Windows 7 BSOD can you help me ?
Can "we" help you? I don't know, but we'll try. :)
0x7E_nt!ExFreePoolWithTag
1. Update or uninstall ASUS Probe
AsIO.sys Mon Dec 17 04:11:49 2007
2. Update Marvell SATA controller
mv61xx.sys Thu Mar 19 23:48:21 2009
3. Update Realtek LAN
Rt64win7.sys Fri May 22 10:52:30 2009
4. Update VIA Audio
viahduaa.sys Tue Jun 02 04:55:21 2009
5. Uninstall Elaborate Bytes AG Virtual Clone
VClone.sys Sun Aug 09 17:25:45 2009
6. Replace Avast with MSE:
avast! Uninstall Utility
Link Removed due to 404 Error
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\031211-26161-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02a61000 PsLoadedModuleList = 0xfffff800`02c9ee50
Debug session time: Fri Mar 11 19:02:57.226 2011 (UTC - 5:00)
System Uptime: 0 days 0:22:42.927
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1000007E, {ffffffffc0000005, fffff80002c060f3, fffff880031bd8b8, fffff880031bd120}
Probably caused by : ntkrnlmp.exe ( nt!ExFreePoolWithTag+43 )
Followup: MachineOwner
3: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002c060f3, The address that the exception occurred at
Arg3: fffff880031bd8b8, Exception Record Address
Arg4: fffff880031bd120, Context Record Address
Debugging Details:
FAULTING_IP:
fffff800`02c060f3 418b45f0        mov     eax,dword ptr [r13-10h]
EXCEPTION_RECORD:  fffff880031bd8b8 -- (.exr 0xfffff880031bd8b8)
ExceptionAddress: fffff80002c060f3 (nt!ExFreePoolWithTag+0x0000000000000043)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: 00000000fff7ffee
Attempt to read from address 00000000fff7ffee
CONTEXT:  fffff880031bd120 -- (.cxr 0xfffff880031bd120)
rax=0000000000000000 rbx=fffff8a0086c24a8 rcx=00000000fff7fffe
rdx=0000000000000000 rsi=0000000000000000 rdi=00000000fff7ffff
rip=fffff80002c060f3 rsp=fffff880031bdaf0 rbp=00000000ffffffff
 r8=fffffa80039e8040  r9=0000000000000800 r10=fffff880031bdc50
r11=fffff80002cd6fa0 r12=0000000000000000 r13=00000000fff7fffe
r14=0000000000000000 r15=0000000000000001
iopl=0         nv up ei pl nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010202
nt!ExFreePoolWithTag+0x43:
fffff800`02c060f3 418b45f0        mov     eax,dword ptr [r13-10h] ds:002b:00000000`fff7ffee=????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  00000000fff7ffee
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002d090e0
 00000000fff7ffee
FOLLOWUP_IP:
BUGCHECK_STR:  0x7E
LAST_CONTROL_TRANSFER:  from fffff80002e02a41 to fffff80002c060f3
STACK_TEXT:
fffff880`031bdaf0 fffff800`02e02a41 : 00000000`00000000 00000000`00000000 fffff800`02cd6fa0 00000000`00000000 : nt!ExFreePoolWithTag+0x43
fffff880`031bdba0 fffff800`02dc37bf : fffff8a0`086c24a8 fffff880`031bdc44 00000000`00000001 00000000`00000000 : nt! ?? ::NNGAKEGL::`string'+0x10341
fffff880`031bdbd0 fffff800`02d28fde : fffff8a0`086c24a8 fffff880`031bdc44 00000000`00000000 00000000`00000000 : nt!CmpCleanUpKcbCacheWithLock+0x2b
fffff880`031bdc00 fffff800`02ade961 : fffff800`02d28ca4 fffff800`02c765f8 fffffa80`039e8040 00000000`00000000 : nt!CmpDelayCloseWorker+0x33a
fffff880`031bdcb0 fffff800`02d747c6 : 00000554`00000000 fffffa80`039e8040 00000000`00000080 fffffa80`039d4040 : nt!ExpWorkerThread+0x111
fffff880`031bdd40 fffff800`02aafc26 : fffff880`02f63180 fffffa80`039e8040 fffff880`02f6dfc0 00000554`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`031bdd80 00000000`00000000 : fffff880`031be000 fffff880`031b8000 fffff880`031bd9f0 00000000`00000000 : nt!KxStartSystemThread+0x16
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!ExFreePoolWithTag+43
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4cc791bd
STACK_COMMAND:  .cxr 0xfffff880031bd120 ; kb
FAILURE_BUCKET_ID:  X64_0x7E_nt!ExFreePoolWithTag+43
Drivers:
fffff880`04239000 fffff880`04277000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f07000 fffff880`00f5e000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`03e20000 fffff880`03eaa000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04fb6000 fffff880`04fcc000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`04131000 fffff880`04146000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`01151000 fffff880`0115c000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`043f8000 fffff880`04400000   ASACPI   ASACPI.sys   Wed May 13 21:25:17 2009 (4A0B72FD)
fffff880`04104000 fffff880`0410b000   AsIO     AsIO.sys     Mon Dec 17 04:11:49 2007 (47663D55)
fffff880`03ff6000 fffff880`03fff000   aswFsBlk aswFsBlk.SYS Wed Feb 23 09:54:56 2011 (4D651FC0)
fffff880`00dbc000 fffff880`00df6000   aswMonFlt aswMonFlt.sys Wed Feb 23 09:55:04 2011 (4D651FC8)
fffff880`03eaa000 fffff880`03eb4000   aswRdr   aswRdr.SYS   Wed Feb 23 09:55:11 2011 (4D651FCF)
fffff880`02c5b000 fffff880`02cdb000   aswSnx   aswSnx.SYS   Wed Feb 23 09:56:59 2011 (4D65203B)
fffff880`040b9000 fffff880`04104000   aswSP    aswSP.SYS    Wed Feb 23 09:57:02 2011 (4D65203E)
fffff880`02d90000 fffff880`02da0000   aswTdi   aswTdi.SYS   Wed Feb 23 09:55:51 2011 (4D651FF7)
fffff880`00e1a000 fffff880`00e23000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e23000 fffff880`00e4d000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`02c00000 fffff880`02c22000   AtiHdmi  AtiHdmi.sys  Thu Jan 28 20:03:36 2010 (4B6233E8)
