BSOD after every shutdown.
Hi whenever I shutdown my computer by going on "Start" then Shutdown (Windows 7), it shutdown normally (looks normally). Then when I start the computer again Windows says it has recovered from an unexpected shutdown (BSOD) and sometimes also ask for startup repair.
The error looks like this
Problem signature:
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1046
Additional information about the problem:
BCCode: a
BCP1: 0000000000000080
BCP2: 0000000000000002
BCP3: 0000000000000001
BCP4: FFFFF80001ADD50F
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
I recently installed a SSD and Windows is in there, not sure if there's anything special about this. :(
Files to search for solutions on attachment.
View attachment SevenForums.zip
If someone can help I would aprecciate, thanks.
Trouble
Noob Whisperer
Hello and welcome to the forum.
Try updating these two drivers
MarvinBus64.sys 9/23/2005 http://www.pinnaclesys.com/PublicSite/us/Support/Consumer+Support/?viewDownload=1 way too old. Update, uninstall or rename
Rt64win7.sys 2/26/2009 update from here Realtek
If Blue Screens persist, remove (completely uninstall Avira. Use the programs uninstaller if available otherwise use the programs and features (uninstall) applet in the control panel. Follow that up with the vendor specific removal tool, a list of some of which can be found here Security Software | SingularLabs
Replace it with MSE from here Spyware Protection | Free Spyware Protection | Microsoft Security Essentials
Good luck
Randy
Hi! Thanks very much! I updated the realtek driver, and couldn't find the Pinaccle update for studio 15, but it seen's to be solved. THANKS !!
