dp345
I have the BSOD Bad Pool Header problem, in addition to having error 39 (no drivers) on an IDE storage controller.
I have the BSOD appear relatively frequently, and just noticed this missing driver.
Help is appreciated.
Minidump.rar
Above link is the minidump rar
Specs: GTX 275, i7 920, 12 GB DDR3 ram, asus p6t mobo, 2 harddrives (1 sata, 1 IDE)
Hi dp345 and Welcome to the Forum.
STOP 0x00000019: BAD_POOL_HEADER
Usual causes:
Device driver
All your dump file list PCTCore64.sys as the probable cause. This is a PCTools driver.
As a Priority:
PC Tools is known to be a cause of BSOD's on many Windows 7 systems. Uninstall PC Tools, including ThreatFire. Download Link Removed due to 404 Error as its replacement. Make sure your Windows firewall is switched on!
ASACPI.sys Mon Mar 28 03:30:36 2005 This driver is notorious for causing BSOD's. There is an update here: Asus ATK0110 driver. Look under the sub-heading: Utilities. Approx. 12th one down.
Driver Install - Manual method...
Usual causes:
Device driver
As a Priority:
  1. Download the driver and extract it to a folder.
  2. Open the Device Manager.
  3. Right click the device you wish to change the drivers for. You can select Properties > Driver > Driver Details to check you have the right device.
  4. Choose Update Driver Software.
  5. Select Browse My Computer For Driver Software.
  6. Select Let me pick from a list of device drivers on my computer.
  7. Select Have disk...
  8. Select Browse..
  9. Navigate to the extracted folder and double click on the .inf file
  10. Hit OK, then Next and the driver(s) will then begin to install.
  11. After it has installed, GoTo C:\Windows\System32\Drivers. Locate the Asacpi.sys driver, right click it and check the dates under its properties. You're looking for a "Modified" date of 2009 or 2010. Occasionally it can be a bit stubborn to change.
sptd.sys Sun Oct 11 21:55:14 2009 The sptd.sys driver is notorious for causing BSOD's with Windows 7. It's a driver used and installed along with Daemon Tools and Alcohol 120 which you'll also have to uninstall.
Then use the correct (32bit or 64bit) download from Link Removed to uninstall the SPTD.SYS driver.
Make sure to select the uninstall button! DO NOT SELECT INSTALL!!
Outdated Drivers. Update:
hamachi.sys Thu Feb 19 10:36:41 2009 Link Removed due to 404 Error
lirsgt.sys Sun May 17 14:06:57 2009 Copy Protection platform by Tages SA.
RimSerial_AMD64.sys Mon Nov 24 17:01:01 2008 Virtual Serial Port driver for Blackberry by Link Removed - Invalid URL
speedfan.sys Sun Sep 24 14:26:48 2006 Update your Speedfan set up.
Bugcheck Analysis:
BugCheck 19, {20, fffff8a0024666b0, fffff8a002466940, 5290105}
Unable to load image \SystemRoot\system32\drivers\PCTCore64.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for PCTCore64.sys
*** ERROR: Module load completed but symbols could not be loaded for PCTCore64.sys
Probably caused by : PCTCore64.sys ( PCTCore64+2c982 )
Followup: MachineOwner
0: kd> !analyze -v
BAD_POOL_HEADER (19)
The pool is already corrupt at the time of the current request.
This may or may not be due to the caller.
The internal pool links must be walked to figure out a possible cause of
the problem, and then special pool applied to the suspect tags or the driver
verifier to a suspect driver.
Arguments:
Arg1: 0000000000000020, a pool block header size is corrupt.
Arg2: fffff8a0024666b0, The pool entry we were looking for within the page.
Arg3: fffff8a002466940, The next pool entry.
Arg4: 0000000005290105, (reserved)
Debugging Details:
BUGCHECK_STR:  0x19_20
POOL_ADDRESS: GetPointerFromAddress: unable to read from fffff800030ac0e0
 fffff8a0024666b0
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002fa76d3 to fffff80002e74700
STACK_TEXT:
fffff880`03354608 fffff800`02fa76d3 : 00000000`00000019 00000000`00000020 fffff8a0`024666b0 fffff8a0`02466940 : nt!KeBugCheckEx
fffff880`03354610 fffff880`00c2c982 : 00000000`00000000 fffff880`03354b40 fffff880`43544350 fffff880`03354800 : nt!ExDeferredFreePool+0x12c4
fffff880`033546c0 00000000`00000000 : fffff880`03354b40 fffff880`43544350 fffff880`03354800 00000000`00000001 : PCTCore64+0x2c982
STACK_COMMAND:  kb
FOLLOWUP_IP:
PCTCore64+2c982
fffff880`00c2c982 ??              ???
