BSOD Again
clootie
Windows 7 64bit
AMD Phenom II X4 925 Processor 2.8 GHz
4 GB Ram
Microsoft Security Essentials
I've had 2 BSOD in the past 2 days. Any help with this would be great, thanks.
cybercore
Update:
LGBusEnum.sys Tue Nov 24 03:36:48 2009
Logitech WingMan
viahduaa.sys Wed Oct 21 06:30:30 2009
VIA Audio
Loading Dump File [I:\102410-14055-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02c11000 PsLoadedModuleList = 0xfffff800`02e4ee50
Debug session time: Mon Oct 25 05:05:49.785 2010 (UTC - 5:00)
System Uptime: 0 days 0:05:02.127
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1000007E, {ffffffffc0000005, fffff88004020cee, fffff880056d16a8, fffff880056d0f10}
Probably caused by : dxgmms1.sys ( dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+22 )
Followup: MachineOwner
3: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff88004020cee, The address that the exception occurred at
Arg3: fffff880056d16a8, Exception Record Address
Arg4: fffff880056d0f10, Context Record Address
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
FAULTING_IP:
fffff880`04020cee 488b18          mov     rbx,qword ptr [rax]
EXCEPTION_RECORD:  fffff880056d16a8 -- (.exr 0xfffff880056d16a8)
ExceptionAddress: fffff88004020cee (dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+0x0000000000000022)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT:  fffff880056d0f10 -- (.cxr 0xfffff880056d0f10)
rax=fdfff8a00a1327c0 rbx=0000000000000000 rcx=fffffa8005a7e000
rdx=fffffa8003f002c0 rsi=fffffa8003e1c760 rdi=fffffa8005a7e000
rip=fffff88004020cee rsp=fffff880056d18e0 rbp=fffffa8003e1e628
 r8=fffffa8003e14f01  r9=0000000000000000 r10=0000000000000000
r11=0000000000000104 r12=0000000000000018 r13=0000000000000001
iopl=0         nv up ei ng nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010282
dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+0x22:
fffff880`04020cee 488b18          mov     rbx,qword ptr [rax] ds:002b:fdfff8a0`0a1327c0=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002eb90e0
 ffffffffffffffff
FOLLOWUP_IP:
BUGCHECK_STR:  0x7E
LAST_CONTROL_TRANSFER:  from fffff8800401ded3 to fffff88004020cee
STACK_TEXT:
fffff880`056d18e0 fffff880`0401ded3 : 00000000`00000000 fffffa80`03e1c760 00000000`00000018 00000000`00000000 : dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+0x22
fffff880`056d1910 fffff880`0403865d : 00000000`00000000 fffff8a0`02a18650 fffffa80`00000000 fffffa80`03e14f10 : dxgmms1!VIDMM_GLOBAL::PrepareDmaBuffer+0x43f
fffff880`056d1ae0 fffff880`04038398 : fffff880`02fd7f40 fffff880`04037d00 fffffa80`00000000 fffffa80`00000000 : dxgmms1!VidSchiSubmitRenderCommand+0x241
fffff880`056d1cd0 fffff880`04037e96 : 00000000`00000000 fffffa80`03c8cd50 00000000`00000080 fffffa80`04f8b410 : dxgmms1!VidSchiSubmitQueueCommand+0x50
fffff880`056d1d00 fffff800`02f25c06 : 00000000`0228579e fffffa80`04f86aa0 fffffa80`03973890 fffffa80`04f86aa0 : dxgmms1!VidSchiWorkerThread+0xd6
fffff880`056d1d40 fffff800`02c5fc26 : fffff880`02fd3180 fffffa80`04f86aa0 fffff880`02fddfc0 fffff880`01248a90 : nt!PspSystemThreadStartup+0x5a
fffff880`056d1d80 00000000`00000000 : fffff880`056d2000 fffff880`056cc000 fffff880`056d10d0 00000000`00000000 : nt!KxStartSystemThread+0x16
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+22
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: dxgmms1
IMAGE_NAME:  dxgmms1.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc578
STACK_COMMAND:  .cxr 0xfffff880056d0f10 ; kb
FAILURE_BUCKET_ID:  X64_0x7E_dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+22
fffff880`00f04000 fffff880`00f5b000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`02cc8000 fffff880`02d52000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`03f9f000 fffff880`03fb5000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`0185a000 fffff880`0186f000   amdppm   amdppm.sys   Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`00ff4000 fffff880`00fff000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`041e7000 fffff880`041ef000   ASACPI   ASACPI.sys   Thu Jul 16 06:31:29 2009 (4A5E9F11)
fffff880`091b1000 fffff880`091bc000   asyncmac asyncmac.sys Tue Jul 14 03:10:13 2009 (4A5BCCE5)
fffff880`00e46000 fffff880`00e4f000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00dc7000 fffff880`00df1000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`042dc000 fffff880`042fc000   AtihdW76 AtihdW76.sys Thu Jul 15 15:46:49 2010 (4C3F0339)
fffff880`0480d000 fffff880`04fc8000   atikmdag atikmdag.sys Thu Aug 26 04:47:22 2010 (4C75C7AA)
fffff880`03ed2000 fffff880`03f1c000   atikmpag atikmpag.sys Thu Aug 26 04:20:56 2010 (4C75C178)
fffff880`01987000 fffff880`0198e000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`02deb000 fffff880`02dfc000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`039d2000 fffff880`039f0000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff960`00690000 fffff960`006b7000   cdd      cdd.dll      unavailable (00000000)
fffff880`01927000 fffff880`01951000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00cab000 fffff880`00d6b000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`018c1000 fffff880`018f1000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00c4d000 fffff880`00cab000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`01073000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`03f8f000 fffff880`03f9f000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`05bd3000 fffff880`05be1000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`0183c000 fffff880`0185a000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`02cb4000 fffff880`02cc3000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`018ab000 fffff880`018c1000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`04339000 fffff880`0435b000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`05bed000 fffff880`05bf6000   dump_atapi dump_atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`05be1000 fffff880`05bed000   dump_dumpata dump_dumpata.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`05a00000 fffff880`05a13000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`05a13000 fffff880`05a1f000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`040e2000 fffff880`041d6000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 04:00:14 2009 (4AC5509E)
