Windows 7 BSOD appears randomly!
utanfantasi
BSOD appears randomly. I haven't managed to figure out when and how it happens, but it happens, several times a day,
I've attached minidump-files and CPU-Z screens.
  • dmp.rar
Your most recent crash was caused by Daemon Tools. However, the real causer is most likely wrong memory settings in the bios. You need to take care of it first of all.
1. Memory is set wrong, 667mhz at the moment while it's rated 800mhz 6-6-6-18. Bios setup > dram.
Adjust the memory settings and re-attach the new snapshot of CPU-Z memory tab.
Also attach Rammon HTML report. http://windows7forums.com/blue-scre...mportant-every-thread-starter-please-see.html
2. Uninstall Daemon Tools for now, until your blue screens go away completely.
DuplexSecure - FAQ
3. Update drivers:
Accelerometer
Accelerometer.sys Wed Jul 08 14:41:38 2009
ENE CIR Driver for eHome
enecir.sys Sun Jun 28 22:17:30 2009
HP Hotkey
HpqKbFiltr.sys Wed Apr 29 09:48:30 2009
Realtek LAN
Rt64win7.sys Fri May 22 10:52:30 2009
Sony Ericsson Mobile Communications
seehcri.sys Wed Jan 09 03:41:35 2008
Wacom Mouse
wacomvhid.sys Mon Sep 21 19:29:14 2009
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\031411-42494-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02e02000 PsLoadedModuleList = 0xfffff800`0303fe50
Debug session time: Mon Mar 14 09:53:58.943 2011 (UTC - 4:00)
System Uptime: 0 days 1:27:31.343
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck D1, {fffff8800cbc0728, 2, 1, fffff88000fcb074}
Unable to load image \SystemRoot\System32\Drivers\sptd.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for sptd.sys
*** ERROR: Module load completed but symbols could not be loaded for sptd.sys
Probably caused by : ataport.SYS ( ataport!memmove+64 )
Followup: MachineOwner
1: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: fffff8800cbc0728, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff88000fcb074, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800030aa0e0
 fffff8800cbc0728
CURRENT_IRQL:  2
FAULTING_IP:
ataport!memmove+64
fffff880`00fcb074 488901          mov     qword ptr [rcx],rax
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xD1
PROCESS_NAME:  firefox.exe
TRAP_FRAME:  fffff88002f22ad0 -- (.trap 0xfffff88002f22ad0)
rax=0000000000000000 rbx=0000000000000000 rcx=fffff8800cbc0728
rdx=000001fff8099a70 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88000fcb074 rsp=fffff88002f22c68 rbp=fffffa8004c6b7d0
 r8=0000000000000012  r9=0000000000000002 r10=fffffa8004c2a610
r11=fffff8800cbc0728 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz ac pe nc
ataport!memmove+0x64:
fffff880`00fcb074 488901          mov     qword ptr [rcx],rax ds:b7a0:fffff880`0cbc0728=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002e71ca9 to fffff80002e72740
STACK_TEXT:
fffff880`02f22988 fffff800`02e71ca9 : 00000000`0000000a fffff880`0cbc0728 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`02f22990 fffff800`02e70920 : fffffa80`06d854a0 00000000`00000002 fffff880`074cd250 00000000`00000001 : nt!KiBugCheckDispatch+0x69
fffff880`02f22ad0 fffff880`00fcb074 : fffff880`00fc44a5 fffffa80`04c291a0 fffffa80`06d854a0 00000000`00000000 : nt!KiPageFault+0x260
fffff880`02f22c68 fffff880`00fc44a5 : fffffa80`04c291a0 fffffa80`06d854a0 00000000`00000000 fffffa80`060121d0 : ataport!memmove+0x64
fffff880`02f22c70 fffff880`00fc40ec : fffffa80`04c291a0 00000000`00000000 fffffa80`04c291a0 fffffa80`047af4a0 : ataport!IdeProcessCompletedRequests+0x18d
fffff880`02f22da0 fffff880`010794ce : fffffa80`049b6000 fffff880`02f22e88 fffffa80`04c29050 fffffa80`049b6750 : ataport!IdePortCompletionDpc+0x1a8
fffff880`02f22e60 fffffa80`049b6000 : fffff880`02f22e88 fffffa80`04c29050 fffffa80`049b6750 fffff880`02f22ea0 : sptd+0x424ce
fffff880`02f22e68 fffff880`02f22e88 : fffffa80`04c29050 fffffa80`049b6750 fffff880`02f22ea0 01cbe24f`447b52c6 : 0xfffffa80`049b6000
fffff880`02f22e70 fffffa80`04c29050 : fffffa80`049b6750 fffff880`02f22ea0 01cbe24f`447b52c6 00000000`732d2450 : 0xfffff880`02f22e88
fffff880`02f22e78 fffffa80`049b6750 : fffff880`02f22ea0 01cbe24f`447b52c6 00000000`732d2450 00000000`00000022 : 0xfffffa80`04c29050
fffff880`02f22e80 fffff880`02f22ea0 : 01cbe24f`447b52c6 00000000`732d2450 00000000`00000022 00000000`00000000 : 0xfffffa80`049b6750
fffff880`02f22e88 01cbe24f`447b52c6 : 00000000`732d2450 00000000`00000022 00000000`00000000 00000000`00000000 : 0xfffff880`02f22ea0
fffff880`02f22e90 00000000`732d2450 : 00000000`00000022 00000000`00000000 00000000`00000000 00000000`00000000 : 0x1cbe24f`447b52c6
fffff880`02f22e98 00000000`00000022 : 00000000`00000000 00000000`00000000 00000000`00000000 fffffa80`04c29118 : 0x732d2450
fffff880`02f22ea0 00000000`00000000 : 00000000`00000000 00000000`00000000 fffffa80`04c29118 fffffa80`04c29050 : 0x22
STACK_COMMAND:  kb
FOLLOWUP_IP:
ataport!memmove+64
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  ataport!memmove+64
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: ataport
IMAGE_NAME:  ataport.SYS
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc118
FAILURE_BUCKET_ID:  X64_0xD1_ataport!memmove+64
Drivers:
fffff880`08fb7000 fffff880`08fe2000   000      000.fcl      Fri Sep 26 09:11:22 2008 (48DCDF7A)
fffff880`03a6a000 fffff880`03aad000   a0g4kpa4 a0g4kpa4.SYS Fri Aug 07 09:30:20 2009 (4A7C2C6C)
fffff880`0727f000 fffff880`0728b000   Accelerometer Accelerometer.sys Wed Jul 08 14:41:38 2009 (4A54E862)