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  PCTCore64+2c982
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: PCTCore64
IMAGE_NAME:  PCTCore64.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4b96e77e
FAILURE_BUCKET_ID:  X64_0x19_20_PCTCore64+2c982
Drivers:
fffff880`10bbb000 fffff880`10bf9000   1394ohci 1394ohci.sys Tue Jul 14 01:07:12 2009 (4A5BCC30)
fffff880`0102f000 fffff880`01086000   ACPI     ACPI.sys     Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`02d6f000 fffff880`02df8000   afd      afd.sys      Mon Apr 25 03:43:58 2011 (4DB4DFEE)
fffff880`0fe27000 fffff880`0fe3d000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`011f3000 fffff880`011fe000   amdxata  amdxata.sys  Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`04274000 fffff880`0427c000   ASACPI   ASACPI.sys   Mon Mar 28 03:30:36 2005 (42476C4C)
fffff880`010b9000 fffff880`010c2000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fd4000 fffff880`00ffe000   ataport  ataport.SYS  Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`06800000 fffff880`0684f000   atksgt   atksgt.sys   Sun May 17 14:36:34 2009 (4A1012E2)
fffff960`00810000 fffff960`00871000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`02cc3000 fffff880`02cca000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`0401e000 fffff880`0402f000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`0693f000 fffff880`0695d000   bowser   bowser.sys   Wed Feb 23 05:15:06 2011 (4D6497DA)
fffff960`00780000 fffff960`007a7000   cdd      cdd.dll      unavailable (00000000)
fffff880`064a0000 fffff880`064bd000   cdfs     cdfs.sys     Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`02c90000 fffff880`02cba000   cdrom    cdrom.sys    Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00d1b000 fffff880`00ddb000   CI       CI.dll       Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`013ac000 fffff880`013dc000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00cbd000 fffff880`00d1b000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`014b3000 fffff880`01526000   cng      cng.sys      Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`0fe00000 fffff880`0fe10000   CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`0684f000 fffff880`06858000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 13:33:36 2010 (4CD94DB0)
fffff880`064f2000 fffff880`06500000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`04164000 fffff880`041e7000   csc      csc.sys      Tue Jul 14 00:24:26 2009 (4A5BC22A)
fffff880`04000000 fffff880`0401e000   dfsc     dfsc.sys     Wed Apr 27 03:57:39 2011 (4DB78623)
fffff880`04155000 fffff880`04164000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`015d9000 fffff880`015ef000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0646c000 fffff880`0648e000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`0650c000 fffff880`06515000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`06500000 fffff880`0650c000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`06515000 fffff880`06528000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`06494000 fffff880`064a0000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`04288000 fffff880`0437c000   dxgkrnl  dxgkrnl.sys  Wed Jan 26 04:22:56 2011 (4D3FA1A0)
fffff880`0437c000 fffff880`043c2000   dxgmms1  dxgmms1.sys  Wed Jan 26 04:22:12 2011 (4D3FA174)
fffff880`04267000 fffff880`04274000   fdc      fdc.sys      Tue Jul 14 01:00:54 2009 (4A5BCAB6)
fffff880`00ddb000 fffff880`00def000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0499d000 fffff880`049a8000   flpydisk flpydisk.sys Tue Jul 14 01:00:54 2009 (4A5BCAB6)
fffff880`00f16000 fffff880`00f62000   fltmgr   fltmgr.sys   Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`01537000 fffff880`01541000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01400000 fffff880`0143a000   fvevol   fvevol.sys   Tue Jul 14 00:22:15 2009 (4A5BC1A7)
fffff880`0168b000 fffff880`016d5000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff880`043f3000 fffff880`04400000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`033e0000 fffff800`03429000   hal      hal.dll      Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`0488c000 fffff880`04897000   hamachi  hamachi.sys  Thu Feb 19 10:36:41 2009 (499D3639)
fffff880`043cf000 fffff880`043f3000   HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`04800000 fffff880`0485c000   HdAudio  HdAudio.sys  Tue Jul 14 01:06:59 2009 (4A5BCC23)
fffff880`048a1000 fffff880`048ba000   HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`048ba000 fffff880`048c2080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`064e4000 fffff880`064f2000   hidusb   hidusb.sys   Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`06877000 fffff880`0693f000   HTTP     HTTP.sys     Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`017f1000 fffff880`017fa000   hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`04055000 fffff880`0406b000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`048ce000 fffff880`048dd000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`049ca000 fffff880`049d8000   kbdhid   kbdhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00ba0000 fffff800`00baa000   kdcom    kdcom.dll    Sat Feb 05 12:21:45 2011 (4D4D40D9)
