- Thread Author
- #1
hello
my system keeps crashing and i don't know why.
My Sistem:
My BlueScreens from today:
My Sistem:
CPU-Z TXT Report
Binaries
CPU-Z version 1.53
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core 2 Quad Q8300
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz
Package (platform ID) Socket 775 LGA (0x4)
CPUID 6.7.A
Extended CPUID 6.17
Core Stepping R0
Technology 45 nm
Core Speed 1999.9 MHz
Multiplier x FSB 6.0 x 333.3 MHz
Rated Bus speed 1333.3 MHz
Stock frequency 2500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 7.5x
Max VID 1.288 V
Chipset
Northbridge Intel P45/P43 rev. A3
Southbridge Intel 82801JR (ICH10R) rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 4096 MBytes
Channels Dual, (Symmetric)
Memory Frequency 666.6 MHz (1:2)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Row Refresh Cycle Time (tRFC) 74
Command Rate (CR) 2T
MCHBAR I/O Base address 0x0FED14000
MCHBAR I/O Size 4096
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Kingston (7F98000000000000)
Size 2048 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number 9905403-011.A03LF
Serial number 9468CC3F
Manufacturing date Week 40/Year 09
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-17-23 @ 457 MHz
JEDEC #2 7.0-7-7-20-27 @ 533 MHz
JEDEC #3 8.0-8-8-22-30 @ 609 MHz
JEDEC #4 9.0-9-9-25-34 @ 685 MHz
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Serial number 945DCC3D
Number of banks 8
EPP no
XMP no
Monitoring
Mainboard Model P5P43TD (0x000001D4 - 0x005A30C4)
LPCIO
LPCIO Vendor Winbond
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xB0
LPCIO Revision ID 0x73
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 B0 73 FF 00 44 00 00 FF 50 00 00 00 9A 21 00 FF
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Winbond W83627DHG
Voltage 0 1.13 Volts [0x8D] (CPU VCORE)
Voltage 1 12.66 Volts [0xE3] (+12V)
Voltage 2 3.34 Volts [0xD1] (AVCC)
Voltage 3 3.36 Volts [0xD2] (+3.3V)
Voltage 4 1.14 Volts [0x8F] (VIN1)
Voltage 5 4.90 Volts [0xCC] (+5V)
Voltage 6 0.98 Volts [0x7A] (VIN3)
Temperature 0 38°C (100°F) [0x26] (SYSTIN)
Temperature 1 40°C (104°F) [0x50] (CPUTIN)
Temperature 2 84°C (183°F) [0xA8] (AUXTIN)
Fan 0 1749 RPM [0xC1] (SYSFANIN)
Fan 1 2744 RPM [0x7B] (CPUFANIN0)
Hardware monitor Intel Core 2 Quad Q8300
Temperature 0 46°C (114°F) [0x36] (Core #0)
Temperature 1 42°C (107°F) [0x3A] (Core #1)
Temperature 2 43°C (109°F) [0x39] (Core #2)
Temperature 3 44°C (111°F) [0x38] (Core #3)
Hardware monitor Radeon HD 4650
Temperature 0 51°C (123°F) (GPU Core)
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x9498
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x08
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xD0000000
Address 2 (memory) 0xFE9E0000
Address 4 (port) 0x0000C000
Subvendor ID 0x174B
Subsystem ID 0xE930
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0x50
Caps version 1.2
PCI capability
Caps class PCI Express
Caps offset 0x58
Device type Legacy PCI-E Endpoint Device
Port 0
Version 2.0
Link width 16x (max 16x)
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0xA0
Extended capabilities
Caps class Vendor Specific
Caps offset 0x100
Vendor ID 1
Size 16
Description Multimedia device
Location bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0xAA38
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x08
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFE9FC000
Subvendor ID 0x174B
Subsystem ID 0xAA38
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 0
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
Description Ethernet Controller
Location bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1969
Model ID 0x1026
Revision ID 0xB0
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFEAC0000
Address 2 (port) 0x0000DC00
Subvendor ID 0x1043
Subsystem ID 0x831C
Int. Line 0x11
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps offset 0x48
PCI capability
Caps offset 0x58
Device type PCI-E Endpoint Device
Port 0
Version 1.0
Link width 1x (max 1x)
Caps class Advanced Error Reporting
Caps offset 0x100
Caps class Device Serial Number
Caps offset 0x180
DMI
DMI BIOS
vendor American Megatrends Inc.
version 0402
date 09/03/2009
DMI System Information
manufacturer System manufacturer
product System Product Name
version System Version
serial System Serial Number
UUID 60100561-6BBADE11-9E3290E6-BA7CA12F
DMI Baseboard
vendor ASUSTeK Computer INC.
