B]ASACPI.sys                  Wed Jul 15 23:31:29 2009 (4A5E9F11)[/B][/COLOR]
[COLOR=RED][B]sptd.sys                    Sun Jul 26 16:13:14 2009 (4A6CB8DA)[/B][/COLOR]
AsIO.sys                    Mon Aug  3 03:03:16 2009 (4A768BB4)
aoitktst.SYS                Fri Aug  7 09:30:20 2009 (4A7C2C6C)
tap0901t.sys                Wed Sep 16 02:02:43 2009 (4AB07F83)
LVPr2M64.sys                Wed Oct  7 04:26:50 2009 (4ACC50CA)
lvrs64.sys                  Wed Oct  7 04:27:59 2009 (4ACC510F)
lvuvc64.sys                 Wed Oct  7 04:28:44 2009 (4ACC513C)
LGBusEnum.sys               Mon Nov 23 20:36:48 2009 (4B0B38B0)
cpuz133_x64.sys             Wed Mar 10 11:18:00 2010 (4B97C638)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
npf.sys                     Fri Jun 25 12:50:58 2010 (4C24DE72)
L1C62x64.sys                Wed Apr 20 05:24:30 2011 (4DAEA64E)
NBVol.sys                   Tue May 17 06:50:37 2011 (4DD252FD)
NBVolUp.sys                 Tue May 17 06:51:20 2011 (4DD25328)
point64.sys                 Wed May 18 04:07:20 2011 (4DD37E38)
RTKVHD64.sys                Tue Jun 28 07:09:04 2011 (4E09B650)
CLVirtualDrive.sys          Thu Sep  8 08:05:10 2011 (4E68AF76)
PxHlpa64.sys                Mon Oct 17 10:29:34 2011 (4E9C3BCE)
bdfwfpf.sys                 Mon Nov 14 12:16:17 2011 (4EC14CE1)
bdvedisk.sys                Tue Apr 17 07:34:26 2012 (4F8D5542)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
gzflt.sys                   Thu Oct  4 07:30:19 2012 (506D734B)
avchv.sys                   Wed Oct 31 13:05:22 2012 (50915A52)
VBoxNetFlt.sys              Wed Dec 19 08:47:16 2012 (50D1C564)
VBoxNetAdp.sys              Wed Dec 19 08:47:17 2012 (50D1C565)
VBoxUSBMon.sys              Wed Dec 19 08:47:17 2012 (50D1C565)
VBoxDrv.sys                 Wed Dec 19 08:48:25 2012 (50D1C5A9)
speedfan.sys                Sat Dec 29 15:59:35 2012 (50DF59B7)
bdfndisf6.sys               Fri Feb 22 11:41:39 2013 (51279FC3)
nvhda64v.sys                Mon Feb 25 00:27:35 2013 (512AF647)
trufos.sys                  Wed Mar  6 06:47:58 2013 (51372CEE)
avc3.sys                    Thu Apr 11 04:31:58 2013 (516674FE)
avckf.sys                   Thu Apr 11 04:35:04 2013 (516675B8)
RzMaelstromVAD.sys          Fri May 17 11:27:53 2013 (51964C79)
nvlddmkm.sys                Fri Jun 21 05:06:16 2013 (51C41788)
acyx5r2d.SYS                Fri Aug  7 09:30:20 2009 (4A7C2C6C)
ALSysIO64.sys               Sat Jul  9 20:27:45 2011 (4E18F201)
mbam.sys                    Tue Mar 20 12:04:48 2012 (4F68AAA0)
spvx.sys                    Sun Jul 26 16:13:14 2009 (4A6CB8DA)
spbm.sys                    Sun Jul 26 16:13:14 2009 (4A6CB8DA)
spjs.sys                    Sun Jul 26 16:13:14 2009 (4A6CB8DA)
spoo.sys                    Sun Jul 26 16:13:14 2009 (4A6CB8DA)
sppm.sys                    Sun Jul 26 16:13:14 2009 (4A6CB8DA)
spvi.sys                    Sun Jul 26 16:13:14 2009 (4A6CB8DA)
spaq.sys                    Sun Jul 26 16:13:14 2009 (4A6CB8DA)
spak.sys                    Sun Jul 26 16:13:14 2009 (4A6CB8DA)
spqv.sys                    Sun Jul 26 16:13:14 2009 (4A6CB8DA)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=ASACPI.sys
http://www.carrona.org/drivers/driver.php?id=sptd.sys
http://www.carrona.org/drivers/driver.php?id=AsIO.sys
aoitktst.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=tap0901t.sys
http://www.carrona.org/drivers/driver.php?id=LVPr2M64.sys
http://www.carrona.org/drivers/driver.php?id=lvrs64.sys
http://www.carrona.org/drivers/driver.php?id=lvuvc64.sys
http://www.carrona.org/drivers/driver.php?id=LGBusEnum.sys
http://www.carrona.org/drivers/driver.php?id=cpuz133_x64.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=npf.sys
http://www.carrona.org/drivers/driver.php?id=L1C62x64.sys
http://www.carrona.org/drivers/driver.php?id=NBVol.sys
http://www.carrona.org/drivers/driver.php?id=NBVolUp.sys
http://www.carrona.org/drivers/driver.php?id=point64.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
http://www.carrona.org/drivers/driver.php?id=CLVirtualDrive.sys
http://www.carrona.org/drivers/driver.php?id=PxHlpa64.sys
http://www.carrona.org/drivers/driver.php?id=bdfwfpf.sys
http://www.carrona.org/drivers/driver.php?id=bdvedisk.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=gzflt.sys
http://www.carrona.org/drivers/driver.php?id=avchv.sys
http://www.carrona.org/drivers/driver.php?id=VBoxNetFlt.sys
http://www.carrona.org/drivers/driver.php?id=VBoxNetAdp.sys
http://www.carrona.org/drivers/driver.php?id=VBoxUSBMon.sys
http://www.carrona.org/drivers/driver.php?id=VBoxDrv.sys
http://www.carrona.org/drivers/driver.php?id=speedfan.sys
http://www.carrona.org/drivers/driver.php?id=bdfndisf6.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=trufos.sys
http://www.carrona.org/drivers/driver.php?id=avc3.sys
http://www.carrona.org/drivers/driver.php?id=avckf.sys
RzMaelstromVAD.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
acyx5r2d.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=ALSysIO64.sys
http://www.carrona.org/drivers/driver.php?id=mbam.sys
spvx.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
spbm.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
spjs.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
spoo.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
sppm.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
spvi.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
spaq.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
spak.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
spqv.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
