Windows 7 BSOD after installing IE10
lisanorfolk
Hi all. I installed the IE 10 preview yesterday and immediately started getting BSOD whenever I launched IE. I then uninstalled it and went back to IE9
Whenever I open up IE now I get the BSOD everytime.
I tried a restore and clean boot and that has not worked.
I have attached the file dumps. any help with this would be hugely appreciated as this is driving me crazy. View attachment W7F_07-12-2012.zip
Here is a pic of the BSOD I am getting in case that helps
The screen shot blames your Intel graphics drivers (as do the memory dumps). Please visit Intel Download Center and get the latest version of the drivers for your system and install them. Then monitor for further BSOD's.
We'll need the full output of the Diagnostic Tool from here: http://windows7forums.com/blue-screen-death-bsod/38837-how-ask-help-bsod-problem.html Let the tool run for at least 15 minutes (or until it tells you it's done).
If updating the video drivers doesn't help with the BSOD's, please run Driver Verifier according to these directions: Driver Verifier Settings
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Fri Dec  7 05:30:26.215 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120712-28142-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 0:05:39.276[/B]
*** WARNING: Unable to verify timestamp for igdpmd64.sys
*** ERROR: Module load completed but symbols could not be loaded for igdpmd64.sys
Probably caused by :[B]igdpmd64.sys ( igdpmd64+15a878 )[/B]
BugCheck [B]50, {fffff8815dd826a0, 0, fffff880069a2878, 5}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000050]PAGE_FAULT_IN_NONPAGED_AREA (50)[/url]
Arguments:
Arg1: fffff8815dd826a0, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff880069a2878, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000005, (reserved)
BUGCHECK_STR:  0x50
PROCESS_NAME: [B]csrss.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x50_igdpmd64+15a878[/B]
**************************Fri Dec  7 05:08:35.371 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120712-30950-01.dmp]
System Uptime:[B]0 days 0:12:04.871[/B]
Probably caused by :[B]wininit.exe[/B]
BugCheck [B]F4, {3, fffffa8008c88b30, fffffa8008c88e10, fffff8000258e460}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000F4]CRITICAL_OBJECT_TERMINATION (f4)[/url]
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa8008c88b30, Terminating object
Arg3: fffffa8008c88e10, Process image file name
Arg4: fffff8000258e460, Explanatory message (ascii)
PROCESS_NAME: [B]WerFault.exe[/B]
BUGCHECK_STR:  0xF4_WerFault.exe
FAILURE_BUCKET_ID: [B]X64_0xF4_WerFault.exe_IMAGE_wininit.exe[/B]
CPUID:        "Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz"
MaxSpeed:     2000
CurrentSpeed: [B]1995[/B]
  BIOS Version                  F.1B
  BIOS Release Date             10/05/2011
  Manufacturer                  Hewlett-Packard
  Product Name                  HP Pavilion dv6 Notebook PC
**************************Fri Dec  7 04:50:57.772 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120712-19266-01.dmp]
System Uptime:[B]0 days 0:57:30.834[/B]
BugCheck [B]50, {fffff8817033b6a0, 0, fffff8800697b878, 5}[/B]
Arguments:
Arg1: fffff8817033b6a0, memory referenced.
Arg3: fffff8800697b878, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
**************************Fri Dec  7 03:38:30.235 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120712-40950-01.dmp]
System Uptime:[B]0 days 1:19:00.297[/B]
BugCheck [B]50, {fffff881734fe6a0, 0, fffff8800699e878, 5}[/B]
Arguments:
Arg1: fffff881734fe6a0, memory referenced.
Arg3: fffff8800699e878, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
**************************Thu Dec  6 13:31:50.467 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120612-40466-01.dmp]
System Uptime:[B]0 days 1:04:55.528[/B]
BugCheck [B]50, {fffff88171aa16a0, 0, fffff88005ba1878, 5}[/B]
Arguments:
Arg1: fffff88171aa16a0, memory referenced.
Arg3: fffff88005ba1878, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
**************************Thu Dec  6 08:05:15.619 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120612-41636-01.dmp]
System Uptime:[B]0 days 0:13:10.681[/B]
BugCheck [B]50, {fffff88172bc3ea0, 0, fffff88006991878, 5}[/B]
Arguments:
Arg1: fffff88172bc3ea0, memory referenced.
Arg3: fffff88006991878, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
**************************Thu Dec  6 07:50:30.552 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120612-37003-01.dmp]
System Uptime:[B]0 days 0:08:30.613[/B]
BugCheck [B]50, {fffff8815abdc6a0, 0, fffff88006986878, 5}[/B]
Arguments:
Arg1: fffff8815abdc6a0, memory referenced.
