BSOD After Random Freezes
I just reinstalled Windows 7 on my Toshiba Satellite A200 and it seems to freeze randomly when I open programs such as iTunes and other programs that need to load a lot of data.
Here is the error that I get whenever it freeezes:
Problem signature:
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 7a
BCP1: C040FD48
BCP2: C0000185
BCP3: 15C5CBE0
BCP4: 81FA9000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\042011-37081-01.dmp
C:\Users\Josh\AppData\Local\Temp\WER-220195-0.sysdata.xml
Read our privacy statement online:
Windows 7 Privacy Statement - Microsoft Windows
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Also, whenever the computer freezes, I can still use my mouse but nothing happens when I click on anything. I opened up Task Manager before it crashed and I noticed that the CPU usage dropped from around 30% to 0% when it froze. I don't know if this is a problem or not but I thought I should post anyway.
Here are my system specs:
Windows 7 Ultimate x86
2x 512MB DDR2 RAM Chips
1.66 GHz Intel Core 2 Duo
Thanks in advance!
1. Attach the crash files from C:\Windows\Minidump.
2. Since you mention about occasional freezes, also attach:
- snips of CPU-Z memory and CPU tabs
- Passmark Rammon HTML report.zip
DISK_HARDWARE_ERROR: There was error with disk hardware :
042011-33961-01.dmp
KERNEL_DATA_INPAGE_ERROR (7a)
The requested page of kernel data could not be read in. Typically caused by
a bad block in the paging file or disk controller error.
ERROR_CODE: (NTSTATUS) 0xc0000185 - The I/O device reported an I/O error.
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_LARGE_4096
042011-37081-01.dmp
FAILURE_BUCKET_ID: 0x7a_c0000185_nt!MiWaitForInPageComplete+2fd
042011-18642-01.dmp
8a8d9000, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
1. Run HDD diagnostics:
HD Diagnostic
HD Tune website
HDDScan
2. Command prompt > chkdsk /f
3. Update drivers:
TOSHIBA ACPI-Based Value Added Logical and General Purpose Device Driver
TVALZ_O.SYS Thu Nov 08 22:07:46 2007
Toshiba Support - Homepage
Intel GMA
igdkmd32.sys Wed Sep 23 15:18:09 2009
Intel® Driver Update Utility
Intel Wireless
netw5v32.sys Thu Mar 26 12:10:37 2009
Realtek LAN
Rt86win7.sys Thu Feb 26 04:04:22 2009
Realtek
CRASH DUMPS
Loading Dump File [F:\DMP\042011-33961-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
Built by: 7600.16695.x86fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0x82853000 PsLoadedModuleList = 0x8299b810
Debug session time: Wed Apr 20 09:01:31.653 2011 (UTC - 4:00)
System Uptime: 0 days 0:14:00.572
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
0: kd> !analyze -v
a bad block in the paging file or disk controller error. Also see
KERNEL_STACK_INPAGE_ERROR.
If the error status is 0xC000000E, 0xC000009C, 0xC000009D or 0xC0000185,
it means the disk subsystem has experienced a failure.
If the error status is 0xC000009A, then it means the request failed because
a filesystem failed to make forward progress.
Arguments:
Arg1: c0415720, lock type that was held (value 1,2,3, or PTE address)
Arg2: c0000185, error status (normally i/o status code)
Arg3: 28172860, current process (virtual address for lock type 3, or PTE)
Arg4: 82ae4d89, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
Debugging Details:
GetPointerFromAddress: unable to read from 829bb700
BUGCHECK_STR:  0x7a_c0000185
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  CODE_CORRUPTION
PROCESS_NAME:  System
CURRENT_IRQL:  0
TRAP_FRAME:  88d23c78 -- (.trap 0xffffffff88d23c78)
ErrCode = 00000010
eax=00000002 ebx=8281f700 ecx=82994300 edx=00000000 esi=829943ac edi=00000004
eip=82ae4d89 esp=88d23cec ebp=88d23d00 iopl=0         nv up ei pl zr na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010246
nt!PopPolicyWorkerAction:
82ae4d89 0000            add     byte ptr [eax],al          ds:0023:00000002=??