fffff880`04000000 fffff880`04046000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`0112d000 fffff880`01141000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`010e1000 fffff880`0112d000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`01871000 fffff880`018ab000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`01598000 fffff880`015e2000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff800`031ed000 fffff800`03236000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff880`04046000 fffff880`0406a000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`043a7000 fffff880`043c0000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`05a21000 fffff880`05a29080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`04399000 fffff880`043a7000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`0390a000 fffff880`039d2000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`01400000 fffff880`01409000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`03e85000 fffff880`03e94000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`04200000 fffff880`0420e000   kbdhid   kbdhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff800`00bca000 fffff800`00bd4000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff880`04214000 fffff880`04257000   ks       ks.sys       Thu Mar 04 06:32:25 2010 (4B8F37D9)
fffff880`013da000 fffff880`013f4000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`0156d000 fffff880`01598000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`0435b000 fffff880`04360200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`0406a000 fffff880`0407f000   L1C62x64 L1C62x64.sys Fri Nov 13 11:47:36 2009 (4AFD2B38)
fffff880`04257000 fffff880`0425ad80   LGBusEnum LGBusEnum.sys Tue Nov 24 03:36:48 2009 (4B0B38B0)
fffff880`043c0000 fffff880`043d5000   LHidFilt LHidFilt.Sys Thu Mar 18 10:51:17 2010 (4BA1E985)
fffff880`03877000 fffff880`0388c000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`043e2000 fffff880`043f6000   LMouFilt LMouFilt.Sys Thu Mar 18 10:51:24 2010 (4BA1E98C)
fffff880`03fd9000 fffff880`03ffc000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`00c2c000 fffff880`00c39000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 04:29:09 2009 (4A5BDF65)
fffff880`03ebe000 fffff880`03ecc000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`03e94000 fffff880`03ea3000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`043d5000 fffff880`043e2000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`00e2c000 fffff880`00e46000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`01951000 fffff880`0197e000   MpFilter MpFilter.sys Sat Mar 20 07:58:08 2010 (4BA463F0)
fffff880`05e00000 fffff880`05e10000   MpNWMon  MpNWMon.sys  Sat Mar 20 07:58:00 2010 (4BA463E8)
fffff880`03800000 fffff880`03818000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`03818000 fffff880`03845000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:52:19 2010 (4B88CF33)
fffff880`05ee6000 fffff880`05f34000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:52:28 2010 (4B88CF3C)
fffff880`05f34000 fffff880`05f57000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:52:26 2010 (4B88CF3A)
fffff880`019ec000 fffff880`019f7000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00f64000 fffff880`00f6e000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`01141000 fffff880`0119f000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`02ca9000 fffff880`02cb4000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`015ea000 fffff880`015fc000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`0141b000 fffff880`0150d000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`04800000 fffff880`0480c000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`038df000 fffff880`038f2000   ndisuio  ndisuio.sys  Tue Jul 14 03:09:25 2009 (4A5BCCB5)
fffff880`03e00000 fffff880`03e2f000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`042c7000 fffff880`042dc000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`02ddc000 fffff880`02deb000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02d52000 fffff880`02d97000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`0150d000 fffff880`0156d000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`03f1c000 fffff880`03f8f000   netr6164 netr6164.sys Wed Apr 07 15:07:21 2010 (4BBC7579)
fffff880`01800000 fffff880`01811000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`02c9d000 fffff880`02ca9000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff800`02c11000 fffff800`031ed000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff880`01237000 fffff880`013da000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`0197e000 fffff880`01987000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`0388c000 fffff880`038df000   nwifi    nwifi.sys    Tue Jul 14 03:07:23 2009 (4A5BCC3B)