model P5P43TD
revision Rev X.0x
serial 102199340000399
DMI System Enclosure
manufacturer Chassis Manufacture
chassis type Desktop
chassis serial Chassis Serial Number
DMI Processor
manufacturer Intel
model Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz
clock speed 2500.0 MHz
FSB speed 333.0 MHz
multiplier 7.5x
DMI Port Connector
designation PS/2 Keyboard (internal)
designation PS/2 Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
designation PS/2 Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation USB12 (internal)
designation USB12 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB34 (internal)
designation USB34 (external)
port type USB
DMI Port Connector
designation USB56 (internal)
designation USB56 (external)
port type USB
DMI Port Connector
designation GbE LAN (internal)
designation GbE LAN (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation LPT (internal)
designation LPT 1 (external)
port type Parallel Port ECP/EPP
connector DB-25 male
DMI Port Connector
designation COM 1 (internal)
designation COM 1 (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation SPDIF_OUT (internal)
designation SPDIF_OUT (external)
port type Audio Port
connector On Board Sound Input From CD-ROM
DMI Port Connector
designation SPDIF_O (internal)
designation SPDIF_O (external)
DMI Port Connector
designation Audio_Line In (internal)
designation Audio_Line In (external)
connector Mini Jack (headphones)
DMI Port Connector
designation Audio_Line Out (internal)
designation Audio_Line Out (external)
DMI Port Connector
designation Audio_Mic In (internal)
designation Audio_Mic In (external)
DMI Port Connector
designation Audio_Center/LFE (internal)
designation Audio_Center/LFE (external)
DMI Port Connector
designation Audio_Surround OUT (internal)
designation Audio_Surround OUT (external)
DMI Port Connector
designation Audio_Surround Back (internal)
designation Audio_Surround Back (external)
DMI Port Connector
designation Panel (internal)
designation Panel (external)
DMI Port Connector
designation SATA1 (internal)
DMI Port Connector
designation SATA2 (internal)
DMI Port Connector
designation SATA3 (internal)
DMI Port Connector
designation SATA4 (internal)
DMI Port Connector
designation SATA5 (internal)
DMI Port Connector
designation SATA6 (internal)
DMI Port Connector
designation PRI_EIDE (internal)
DMI Port Connector
designation USB78 (internal)
port type USB
DMI Port Connector
designation USB910 (internal)
port type USB
DMI Port Connector
designation USB1112 (internal)
port type USB
DMI Port Connector
designation CD (internal)
DMI Port Connector
designation AAFP (internal)
DMI Port Connector
designation CPU_FAN (internal)
DMI Port Connector
designation PWR_FAN (internal)
DMI Port Connector
designation CHA_FAN (internal)
DMI Extension Slot
designation PCIEX16_1
type A5
width 32 bits
populated yes
DMI Extension Slot
designation PCIEX1_1
type A5
width 32 bits
populated no
DMI Extension Slot
designation PCIEX1_2
type A5
width 32 bits
populated no
DMI Extension Slot
designation PCI_1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI_2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI_3
type PCI
width 32 bits
populated no
DMI OEM Strings
string[0] 90E6BA7CA12F
string[1] To Be Filled By O.E.M.
string[2] To Be Filled By O.E.M.
string[3] To Be Filled By O.E.M.
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 16384 MBytes
max# of devices 4
DMI Memory Device
designation DIMM0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type unknown
DMI Memory Device
designation DIMM2
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM3
format DIMM
type unknown
Graphics
Number of adapters 1
Graphic APIs
API ATI OD5
API ATI I/O
Display Adapters
Display adapter 0
Manuf. API index 0
Display name \\.\DISPLAY1
Name Radeon HD 4650
Codename RV730
Technology 55 nm
Memory size 1024 MB
Memory bus width 128 bits
GPU ref clock 27000
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x174B)
Model ID 0x9498 (0xE930)
Performance Level 0
Core clock 300.0 MHz
Memory clock 400.0 MHz
Software
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
DirectX Version 11.0
Problem signature:
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1048
Additional information about the problem:
BCCode: 1000007e
BCP1: FFFFFFFFC000001D
BCP2: FFFFF88004B42975
BCP3: FFFFF880025B23B8
BCP4: FFFFF880025B1C10
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Problem signature:
Locale ID: 1048
BCCode: 1e
BCP1: 0000000000000000
BCP2: 0000000000000000
BCP3: 0000000000000000
BCP4: 0000000000000000
Service Pack: 0_0
Product: 256_1
Problem signature:
Locale ID: 1048
BCCode: fc
BCP1: FFFFF88005B1C230
BCP2: 800000012765C963
BCP3: FFFFF88005374A60
BCP4: 0000000000000002
Service Pack: 0_0
Product: 256_1
Problem signature:
Locale ID: 1048
BCCode: 3b
BCP1: 00000000C0000005
BCP2: FFFFF8800108D9BF
BCP3: FFFFF880079E5FF0
Service Pack: 0_0
Product: 256_1
BCCode: a
BCP2: 000000000000000D
BCP3: 0000000000000001
BCP4: FFFFF80002C88E4B
Service Pack: 0_0
Product: 256_1