Resetting default scope
LAST_CONTROL_TRANSFER:  from 8290770a to 8292fdfc
STACK_TEXT:
88d23ad4 8290770a 0000007a c0415720 c0000185 nt!KeBugCheckEx+0x1e
88d23b48 828ff1d5 8533f7b4 88d23ba0 82987540 nt!MiWaitForInPageComplete+0x2fd
88d23bdc 828daf47 82987540 82ae4d89 8533f720 nt!MiIssueHardFault+0x3b2
88d23c60 82899628 00000008 82ae4d89 00000000 nt!MmAccessFault+0x2656
88d23c60 82ae4d89 00000008 82ae4d89 00000000 nt!KiTrap0E+0xdc
88d23d00 828c103b 00000000 00000000 8419b4c0 nt!PopPolicyWorkerAction
88d23d50 82a619df 00000001 9f5ddd4b 00000000 nt!ExpWorkerThread+0x10d
88d23d90 829131d9 828c0f2e 00000001 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
STACK_COMMAND:  kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !nt
    82ae4000-82ae4071  114 bytes - nt!PopDispatchStateCallout+8b
	[ 56 ff 15 5c aa 98 82 89:00 00 00 00 00 00 00 00 ]
    82ae4073 - nt!PopDispatchStateCallout+fe (+0x73)
	[ 80:00 ]
    82ae4076-82ae407e  9 bytes - nt!PopDispatchStateCallout+101 (+0x03)
	[ 74 34 8b 45 f8 68 02 18:00 00 00 00 00 00 00 00 ]
    82ae4080-82ae4083  4 bytes - nt!PopDispatchStateCallout+10b (+0x0a)
	[ 57 68 29 12:00 00 00 00 ]
    82ae4086-82ae408c  7 bytes - nt!PopDispatchStateCallout+111 (+0x06)
	[ 89 45 08 8d 45 08 68:00 00 00 00 00 00 00 ]
    82ae408e - nt!PopDispatchStateCallout+119 (+0x08)
	[ 80:00 ]
    82ae4090-82ae40a0  17 bytes - nt!PopDispatchStateCallout+11b (+0x02)
	[ 80 89 45 d4 6a 01 8d 45:00 00 00 00 00 00 00 00 ]
    82ae40a4-82ae40b3  16 bytes - nt!PopDispatchStateCallout+12f (+0x14)
	[ 89 7d e0 e8 e9 7c e2 ff:00 00 00 00 00 00 00 00 ]
    82ae40b5-82ae40d7  35 bytes - nt!PopDispatchStateCallout+140 (+0x11)
	[ 90 90 90 90 90 8b ff 55:00 00 00 00 00 00 00 00 ]
    82ae40d9-82ae40f3  27 bytes - nt!CmSetLazyFlushState+1f (+0x24)
	[ 9d 98 82 74 0a 68 40 9e:00 00 00 00 00 00 00 00 ]
    82ae40f7-82ae410f  25 bytes - nt!CmSetLazyFlushState+3d (+0x1e)
	[ a3 0c 9e 9b 82 89 1d 80:00 00 00 00 00 00 00 00 ]
    82ae4111-82ae4120  16 bytes - nt!CmSetLazyFlushState+57 (+0x1a)
	[ 9d 98 82 74 1d 68 20 9e:00 00 00 00 00 00 00 00 ]
    82ae4122-82ae413e  29 bytes - nt!CmSetLazyFlushState+68 (+0x11)
	[ 17 5b ca 51 50 bf 40 9e:00 00 00 00 00 00 00 00 ]
    82ae4140-82ae4150  17 bytes - nt!CmSetLazyFlushState+86 (+0x1e)
    82ae4153-82ae4184  50 bytes - nt!ExSwapinWorkerThreads+e (+0x13)
	[ 53 56 57 33 ff 57 89 45:00 00 00 00 00 00 00 00 ]
    82ae4186-82ae4190  11 bytes - nt!ExSwapinWorkerThreads+41 (+0x33)
	[ 72 05 e8 86 ab d9 ff 64:00 00 00 00 00 00 00 00 ]
    82ae4193-82ae41a4  18 bytes - nt!ExSwapinWorkerThreads+4e (+0x0d)
	[ a3 24 d5 98 82 0f b6 45:00 00 00 00 00 00 00 00 ]
    82ae41a6-82ae41b1  12 bytes - nt!ExSwapinWorkerThreads+61 (+0x13)
	[ d5 98 82 57 8b c3 eb 57:00 00 00 00 00 00 00 00 ]
    82ae41b4-82ae4258  165 bytes - nt!ExSwapinWorkerThreads+6f (+0x0e)
	[ 02 74 4a 3b 5d f4 75 0a:00 00 00 00 00 00 00 00 ]
    82ae425a-82ae4279  32 bytes - nt!ExSwapinWorkerThreads+115 (+0xa6)
    82ae427b-82ae42ba  64 bytes - nt!PfpLogScenarioEvent+1c (+0x21)
	[ 6a 10 e8 e3 6b e3 ff 8b:00 00 00 00 00 00 00 00 ]
    82ae42bc-82ae42eb  48 bytes - nt!PfpLogScenarioEvent+5d (+0x41)
	[ df ff 6a 08 8d 45 f8 50:00 00 00 00 00 00 00 00 ]
    82ae42ed - nt!PfpLogScenarioEvent+8e (+0x31)
	[ 01:00 ]
    82ae42f0-82ae4319  42 bytes - nt!PfpLogScenarioEvent+91 (+0x03)
