Windows 7 BSOD after reinstall and all other advice!!
chazzg
This BSoding has gone on long enough i've tried everything to fix it but need some advice i've zipped up the minidump and would liek some kind person to give me teh info i need to sort this out once and for all.
Thanks
ChazzG
View attachment 102210-38298-01.zip
Hi, welcome.
1) Uninstall ESET in safe mode with this tool:
AV Uninstallers - Windows 7 Forums
Reboot and install MSE.
2) Navigate to C:\Windows\System32\drivers and delete:
PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009
3) Update your video card driver:
nvlddmkm nvlddmkm.sys Thu May 14 16:48:07 2009
Link Removed - Invalid URL
4) Update your Realtek network driver:
Rt64win7 Rt64win7.sys Thu Feb 26 04:04:13 2009
RTL8111
Enjoy. :)
Update the video card driver from my link.
nvlddmkm nvlddmkm.sys Tue Jul 14 15:50:52 2009
If you do so, it will be from September 2010 instead.
Update the Pinncale software you have. If there is no very recent update from July 2009 or newer, uninstall:
MarvinBus64 MarvinBus64.sys Fri Sep 23 17:17:03 2005
(This was not present before.)
You're welcome.
i bought just a cheap zotac geforce 210 its alright for a slight bit of gaming and photoshop/after effects :)
right its gone worse since installing magic iso :( ill upoad teh two BSOD's ive had...
thanks
chazzg
Unfortunately, in these 3 new crashes you posted, there are no bad or suspect drivers. That means there is a memory defect or improper bios setting.
1) Go into the bios settings and on the first screen - "Load Optimized Defaults". Save.
2) If any new crashes happen, run Memtest86+ overnight to test the memory. 8-10 passes. If any errors are shown, replace the RAM in the system for new.
Things are gradually getting better but there are still the odd slip ups and i get a BSOD so I've zipped my latest BSOD's together and i was wondering if you can tell me if its hardware or a driver error.
View attachment BSODS.zip
Thanks
ChazzG :)
Update:
RtWLan.exe
RtWLan Application For WinXP/2003
SCDEmu.SYS Sun Nov 08 22:27:29 2009
PowerISO
Loading Dump File [F:\a\Minidump\D M P\112010-25677-01.dmp]
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff88006dc8e20, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff960000d9dc9, If non-zero, the instruction address which referenced the bad memory
	address.
Arg4: 0000000000000000, (reserved)
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800035010e0
 fffff88006dc8e20
FAULTING_IP:
win32k!xxxRealInternalGetMessage+6fd
fffff960`000d9dc9 448bb424e8000000 mov     r14d,dword ptr [rsp+0E8h]
MM_INTERNAL_CODE:  0
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP
BUGCHECK_STR:  0x50
PROCESS_NAME:  RtWLan.exe
CURRENT_IRQL:  0
TRAP_FRAME:  fffff88006dbb8a0 -- (.trap 0xfffff88006dbb8a0)
rax=fffff900c0c16710 rbx=0000000000000000 rcx=0000000000000000
rdx=000000000000da40 rsi=0000000000000000 rdi=0000000000000000
rip=fffff960000d9dc9 rsp=fffff88006dbba38 rbp=fffff88006dbbc60
 r8=0000000000000000  r9=0000000000000315 r10=fffff900c0c04a60
r11=fffff900c0082120 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl zr na po nc
win32k!xxxRealInternalGetMessage+0x6fd:
fffff960`000d9dc9 448bb424e8000000 mov     r14d,dword ptr [rsp+0E8h] ss:0018:fffff880`06dbbb20=00000000
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80003349f14 to fffff800032c9740
STACK_TEXT:
fffff880`06dbb738 fffff800`03349f14 : 00000000`00000050 fffff880`06dc8e20 00000000`00000000 fffff880`06dbb8a0 : nt!KeBugCheckEx
fffff880`06dbb740 fffff800`032c782e : 00000000`00000000 fffff900`c09cb250 00000000`00000000 fffff800`032d2cff : nt! ?? ::FNODOBFM::`string'+0x42837
fffff880`06dbb8a0 fffff960`000d9dc9 : fffff900`c09cb250 00000000`00000001 fffffa80`00000000 fffffa80`ffffffff : nt!KiPageFault+0x16e
fffff880`06dbba38 00000000`00000000 : fffff800`000025ff 00000000`00000000 fffffa80`ffffffff fffff880`00000001 : win32k!xxxRealInternalGetMessage+0x6fd
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  win32k!xxxRealInternalGetMessage+6fd
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: win32k
IMAGE_NAME:  win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4c7dc13c
FAILURE_BUCKET_ID:  X64_0x50_VRF_win32k!xxxRealInternalGetMessage+6fd
Followup: MachineOwner
fffff880`00ece000 fffff880`00f25000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02cb1000 fffff880`02d3b000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04200000 fffff880`04216000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`01168000 fffff880`01173000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`00c1a000 fffff880`00c23000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00c23000 fffff880`00c4d000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`00820000 fffff960`00881000   ATMFD    ATMFD.DLL    Thu May 27 00:11:31 2010 (4BFDF0F3)
fffff880`01860000 fffff880`01867000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`04193000 fffff880`041a4000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`02935000 fffff880`02953000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00630000 fffff960`00657000   cdd      cdd.dll      Wed May 19 15:48:26 2010 (4BF4408A)
fffff880`019c6000 fffff880`019e3000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
