Paulcharles84
- Joined
- Mar 13, 2012
- Messages
- 6
- Thread Author
- #1
First off, why is reinstalling windows 7 such a pita? I've done it several times and it's soooooooo bad. With that aside, tonight I was attempting to reinstall 64 bit from 32 bit. I reformatted my hd using dos because advanced recovery simple does not work. After formatting and restarting I'm getting te bootmgr error. After reading countless threads with fixes nothing is helping. I CANNOT get past this error. I have the disc in, it won't go past the error. Pushing f2, f8, and f12 does not work. I can't do anything in the bios. Most of the solutions simply assume you can get PAST the error.
The next step I tried was unplugging the hd I formatted and installing to a different hd. This gives me an error of missing a device required. At this point I have no idea what to do besides maybe reformatting the hd again using another pc. Is there a recovery program I should dl to a blank cd?
Help!!!!
Help!!!!