	[ 52 50 e8 69 d0 da ff 03:00 00 00 00 00 00 00 00 ]
    82ae431b-82ae4328  14 bytes - nt!PfpLogScenarioEvent+bc (+0x2b)
    82ae432a - nt!PopFinalizeWakeInfo+a (+0x0f)
	[ 6a:00 ]
    82ae432c-82ae4342  23 bytes - nt!PopFinalizeWakeInfo+c (+0x02)
	[ 68 d0 48 99 82 e8 cf 64:00 00 00 00 00 00 00 00 ]
    82ae4344-82ae4383  64 bytes - nt!PopFinalizeWakeInfo+24 (+0x18)
	[ 75 32 8b 46 18 85 c0 74:00 00 00 00 00 00 00 00 ]
    82ae4385-82ae43a6  34 bytes - nt!PopFinalizeWakeInfo+65 (+0x41)
    82ae43a8-82ae43b4  13 bytes - nt!PopUnlinkWakeSources+1e (+0x23)
	[ ff 4b 14 39 3f 75 eb 5f:00 00 00 00 00 00 00 00 ]
    82ae43b6-82ae43c8  19 bytes - nt!PopUnlinkWakeSources+2c (+0x0e)
    82ae43ca-82ae43e9  32 bytes - nt!PopNewWakeSource+f (+0x14)
	[ e8 dc e7 e8 ff 8b d0 85:00 00 00 00 00 00 00 00 ]
    82ae43eb-82ae4406  28 bytes - nt!PopNewWakeSource+30 (+0x21)
    82ae4409-82ae4428  32 bytes - nt!PopFreeHiberContext+19 (+0x1e)
	[ 8d 45 fc 50 e8 eb 0a ef:00 00 00 00 00 00 00 00 ]
    82ae442c-82ae44c3  152 bytes - nt!PopFreeHiberContext+3c (+0x23)
	[ 8b 07 3b c3 74 3b 53 50:00 00 00 00 00 00 00 00 ]
    82ae44c7-82ae44df  25 bytes - nt!PopFreeHiberContext+d7 (+0x9b)
	[ 8b 07 3b c3 74 10 50 e8:00 00 00 00 00 00 00 00 ]
    82ae44e3-82ae4502  32 bytes - nt!PopFreeHiberContext+f3 (+0x1c)
    82ae4506-82ae4516  17 bytes - nt!PopFreeHiberContext+116 (+0x23)
	[ 53 8b d7 8b ce e8 bf e8:00 00 00 00 00 00 00 00 ]
    82ae4519-82ae4524  12 bytes - nt!PopFreeHiberContext+129 (+0x13)
	[ 57 e8 bf b8 e4 ff cc 81:00 00 00 00 00 00 00 00 ]
    82ae4526-82ae4558  51 bytes - nt!PopFreeHiberContext+135 (+0x0d)
	[ 40 75 05 e8 8d 07 ef ff:00 00 00 00 00 00 00 00 ]
    82ae455c-82ae4564  9 bytes - nt!PoUnblockConsoleSwitch+13 (+0x36)
	[ e8 14 fa ff ff 5e 5d c2:00 00 00 00 00 00 00 00 ]
    82ae4566-82ae4570  11 bytes - nt!PoUnblockConsoleSwitch+1d (+0x0a)
	[ 90 90 90 90 90 8b ff 56:00 00 00 00 00 00 00 00 ]
    82ae4572-82ae4575  4 bytes - nt!PoEndPowerStateTasks+7 (+0x0c)
	[ c7 46 10 08:00 00 00 00 ]
    82ae4579-82ae45cf  87 bytes - nt!PoEndPowerStateTasks+e (+0x07)
	[ e8 f7 f9 ff ff 5e c3 90:00 00 00 00 00 00 00 00 ]
    82ae45d3-82ae45dc  10 bytes - nt!PopDiagTracePowerTransitionEnd+4e (+0x5a)
	[ 89 5d e0 89 5d e8 c7 45:00 00 00 00 00 00 00 00 ]
    82ae45e0-82ae45eb  12 bytes - nt!PopDiagTracePowerTransitionEnd+5b (+0x0d)
	[ 89 5d f0 e8 5b 8c ef ff:00 00 00 00 00 00 00 00 ]
    82ae45ed-82ae460f  35 bytes - nt!PopDiagTracePowerTransitionEnd+68 (+0x0d)
	[ 90 90 90 90 90 8b ff 51:00 00 00 00 00 00 00 00 ]
    82ae4612-82ae4615  4 bytes - nt!ExpReleaseMicrocodeUpdateLock+c (+0x25)
	[ 66 ff 8f 86:00 00 00 00 ]
    82ae4619-82ae4623  11 bytes - nt!ExpReleaseMicrocodeUpdateLock+13 (+0x07)
	[ be 2c cc 98 82 8b c6 f0:00 00 00 00 00 00 00 00 ]
    82ae4625-82ae4634  16 bytes - nt!ExpReleaseMicrocodeUpdateLock+1f (+0x0c)
	[ 72 07 8b ce e8 57 3d da:00 00 00 00 00 00 00 00 ]
WARNING: !chkimg output was truncated to 50 lines. Invoke !chkimg without '-lo [num_lines]' to view  entire output.
3857 errors : !nt (82ae4000-82ae4fff)
MODULE_NAME: memory_corruption
IMAGE_NAME:  memory_corruption
FOLLOWUP_NAME:  memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MEMORY_CORRUPTOR:  LARGE_4096
Followup: memory_corruption
