yeechung210594
- Joined
- May 21, 2011
View attachment 052111-21574-01.dmp
Wonders what happening...
0: kd> !analyze -v
* Bugcheck Analysis *
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c000001d, The exception code that was not handled
Arg2: 82a99317, The address that the exception occurred at
Arg3: 9ecb4cc0, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc000001d - {EXCEPTION} Illegal Instruction An attempt was made to execute an illegal instruction.
FAULTING_IP:
nt!KiTrap07+cf
82a99317 0fae29 xrstor [ecx]
TRAP_FRAME: 9ecb4cc0 -- (.trap 0xffffffff9ecb4cc0)
ErrCode = 00000000
eax=00000007 ebx=80010031 ecx=9ecb4dc0 edx=00000000 esi=11cc42f0 edi=84c3b938
eip=82a99317 esp=9ecb4d34 ebp=9ecb4d34 iopl=0 nv up di pl nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010006
nt!KiTrap07+0xcf:
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x8E
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 6cc05792 to 82a99317
FAILED_INSTRUCTION_ADDRESS:
nt!KiTrap07+cf
STACK_TEXT:
9ecb4d34 6cc05792 badb0d00 77db6344 00000000 nt!KiTrap07+0xcf
WARNING: Frame IP not in any known module. Following frames may be wrong.
1329fefc 00000000 00000000 00000000 00000000 0x6cc05792
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!KiTrap07+cf
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt!KiTrap07+cf
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrpamp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4d9fd915
FAILURE_BUCKET_ID: 0x8E_BAD_IP_nt!KiTrap07+cf
Followup: MachineOwner
0: kd> !analyze -v
happening.
Arguments:
Arg4: 00000000
Debugging Details:
FAULTING_IP:
nt!KiTrap07+cf
ErrCode = 00000000
nt!KiTrap07+0xcf:
BUGCHECK_STR: 0x8E
CURRENT_IRQL: 0
nt!KiTrap07+cf
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!KiTrap07+cf
MODULE_NAME: nt
start end module name
80bba000 80bc2000 kdcom kdcom.dll Tue Jul 14 02:08:58 2009 (4A5BDAAA)
82a1d000 82a54000 hal halmacpi.dll Tue Jul 14 00:11:03 2009 (4A5BBF07)
82a54000 82e64000 nt ntkrpamp.exe Sat Apr 09 04:57:09 2011 (4D9FD915)
88800000 88808000 rdpencdd rdpencdd.sys Tue Jul 14 01:01:39 2009 (4A5BCAE3)
88808000 88810000 rdprefmp rdprefmp.sys Tue Jul 14 01:01:41 2009 (4A5BCAE5)
88810000 8881b000 Msfs Msfs.SYS Tue Jul 14 00:11:26 2009 (4A5BBF1E)
8881e000 88896000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:06:41 2009 (4A5BDA21)
88896000 888a7000 PSHED PSHED.dll Tue Jul 14 02:09:36 2009 (4A5BDAD0)
888a7000 888af000 BOOTVID BOOTVID.dll Tue Jul 14 02:04:34 2009 (4A5BD9A2)
888af000 888f1000 CLFS CLFS.SYS Tue Jul 14 00:11:10 2009 (4A5BBF0E)
888f1000 8899c000 CI CI.dll Tue Jul 14 02:09:28 2009 (4A5BDAC8)
