BSOD. "A clock interrupt was not received on a secondary processor"
New to site, first post.
I am logged on as the administrator and my Windows dump file is locked. When I open it it's empty. When I attempt to open previous versions it says I do not have admin privileges. I attempted to download and open the Take File Ownership shortcut but I get an error when I attemp to run the program after using the merge option.
I have already made sure my dump file is set up correctly by following these instructions:
  1. Go to Start and type in sysdm.cpl and press Enter
  2. Click on the Advanced tab
  3. Click on the Startup and Recovery Settings button
  4. Ensure that Automatically restart is unchecked
  5. Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
  6. Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be found later
  7. Click OK twice to exit the dialogs, then reboot for the changes to take effect.
I had a crash after setting it up.
I am trying to get help with this issue:
I get random crashes when I play DDO online. The screen freezes and I have to do a manual restart. I get a Kernal error, Event ID 41.
Del lStudio XPS Desktop 435MT
· OS -Windows 7
· x64 ?
· What was original installed OS on system? Vista 64
· Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? Free copy of Win 7 for taking Microsoft cert classes
· Age of system (hardware) 8/08/09
· Age of OS installation - have you re-installed the OS? Installed December 09
· CPU- I7-950, 3.06, 8MB, BLM, D0
· Video Card Radeon HD 4850
· MotherBoard
· Power Supply - 360W Liteon (?)
I also attached 2 zipped files that may help.
Thanks
Hi.
Please go to C:\Windows\Minidump
Copy the files in there to any other folder. Then zip them. Attach the zip to a post and we can have a look.
When I go to that folder it's locked and the folder is empty.
First of all I am logged on as the administrator. How do I get past this:
Try copying/pasting this to the start menu then hit enter:
It takes me to an empty folder. When I attempt to look at older versions it says I do not have the correct permissions and I am logged in as the admin.
Captain Jack
#7
Hello and Welcome !
By looking through your logs found that you have a Memory Dump C:\Windows\MEMORY.DMP upload that to some websites like Megaupload and post the link here.
Meantime found some Hardware problem with the PC
  Log Name: System
  Source: Microsoft-Windows-WHEA-Logger
  Date: 2010-07-06T09:33:35.516
  Event ID: 18
  Task: N/A
  Level: Error
  Opcode: Info
  Keyword: N/A
  User: S-1-5-19
  User Name: NT AUTHORITY\LOCAL SERVICE
  Computer: Dads-PC
  Description:
A fatal hardware error has occurred.
Reported by component: Processor Core
Error Source: Machine Check Exception
Error Type: Internal Timer Error
For that run a Hardware Diagnostic: Hardware Diagnostic !!
If your Overclocking please stop reset the BIOS to default settings.
Good Luck,
Captain