Loading Dump File [F:\DMP\042011-37081-01.dmp]
Built by: 7600.16385.x86fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0x82809000 PsLoadedModuleList = 0x82951810
Debug session time: Wed Apr 20 08:43:20.201 2011 (UTC - 4:00)
System Uptime: 0 days 22:07:15.844
0: kd> !analyze -v
Arguments:
Arg1: c040fd48, lock type that was held (value 1,2,3, or PTE address)
Arg3: 15c5cbe0, current process (virtual address for lock type 3, or PTE)
Arg4: 81fa9000, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
Debugging Details:
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 828bd60a to 828e5d10
STACK_TEXT:
88d4fb24 828bd60a 0000007a c040fd48 c0000185 nt!KeBugCheckEx+0x1e
88d4fb98 828b50d5 9289909c 88d4fbc0 8293d540 nt!MiWaitForInPageComplete+0x2fd
88d4fbfc 82890e3f 8293d540 81fa9000 92899008 nt!MiIssueHardFault+0x3b2
88d4fc80 8283d259 00000001 81fa9000 00000000 nt!MmAccessFault+0x2656
88d4fd10 8283cf7a 856d7d48 88d4fd30 00000000 nt!MiInPageSingleKernelStack+0x1cf
88d4fd44 82895003 856d7dbc 88d4fd90 82a1766d nt!KiInSwapKernelStacks+0x41
88d4fd50 82a1766d 00000000 9fa484f2 00000000 nt!KeSwapProcessOrStack+0x78
88d4fd90 828c90d9 82894f8b 00000000 00000000 nt!PspSystemThreadStartup+0x9e
STACK_COMMAND:  kb
FOLLOWUP_IP:
828bd60a cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!MiWaitForInPageComplete+2fd
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc007
Followup: MachineOwner
Loading Dump File [F:\DMP\042011-18642-01.dmp]
Machine Name:
Kernel base = 0x8280c000 PsLoadedModuleList = 0x82954810
Debug session time: Wed Apr 20 09:25:54.646 2011 (UTC - 4:00)
System Uptime: 0 days 0:23:58.691
0: kd> !analyze -v
Arguments:
Arg1: c04546c8, lock type that was held (value 1,2,3, or PTE address)
Arg3: 2978abe0, current process (virtual address for lock type 3, or PTE)
Arg4: 8a8d9000, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
Debugging Details:
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 828c070a to 828e8dfc
STACK_TEXT:
88d4faf4 828c070a 0000007a c04546c8 c0000185 nt!KeBugCheckEx+0x1e
88d4fb68 828b81d5 84ffa3fc 88d4fbc0 82940540 nt!MiWaitForInPageComplete+0x2fd
88d4fbfc 82893f47 82940540 8a8d9000 84ffa368 nt!MiIssueHardFault+0x3b2
88d4fc80 82840249 00000001 8a8d9000 00000000 nt!MmAccessFault+0x2656
88d4fd10 8283ff6a 8c132980 88d4fd30 00000000 nt!MiInPageSingleKernelStack+0x1cf
88d4fd44 8289810b 8c1329f4 88d4fd90 82a1a9df nt!KiInSwapKernelStacks+0x41
88d4fd50 82a1a9df 00000000 9faf7d99 00000000 nt!KeSwapProcessOrStack+0x78
88d4fd90 828cc1d9 82898093 00000000 00000000 nt!PspSystemThreadStartup+0x9e
STACK_COMMAND:  kb
FOLLOWUP_IP:
828c070a cc              int     3
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4cc78ed4
DRIVERS
start    end        module name
91a1f000 91a4b000   1394ohci 1394ohci.sys Mon Jul 13 19:51:59 2009 (4A5BC89F)
86aae000 86af6000   ACPI     ACPI.sys     Mon Jul 13 19:11:11 2009 (4A5BBF0F)
8c2cf000 8c329000   afd      afd.sys      Mon Jul 13 19:12:34 2009 (4A5BBF62)
91aad000 91abf000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
94eba000 94fc0000   AGRSM    AGRSM.sys    Mon Nov 10 09:56:37 2008 (49184BA5)
82fd3000 82fdc000   amdxata  amdxata.sys  Tue May 19 13:57:35 2009 (4A12F30F)
86a16000 86a1f000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
82fb0000 82fd3000   ataport  ataport.SYS  Mon Jul 13 19:11:18 2009 (4A5BBF16)