fffff880`01800000 fffff880`0182a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00d37000 fffff880`00df7000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01962000 fffff880`01992000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cd9000 fffff880`00d37000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0141c000 fffff880`0148f000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`04800000 fffff880`04810000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`019e3000 fffff880`019f1000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`040f2000 fffff880`04175000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`04175000 fffff880`04193000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`040e3000 fffff880`040f2000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0194c000 fffff880`01962000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`059da000 fffff880`059fc000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`02c6b000 fffff880`02c75000   dump_diskdump dump_diskdump.sys Mon Jul 12 23:32:05 2010 (4C3BDE35)
fffff880`01f1c000 fffff880`01f2f000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`01edd000 fffff880`01f1c000   dump_nvstor64 dump_nvstor64.sys Tue Aug 04 20:31:07 2009 (4A78D2CB)
fffff880`05806000 fffff880`05812000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04460000 fffff880`04554000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`04554000 fffff880`0459a000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`011bf000 fffff880`011d3000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01173000 fffff880`011bf000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`014a0000 fffff880`014aa000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`01912000 fffff880`0194c000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0105e000 fffff880`010a8000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`04090000 fffff880`0409d000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`03210000 fffff800`03259000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`0409d000 fffff880`040c1000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`019ad000 fffff880`019c6000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`05822000 fffff880`0582a080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`045f1000 fffff880`045ff000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0286d000 fffff880`02935000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01909000 fffff880`01912000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`041e0000 fffff880`041fe000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`041ca000 fffff880`041e0000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`04000000 fffff880`0400f000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00ba8000 fffff800`00bb2000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`058c0000 fffff880`05903000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013e0000 fffff880`013fa000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01200000 fffff880`0122b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`05800000 fffff880`05805200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`01f73000 fffff880`01f88000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01f2f000 fffff880`01f52000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c81000 fffff880`00cc5000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`05812000 fffff880`05820000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0400f000 fffff880`0401e000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`00c00000 fffff880`00c1a000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0182a000 fffff880`01857000   MpFilter MpFilter.sys Sat Mar 20 01:58:08 2010 (4BA463F0)
fffff880`06096000 fffff880`060a6000   MpNWMon  MpNWMon.sys  Sat Mar 20 01:58:00 2010 (4BA463E8)
fffff880`02953000 fffff880`0296b000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`0296b000 fffff880`02998000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`02998000 fffff880`029e6000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`02800000 fffff880`02823000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`00c4d000 fffff880`00c58000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`011e9000 fffff880`011f4000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f2e000 fffff880`00f38000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01000000 fffff880`0105e000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`011f4000 fffff880`011ff000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`018f7000 fffff880`01909000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014aa000 fffff880`0159c000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0423a000 fffff880`04246000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`01fdb000 fffff880`01fee000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`0582e000 fffff880`0585d000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0596f000 fffff880`05984000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02daf000 fffff880`02dbe000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d3b000 fffff880`02d80000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0159c000 fffff880`015fc000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02c75000 fffff880`02c86000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02ded000 fffff880`02df9000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`03259000 fffff800`03835000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`0123d000 fffff880`013e0000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01857000 fffff880`01860000   Null     Null.SYS     unavailable (00000000)
fffff880`053ec000 fffff880`053ed180   nvBridge nvBridge.kmd Sat Oct 16 13:06:16 2010 (4CB9DB88)
fffff880`05984000 fffff880`0599d000   nvhda64v nvhda64v.sys Thu Jan 28 09:24:54 2010 (4B619E36)
fffff880`04812000 fffff880`053eba80   nvlddmkm nvlddmkm.sys Sat Oct 16 13:12:46 2010 (4CB9DD0E)
fffff880`010c7000 fffff880`01106000   nvstor64 nvstor64.sys Tue Aug 04 20:31:07 2009 (4A78D2CB)
