BSOD: a clock interrupt was not received on a secondary processor
Hello my name is Nick and I have had my computer for about 7 months now. I have had many issues with it including bad RAM and what not. My latest issue is BOSD let me try to describe how it happens. I will be watching a youtube video and my computer will completely lock up. And the last sound made will loop for about 5 -7 seconds while I can still see the desktop but have no control over it. The I get the Blue Screen in my case "A clock interrupt was not received on a secondary processor" I feel that it may have something to do with Flash but im not sure. I dont have any viruses and I have already done a clean windows install and my BIOS is up to date. This has become a real pain as I am a live steamer and the BSOD sometimes happens during the live stream. Here all files I was told to put in. Thanks for your help in advance and I hope we can find a fix.
View attachment CPU-Z.rar
View attachment dmp.rar
View attachment Seven Forums.rar
[h=3]RAMMon v1.0 Build: 1005 built with SysInfo v1.0 Build: 1027
PassMark (R) Software - www.passmark.com[/h]Memory Summary For NICK-PC
Number of Memory Devices: 2 Total Physical Memory: 8173 MB (8192 MB) Total Available Physical Memory: 5824 MB Memory Load: 28%
[TABLE]
[TR]
[TH]Item[/TH]
[TH]Slot #1[/TH]
[TH]Slot #2[/TH]
[TH]Slot #3[/TH]
[TH]Slot #4[/TH]
[/TR]
[TR]
[TD="class: value, width: 240"]Ram Type [/TD]
[TD="class: altvalue"]DDR3 [/TD]
[TD="class: altvalue"]Not Populated [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Standard Name [/TD]
[TD="class: altvalue"]DDR3-1333 [/TD]
[TD="class: altvalue"] [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Module Name [/TD]
[TD="class: altvalue"]PC3-10600 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Memory Capacity (MB) [/TD]
[TD="class: altvalue"]4096 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Bus Clockspeed (Mhz) [/TD]
[TD="class: altvalue"]666.67 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Jedec Manufacture Name [/TD]
[TD="class: altvalue"]Kingston [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Search Amazon.com [/TD]
[TD="class: altvalue"]Search! [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]SPD Revision [/TD]
[TD="class: altvalue"]1.0 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Registered [/TD]
[TD="class: altvalue"]No [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]ECC [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]DIMM Slot # [/TD]
[TD="class: altvalue"]1 [/TD]
[TD="class: altvalue"]2 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Manufactured [/TD]
[TD="class: altvalue"]Year 0 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Module Part # [/TD]
[TD="class: altvalue"]9905403-400.A00LF [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Module Revision [/TD]
[TD="class: altvalue"]0x0 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Module Serial # [/TD]
[TD="class: altvalue"]0x4814CADA [/TD]
[TD="class: altvalue"]0x571411DC [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Module Manufacturing Location [/TD]
[TD="class: altvalue"]4 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]# of Row Addressing Bits [/TD]
[TD="class: altvalue"]15 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]# of Column Addressing Bits [/TD]
[TD="class: altvalue"]10 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]# of Banks [/TD]
[TD="class: altvalue"]8 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]# of Ranks [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Device Width in Bits [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Bus Width in Bits [/TD]
[TD="class: altvalue"]64 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Module Voltage [/TD]
[TD="class: altvalue"]1.5V [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]CAS Latencies Supported [/TD]
[TD="class: altvalue"]6 7 8 9 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]Timings @ Max Frequency [/TD]
[TD="class: altvalue"]9-9-9-24 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Minimum Clock Cycle Time, tCK (ns) [/TD]
[TD="class: altvalue"]1.500 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Minimum CAS Latency Time, tAA (ns) [/TD]
[TD="class: altvalue"]13.125 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Minimum RAS to CAS Delay, tRCD (ns) [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Minimum Row Precharge Time, tRP (ns) [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Minimum Active to Precharge Time, tRAS (ns) [/TD]
[TD="class: altvalue"]36.000 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Minimum Row Active to Row Active Delay, tRRD (ns) [/TD]
[TD="class: altvalue"]6.000 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Minimum Auto-Refresh to Active/Auto-Refresh Time, tRC (ns) [/TD]
[TD="class: altvalue"]49.125 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Minimum Auto-Refresh to Active/Auto-Refresh Command Period, tRFC (ns) [/TD]
[TD="class: altvalue"]160.000 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"]DDR3 Specific SPD Attributes [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Write Recovery Time, tWR (ns) [/TD]
[TD="class: altvalue"]15.000 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Internal Write to Read Command Delay, tWTR (ns) [/TD]
[TD="class: altvalue"]7.500 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Internal Read to Precharge Command Delay, tRTP (ns) [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Minimum Four Activate Window Delay, tFAW (ns) [/TD]
[TD="class: altvalue"]30.000 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] RZQ / 6 Supported [/TD]
[TD="class: altvalue"]Yes [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] RZQ / 7 Supported [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] DLL-Off Mode Supported [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Maximum Operating Temperature (C) [/TD]
[TD="class: altvalue"]95 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Refresh Rate at Extended Operating Temperature Range [/TD]
[TD="class: altvalue"]1X [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Auto-self Refresh Supported [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] On-die Thermal Sensor Readout Supported [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Partial Array Self Refresh Supported [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Thermal Sensor Present [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Non-standard SDRAM Type [/TD]
[TD="class: altvalue"]Standard Monolithic [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Module Type [/TD]
[TD="class: altvalue"]UDIMM [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Module Height (mm) [/TD]
[TD="class: altvalue"]30 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Module Thickness (front), (mm) [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Module Thickness (back), (mm) [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Module Width (mm) [/TD]
[TD="class: altvalue"]133.5 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Reference Raw Card Used [/TD]
[TD="class: altvalue"]Raw Card B Rev. 0 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] DRAM Manufacture ID [/TD]
[TD="class: altvalue"]0 [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] # of DRAM Rows [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] # of Registers [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Register Manufacturer [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Register Type [/TD]
[/TR]
[TR]
[TD="class: value, width: 240"] Register Revision [/TD]
[/TR]
[/TABLE]
I am getting the same exact thing that you are getting:(
Even the audio loop thing? Im glad to know im not the only one with the issue.
Yes, exactly. Everything you mentioned is what I have been getting. Does your pc freeze like 3 seconds after the audio loop happens?
Yeah, What are you PC specs? Maybe a bad part we both have and who is the maker?
I'm running an intel core i5 processor (3.33 ghz 661) on a MSI H55M-E23 motherboard. I also have a sapphire radeon 6770 video card, 2x2gb Crucial Ballistix ram (1333mhz,9-9-9-24).Lastly a 1 terabyte Seagate barracuda hdd.
#7
The only thing we have in common is the graphics card I have the radeon 6790. What programs do you run when this happens?
#8
Usually youtube or skype.