fffff880`048ee000 fffff880`04931000   ks       ks.sys       Tue Jul 14 01:00:31 2009 (4A5BCA9F)
fffff880`01499000 fffff880`014b3000   ksecdd   ksecdd.sys   Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`01660000 fffff880`0168b000   ksecpkg  ksecpkg.sys  Fri Dec 11 06:03:32 2009 (4B21E0B4)
fffff880`0648e000 fffff880`06493200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`064dc000 fffff880`064e3500   Lachesis Lachesis.sys Fri Oct 16 14:09:12 2009 (4AD87078)
fffff880`06858000 fffff880`06865000   lirsgt   lirsgt.sys   Sun May 17 14:06:57 2009 (4A100BF1)
fffff880`0657f000 fffff880`06594000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0653b000 fffff880`0655e000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`06528000 fffff880`0652cf80   Lycosa   Lycosa.sys   Wed Sep 30 05:45:50 2009 (4AC2E27E)
fffff880`00c65000 fffff880`00ca9000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`0fe18000 fffff880`0fe27000   modem    modem.sys    Tue Jul 14 01:10:48 2009 (4A5BCD08)
fffff880`0652d000 fffff880`0653b000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`048dd000 fffff880`048ec000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`049bd000 fffff880`049ca000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00fba000 fffff880`00fd4000   mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`0695d000 fffff880`0698a000   mrxsmb   mrxsmb.sys   Wed May 04 03:51:06 2011 (4DC0BF1A)
fffff880`0698a000 fffff880`069d8000   mrxsmb10 mrxsmb10.sys Wed May 04 03:51:08 2011 (4DC0BF1C)
fffff880`069d8000 fffff880`069fb000   mrxsmb20 mrxsmb20.sys Wed May 04 03:51:05 2011 (4DC0BF19)
fffff880`02d28000 fffff880`02d33000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01086000 fffff880`01090000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`0143b000 fffff880`01499000   msrpc    msrpc.sys    Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`0414a000 fffff880`04155000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`015c7000 fffff880`015d9000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`016e0000 fffff880`017d2000   ndis     ndis.sys     Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`0fe61000 fffff880`0fe6d000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`0fe6d000 fffff880`0fe9c000   ndiswan  ndiswan.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`049a8000 fffff880`049bd000   NDProxy  NDProxy.SYS  Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`02c7f000 fffff880`02c8e000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02c00000 fffff880`02c45000   netbt    netbt.sys    Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`01600000 fffff880`01660000   NETIO    NETIO.SYS    Fri Apr 09 03:43:59 2010 (4BBE946F)
fffff880`02d33000 fffff880`02d44000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0413e000 fffff880`0414a000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02e04000 fffff800`033e0000   nt       ntkrnlmp.exe Sat Apr 09 05:14:44 2011 (4D9FDD34)
fffff880`01209000 fffff880`013ac000   Ntfs     Ntfs.sys     Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`02cba000 fffff880`02cc3000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`10b4f000 fffff880`10b54000   nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`0fea1000 fffff880`10b4f000   nvlddmkm nvlddmkm.sys Sat May 21 05:07:04 2011 (4DD73A68)
fffff880`02c59000 fffff880`02c7f000   pacer    pacer.sys    Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`0109d000 fffff880`010b2000   partmgr  partmgr.sys  Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00f62000 fffff880`00f95000   pci      pci.sys      Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`010b2000 fffff880`010b9000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00faa000 fffff880`00fba000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`00c00000 fffff880`00c3a000   PCTCore64 PCTCore64.sys Wed Mar 10 00:27:42 2010 (4B96E77E)
fffff880`01526000 fffff880`01537000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`07abd000 fffff880`07b63000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0642f000 fffff880`0646c000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00ca9000 fffff880`00cbd000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00c3a000 fffff880`00c45e00   PxHlpa64 PxHlpa64.sys Wed Jun 24 00:16:35 2009 (4A416253)
fffff880`0fe3d000 fffff880`0fe61000   rasl2tp  rasl2tp.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`0406b000 fffff880`04086000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04086000 fffff880`040a7000   raspptp  raspptp.sys  Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`04872000 fffff880`0488c000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`040ed000 fffff880`0413e000   rdbss    rdbss.sys    Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`048c3000 fffff880`048ce000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`02d0d000 fffff880`02d16000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`02d16000 fffff880`02d1f000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`02d1f000 fffff880`02d28000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`0158d000 fffff880`015c7000   rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`04897000 fffff880`0489ec00   RimSerial_AMD64 RimSerial_AMD64.sys Mon Nov 24 17:01:01 2008 (492ADDCD)