8899c000 889a9300 tpcfgoqw tpcfgoqw.sys Wed Sep 02 22:37:57 2009 (4A9EE5B5)
889aa000 889de000 fltmgr fltmgr.sys Tue Jul 14 00:11:13 2009 (4A5BBF11)
889de000 889ff000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:25:49 2009 (4A5BC27D)
88a00000 88a23000 ataport ataport.SYS Tue Jul 14 00:11:18 2009 (4A5BBF16)
88a23000 88a2c000 amdxata amdxata.sys Tue May 19 18:57:35 2009 (4A12F30F)
88a2c000 88a3d000 fileinfo fileinfo.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
88a3d000 88aae000 Wdf01000 Wdf01000.sys Tue Jul 14 00:11:36 2009 (4A5BBF28)
88aae000 88abc000 WDFLDR WDFLDR.SYS Tue Jul 14 00:11:25 2009 (4A5BBF1D)
88abc000 88b04000 ACPI ACPI.sys Tue Jul 14 00:11:11 2009 (4A5BBF0F)
88b04000 88b0d000 WMILIB WMILIB.SYS Tue Jul 14 00:11:22 2009 (4A5BBF1A)
88b0d000 88b15000 msisadrv msisadrv.sys Tue Jul 14 00:11:09 2009 (4A5BBF0D)
88b15000 88b3f000 pci pci.sys Tue Jul 14 00:11:16 2009 (4A5BBF14)
88b3f000 88b4a000 vdrvroot vdrvroot.sys Tue Jul 14 00:46:19 2009 (4A5BC74B)
88b4a000 88b5b000 partmgr partmgr.sys Tue Jul 14 00:11:35 2009 (4A5BBF27)
88b5b000 88b63000 compbatt compbatt.sys Tue Jul 14 00:19:18 2009 (4A5BC0F6)
88b63000 88b6e000 BATTC BATTC.SYS Tue Jul 14 00:19:15 2009 (4A5BC0F3)
88b6e000 88b7e000 volmgr volmgr.sys Tue Jul 14 00:11:25 2009 (4A5BBF1D)
88b7e000 88bc9000 volmgrx volmgrx.sys Tue Jul 14 00:11:41 2009 (4A5BBF2D)
88bc9000 88bd0000 pciide pciide.sys Tue Jul 14 00:11:19 2009 (4A5BBF17)
88bd0000 88bde000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:11:15 2009 (4A5BBF13)
88bde000 88bf4000 mountmgr mountmgr.sys Tue Jul 14 00:11:27 2009 (4A5BBF1F)
88bf4000 88bfd000 atapi atapi.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
88c00000 88c0c000 vga vga.sys Tue Jul 14 00:25:50 2009 (4A5BC27E)
88c0c000 88c19000 watchdog watchdog.sys Tue Jul 14 00:24:10 2009 (4A5BC21A)
88c1f000 88d4e000 Ntfs Ntfs.sys Tue Jul 14 00:12:05 2009 (4A5BBF45)
88d4e000 88d79000 msrpc msrpc.sys Tue Jul 14 00:11:59 2009 (4A5BBF3F)
88d79000 88d8c000 ksecdd ksecdd.sys Tue Jul 14 00:11:56 2009 (4A5BBF3C)
88d8c000 88de9000 cng cng.sys Tue Jul 14 00:32:55 2009 (4A5BC427)
88de9000 88df7000 pcw pcw.sys Tue Jul 14 00:11:10 2009 (4A5BBF0E)
88df7000 88e00000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:11:14 2009 (4A5BBF12)
88e11000 88e30000 cdrom cdrom.sys Tue Jul 14 00:11:24 2009 (4A5BBF1C)
88e32000 88ee9000 ndis ndis.sys Tue Jul 14 00:12:24 2009 (4A5BBF58)
88ee9000 88f27000 NETIO NETIO.SYS Tue Jul 14 00:12:35 2009 (4A5BBF63)
88f27000 88f4c000 ksecpkg ksecpkg.sys Fri Dec 11 04:04:22 2009 (4B21C4C6)
88f4c000 88f79000 rdyboost rdyboost.sys Tue Jul 14 00:22:02 2009 (4A5BC19A)