fffff880`01195000 fffff880`011ec000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02ce8000 fffff880`02d72000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03bc9000 fffff880`03bdf000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`03d52000 fffff880`03d67000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00fed000 fffff880`00ff8000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`0957d000 fffff880`09588000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00faf000 fffff880`00fb8000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fb8000 fffff880`00fe2000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`072a2000 fffff880`074ec000   athrx    athrx.sys    Sun Sep 26 23:15:20 2010 (4CA00C48)
fffff880`0777e000 fffff880`0779f000   AtiHdmi  AtiHdmi.sys  Fri Jul 24 02:33:11 2009 (4A6955A7)
fffff880`06806000 fffff880`06ffb000   atikmdag atikmdag.sys Tue Oct 26 22:29:53 2010 (4CC78EA1)
fffff880`03d67000 fffff880`03db2000   atikmpag atikmpag.sys Tue Oct 26 22:14:23 2010 (4CC78AFF)
fffff880`017f8000 fffff880`01800000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff960`00890000 fffff960`008f1000   ATMFD    ATMFD.DLL    Fri Jan 07 00:49:20 2011 (4D26A960)
fffff880`0102b000 fffff880`01037000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`02c3c000 fffff880`02c43000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03d1b000 fffff880`03d2c000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0895a000 fffff880`08978000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00670000 fffff960`00697000   cdd      cdd.dll      Wed Jan 26 01:31:34 2011 (4D3FBFC6)
fffff880`00c00000 fffff880`00c2a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cd8000 fffff880`00d98000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`013ab000 fffff880`013db000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c7a000 fffff880`00cd8000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0728b000 fffff880`0728f500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`0152b000 fffff880`0159e000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`01022000 fffff880`0102b000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`075ec000 fffff880`075fc000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`087d0000 fffff880`087de000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03cfd000 fffff880`03d1b000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03cee000 fffff880`03cfd000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01486000 fffff880`0149c000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`077dc000 fffff880`077fe000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`03c0a000 fffff880`03c4d000   dtsoftbus01 dtsoftbus01.sys Thu Jan 13 03:27:08 2011 (4D2EB75C)
fffff880`087de000 fffff880`087ea000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`08600000 fffff880`08613000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`087ea000 fffff880`087f5000   dump_msahci dump_msahci.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`087b6000 fffff880`087c2000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`03ad5000 fffff880`03bc9000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`03a00000 fffff880`03a46000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`07262000 fffff880`0727f000   enecir   enecir.sys   Sun Jun 28 22:17:30 2009 (4A48243A)
fffff880`095a3000 fffff880`095d9000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`00e00000 fffff880`00e14000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00d98000 fffff880`00de4000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`015af000 fffff880`015b9000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`015b9000 fffff880`015f3000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01600000 fffff880`0164a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`033df000 fffff800`03428000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`03a46000 fffff880`03a6a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`03aad000 fffff880`03ac6000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`07299000 fffff880`072a1080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`087c2000 fffff880`087d0000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`01652000 fffff880`0165c000   hpdskflt hpdskflt.sys Wed Jul 08 14:41:38 2009 (4A54E862)
fffff880`075d1000 fffff880`075dd000   HpqKbFiltr HpqKbFiltr.sys Wed Apr 29 09:48:30 2009 (49F85AAE)
fffff880`08892000 fffff880`0895a000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`03ce4000 fffff880`03cee000   HWiNFO64A HWiNFO64A.SYS Wed Sep 29 18:13:23 2010 (4CA3BA03)
fffff880`017ef000 fffff880`017f8000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`075b3000 fffff880`075d1000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`075dd000 fffff880`075ec000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00ba4000 fffff800`00ba7000   kdcom    kdcom.dll    Mon Mar 07 06:49:26 2011 (4D74C646)
fffff880`076a5000 fffff880`076e8000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01511000 fffff880`0152b000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`017b2000 fffff880`017dd000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`07600000 fffff880`07605200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`08665000 fffff880`0867a000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`08621000 fffff880`08644000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c59000 fffff880`00c66000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`08613000 fffff880`08621000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`07253000 fffff880`07262000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`07754000 fffff880`07761000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00f95000 fffff880`00faf000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02c02000 fffff880`02c33000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`08978000 fffff880`08990000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`08990000 fffff880`089bd000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`08800000 