fffff880`0fe10000 fffff880`0fe18000   RootMdm  RootMdm.sys  Tue Jul 14 01:10:47 2009 (4A5BCD07)
fffff880`06594000 fffff880`065ac000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`10b54000 fffff880`10bbb000   Rt64win7 Rt64win7.sys Fri Jan 21 07:34:00 2011 (4D3936E8)
fffff880`040d3000 fffff880`040ed000   SCDEmu   SCDEmu.SYS   Mon Apr 12 09:52:25 2010 (4BC2DF49)
fffff880`01000000 fffff880`0102f000   SCSIPORT SCSIPORT.SYS Tue Jul 14 01:01:04 2009 (4A5BCAC0)
fffff880`017ea000 fffff880`017f1000   speedfan speedfan.sys Sun Sep 24 14:26:48 2006 (45168798)
fffff880`017e2000 fffff880`017ea000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`010c4000 fffff880`011ea000   sptd     sptd.sys     Sun Oct 11 21:55:14 2009 (4AD24632)
fffff880`048ec000 fffff880`048ed480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01802000 fffff880`019ff000   tcpip    tcpip.sys    Mon Apr 25 03:47:33 2011 (4DB4E0C5)
fffff880`02d62000 fffff880`02d6f000   TDI      TDI.SYS      Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`02d44000 fffff880`02d62000   tdx      tdx.sys      Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`040bf000 fffff880`040d3000   termdd   termdd.sys   Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`00540000 fffff960`0054a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`0402f000 fffff880`04055000   tunnel   tunnel.sys   Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`04931000 fffff880`04943000   umbus    umbus.sys    Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`064bd000 fffff880`064da000   usbccgp  usbccgp.sys  Tue Jul 14 01:06:45 2009 (4A5BCC15)
fffff880`064da000 fffff880`064dbf00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`04256000 fffff880`04267000   usbehci  usbehci.sys  Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`04943000 fffff880`0499d000   usbhub   usbhub.sys   Tue Jul 14 01:07:09 2009 (4A5BCC2D)
fffff880`04200000 fffff880`04256000   USBPORT  USBPORT.SYS  Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`043c2000 fffff880`043cf000   usbuhci  usbuhci.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`01090000 fffff880`0109d000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`02cca000 fffff880`02cd8000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0489f000 fffff880`048a0d80   vHidDev  vHidDev.sys  Mon Dec 21 13:49:58 2009 (4B2F7D06)
fffff880`02cd8000 fffff880`02cfd000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`017d2000 fffff880`017e2000   vmstorfl vmstorfl.sys Tue Jul 14 00:42:54 2009 (4A5BC67E)
fffff880`00f95000 fffff880`00faa000   volmgr   volmgr.sys   Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`01541000 fffff880`0158d000   volsnap  volsnap.sys  Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`00c46000 fffff880`00c61000   wanarp   wanarp.sys   Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`02cfd000 fffff880`02d0d000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e63000 fffff880`00f07000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f07000 fffff880`00f16000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02c50000 fffff880`02c59000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00040000 fffff960`00352000   win32k   win32k.sys   unavailable (00000000)
fffff880`0427c000 fffff880`04285000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`011ea000 fffff880`011f3000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`02c45000 fffff880`02c50000   ws2ifsl  ws2ifsl.sys  Tue Jul 14 01:10:33 2009 (4A5BCCF9)
fffff880`0655e000 fffff880`0657f000   WudfPf   WudfPf.sys   Tue Jul 14 01:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`015ef000 fffff880`015fd000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`013dc000 fffff880`013e8000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`016d5000 fffff880`016de000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`013e8000 fffff880`013fb000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`049e3000 fffff880`049e5000   USBD.SYS
    Checksum:  00000000
    ImageSize:  00002000
fffff880`049d8000 fffff880`049e3000   LVUSBS64.sys
    Checksum:  00000000
    ImageSize:  0000B000
Let us know how it goes.
HTH.
Excellent information, I appreciate it.
I did everything, however I do not have daemon tools, but it has been uninstalled for some time. I still went ahead to uninstall the driver.
As for the driver update (ATK0110), I simply double clicked the bat file which rebooted... so I presume it worked?
So far so good, I'll update if anything changes
The only way to know for sure (with the ATK110) is to check its dates as detailed above. You really need to make sure it gets changed as it's a time bomb waiting to happen!
Although you've uninstalled D Tools, it does tend to leave that (sptd.sys) behind.