86b55000 86b60000   BATTC    BATTC.SYS    Mon Jul 13 19:19:15 2009 (4A5BC0F3)
8c23b000 8c242000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
8d281000 8d28f000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
82ebb000 82ec3000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
8a6ee000 8a707000   bowser   bowser.sys   Wed Feb 23 00:05:24 2011 (4D649594)
96110000 9612e000   cdd      cdd.dll      unavailable (00000000)
82e00000 82e1f000   cdrom    cdrom.sys    Mon Jul 13 19:11:24 2009 (4A5BBF1C)
82f05000 82fb0000   CI       CI.dll       Mon Jul 13 21:09:28 2009 (4A5BDAC8)
86db8000 86ddd000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
82ec3000 82f05000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
91a64000 91a67700   CmBatt   CmBatt.sys   Mon Jul 13 19:19:18 2009 (4A5BC0F6)
86e3d000 86e9a000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
86b4d000 86b55000   compbatt compbatt.sys Mon Jul 13 19:19:18 2009 (4A5BC0F6)
91aa0000 91aad000   CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
94fcf000 94fdc000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
8d205000 8d269000   csc      csc.sys      Mon Jul 13 19:15:08 2009 (4A5BBFFC)
8d269000 8d281000   dfsc     dfsc.sys     Mon Jul 13 19:14:16 2009 (4A5BBFC8)
86df4000 86e00000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
871ee000 871ff000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
94ea1000 94eba000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
91b8a000 91bc5000   dtsoftbus01 dtsoftbus01.sys Thu Jan 13 03:26:59 2011 (4D2EB753)
94fdc000 94fe7000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:11:16 2009 (4A5BBF14)
94e00000 94e11000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
94fe7000 94ff1000   dump_msahci dump_msahci.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
94e11000 94e1b000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
8db12000 8dbc9000   dxgkrnl  dxgkrnl.sys  Mon Nov 01 22:37:53 2010 (4CCF7981)
8d2c2000 8d2fb000   dxgmms1  dxgmms1.sys  Wed Feb 02 22:34:49 2011 (4D4A2259)
86c3a000 86c4b000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
86c06000 86c3a000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
86ea8000 86eb1000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
86e00000 86e32000   fvevol   fvevol.sys   Fri Sep 25 22:24:21 2009 (4ABD7B55)
87150000 87181000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
91a9a000 91a9f280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:16:53 2009 (4A1151B5)
82c1c000 82c53000   hal      halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
8d346000 8d365000   HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
94e22000 94e72000   HdAudio  HdAudio.sys  Mon Jul 13 19:51:46 2009 (4A5BC892)
8a669000 8a6ee000   HTTP     HTTP.sys     Mon Jul 13 19:12:53 2009 (4A5BBF75)
871e6000 871ee000   hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
91a68000 91a80000   i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B)
8d609000 8db12000   igdkmd32 igdkmd32.sys Wed Sep 23 15:18:09 2009 (4ABA7471)
86bbb000 86bc2000   intelide intelide.sys Mon Jul 13 19:11:19 2009 (4A5BBF17)
8d2b0000 8d2c2000   intelppm intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07)
