Bluetooth - VM does not see a built-in receiver
I've 7 on the VM (Parallels) on macbookpro. I see the BT device on the Mac OS - it can easily connecting other devices(for example telephon Nokia).
There is a problem in Windows 7 The device(BT) do not see at all in device manager. I have downloaded all the updates.
Are there any unknown devices in the device manager of your virtual machine ? Blue tooth device may appear after you download and install Blue tooth driver.
