Windows 7 BSOD again help me Please
keddepryhsel
My computer is doing again BSOD after 3 days without any errors I've run memtest 10 pass and 0 errors, I've run chdsk it could not find any errors I have also update the drivers,
I have attached the files on rapidshare because I can not upload them to windows7forums.com Link Removed - Invalid URL
RAM is the culprit of your blue screens:
041211-19422-01.dmp
MEMORY_MANAGEMENT (1a)
040911-25521-01.dmp
BugCheck 1E, {ffffffffc0000005, 1fffff, 8, 1fffff}
Kingston DDR3-1333 9-9-9-24 1.5V in slot #2,
your current RAM settings look right.
Update drivers:
ALPHA Networks - update or uninstall it
anodlwfx.sys Fri Mar 06 05:10:08 2009
USB 3.0
nusb3xhc.sys Thu Apr 22 21:34:36 2010
Run 10 passes of Memtest86+ - Advanced Memory Diagnostic Tool.
CRASH DUMPS
Loading Dump File [F:\DMP\040911-25521-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (6 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02a5e000 PsLoadedModuleList = 0xfffff800`02c9be50
Debug session time: Sat Apr  9 01:36:36.469 2011 (UTC - 4:00)
System Uptime: 0 days 0:00:57.905
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Probably caused by : ntkrnlmp.exe ( nt!KiDispatchException+1b9 )
Followup: MachineOwner
4: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: 00000000001fffff, The address that the exception occurred at
Arg3: 0000000000000008, Parameter 0 of the exception
Arg4: 00000000001fffff, Parameter 1 of the exception
Debugging Details:
FAULTING_IP:
+3661376264666230
00000000`001fffff ??              ???
EXCEPTION_PARAMETER1:  0000000000000008
EXCEPTION_PARAMETER2:  00000000001fffff
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002d060e0
 00000000001fffff
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
BUGCHECK_STR:  0x1E_c0000005
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  0
EXCEPTION_RECORD:  fffff8800d75e998 -- (.exr 0xfffff8800d75e998)
ExceptionAddress: 00000000001fffff
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000008
   Parameter[1]: 00000000001fffff
Attempt to execute non-executable address 00000000001fffff
TRAP_FRAME:  fffff8800d75ea40 -- (.trap 0xfffff8800d75ea40)
rax=fffff8a00227bc70 rbx=0000000000000000 rcx=fffff8a002aa4e00
rdx=0000000000000b1c rsi=0000000000000000 rdi=0000000000000000
rip=00000000001fffff rsp=fffff8800d75ebd0 rbp=fffffa800682a750
 r8=fffff8a001c0b000  r9=0000000000000010 r10=fffff80002de2460
r11=0000000000313160 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na pe nc
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002b08a39 to fffff80002ace740
STACK_TEXT:
fffff880`0d75e1c8 fffff800`02b08a39 : 00000000`0000001e ffffffff`c0000005 00000000`001fffff 00000000`00000008 : nt!KeBugCheckEx
fffff880`0d75e1d0 fffff800`02acdd82 : fffff880`0d75e998 fffffa80`083b55f1 fffff880`0d75ea40 fffff8a0`0147e190 : nt!KiDispatchException+0x1b9
fffff880`0d75e860 fffff800`02acc8fa : 00000000`00000008 fffffa80`083b55f1 00000000`0486e400 00000000`00000000 : nt!KiExceptionDispatch+0xc2
fffff880`0d75ea40 00000000`001fffff : 00000000`00000b1c fffff8a0`0147e190 00000000`0486e410 00000000`00020019 : nt!KiPageFault+0x23a
fffff880`0d75ebd0 00000000`00000b1c : fffff8a0`0147e190 00000000`0486e410 00000000`00020019 00000000`0486e498 : 0x1fffff
fffff880`0d75ebd8 fffff8a0`0147e190 : 00000000`0486e410 00000000`00020019 00000000`0486e498 00000000`00000000 : 0xb1c
fffff880`0d75ebe0 00000000`0486e410 : 00000000`00020019 00000000`0486e498 00000000`00000000 00000000`00000000 : 0xfffff8a0`0147e190
fffff880`0d75ebe8 00000000`00020019 : 00000000`0486e498 00000000`00000000 00000000`00000000 00000000`00020019 : 0x486e410
fffff880`0d75ebf0 00000000`0486e498 : 00000000`00000000 00000000`00000000 00000000`00020019 00000000`00000000 : 0x20019
fffff880`0d75ebf8 00000000`00000000 : 00000000`00000000 00000000`00020019 00000000`00000000 fffff800`02acd993 : 0x486e498
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02b08a39 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!KiDispatchException+1b9
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4cc791bd
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!KiDispatchException+1b9
Loading Dump File [F:\DMP\041211-19422-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a0e000 PsLoadedModuleList = 0xfffff800`02c4be50
Debug session time: Tue Apr 12 10:06:11.196 2011 (UTC - 4:00)
System Uptime: 0 days 10:30:41.632
BugCheck 1A, {41287, 100000000, 0, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+42ba5 )
4: kd> !analyze -v
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041287, The subtype of the bugcheck.