88f79000 88fab000 fvevol fvevol.sys Sat Sep 26 03:24:21 2009 (4ABD7B55)
88fab000 88fd0000 CLASSPNP CLASSPNP.SYS Tue Jul 14 00:11:20 2009 (4A5BBF18)
88ff1000 88ff8000 Beep Beep.SYS Tue Jul 14 00:45:00 2009 (4A5BC6FC)
88ff8000 89000000 RDPCDD RDPCDD.sys Tue Jul 14 01:01:40 2009 (4A5BCAE4)
89000000 89008000 hwpolicy hwpolicy.sys Tue Jul 14 00:11:01 2009 (4A5BBF05)
89008000 89019000 disk disk.sys Tue Jul 14 00:11:28 2009 (4A5BBF20)
89019000 89020000 Null Null.SYS Tue Jul 14 00:11:12 2009 (4A5BBF10)
89021000 8916a000 tcpip tcpip.sys Mon Jun 14 04:36:59 2010 (4C15A3DB)
8916a000 8919b000 fwpkclnt fwpkclnt.sys Tue Jul 14 00:12:03 2009 (4A5BBF43)
8919b000 891a3380 vmstorfl vmstorfl.sys Tue Jul 14 00:28:44 2009 (4A5BC32C)
891a4000 891e3000 volsnap volsnap.sys Tue Jul 14 00:11:34 2009 (4A5BBF26)
891e3000 891eb000 spldr spldr.sys Mon May 11 17:13:47 2009 (4A084EBB)
891eb000 891fb000 mup mup.sys Tue Jul 14 00:14:14 2009 (4A5BBFC6)
8e615000 8e679000 csc csc.sys Tue Jul 14 00:15:08 2009 (4A5BBFFC)
8e679000 8e691000 dfsc dfsc.sys Tue Jul 14 00:14:16 2009 (4A5BBFC8)
8e691000 8e69f000 blbdrive blbdrive.sys Tue Jul 14 00:23:04 2009 (4A5BC1D8)
8e69f000 8e6a0440 AsIO AsIO.sys Mon Dec 17 09:10:20 2007 (47663CFC)
8e6a1000 8e6c2000 tunnel tunnel.sys Tue Jul 14 00:54:03 2009 (4A5BC91B)
8e6c2000 8e6d4000 intelppm intelppm.sys Tue Jul 14 00:11:03 2009 (4A5BBF07)
8e6d4000 8e6ec000 i8042prt i8042prt.sys Tue Jul 14 00:11:23 2009 (4A5BBF1B)
8e6ec000 8e6fe000 AgileVpn AgileVpn.sys Tue Jul 14 00:55:00 2009 (4A5BC954)
8e6fe000 8e716000 rasl2tp rasl2tp.sys Tue Jul 14 00:54:33 2009 (4A5BC939)
8e716000 8e721000 ndistapi ndistapi.sys Tue Jul 14 00:54:24 2009 (4A5BC930)
8e721000 8e743000 ndiswan ndiswan.sys Tue Jul 14 00:54:34 2009 (4A5BC93A)
8e743000 8e75b000 raspppoe raspppoe.sys Tue Jul 14 00:54:53 2009 (4A5BC94D)
8e75b000 8e772000 raspptp raspptp.sys Tue Jul 14 00:54:47 2009 (4A5BC947)
8e772000 8e789000 rassstp rassstp.sys Tue Jul 14 00:54:57 2009 (4A5BC951)
8e789000 8e793000 rdpbus rdpbus.sys Tue Jul 14 01:02:40 2009 (4A5BCB20)
8e793000 8e7a0000 mouclass mouclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
8e7a0000 8e7d4000 ks ks.sys Thu Mar 04 03:57:52 2010 (4B8F2FC0)
8e7d4000 8e7e2000 umbus umbus.sys Tue Jul 14 00:51:38 2009 (4A5BC88A)
8e83a000 8e848000 Npfs Npfs.SYS Tue Jul 14 00:11:31 2009 (4A5BBF23)
8e848000 8e85f000 tdx tdx.sys Tue Jul 14 00:12:10 2009 (4A5BBF4A)
8e85f000 8e86a000 TDI TDI.SYS Tue Jul 14 00:12:12 2009 (4A5BBF4C)
8e86a000 8e8c4000 afd afd.sys Tue Jul 14 00:12:34 2009 (4A5BBF62)
8e8c4000 8e8f6000 netbt netbt.sys Tue Jul 14 00:12:18 2009 (4A5BBF52)
