- Thread Author
- #1
Two weeks ago I built a brand new PC for work use (Adobe cs4 suite mainly).
I was using XP 32 bit. I did not upgrade to Vista as I had no problems with XP.
I wanted a 64 bit system so I could have access to more ram for HD video editing.
Also I sometimes use a PC at a friend’s office which has the same specs as my new build (see below) which so far work has worked without any problems and is wonderfully fast, responsive, and reliable.
However, my new PC blue screens every time I do something that is CPU or memory intensive.
So far it has blue screened while trying to open a large premiere pro CS4 project, during two attempts to render from premiere pro projects that did open, while importing music files into a new install of ITunes and while trying to play some large video files with GOM player and WMP.
I tried to use a debugger to interpret the DMP file with no success. I have no idea what any of it means.
I have had to go back to my old XP machine which is hugely disappointing.
I have downloaded the latest drivers for the GPU and onboard audio for the motherboard.
I would be hugely grateful if someone could help me diagnose the problem
I have attached a zip file with the DMP files and a file called ' WER-48937-0.sysdata.xml' (win7 told me this contains info on the crash when it re-started).
Below are the specs of the new build.
Intel Core i7 920 D0 Stepping
Asus P6T SE Intel X58
OCZ Gold 6GB (3x2GB) DDR3 PC3-10666C9
GeForce GTX 260
Samsung SpinPoint F1 1TB x2 (data)
Samsung SpinPoint F3 1TB (system OS and APPs)
Corsair TX 650W ATX
Thanks in advance
JH
GeForce GTX 260
Corsair TX 650W ATX
Thanks in advance
JH