Arg2: 0000000100000000
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
BUGCHECK_STR:  0x1a_41287
PROCESS_NAME:  System
CURRENT_IRQL:  0
TRAP_FRAME:  fffff8800eaf2940 -- (.trap 0xfffff8800eaf2940)
rax=0000000075aa0000 rbx=0000000000000000 rcx=fffff8a00ef27000
rdx=fffffffff3eac000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002a7563b rsp=fffff8800eaf2ad8 rbp=0000000000000001
 r8=0000000000000010  r9=0000000000000001 r10=00000000000075aa
r11=fffff8a00ef26ff8 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na pe nc
nt!memmove+0x20b:
fffff800`02a7563b 488901          mov     qword ptr [rcx],rax ds:0002:fffff8a0`0ef27000=????????????????
LAST_CONTROL_TRANSFER:  from fffff80002a2ab7a to fffff80002a7e740
STACK_TEXT:
fffff880`0eaf22d8 fffff800`02a2ab7a : 00000000`0000001a 00000000`00041287 00000001`00000000 00000000`00000000 : nt!KeBugCheckEx
fffff880`0eaf22e0 fffff800`02a7c82e : 00000000`00000000 00000000`00000000 fffff880`0eaf2600 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x42ba5
fffff880`0eaf2440 fffff800`02a81905 : 00000000`00000000 fffff800`02a9c322 80000000`42cb6963 fffff880`0eaf2640 : nt!KiPageFault+0x16e
fffff880`0eaf25d0 fffff800`02a9c322 : 80000000`42cb6963 fffff880`0eaf2640 fffff800`02c0ab40 fffff800`02c0ab40 : nt!ExpInterlockedPopEntrySListFault16
fffff880`0eaf25e0 fffff800`02a9aca2 : 00000000`00000001 fffff8a0`0ef27000 fffff880`0eaf2940 fffff6fc`50077938 : nt!MiResolveDemandZeroFault+0x5d2
fffff880`0eaf26d0 fffff800`02a98cf1 : 00000000`00000000 fffff880`0eaf2880 00000000`00000000 00000000`00000000 : nt!MiDispatchFault+0x8c2
fffff880`0eaf27e0 fffff800`02a7c82e : 00000000`00000001 fffff8a0`02dd2ff8 00000000`00000000 00000000`00000030 : nt!MmAccessFault+0x8f1
fffff880`0eaf2940 fffff800`02a7563b : fffff800`02e9d673 fffff8a0`02dd2fe8 00000000`00000001 fffff8a0`0ef26fe8 : nt!KiPageFault+0x16e
fffff880`0eaf2ad8 fffff800`02e9d673 : fffff8a0`02dd2fe8 00000000`00000001 fffff8a0`0ef26fe8 fffff800`02e0c735 : nt!memmove+0x20b
fffff880`0eaf2ae0 fffff800`02eeba60 : fffff880`0eaf2c10 fffff8a0`02dd1018 fffff8a0`0ef1d000 fffff8a0`06eaa000 : nt!PfTCreateTraceDump+0x2e3
fffff880`0eaf2be0 fffff800`02ef1653 : fffffa80`0845cb01 00000000`00000080 fffffa80`0396eb30 fffff800`02c0c568 : nt!PfTGenerateTrace+0x10
fffff880`0eaf2c10 fffff800`02d217c6 : ffffffff`ff676980 fffffa80`0845cb60 fffff880`0eaf2db0 fffffa80`0845cb60 : nt!PfTLoggingWorker+0x113
fffff880`0eaf2d40 fffff800`02a5cc26 : fffff880`009b1180 fffffa80`0845cb60 fffff880`009bc040 fffff880`0125ba90 : nt!PspSystemThreadStartup+0x5a
fffff880`0eaf2d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02a2ab7a cc              int     3
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+42ba5
MODULE_NAME: nt
FAILURE_BUCKET_ID:  X64_0x1a_41287_nt!_??_::FNODOBFM::_string_+42ba5
DRIVERS
fffff880`14b5d000 fffff880`14b9b000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f22000 fffff880`00f79000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`06880000 fffff880`0690a000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`13e83000 fffff880`13e99000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`06bb7000 fffff880`06bcc000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00dcb000 fffff880`00dd6000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`06939000 fffff880`06942000   anodlwfx anodlwfx.sys Fri Mar 06 05:10:08 2009 (49B0F680)
fffff880`06df1000 fffff880`06df9000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff880`0992e000 fffff880`09939000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00e63000 fffff880`00e6c000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00da1000 fffff880`00dcb000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`00800000 fffff960`00861000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`01864000 fffff880`0186b000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`06b80000 fffff880`06b91000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`063bc000 fffff880`063da000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`007a0000 fffff960`007c7000   cdd      cdd.dll      unavailable (00000000)
fffff880`01800000 fffff880`0182a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cb7000 fffff880`00d77000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01942000 fffff880`01972000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c59000 fffff880`00cb7000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01171000 fffff880`011e4000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`13e73000 fffff880`13e83000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`084ea000 fffff880`084f8000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`01e09000 fffff880`01f16000   Darusb_win7x Darusb_win7x.sys Wed Jun 23 23:42:49 2010 (4C22D439)
