Loading Dump File [F:\a\Minidump\D M P\DMP\022511-29671-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02e07000 PsLoadedModuleList = 0xfffff800`03044e50
Debug session time: Fri Feb 25 09:15:46.159 2011 (UTC - 5:00)
System Uptime: 0 days 3:03:39.314
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 1E, {ffffffffc0000005, fffff80002e836e0, 0, ffffffffffffffff}
Probably caused by : ntkrnlmp.exe ( nt!KiDispatchException+1b9 )
Followup: MachineOwner
1: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002e836e0, The address that the exception occurred at
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
FAULTING_IP:
nt!ObfReferenceObject+20
fffff800`02e836e0 f0480fc11f lock xadd qword ptr [rdi],rbx
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800030af0e0
ffffffffffffffff
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
BUGCHECK_STR: 0x1E_c0000005
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
CURRENT_IRQL: 2
EXCEPTION_RECORD: fffff88003f369a8 -- (.exr 0xfffff88003f369a8)
ExceptionAddress: fffff80002e836e0 (nt!ObfReferenceObject+0x0000000000000020)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
TRAP_FRAME: fffff88003f36a50 -- (.trap 0xfffff88003f36a50)
rax=0000000000000001 rbx=0000000000000000 rcx=0056006b00730069
rdx=0000000000000009 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002e836e0 rsp=fffff88003f36be0 rbp=0000000000000001
r8=00000000ffffffe2 r9=0000000000000000 r10=fffff80002e07000
r11=0000000000007531 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl zr na po nc
nt!ObfReferenceObject+0x20:
fffff800`02e836e0 f0480fc11f lock xadd qword ptr [rdi],rbx ds:0114:00000000`00000000=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002eb1a39 to fffff80002e77740
STACK_TEXT:
fffff880`03f361d8 fffff800`02eb1a39 : 00000000`0000001e ffffffff`c0000005 fffff800`02e836e0 00000000`00000000 : nt!KeBugCheckEx
fffff880`03f361e0 fffff800`02e76d82 : fffff880`03f369a8 00000000`00000001 fffff880`03f36a50 fffffa80`04eb73e0 : nt!KiDispatchException+0x1b9
fffff880`03f36870 fffff800`02e7568a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatch+0xc2
fffff880`03f36a50 fffff800`02e836e0 : 00000000`00000039 fffff800`02e80800 00000000`00000030 00000000`0000000b : nt!KiGeneralProtectionFault+0x10a
fffff880`03f36be0 fffff800`02f61b1c : fffffa80`050e3f48 fffffa80`050e3f48 00000000`00000001 00000000`00000000 : nt!ObfReferenceObject+0x20
fffff880`03f36c10 fffff800`030e029f : fffffa80`050e3f48 00000000`00000001 00000000`00000000 00000000`00007532 : nt!IopDisassociateThreadIrp+0x9c
fffff880`03f36c40 fffff800`0315a71b : 00000000`00000000 ffffffff`fffe7960 00000000`00000000 00000000`00000000 : nt! ?? ::NNGAKEGL::`string'+0x1e4ca
fffff880`03f36c70 fffff800`0315e41d : 00000000`00000000 fffff800`0311a700 fffffa80`050e3b00 00000000`00000000 : nt!PspExitThread+0x58b
fffff880`03f36d30 fffff800`02e55c26 : fffff880`009e9180 00000000`00000080 fffffa80`050e3b60 00000000`00000000 : nt!PspTerminateThreadByPointer+0x4d
fffff880`03f36d80 00000000`00000000 : fffff880`03f37000 fffff880`03f31000 fffff880`03f369c0 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff800`02eb1a39 cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt!KiDispatchException+1b9
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4cc791bd
FAILURE_BUCKET_ID: X64_0x1E_c0000005_nt!KiDispatchException+1b9