91a80000 91a8d000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
80bd3000 80bdb000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
91b56000 91b8a000   ks       ks.sys       Wed Mar 03 22:57:52 2010 (4B8F2FC0)
86da5000 86db8000   ksecdd   ksecdd.sys   Mon Jul 13 19:11:56 2009 (4A5BBF3C)
86fa6000 86fcb000   ksecpkg  ksecpkg.sys  Thu Dec 10 23:04:22 2009 (4B21C4C6)
86ddd000 86ded000   lltdio   lltdio.sys   Mon Jul 13 19:53:18 2009 (4A5BC8EE)
8dbe3000 8dbfe000   luafv    luafv.sys    Mon Jul 13 19:15:44 2009 (4A5BC020)
82e32000 82eaa000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:06:41 2009 (4A5BDA21)
94fc2000 94fcf000   modem    modem.sys    Mon Jul 13 19:55:24 2009 (4A5BC96C)
94ff1000 94ffc000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
91a8d000 91a9a000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
86a00000 86a16000   mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
8c20d000 8c233680   MpFilter MpFilter.sys Tue Sep 14 17:23:59 2010 (4C8FE7EF)
9659c000 965a1900   MpKsl3fca8543 MpKsl3fca8543.sys Tue Mar 30 22:06:14 2010 (4BB2AE16)
87000000 87005900   MpKsl794c2da5 MpKsl794c2da5.sys Tue Mar 30 22:06:14 2010 (4BB2AE16)
96592000 9659b200   MpNWMon  MpNWMon.sys  Tue Sep 14 17:23:50 2010 (4C8FE7E6)
8a707000 8a719000   mpsdrv   mpsdrv.sys   Mon Jul 13 19:52:52 2009 (4A5BC8D4)
8a719000 8a73c000   mrxsmb   mrxsmb.sys   Wed Feb 23 00:05:29 2011 (4D649599)
8a73c000 8a777000   mrxsmb10 mrxsmb10.sys Wed Feb 23 00:05:39 2011 (4D6495A3)
8a777000 8a792000   mrxsmb20 mrxsmb20.sys Wed Feb 23 00:05:33 2011 (4D64959D)
86a1f000 86a29000   msahci   msahci.sys   Mon Jul 13 19:45:50 2009 (4A5BC72E)
8c294000 8c29f000   Msfs     Msfs.SYS     unavailable (00000000)
86aff000 86b07000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
86d7a000 86da5000   msrpc    msrpc.sys    unavailable (00000000)
8c200000 8c20a000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
871d6000 871e6000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
86eb1000 86f68000   ndis     ndis.sys     Mon Jul 13 19:12:24 2009 (4A5BBF58)
91ad7000 91ae2000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
8a646000 8a656000   ndisuio  ndisuio.sys  Mon Jul 13 19:53:51 2009 (4A5BC90F)
91ae2000 91b04000   ndiswan  ndiswan.sys  Mon Jul 13 19:54:34 2009 (4A5BC93A)
91bd3000 91be4000   NDProxy  NDProxy.SYS  Mon Jul 13 19:54:27 2009 (4A5BC933)
8c381000 8c38f000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
8c329000 8c35b000   netbt    netbt.sys    Mon Jul 13 19:12:18 2009 (4A5BBF52)
86f68000 86fa6000   NETIO    NETIO.SYS    Mon Jul 13 19:12:35 2009 (4A5BBF63)
9160c000 91a1f000   netw5v32 netw5v32.sys Thu Mar 26 12:10:37 2009 (49CBA8FD)
8c29f000 8c2ad000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
8c3f3000 8c3fd000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
8280c000 82c1c000   nt       ntkrpamp.exe Tue Oct 26 22:30:44 2010 (4CC78ED4)
86c4b000 86d7a000   Ntfs     Ntfs.sys     Mon Jul 13 19:12:05 2009 (4A5BBF45)
8c234000 8c23b000   Null     Null.SYS     unavailable (00000000)
8a600000 8a646000   nwifi    nwifi.sys    Mon Jul 13 19:51:59 2009 (4A5BC89F)
8c362000 8c381000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
86b3c000 86b4d000   partmgr  partmgr.sys  Mon Jul 13 19:11:35 2009 (4A5BBF27)
86b07000 86b31000   pci      pci.sys      Mon Jul 13 19:11:16 2009 (4A5BBF14)
