browers scroll when cursor not in scroll area
Discussion in 'Windows 7 Help and Support' started by dmodie, Dec 22, 2011.
  1. dmodie
    dmodie Well-Known Member
    Dec 22, 2011
    2
    0
    I have a gateway m-6843 laptop that originally came with vista. It has a track pad, or whatever that thing on laptops is called.
    I installed windows 7. In both FF and IE when the cursor is NOT in the scroll area, it acts as though I am holding on to the scroll bar. So if I move my cursor down near the bottom of the main part of the browser page (again, outside of the scroll area) it acts as if I grabbed the scroll bar and flung it down. It is intermittent, but bad enough that doing anything online is almost impossible.
    Other apps probably act this way as well for me, but i haven't tried them, yet.
    Any ideas? thanks
  2. patcooke
    patcooke Microsoft MVP
    Staff Member Premium Supporter Microsoft MVP
    May 16, 2010
    5,466
    269
    Try using normal mouse via the usb port to determine if the trackpad is at fault - if the problem ceases then the cause must be with the trackpad itself.
  3. davehc
    davehc Microsoft MVP
    May 1, 2008
    5,116
    302
    I would unictall the mouse from the device manager, and reboot. Let Windows reintall the drivers correctl and see if it works.You could try disabling the touchpad, on a temporary basis, to see if that might be the problem.
Share This Page
Loading...