fffff880`04146000 fffff880`0417a000   atikmpag atikmpag.sys Tue Mar 02 22:07:33 2010 (4B8DD275)
fffff880`019cc000 fffff880`019d4000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff880`0489f000 fffff880`04f0e000   atipmdag atipmdag.sys Tue Mar 02 22:47:08 2010 (4B8DDBBC)
fffff960`00880000 fffff960`008e1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`02ce4000 fffff880`02ceb000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`040a8000 fffff880`040b9000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0555a000 fffff880`05578000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006d0000 fffff960`006f7000   cdd      cdd.dll      unavailable (00000000)
fffff880`01813000 fffff880`0183d000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cfc000 fffff880`00dbc000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`0199c000 fffff880`019cc000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c9e000 fffff880`00cfc000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0105e000 fffff880`010d1000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`04fa6000 fffff880`04fb6000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`061a4000 fffff880`061b2000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04007000 fffff880`0408a000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`0408a000 fffff880`040a8000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03e00000 fffff880`03e0f000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01986000 fffff880`0199c000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`02c22000 fffff880`02c44000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`061be000 fffff880`061c7000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`061b2000 fffff880`061be000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`061c7000 fffff880`061da000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06000000 fffff880`0600c000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0429a000 fffff880`0438e000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`0438e000 fffff880`043d4000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`03feb000 fffff880`03ff6000   ElbyCDIO ElbyCDIO.sys Thu Dec 17 17:25:16 2009 (4B2AAFCC)
fffff880`011a8000 fffff880`011bc000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0115c000 fffff880`011a8000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01200000 fffff880`0120a000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0194c000 fffff880`01986000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01400000 fffff880`0144a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02a18000 fffff800`02a61000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`043d4000 fffff880`043f8000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0187a000 fffff880`01893000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`061e8000 fffff880`061f0080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`061da000 fffff880`061e8000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`05492000 fffff880`0555a000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01943000 fffff880`0194c000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04f70000 fffff880`04f8e000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05471000 fffff880`05479000   iPodDrv  iPodDrv.sys  Fri Apr 10 00:07:40 2009 (49DEC60C)
fffff880`04f8e000 fffff880`04f9d000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00ba2000 fffff800`00bac000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04189000 fffff880`041cc000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013d0000 fffff880`013ea000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`015a2000 fffff880`015cd000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`041f3000 fffff880`041f8200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`02c44000 fffff880`02c59000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`019d4000 fffff880`019f7000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c7d000 fffff880`00c8a000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`03e0f000 fffff880`03e1d000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04890000 fffff880`0489f000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`061f3000 fffff880`06200000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e00000 fffff880`00e1a000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`05578000 fffff880`05590000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`05590000 fffff880`055bd000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`05400000 fffff880`0544e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0544e000 fffff880`05471000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`02d49000 fffff880`02d54000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f67000 fffff880`00f71000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01000000 fffff880`0105e000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03fe0000 fffff880`03feb000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01931000 fffff880`01943000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`010dc000 fffff880`01122000   mv61xx   mv61xx.sys   Thu Mar 19 23:48:21 2009 (49C31205)
