BOOTMGR problem
#21
my roomates girlfriend is bringing her laptop over so i can download them.
the only things i have plugged into my pc is the power cable, monitor, usb keyboard and wireless mouse..
i even took out my second gfx card and 3 of my 4 sticks of ram..
#22
do you think linux will load on it? or will the old windows errors get in the way?
#23
I had a similar issue with Vista, where it refused to do anything. I grabbed a linux live cd off the net and booted up using that. You will be able to see everything that is on your drive and copy the files off if needed. There are also disk utilities which will let you scan the drive. In my case the hard drive was fried and needed to be replaced.
#25
yea i tried the partion wizard image and it didnt work. it brought me to te first screen to boot from the partion wizard. Then went to a screen with alot of scrolling black text and stopped after about a minute. my keyboard froze and it wasnt doing anything.
will the other one work since its an application?
#26
im downloading linux mint 7 from the sites direct download but its taking forever
#27
You won't know unless you try it.
Did you disconnect external devices?
#28
yea the only ones i had plugged in was the mouse and keyboard
i unplugged the mouse since i dont really need it