Arg3: fffff88006986878, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
[/font]
3rd Party Drivers:
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
clwvd.sys                   Tue Jul 27 21:13:47 2010 (4C4F844B)
IntcDAud.sys                Fri Oct 15 04:28:17 2010 (4CB810A1)
HECIx64.sys                 Tue Oct 19 19:33:43 2010 (4CBE2AD7)
WDKMD.sys                   Thu Dec 23 05:28:18 2010 (4D132442)
igdpmd64.sys                Thu Jan 27 11:57:05 2011 (4D41A3E1)
Rt64win7.sys                Wed Feb 16 04:03:57 2011 (4D5B92FD)
atikmpag.sys                Tue Apr 12 22:17:14 2011 (4DA507AA)
atikmdag.sys                Tue Apr 12 23:08:37 2011 (4DA513B5)
Accelerometer.sys           Fri May 13 14:47:02 2011 (4DCD7CA6)
hpdskflt.sys                Fri May 13 14:47:02 2011 (4DCD7CA6)
iaStor.sys                  Fri May 20 12:52:24 2011 (4DD69C48)
RtsPStor.sys                Mon May 30 03:50:40 2011 (4DE34C50)
stwrt64.sys                 Thu Jun  2 06:18:43 2011 (4DE76383)
[COLOR=RED][B]nusb3hub.sys                Fri Jun 10 04:00:35 2011 (4DF1CF23)[/B][/COLOR]
[COLOR=RED][B]nusb3xhc.sys                Fri Jun 10 04:00:38 2011 (4DF1CF26)[/B][/COLOR]
NETwNs64.sys                Wed Aug  3 20:28:26 2011 (4E39E7AA)
btmaux.sys                  Fri Aug  5 08:45:03 2011 (4E3BE5CF)
Sftvollh.sys                Fri Sep 30 12:42:46 2011 (4E85F186)
Sftplaylh.sys               Fri Sep 30 12:43:05 2011 (4E85F199)
Sftfslh.sys                 Fri Sep 30 12:43:06 2011 (4E85F19A)
Sftredirlh.sys              Fri Sep 30 12:43:14 2011 (4E85F1A2)
SynTP.sys                   Thu Oct 13 22:34:52 2011 (4E979FCC)
btmhsf.sys                  Wed Nov  2 08:26:12 2011 (4EB136E4)
iBtFltCoex.sys              Fri Dec  9 14:45:13 2011 (4EE26549)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
avgtpx64.sys                Tue Aug 21 10:16:24 2012 (50339838)
avgrkx64.sys                Thu Sep 13 20:41:40 2012 (50527D44)
avgloga.sys                 Thu Sep 20 21:23:51 2012 (505BC1A7)
avgtdia.sys                 Thu Sep 20 21:25:33 2012 (505BC20D)
avgldx64.sys                Mon Oct  1 21:05:50 2012 (506A3DEE)
avgmfx64.sys                Thu Oct  4 21:08:44 2012 (506E331C)
avgidsha.sys                Sun Oct 14 21:22:54 2012 (507B656E)
avgidsdrivera.sys           Mon Oct 22 06:47:11 2012 (5085242F)
mbam.sys                    Mon Aug 20 12:49:41 2012 (50326AA5)
SynTP.sys                   Thu Jun  9 20:15:09 2011 (4DF1620D)
btmhsf.sys                  Fri Oct  7 07:08:05 2011 (4E8EDD95)
iBtFltCoex.sys              Tue Oct 11 16:07:59 2011 (4E94A21F)
atikmpag.sys                Tue Mar 15 09:24:37 2011 (4D7F6895)
atikmdag.sys                Tue Mar 15 09:51:43 2011 (4D7F6EEF)
[/font]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=clwvd.sys
http://www.carrona.org/drivers/driver.php?id=IntcDAud.sys
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys
http://www.carrona.org/drivers/driver.php?id=WDKMD.sys
http://www.carrona.org/drivers/driver.php?id=igdpmd64.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=atikmpag.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
http://www.carrona.org/drivers/driver.php?id=Accelerometer.sys
http://www.carrona.org/drivers/driver.php?id=hpdskflt.sys
http://www.carrona.org/drivers/driver.php?id=iaStor.sys
http://www.carrona.org/drivers/driver.php?id=RtsPStor.sys
http://www.carrona.org/drivers/driver.php?id=stwrt64.sys
http://www.carrona.org/drivers/driver.php?id=nusb3hub.sys
http://www.carrona.org/drivers/driver.php?id=nusb3xhc.sys
http://www.carrona.org/drivers/driver.php?id=NETwNs64.sys
http://www.carrona.org/drivers/driver.php?id=btmaux.sys
http://www.carrona.org/drivers/driver.php?id=Sftvollh.sys
http://www.carrona.org/drivers/driver.php?id=Sftplaylh.sys
http://www.carrona.org/drivers/driver.php?id=Sftfslh.sys
http://www.carrona.org/drivers/driver.php?id=Sftredirlh.sys
http://www.carrona.org/drivers/driver.php?id=SynTP.sys
http://www.carrona.org/drivers/driver.php?id=btmhsf.sys
http://www.carrona.org/drivers/driver.php?id=iBtFltCoex.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=avgtpx64.sys
http://www.carrona.org/drivers/driver.php?id=avgrkx64.sys
http://www.carrona.org/drivers/driver.php?id=avgloga.sys
http://www.carrona.org/drivers/driver.php?id=avgtdia.sys
http://www.carrona.org/drivers/driver.php?id=avgldx64.sys
http://www.carrona.org/drivers/driver.php?id=avgmfx64.sys
http://www.carrona.org/drivers/driver.php?id=avgidsha.sys
http://www.carrona.org/drivers/driver.php?id=avgidsdrivera.sys
http://www.carrona.org/drivers/driver.php?id=mbam.sys
I have tried to update to the latest graphic driver as I can see mine is not the latest but It wont let me, I get the message 'your computer does not meet minimum system requirements!
Some ATI drivers don't work on some laptops - don't worry about that for now, just get the latest one's from the HP website.
Is the laptop still under warranty? If so, please take it in and tell them you can't install video drivers.
I think I have solved the problem now, I had to install the AMD driver instead of the intel driver and so far IE has not crashed once :)
Top Bottom
