BlueScreen Problem
I am facing the BlueScreen Problem. My recent Hardware installation is my Graphics Card. But I installed it two months ago. And the problem is recent. I don't know why it is happening. Some information about crash.
Problem signature:
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 1000008e
BCP1: C0000005
BCP2: 832826B8
BCP3: A891E5DC
BCP4: 00000000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
I am attaching the dump file. View attachment 082612-15802-01.zip
Please help me.
Regards
Khalid Hasan
Saltgrass
I am not the best at this, but maybe I will stumble on something.
The dump file indicates a problem with Memory Corruption, but not sure it is telling you anything useful. It probably means some driver is messing up, but I don't have a good explanation.
Since you said it started recently, you do seem to have a newer driver called:
AntiLog32.sys Tue Aug 07 04:46:06 2012 Possibly an anti-key logger?
May not be related, but you might check to see if you can find what it is.
You also have a couple of older drivers. Again, does not necessarily mean that are at fault, but something to check.
000.fcl Fri Sep 26 08:11:12 2008
gdrv.sys Fri Dec 07 00:21:04 2007
You are running a TuneUP Utilities? Is that recent and can you stop if from running for testing?
Make sure you check the event viewer for any errors or warnings that seem to be consistent, especially if they show up around the time of the crashes. And Kernel Power entries are normally associated with crashes and not usually causes.
