Windows 7 BSOD after checking for errors on drive C
rainbowmaks
My system had been very slow and hanging for a while now, so i decided to to check for errors in my drive C. Since then anytime i put on system it show the BSOD at approximately 3 minutes after booting. Currently my system only works fine in safe mode.Thanks
SP1 isn't installed, please do the following:
Installing Windows 7 Service Pack 1
1. Visit the PC manufacturer's website and update ALL drivers. DO NOT use Windows Update or the "Update drivers" function of Device Manager.
2. Check Device Manager for any unknown/disabled devices - if there are unknown/disabled devices, fix them with the latest drivers from the device manufacturer's website (not the PC Manufacturer)
3. Visit Windows Update and get all updates (may take repeated visits)
4. Visit Windows Update and get Service Pack 1 (usually under Important Updates). Read these notes for installing SP1: Steps to follow before you install Windows 7 SP1 and Windows Server 2008 R2 SP1...
4. Visit Windows Update and get Service Pack 1 (usually under Important Updates). Read these notes for installing SP1: Steps to follow before you install Windows 7 SP1 and Windows Server 2008 R2 SP1 from the Microsoft Download Center
NOTE: For Vista, read these notes:
Read these notes for installing Vista SP1: Learn how to install Windows Vista Service Pack 1 (SP1)
Read these notes for installing Vista SP2: Learn how to install Windows Vista Service Pack 2 (SP2)
5. Visit Windows Update and get any other available updates. May take repeated visits, but keep it up until you get several "Windows is updated" results.
If you're having difficulties with installing a Service Pack, please use the SURTool from this link: What is the System Update Readiness Tool?
Also, check out this troubleshooting link from Microsoft: Troubleshoot problems installing Service Pack 1 (SP1) for Windows 7 and Windows Server 2008 R2
I have had limited success in installing updates/Service Packs when using a "clean boot". I suspect that I'm just bypassing the problem - and that it can come back to bite me in the butt later on.
You have these problem devices:
Network Controller PCI\VEN_1814&DEV_3090&SUBSYS_03071A32&REV_00\4&359364DA&0&00E1 The drivers for this device are not installed.
Broadcom BCM2070 Bluetooth 2.1+EDR USB Device USB\VID_0A5C&PID_219B\5&931ED4A&0&1 This device is disabled.
Not Available ROOT\WPD\0000 The drivers for this device are not installed.
Security Processor Loader Driver ROOT\LEGACY_SPLDR\0000 This device is not present, is not working properly, or does not have all its drivers installed.
Please install the drivers for your Network Controller (wired networking)
Please enable your Bluetooth device and then update it's drivers
What portable Windows devices (includes phones) are attached/installed on your system (that's the ROOT\WPD\0000 device)? Please install drivers for it/them.
The Security Processor Loader Driver entry is usually present if you have a malware infection, or an improperly removed malware infection. Please use several of the free anti-malware scans at this link: Link Removed - Invalid URL
More to follow when all 30 memory dumps are finished running......
There is an extremely ancient version of the driver GearAspiWDM.sys present on your system. It dates from 2003 and is likely not compatible with Win7. This driver must be replaced. If unable to locate the program that it belongs to, try installing iTunes (as it has the 2009 version of this driver).
Your wireless air card drivers date from 2008. Again, they are likely not compatible with Win7 and must be updated.
Also, your storage controller drivers, your video drivers, your audio drivers, your touchpad drivers, and your networking drivers (wired and wireless) all date from 2009 and should also be updated.
In the event that the above things don't stop the BSOD's, please run Driver Verifier according to these directions: Link Removed
Analysis:
[FONT=lucida console]**************************Sun Aug 26 09:19:50.353 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082612-23056-01.dmp]
Windows 7 Kernel Version [B]7600 [/B]MP (2 procs) Free x86 compatible
Built by: [B]7600[/B].16617.x86fre.win7_gdr.100618-1621
System Uptime:[B]0 days 0:09:06.072[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 80c838a4, 0}[/B]
Probably caused by :[B]win32k.sys ( win32k!sfac_GetLongGlyphIDs+5a )[/B]
BugCheck Info: [B]PAGE_FAULT_IN_NONPAGED_AREA (50)[/B]
BUGCHECK_STR:  0x50
PROCESS_NAME: [B]csrss.exe[/B]
FAILURE_BUCKET_ID: [B]0x50_win32k!sfac_GetLongGlyphIDs+5a[/B]
CPUID:        "Intel(R) Atom(TM) CPU N270   @ 1.60GHz"
MaxSpeed:     1600
CurrentSpeed:[B]1596[/B]
  BIOS Version                  UL1F3G11
  BIOS Release Date             12/08/2009
  Manufacturer                  LG Electronics
  Product Name                  X130-L.AS6BAD
**************************Sun Aug 26 02:23:26.905 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082612-16099-01.dmp]
System Uptime:[B]0 days 0:08:27.624[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 8fdb38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Sat Aug 25 18:37:48.394 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082512-23914-01.dmp]
System Uptime:[B]0 days 0:08:08.128[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 8fce38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Sat Aug 25 18:13:30.604 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082512-18111-01.dmp]
System Uptime:[B]0 days 0:05:12.323[/B]
BugCheck Code: [B]BugCheck 50, {fcc00000, 1, 80ce38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Sat Aug 25 18:07:37.029 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082512-19453-01.dmp]
System Uptime:[B]0 days 0:18:09.747[/B]
BugCheck Code: [B]BugCheck 50, {fde68000, 1, 8fdb38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Sat Aug 25 17:36:57.209 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082512-17113-01.dmp]
System Uptime:[B]0 days 0:08:24.709[/B]
BugCheck Code: [B]BugCheck 50, {ff0a5000, 1, 8f0938a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Sat Aug 25 04:41:35.634 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082512-17019-01.dmp]
System Uptime:[B]0 days 0:06:09.368[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 8f9138a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Sat Aug 25 04:34:32.729 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082512-17752-01.dmp]