8e8f6000 8e8fd000 wfplwf wfplwf.sys Tue Jul 14 00:53:51 2009 (4A5BC90F)
8e8fd000 8e91c000 pacer pacer.sys Tue Jul 14 00:53:58 2009 (4A5BC916)
8e91c000 8e939000 dnelwf dnelwf.sys Thu Mar 31 02:47:36 2011 (4D93DD38)
8e939000 8e947000 netbios netbios.sys Tue Jul 14 00:53:54 2009 (4A5BC912)
8e947000 8e961000 serial serial.sys Tue Jul 14 00:45:33 2009 (4A5BC71D)
8e961000 8e974000 wanarp wanarp.sys Tue Jul 14 00:55:02 2009 (4A5BC956)
8e974000 8e984000 termdd termdd.sys Tue Jul 14 01:01:35 2009 (4A5BCADF)
8e984000 8e9c5000 rdbss rdbss.sys Tue Jul 14 00:14:26 2009 (4A5BBFD2)
8e9c5000 8e9cf000 nsiproxy nsiproxy.sys Tue Jul 14 00:12:08 2009 (4A5BBF48)
8e9cf000 8e9d9000 mssmbios mssmbios.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
8e9d9000 8e9e5000 discache discache.sys Tue Jul 14 00:24:04 2009 (4A5BC214)
90c00000 90c18000 parport parport.sys Tue Jul 14 00:45:34 2009 (4A5BC71E)
90c18000 90c196c0 ASACPI ASACPI.sys Wed May 13 12:11:32 2009 (4A0AAAE4)
90c1a000 90c24000 serenum serenum.sys Tue Jul 14 00:45:27 2009 (4A5BC717)
90c24000 90c31000 kbdclass kbdclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
90c36000 91666380 nvlddmkm nvlddmkm.sys Fri Apr 08 04:18:51 2011 (4D9E7E9B)
91667000 91668040 nvBridge nvBridge.kmd Fri Apr 08 04:14:44 2011 (4D9E7DA4)
91669000 91720000 dxgkrnl dxgkrnl.sys Tue Nov 02 02:37:53 2010 (4CCF7981)
91720000 91759000 dxgmms1 dxgmms1.sys Thu Feb 03 03:34:49 2011 (4D4A2259)
91759000 91764000 usbuhci usbuhci.sys Tue Jul 14 00:51:10 2009 (4A5BC86E)
91764000 917af000 USBPORT USBPORT.SYS Tue Jul 14 00:51:13 2009 (4A5BC871)
917af000 917be000 usbehci usbehci.sys Tue Jul 14 00:51:14 2009 (4A5BC872)
917be000 917dd000 HDAudBus HDAudBus.sys Tue Jul 14 00:50:55 2009 (4A5BC85F)
917dd000 917ec000 L1E62x86 L1E62x86.sys Thu Jun 11 07:39:12 2009 (4A30A690)
917ec000 917f9000 CompositeBus CompositeBus.sys Tue Jul 14 00:45:26 2009 (4A5BC716)
917f9000 917fa380 swenum swenum.sys Tue Jul 14 00:45:08 2009 (4A5BC704)
9380a000 9384e000 usbhub usbhub.sys Tue Jul 14 00:52:06 2009 (4A5BC8A6)
9384e000 9385f000 NDProxy NDProxy.SYS Tue Jul 14 00:54:27 2009 (4A5BC933)
9385f000 9387a000 luafv luafv.sys Tue Jul 14 00:15:44 2009 (4A5BC020)
9387a000 93894000 WudfPf WudfPf.sys Tue Jul 14 00:50:13 2009 (4A5BC835)
93894000 938a7000 rspndr rspndr.sys Tue Jul 14 00:53:20 2009 (4A5BC8F0)
938a7000 9392c000 HTTP HTTP.sys Tue Jul 14 00:12:53 2009 (4A5BBF75)
9392c000 93945000 bowser bowser.sys Wed Feb 23 05:05:24 2011 (4D649594)
93945000 93957000 mpsdrv mpsdrv.sys Tue Jul 14 00:52:52 2009 (4A5BC8D4)
93957000 9397a000 mrxsmb mrxsmb.sys Wed Feb 23 05:05:29 2011 (4D649599)