fffff880`06b62000 fffff880`06b80000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`06b53000 fffff880`06b62000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0192c000 fffff880`01942000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`084c2000 fffff880`084e4000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`019a8000 fffff880`019ee000   dtsoftbus01 dtsoftbus01.sys Mon Mar 14 09:15:36 2011 (4D7E14F8)
fffff880`08504000 fffff880`0850d000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`084f8000 fffff880`08504000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0850d000 fffff880`08520000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`08520000 fffff880`0852c000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`06c7a000 fffff880`06d6e000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`06d6e000 fffff880`06db4000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`010ff000 fffff880`01113000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010b3000 fffff880`010ff000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`018f2000 fffff880`0192c000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0148b000 fffff880`014d5000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02feb000 fffff800`03034000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`14b39000 fffff880`14b5d000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`08429000 fffff880`08485000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`01f4e000 fffff880`01f67000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`01f67000 fffff880`01f6f080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`01f40000 fffff880`01f4e000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`062f4000 fffff880`063bc000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`015f1000 fffff880`015fa000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`13ec9000 fffff880`13ed8000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`01f70000 fffff880`01f7e000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00ba1000 fffff800`00bab000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`06a00000 fffff880`06a43000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`084e4000 fffff880`084e9200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`01fdd000 fffff880`01ff2000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01f99000 fffff880`01fbc000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c38000 fffff880`00c45000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`01f8b000 fffff880`01f99000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`06bed000 fffff880`06bfc000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`01f7e000 fffff880`01f8b000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00d87000 fffff880`00da1000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0182a000 fffff880`0185b000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`09798000 fffff880`097a8000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`063da000 fffff880`063f2000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`06200000 fffff880`0622d000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`0622d000 fffff880`0627b000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0627b000 fffff880`0629e000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`018c9000 fffff880`018d4000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f82000 fffff880`00f8c000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01113000 fffff880`01171000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`06b48000 fffff880`06b53000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`015df000 fffff880`015f1000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014ed000 fffff880`015df000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`13ebd000 fffff880`13ec9000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0857f000 fffff880`08592000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`14b9b000 fffff880`14bca000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`06ac7000 fffff880`06adc000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`06958000 fffff880`06967000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`0683b000 fffff880`06880000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`098a8000 fffff880`098bd000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`018d4000 fffff880`018e5000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`06b3c000 fffff880`06b48000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a0e000 fffff800`02feb000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`0124a000 fffff880`013ed000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`0185b000 fffff880`01864000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`06a55000 fffff880`06a6d000   nusb3hub nusb3hub.sys Thu Apr 22 21:34:35 2010 (4BD0F92B)
fffff880`06db4000 fffff880`06de4000   nusb3xhc nusb3xhc.sys Thu Apr 22 21:34:36 2010 (4BD0F92C)
fffff880`14b37000 fffff880`14b38180   nvBridge nvBridge.kmd Fri Jan 07 20:57:22 2011 (4D27C482)
fffff880`13edc000 fffff880`14b36d00   nvlddmkm nvlddmkm.sys Fri Jan 07 21:07:22 2011 (4D27C6DA)