86bc2000 86bd0000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
86bd0000 86bfe000   pcmcia   pcmcia.sys   Mon Jul 13 19:19:29 2009 (4A5BC101)
86e9a000 86ea8000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
96422000 964b9000   peauth   peauth.sys   Mon Jul 13 20:35:44 2009 (4A5BD2E0)
94e72000 94ea1000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
82eaa000 82ebb000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
91abf000 91ad7000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
91b04000 91b1c000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
91b1c000 91b33000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
91b33000 91b4a000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
8c3b2000 8c3f3000   rdbss    rdbss.sys    Mon Jul 13 19:14:26 2009 (4A5BBFD2)
91b4a000 91b54000   rdpbus   rdpbus.sys   Mon Jul 13 20:02:40 2009 (4A5BCB20)
8c27c000 8c284000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:01:40 2009 (4A5BCAE4)
8c284000 8c28c000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
8c28c000 8c294000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
86fcb000 86ff8000   rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
8a656000 8a669000   rspndr   rspndr.sys   Mon Jul 13 19:53:20 2009 (4A5BC8F0)
8d365000 8d38a000   Rt86win7 Rt86win7.sys Thu Feb 26 04:04:22 2009 (49A65B16)
91a4b000 91a64000   sdbus    sdbus.sys    Fri Oct 09 22:31:24 2009 (4ACFF1FC)
964b9000 964c3000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
871ce000 871d6000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
96540000 96592000   srv      srv.sys      Wed Feb 23 00:06:08 2011 (4D6495C0)
964f1000 96540000   srv2     srv2.sys     Wed Feb 23 00:05:54 2011 (4D6495B2)
964c3000 964e4000   srvnet   srvnet.sys   Wed Feb 23 00:05:46 2011 (4D6495AA)
91b54000 91b55380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
87007000 87150000   tcpip    tcpip.sys    Sun Jun 13 23:36:59 2010 (4C15A3DB)
964e4000 964f1000   tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
8c2c4000 8c2cf000   TDI      TDI.SYS      Mon Jul 13 19:12:12 2009 (4A5BBF4C)
8c2ad000 8c2c4000   tdx      tdx.sys      Mon Jul 13 19:12:10 2009 (4A5BBF4A)
8c3a2000 8c3b2000   termdd   termdd.sys   Mon Jul 13 20:01:35 2009 (4A5BCADF)
960e0000 960e9000   TSDDD    TSDDD.dll    unavailable (00000000)
8d28f000 8d2b0000   tunnel   tunnel.sys   Mon Jul 13 19:54:03 2009 (4A5BC91B)
871c9000 871cd180   TVALZ_O  TVALZ_O.SYS  Thu Nov 08 22:07:46 2007 (4733CF02)
91bc5000 91bd3000   umbus    umbus.sys    Mon Jul 13 19:51:38 2009 (4A5BC88A)
91be4000 91bfb000   usbccgp  usbccgp.sys  Mon Jul 13 19:51:31 2009 (4A5BC883)
94fc0000 94fc1700   USBD     USBD.SYS     Mon Jul 13 19:51:05 2009 (4A5BC869)
8dbd4000 8dbe3000   usbehci  usbehci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
8d38a000 8d3ce000   usbhub   usbhub.sys   Mon Jul 13 19:52:06 2009 (4A5BC8A6)
8d2fb000 8d346000   USBPORT  USBPORT.SYS  Mon Jul 13 19:51:13 2009 (4A5BC871)
8dbc9000 8dbd4000   usbuhci  usbuhci.sys  Mon Jul 13 19:51:10 2009 (4A5BC86E)
8d3ce000 8d3f1b80   usbvideo usbvideo.sys Wed Mar 03 23:04:40 2010 (4B8F3158)
86b31000 86b3c000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
8c242000 8c24e000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