fffff880`02da0000 fffff880`02dc6000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`04fc8000 fffff880`04fe5000   parport  parport.sys  Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`00fae000 fffff880`00fc3000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00f6e000 fffff880`00fa1000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00e15000 fffff880`00e1c000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`00e1c000 fffff880`00e2c000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`05f57000 fffff880`05ffd000   peauth   peauth.sys   Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`042fc000 fffff880`04339000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`00c39000 fffff880`00c4d000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`03fb5000 fffff880`03fd9000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`03e2f000 fffff880`03e4a000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`03e4a000 fffff880`03e6b000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`03e6b000 fffff880`03e85000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`02c4c000 fffff880`02c9d000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`019d1000 fffff880`019da000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`019da000 fffff880`019e3000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`019e3000 fffff880`019ec000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`0119f000 fffff880`011d9000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`038f2000 fffff880`0390a000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`05e10000 fffff880`05e1b000   secdrv   secdrv.SYS   Wed Sep 13 16:18:38 2006 (4508052E)
fffff880`041ef000 fffff880`041fb000   serenum  serenum.sys  Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`02c00000 fffff880`02c1d000   serial   serial.sys   Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`015e2000 fffff880`015ea000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`09140000 fffff880`091b1000   spsys    spsys.sys    Mon May 11 20:20:58 2009 (4A085E7A)
fffff880`090aa000 fffff880`09140000   srv      srv.sys      Fri Aug 27 06:38:00 2010 (4C773318)
fffff880`05e5a000 fffff880`05ec1000   srv2     srv2.sys     Fri Aug 27 06:37:46 2010 (4C77330A)
fffff880`05e1b000 fffff880`05e48000   srvnet   srvnet.sys   Fri Aug 27 06:37:24 2010 (4C7732F4)
fffff880`00fc3000 fffff880`00fd0000   ssfs0bbc ssfs0bbc.sys Fri Nov 06 21:39:46 2009 (4AF47B82)
fffff880`00fd0000 fffff880`00ff4000   ssidrv   ssidrv.sys   Fri Nov 06 21:39:15 2009 (4AF47B63)
fffff880`041fb000 fffff880`041fc480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`01600000 fffff880`017fd000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
fffff880`05e48000 fffff880`05e5a000   tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`0182f000 fffff880`0183c000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`01811000 fffff880`0182f000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`02c38000 fffff880`02c4c000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff960`00590000 fffff960`0059a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`011d9000 fffff880`011ff000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`0425b000 fffff880`0426d000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`0437e000 fffff880`04398c00   usbaudio usbaudio.sys Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`04361000 fffff880`0437e000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff880`05a1f000 fffff880`05a20f00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`041d6000 fffff880`041e7000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`0426d000 fffff880`042c7000   usbhub   usbhub.sys   Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`0407f000 fffff880`0408a000   usbohci  usbohci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`0408a000 fffff880`040e0000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`03ea3000 fffff880`03ebe000   USBSTOR  USBSTOR.SYS  Tue Jul 14 03:06:34 2009 (4A5BCC0A)
fffff880`00fa1000 fffff880`00fae000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`0198e000 fffff880`0199c000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`05a2b000 fffff880`05bd3000   viahduaa viahduaa.sys Wed Oct 21 06:30:30 2009 (4ADE8056)
fffff880`0199c000 fffff880`019c1000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`00e00000 fffff880`00e15000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00d6b000 fffff880`00dc7000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`01073000 fffff880`010bf000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`04fe5000 fffff880`04ff2000   vwifibus vwifibus.sys Tue Jul 14 03:07:21 2009 (4A5BCC39)
fffff880`02dc6000 fffff880`02ddc000   vwififlt vwififlt.sys Tue Jul 14 03:07:22 2009 (4A5BCC3A)
fffff880`02c1d000 fffff880`02c38000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`019c1000 fffff880`019d1000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`00e51000 fffff880`00ef5000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00ef5000 fffff880`00f04000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`02d97000 fffff880`02da0000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff960`000e0000 fffff960`003ef000   win32k   win32k.sys   unavailable (00000000)
fffff880`04ff2000 fffff880`04ffb000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`00f5b000 fffff880`00f64000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`018f1000 fffff880`01912000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`03846000 fffff880`03877000   WUDFRd   WUDFRd.sys   Tue Jul 14 03:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`018f1000 fffff880`018ff000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`018ff000 fffff880`0190b000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0190b000 fffff880`01914000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01914000 fffff880`01927000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`042b1000 fffff880`042e2000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`042b7000 fffff880`042e8000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
clootie
I'm guessing the Logitech Wingman is my mouse and everytime I try to update it, it says already up to date. As for the VIA Audio, how exactly do you find which model I have or does it matter. Also thanks I updated my DX. I'll let you know if I have more crashes.
clootie
Another crash today. I uninstalled VIA Audio and I don't have anything on my computer about Logitech Wingman. I have two Logitech items on my computer, G15 keyboard and a G5 laser mouse.
TorrentG
Banned
Test the memory overnight with Memtest86+ to see if errors show. It's faulty.