fffff880`0852c000 fffff880`0857f000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`06913000 fffff880`06939000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00fcc000 fffff880`00fe1000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f8c000 fffff880`00fbf000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e5c000 fffff880`00e63000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00d77000 fffff880`00d87000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`09641000 fffff880`096e7000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`08485000 fffff880`084c2000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c45000 fffff880`00c59000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`13e99000 fffff880`13ebd000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`14bca000 fffff880`14be5000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`06bcc000 fffff880`06bed000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`14be5000 fffff880`14bff000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`06aeb000 fffff880`06b3c000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`018ae000 fffff880`018b7000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`018b7000 fffff880`018c0000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`018c0000 fffff880`018c9000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0104c000 fffff880`01086000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`08592000 fffff880`085aa000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`13e00000 fffff880`13e6a000   Rt64win7 Rt64win7.sys Wed Feb 16 04:03:57 2011 (4D5B92FD)
fffff880`096e7000 fffff880`096f2000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`06c67000 fffff880`06c73000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`06967000 fffff880`06984000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`014d5000 fffff880`014dd000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`09812000 fffff880`098a8000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`09731000 fffff880`09798000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`096f2000 fffff880`0971f000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`06df9000 fffff880`06dfa480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`0971f000 fffff880`09731000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`018e5000 fffff880`018f2000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01086000 fffff880`010a4000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`0699f000 fffff880`069b3000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00570000 fffff960`0057a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`06b91000 fffff880`06bb7000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`06a43000 fffff880`06a55000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`01f23000 fffff880`01f40000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`06de4000 fffff880`06de5f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`06c56000 fffff880`06c67000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`06a6d000 fffff880`06ac7000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`06de6000 fffff880`06df1000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`06c00000 fffff880`06c56000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00fbf000 fffff880`00fcc000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0186b000 fffff880`01879000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01879000 fffff880`0189e000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00fe1000 fffff880`00ff6000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`01f16000 fffff880`01f23000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`06942000 fffff880`06958000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`06984000 fffff880`0699f000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`0189e000 fffff880`018ae000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e6f000 fffff880`00f13000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f13000 fffff880`00f22000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0690a000 fffff880`06913000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00030000 fffff960`00340000   win32k   win32k.sys   unavailable (00000000)
fffff880`13e6a000 fffff880`13e73000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f79000 fffff880`00f82000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`01fbc000 fffff880`01fdd000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`098bd000 fffff880`0992e000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01972000 fffff880`01980000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01980000 fffff880`0198c000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0198c000 fffff880`01995000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01995000 fffff880`019a8000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