System Uptime:[B]0 days 0:33:15.448[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 811138a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Sat Aug 25 03:41:43.920 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082512-27705-01.dmp]
System Uptime:[B]0 days 0:06:05.654[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 815f38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Fri Aug 24 15:56:11.022 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082412-21294-01.dmp]
System Uptime:[B]0 days 0:04:42.756[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 815c38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Fri Aug 24 15:18:45.687 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082412-20997-01.dmp]
System Uptime:[B]0 days 0:04:38.405[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 815538a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Thu Aug 23 16:13:33.497 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082312-20997-01.dmp]
System Uptime:[B]0 days 0:04:54.200[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 814e38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Thu Aug 23 16:08:16.179 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082312-24445-01.dmp]
System Uptime:[B]0 days 0:03:22.897[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Thu Aug 23 16:04:02.862 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082312-23977-01.dmp]
System Uptime:[B]0 days 0:04:42.455[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 810e38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Thu Aug 23 05:31:58.816 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082312-22042-01.dmp]
System Uptime:[B]0 days 0:09:35.316[/B]
BugCheck Code: [B]BugCheck 50, {fdc99000, 1, 8f4c38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Thu Aug 23 05:21:37.686 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082312-22947-01.dmp]
System Uptime:[B]0 days 0:04:48.404[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 811338a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Thu Aug 23 04:28:31.285 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082312-21278-01.dmp]
System Uptime:[B]0 days 0:04:47.003[/B]
BugCheck Code: [B]BugCheck 50, {fde4a000, 1, 811938a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Thu Aug 23 02:53:32.999 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082312-20732-01.dmp]
System Uptime:[B]0 days 0:04:39.717[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Thu Aug 23 00:26:08.110 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082312-21871-01.dmp]
System Uptime:[B]0 days 0:04:43.828[/B]
BugCheck Code: [B]BugCheck 50, {fde50000, 1, 815838a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Wed Aug 22 16:29:28.866 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082212-18829-01.dmp]
System Uptime:[B]0 days 0:04:15.584[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 8ecf38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Wed Aug 22 15:56:23.941 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082212-19141-01.dmp]
System Uptime:[B]0 days 0:05:03.644[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 8ec938a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Wed Aug 22 15:34:56.602 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082212-19749-01.dmp]
System Uptime:[B]0 days 0:05:01.321[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 810b38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Wed Aug 22 15:17:21.544 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082212-21840-01.dmp]
System Uptime:[B]0 days 0:04:12.278[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 8e9738a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Wed Aug 22 12:35:03.300 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082212-20841-01.dmp]
System Uptime:[B]0 days 0:04:12.003[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 8edb38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Wed Aug 22 12:19:08.708 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082212-15912-01.dmp]
System Uptime:[B]0 days 0:04:15.426[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 8e1838a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Wed Aug 22 11:19:43.123 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082212-24616-01.dmp]
System Uptime:[B]0 days 3:42:42.826[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 80dc38a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Wed Aug 22 07:36:32.502 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082212-23103-01.dmp]
System Uptime:[B]0 days 0:04:39.095[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 810538a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Wed Aug 22 07:27:48.002 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082212-15615-01.dmp]
System Uptime:[B]0 days 0:04:12.720[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 8f0438a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Wed Aug 22 07:21:12.042 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082212-22323-01.dmp]
System Uptime:[B]0 days 0:04:20.760[/B]
BugCheck Code: [B]BugCheck 50, {fde70000, 1, 8f1138a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
**************************Wed Aug 22 07:16:27.344 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082212-23571-01.dmp]
System Uptime:[B]0 days 0:01:06.047[/B]
BugCheck Code: [B]BugCheck 50, {fdc00000, 1, 901638a4, 0}[/B]
BUGCHECK_STR:  0x50
MaxSpeed:     1600
[/FONT]
3rd Party Drivers:
The following is for information purposes only. Any drivers in red should be updated.
SCDEmu.SYS                  Sun Mar 15 06:25:46 2009 (49BCD7AA)
amdxata.sys                 Tue May 19 13:57:35 2009 (4A12F30F)
iaStor.sys                  Thu Jun  4 21:42:33 2009 (4A287809)
SynTP.sys                   Thu Jun 18 22:33:00 2009 (4A3AF8DC)
intelppm.sys                Mon Jul 13 19:11:03 2009 (4A5BBF07)
intelide.sys                Mon Jul 13 19:11:19 2009 (4A5BBF17)
Rt86win7.sys                Thu Aug 20 12:04:54 2009 (4A8D7426)
RTKVHDA.sys                 Mon Sep 21 05:59:47 2009 (4AB74E93)
igdkmd32.sys                Wed Sep 23 15:18:09 2009 (4ABA7471)
[B]GEARAspiWDM.sys             Mon Sep  8 11:35:05 2003 (3F5CA1A9)[/B]
[B]ewusbmdm.sys                Fri Dec 12 22:27:48 2008 (49432BB4)[/B]
netr28.sys                  Wed Feb 25 21:56:57 2009 (49A604F9)
netr28.sys                  Tue Aug  4 05:48:15 2009 (4A7803DF)
[/FONT]
