BSoD and messed up system -- dies almost daily
I have an Acer laptop with serious issues. The original hard drive was replaced while under warranty in Thailand (at supposed "authorized" Acer service center). The way they set it up is bizarre and admin rights are questionable.
BSoD happens regularly, tho so quickly that there is no notice, just a complete shutdown then dump file. It can happen any time - no discernible pattern, although if more than one program is running it is more likely.
I tried to run WinDbg but got the message below.
I am attaching the dmp files for about the past month only.
I regularly run CCleaner and Smart Defrag and have checked the entire mess with Malwarebytes, spybot S&D, Ad Aware (none of which find anything malicious). Also running Zone Alarm.
Any help or advice very welcome!
J
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Loading Dump File [C:\Windows\Minidump\060811-23197-01.dmp]
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntkrnlpa.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntkrnlpa.exe
*** ERROR: Module load completed but symbols could not be loaded for ntkrnlpa.exe
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
Built by: 7600.16385.x86fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0x82e16000 PsLoadedModuleList = 0x82f5e810
Debug session time: Wed Jun 8 20:55:32.356 2011 (UTC + 7:00)
System Uptime: 0 days 11:43:01.384
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 1000008E, {c0000005, 68, b6b07bd4, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** WARNING: Unable to verify timestamp for halmacpi.dll
*** ERROR: Module load completed but symbols could not be loaded for halmacpi.dll
*** work. ***
*** work. ***
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
Followup: MachineOwner
yowanvista
Well-Known Member
Its a hardware error caused by defective components/outdated BIOS
Stop any overclocking
Run Prime 95 again to test your CPU. Carefully the instructions in this tutorial: CPU - Stress Test with Prime95. Run 3 separate tests, one on each of the settings (Blend, Small FFTs, Large FFTs). Post back with your results.
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 00000000, Machine Check Exception
Arg2: 867ca8fc, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000, High order 32-bits of the MCi_STATUS value.
Arg4: 00000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR:  0x124_AuthenticAMD
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
STACK_TEXT:
8d71bcc4 832d2fc5 867ca8e0 8336bc28 8336bc20 nt!WheapCreateTriageDumpFromPreviousSession+0x32
8d71bce4 832d3def 8336bc20 867ca8e0 8336bc50 nt!WheapProcessWorkQueueItem+0x56
8d71bd00 83271f2b 8336bc20 00000000 857e5d48 nt!WheapWorkQueueWorkerRoutine+0x1f
8d71bd50 8341266d 00000001 aa5e63cf 00000000 nt!ExpWorkerThread+0x10d
8d71bd90 832c40d9 83271e1e 00000001 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  0x124_AuthenticAMD_PROCESSOR__UNKNOWN_PRV