8c24e000 8c26f000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
87181000 8718a000   vmstorfl vmstorfl.sys unavailable (00000000)
86b60000 86b70000   volmgr   volmgr.sys   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
86b70000 86bbb000   volmgrx  volmgrx.sys  unavailable (00000000)
8718a000 871c9000   volsnap  volsnap.sys  Mon Jul 13 19:11:34 2009 (4A5BBF26)
8c38f000 8c3a2000   wanarp   wanarp.sys   Mon Jul 13 19:55:02 2009 (4A5BC956)
8c26f000 8c27c000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
86a2f000 86aa0000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
86aa0000 86aae000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8c35b000 8c362000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
95e80000 960cb000   win32k   win32k.sys   unavailable (00000000)
86af6000 86aff000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
82fdc000 82ff6000   WudfPf   WudfPf.sys   Mon Jul 13 19:50:13 2009 (4A5BC835)
Unloaded modules:
8a792000 8a7fc000   spsys.sys
    Checksum:  00000000
    ImageSize:  0006A000
8a792000 8a7aa000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
86ddd000 86dea000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
86e32000 86e3d000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000B000
86dea000 86df4000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000A000
82fdc000 82fed000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
I have just started running HD Tune and I currently have 27 errors. Also, the hard drive is making funny noises, kind of like when a CD skips.
I ran Chkdsk earlier and it froze at 63%. Does this mean that I'll have to get a new hard drive?
(My computer is unusable right now so I'm using my iPod to type this)
HDD is the source of your blue screens.
#7
OK, thank you...
I'll run out to the local computer store and buy myself a new one, then.
My computer just crash dumped again during the HD Tune checkup and it had about 120 errors just before it died.
And it's weird because I just bought this hard drive about 2 months ago. I'll try a different maker next time.
Thank you for all your help, I wouldn't have gotten anywhere without it!
#8
You are welcome, thanks for the update.
#9
Sorry, just one more thing...
It isn't possible to fix my hard drive now, is it? I just want to make sure before I go get a new one.
#10
It does sound like your hdd or perhaps your motherboard is dying. Feel free to consult other forums on this,
Confused on HD Tune test - [H]ard|Forum
Try:
1. Upgrade bios.
2. Format the hard drive using [email protected] Kill Disk Hard Drive Eraser. Low Level Format.
3. Load bios setup defaults.
4. Install the OS.
5. The problem might be with the HDD controller, which is your motherboard device. You can try different modes - AHCI/IDE(/RAID), but if you do so each time you'll have to reformat the hard drive and reinstall the OS. So it's easier to try another hard drive.
#11
OK, I'll try that, thank you so much!! =]
#12
Sorry, how do you use the different modes? I don't really know about AHCI/IDE(/RAID)...
Also updating the BIOS and the HDD drivers but had no luck... I'm going to try [email protected] now.
#13
IDE/AHCI/RAID is in the bios. Just try another HDD.
042011-33961-01.dmp
042011-37081-01.dmp
042011-18642-01.dmp
#14
OK, thanks =D