fffff880`0884e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0884e000 fffff880`08871000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`00fe2000 fffff880`00fed000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02ca1000 fffff880`02cac000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`011ec000 fffff880`011f6000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`014b3000 fffff880`01511000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03cd9000 fffff880`03ce4000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`017dd000 fffff880`017ef000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01660000 fffff880`01752000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03bdf000 fffff880`03beb000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`086cd000 fffff880`086e0000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`00c2a000 fffff880`00c59000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`07769000 fffff880`0777e000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`095ea000 fffff880`095f7000   netaapl64 netaapl64.sys Tue Mar 16 19:19:12 2010 (4BA011F0)
fffff880`00e14000 fffff880`00e23000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d72000 fffff880`02db7000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01752000 fffff880`017b2000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`09497000 fffff880`094ac000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`02cac000 fffff880`02cbd000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03ccd000 fffff880`03cd9000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e02000 fffff800`033df000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`01208000 fffff880`013ab000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02c33000 fffff880`02c3c000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`0867a000 fffff880`086cd000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02dc0000 fffff880`02de6000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`0100d000 fffff880`01022000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00ee1000 fffff880`00f14000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`011f6000 fffff880`011fd000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00f85000 fffff880`00f95000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0159e000 fffff880`015af000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`08ec7000 fffff880`08f6d000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0779f000 fffff880`077dc000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c66000 fffff880`00c7a000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`03db2000 fffff880`03dd6000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03dd6000 fffff880`03df1000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0765c000 fffff880`0767d000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`0767d000 fffff880`07697000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03c7c000 fffff880`03ccd000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`02c86000 fffff880`02c8f000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02c8f000 fffff880`02c98000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02c98000 fffff880`02ca1000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0144c000 fffff880`01486000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`07606000 fffff880`0761e000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`074f9000 fffff880`07532000   Rt64win7 Rt64win7.sys Fri May 22 10:52:30 2009 (4A16BC2E)
fffff880`01166000 fffff880`01195000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`08f6d000 fffff880`08f78000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`07697000 fffff880`076a3000   seehcri  seehcri.sys  Wed Jan 09 03:41:35 2008 (478488BF)
fffff880`0164a000 fffff880`01652000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`01037000 fffff880`0115d000   sptd     sptd.sys     Sun Oct 11 16:55:14 2009 (4AD24632)
fffff880`09401000 fffff880`09497000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`08e00000 fffff880`08e67000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`08f78000 fffff880`08fa5000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`086ec000 fffff880`0876b000   stwrt64  stwrt64.sys  Wed Mar 24 00:01:24 2010 (4BA98E94)
fffff880`076a3000 fffff880`076a4480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`07200000 fffff880`07253000   SynTP    SynTP.sys    Thu May 27 17:41:36 2010 (4BFEE710)
fffff880`01802000 fffff880`019ff000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`08fa5000 fffff880`08fb7000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02cdb000 fffff880`02ce8000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02cbd000 fffff880`02cdb000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03c68000 fffff880`03c7c000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00560000 fffff960`0056a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03d2c000 fffff880`03d52000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`076e8000 fffff880`076fa000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`095d9000 fffff880`095ea000   usbaapl64 usbaapl64.sys Thu Sep 16 22:19:05 2010 (4C92D019)
fffff880`0876b000 fffff880`08788000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`075a0000 fffff880`075a1f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`075a2000 fffff880`075b3000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`07593000 fffff880`075a0000   usbfilter usbfilter.sys Mon Mar 09 07:49:01 2009 (49B5022D)
fffff880`076fa000 fffff880`07754000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`07532000 fffff880`0753d000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0753d000 fffff880`07593000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`08788000 fffff880`087b5200   usbvideo usbvideo.sys Wed Mar 03 23:40:57 2010 (4B8F39D9)