fffff880`01f88000 fffff880`01fdb000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02d89000 fffff880`02daf000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00f78000 fffff880`00f8d000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f38000 fffff880`00f6b000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e00000 fffff880`00e07000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e07000 fffff880`00e17000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0148f000 fffff880`014a0000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`01e18000 fffff880`01ebe000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0599d000 fffff880`059da000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cc5000 fffff880`00cd9000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`011d3000 fffff880`011df040   PxHlpa64 PxHlpa64.sys Tue Oct 20 14:08:42 2009 (4ADDFCAA)
fffff880`04216000 fffff880`0423a000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0585d000 fffff880`05878000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`05878000 fffff880`05899000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`05899000 fffff880`058b3000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02c1a000 fffff880`02c6b000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`058b3000 fffff880`058be000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01410000 fffff880`01419000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`010b8000 fffff880`010c1000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`011e0000 fffff880`011e9000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`018bd000 fffff880`018f7000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`01e00000 fffff880`01e18000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0459a000 fffff880`045f1000   Rt64win7 Rt64win7.sys Mon Sep 20 03:38:09 2010 (4C970F61)
fffff880`0424a000 fffff880`04460000   RTL85n64 RTL85n64.sys Sun Mar 14 22:10:44 2010 (4B9D9724)
fffff880`02c00000 fffff880`02c1a000   SCDEmu   SCDEmu.SYS   Sun Nov 08 22:27:29 2009 (4AF78C21)
fffff880`02823000 fffff880`0282e000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`018b5000 fffff880`018bd000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06000000 fffff880`06096000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`0615d000 fffff880`061c4000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`0282e000 fffff880`0285b000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`01106000 fffff880`01168000   storport storport.sys Mon Jul 13 20:01:18 2009 (4A5BCACE)
fffff880`058be000 fffff880`058bf480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01600000 fffff880`017fd000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`0614b000 fffff880`0615d000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02ca4000 fffff880`02cb1000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02c86000 fffff880`02ca4000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02dd9000 fffff880`02ded000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00480000 fffff960`0048a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`061c4000 fffff880`061cc000   TuneUpUtilitiesDriver64 TuneUpUtilitiesDriver64.sys Thu Sep 17 07:54:52 2009 (4AB2238C)
fffff880`041a4000 fffff880`041ca000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`05903000 fffff880`05915000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`040c1000 fffff880`040de000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`05820000 fffff880`05821f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`0407f000 fffff880`04090000   usbehci  usbehci.sys  Sat Oct 24 00:27:33 2009 (4AE28235)
fffff880`05915000 fffff880`0596f000   usbhub   usbhub.sys   Sat Oct 24 00:28:24 2009 (4AE28268)
fffff880`0401e000 fffff880`04029000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04029000 fffff880`0407f000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`01992000 fffff880`019ad000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`00f6b000 fffff880`00f78000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0122b000 fffff880`01239000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`00c58000 fffff880`00c7d000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`01400000 fffff880`01410000   vmstorfl vmstorfl.sys unavailable (00000000)
fffff880`00f8d000 fffff880`00fa2000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00fa2000 fffff880`00ffe000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`01869000 fffff880`018b5000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02dbe000 fffff880`02dd9000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`010a8000 fffff880`010b8000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e1b000 fffff880`00ebf000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ebf000 fffff880`00ece000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d80000 fffff880`02d89000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00010000 fffff960`0031f000   win32k   win32k.sys   Tue Aug 31 22:58:04 2010 (4C7DC13C)
fffff880`053ee000 fffff880`053f7000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f25000 fffff880`00f2e000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`01f52000 fffff880`01f73000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`060a6000 fffff880`060d7000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`060da000 fffff880`0614b000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01992000 fffff880`019a0000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`019a0000 fffff880`019aa000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`019aa000 fffff880`019e9000   dump_nvstor6
    Checksum:  00000000
    ImageSize:  0003F000
fffff880`019e9000 fffff880`019fc000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Top Bottom