9397a000 939b5000 mrxsmb10 mrxsmb10.sys Wed Feb 23 05:05:39 2011 (4D6495A3)
939b5000 939d0000 mrxsmb20 mrxsmb20.sys Wed Feb 23 05:05:33 2011 (4D64959D)
95200000 95211000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:12:47 2009 (4A5BBF6F)
95211000 95221000 lltdio lltdio.sys Tue Jul 14 00:53:18 2009 (4A5BC8EE)
95221000 95228000 parvdm parvdm.sys Tue Jul 14 00:45:29 2009 (4A5BC719)
95228000 95530a00 RTKVHDA RTKVHDA.sys Tue Sep 07 12:13:32 2010 (4C861E5C)
95531000 95560000 portcls portcls.sys Tue Jul 14 00:51:00 2009 (4A5BC864)
95560000 95579000 drmk drmk.sys Tue Jul 14 01:36:05 2009 (4A5BD2F5)
95579000 95583000 Dxapi Dxapi.sys Tue Jul 14 00:25:25 2009 (4A5BC265)
95583000 9558e000 monitor monitor.sys Tue Jul 14 00:25:58 2009 (4A5BC286)
9558e000 95599000 hidusb hidusb.sys Tue Jul 14 00:51:04 2009 (4A5BC868)
95599000 955ac000 HIDCLASS HIDCLASS.SYS Tue Jul 14 00:51:01 2009 (4A5BC865)
955ac000 955b2480 HIDPARSE HIDPARSE.SYS Tue Jul 14 00:50:59 2009 (4A5BC863)
955b3000 955b4700 USBD USBD.SYS Tue Jul 14 00:51:05 2009 (4A5BC869)
955b5000 955c0000 mouhid mouhid.sys Tue Jul 14 00:45:08 2009 (4A5BC704)
955c0000 955d6000 cdfs cdfs.sys Tue Jul 14 00:11:14 2009 (4A5BBF12)
955d6000 955e3000 crashdmp crashdmp.sys Tue Jul 14 00:45:50 2009 (4A5BC72E)
955e3000 955ee000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:11:16 2009 (4A5BBF14)
955ee000 955f7000 dump_atapi dump_atapi.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
95c02000 95c54000 srv srv.sys Wed Feb 23 05:06:08 2011 (4D6495C0)
95c54000 95cc4e80 EagleNT EagleNT.sys Wed Jul 28 10:48:48 2010 (4C4FFD00)
95cc5000 95ce5000 Mkd2kfNt Mkd2kfNt.sys Fri Oct 17 09:50:22 2008 (48F851CE)
96340000 9658b000 win32k win32k.sys Thu Mar 03 03:31:07 2011 (4D6F0B7B)
965a0000 965a9000 TSDDD TSDDD.dll unavailable (00000000)
965d0000 965ee000 cdd cdd.dll Tue Nov 02 04:23:36 2010 (4CCF9248)
9823d000 982d4000 peauth peauth.sys Tue Jul 14 01:35:44 2009 (4A5BD2E0)
982d4000 982de000 secdrv secdrv.SYS Wed Sep 13 14:18:32 2006 (45080528)
982de000 982ff000 srvnet srvnet.sys Wed Feb 23 05:05:46 2011 (4D6495AA)
982ff000 98369000 spsys spsys.sys Mon May 11 17:37:10 2009 (4A085436)
98369000 98376000 tcpipreg tcpipreg.sys Tue Jul 14 00:54:14 2009 (4A5BC926)
98376000 983c5000 srv2 srv2.sys Wed Feb 23 05:05:54 2011 (4D6495B2)
Unloaded modules:
88fd0000 88fdd000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000D000
88fdd000 88fe8000 dump_ataport
Checksum: 00000000
ImageSize: 0000B000
88fe8000 88ff1000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
88e00000 88e11000 dump_dumpfve
Checksum: 00000000
ImageSize: 00011000