fffff880`01000000 fffff880`0100d000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02c43000 fffff880`02c51000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02c51000 fffff880`02c76000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00f14000 fffff880`00f29000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00f29000 fffff880`00f85000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01400000 fffff880`0144c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`074ec000 fffff880`074f9000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`02de6000 fffff880`02dfc000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`07761000 fffff880`07769000   wacommousefilter wacommousefilter.sys Fri Feb 16 13:12:17 2007 (45D5F401)
fffff880`075fc000 fffff880`075fea00   wacomvhid wacomvhid.sys Mon Sep 21 19:29:14 2009 (4AB80C4A)
fffff880`03c4d000 fffff880`03c68000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02c76000 fffff880`02c86000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e2e000 fffff880`00ed2000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ed2000 fffff880`00ee1000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02db7000 fffff880`02dc0000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000e0000 fffff960`003f0000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`094ac000 fffff880`094bd000   WinUsb   WinUsb.sys   Mon Jul 13 20:06:28 2009 (4A5BCC04)
fffff880`07290000 fffff880`07299000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`0115d000 fffff880`01166000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`08644000 fffff880`08665000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`094bd000 fffff880`094ee000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`094ac000 fffff880`094bd000   usbaapl64.sy
    Checksum:  00000000
    ImageSize:  00011000
fffff880`094bd000 fffff880`094ca000   netaapl64.sy
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`094db000 fffff880`0950c000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`094ca000 fffff880`094db000   WinUsb.sys
    Checksum:  00000000
    ImageSize:  00011000
fffff880`09588000 fffff880`095a3000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`0950c000 fffff880`0957d000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0149c000 fffff880`014aa000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`015f3000 fffff880`015ff000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`013db000 fffff880`013e6000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`013e6000 fffff880`013f9000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
I can't find any updated drivers of any in the list.
Also, in my BIOS-setup I don't have the choice to change anything.
Daemon tools is uninstalled, otherwise I couldn't do much. I can't attach the Rammon-report. The uploader just says that there's errors in the file.
If your notebook is compatible with Windows 7, there should be compatible drivers available for it at HP support:
Realtek
HP Support & Drivers
Rammon - install, run, save result as an html file, zip and attach.
I would love to give you precise instructions but the problem is I don't know your bios. If your motherboard has support for DDR800, then you should be able to set DRAM frequency 800Mhz. Bios optimized defaults could do the job, but it will also reset all other settings in the bios and I can't guarantee it'll be safe in your case. If you are not familiar enough with your bios, send your PC to the repairs shop or have someone savvy near you to set the RAM right.
The problem isn't that I don't know how to change things in BIOS. The problem is that there are no options. Since I bought my first PC a long ago I've changed things in BIOS several times. The BIOS used for my current computer is, by far, the one with least options. There aren't really anything I can change. I could take pictures of it and attach.
Anyhow. According to HP website there is only one update I haven't done. The realtek update is done. I also attach the rammon-report.
  • RAMMon - SPD Info.rar
Can you also attach:
Absolutely!
Absolutely wrong again: you have 2x2048Mb Samsung sticks,
M4 70T5663EH3-CF7
800Mhz
6-6-6-18
1.8v
Your current setup is 667Mhz 5-5-5-15. Wrong.
Please ask someone savvy around you to set the memory correctly,
-BIOS setup>DRAM options
-Ootimized Defaults
If the motherbord has support for DDR800, should be no problem.
Really wierd since the settings in BIOS has been the same all the time.
I suppose that my motherboard has support since everything is standard.
A question that follows is if it is possible for me to change settings in BIOS? Since there are no options in my BIOS to change (basicly) any settings. I'm quite able to fix things but the problem is that I don't have the choice to.
Is there a way to get pass my bios in some way. Since it seems like the memory issue is the problem (BSOD happens three out of four times I start my computer) I would like to fix it. Is there a way?
Look, unfortunately I know nothing about your bios. What I see is that your RAM is rated:
M4 70T5663EH3-CF7
800Mhz
6-6-6-18
1.8v
And is currently set 667Mhz 5-5-5-15. Which is wrong.
You also have a bunch of old drivers that you have to update:
Accelerometer
HP Hotkey
Realtek LAN
Wacom Mouse
You're having blue screens, and this is why I suggest you do your best to update them all. Uninstall Sony Ericsson if you're not using it.
What you need to do:
1. Update old drivers.
2. If blue screens persist after you update the drivers, your memory needs to be set according to its rated specs.