fffff880`01450000 fffff880`01542000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04ff0000 fffff880`04ffc000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04800000 fffff880`0482f000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`041de000 fffff880`041f3000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03f28000 fffff880`03f37000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03eb4000 fffff880`03ef9000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01542000 fffff880`015a2000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02d54000 fffff880`02d65000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03fd4000 fffff880`03fe0000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a61000 fffff800`0303e000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`0122d000 fffff880`013d0000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02cdb000 fffff880`02ce4000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`03f02000 fffff880`03f28000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00fb1000 fffff880`00fc6000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f71000 fffff880`00fa4000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fdb000 fffff880`00fe2000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fe2000 fffff880`00ff2000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013ea000 fffff880`013fb000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`06ceb000 fffff880`06d91000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0183d000 fffff880`0187a000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c8a000 fffff880`00c9e000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`011bc000 fffff880`011c7e00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
fffff880`04fcc000 fffff880`04ff0000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0482f000 fffff880`0484a000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0484a000 fffff880`0486b000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`0486b000 fffff880`04885000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03f83000 fffff880`03fd4000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`04885000 fffff880`04890000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02d2e000 fffff880`02d37000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`072b7000 fffff880`072e5000   rdpdr    rdpdr.sys    Mon Jul 13 20:18:02 2009 (4A5BCEBA)
fffff880`02d37000 fffff880`02d40000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02d40000 fffff880`02d49000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`072ff000 fffff880`07337000   RDPWD    RDPWD.SYS    Mon Jul 13 20:16:47 2009 (4A5BCE6F)
fffff880`018f7000 fffff880`01931000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`0120a000 fffff880`01222000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04200000 fffff880`04239000   Rt64win7 Rt64win7.sys Fri May 22 10:52:30 2009 (4A16BC2E)
fffff880`01122000 fffff880`01151000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`06d91000 fffff880`06d9c000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`04f64000 fffff880`04f70000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03f37000 fffff880`03f54000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`018ef000 fffff880`018f7000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`07221000 fffff880`072b7000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`06c00000 fffff880`06c67000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`06d9c000 fffff880`06dc9000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04293000 fffff880`04294480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01602000 fffff880`017ff000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`06dc9000 fffff880`06ddb000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02d83000 fffff880`02d90000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`072e5000 fffff880`072f0000   tdtcp    tdtcp.sys    Mon Jul 13 20:16:32 2009 (4A5BCE60)
fffff880`02d65000 fffff880`02d83000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03f6f000 fffff880`03f83000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00540000 fffff960`0054a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`072f0000 fffff880`072ff000   tssecsrv tssecsrv.sys Mon Jul 13 20:16:41 2009 (4A5BCE69)
fffff880`0410b000 fffff880`04131000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`041cc000 fffff880`041de000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`061f1000 fffff880`061f2f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04282000 fffff880`04293000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`02da0000 fffff880`02dfa000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04277000 fffff880`04282000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04f0e000 fffff880`04f64000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0417a000 fffff880`04189000   VClone   VClone.sys   Sun Aug 09 17:25:45 2009 (4A7F3ED9)
fffff880`00fa4000 fffff880`00fb1000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02ceb000 fffff880`02cf9000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`06013000 fffff880`061a4000   viahduaa viahduaa.sys Tue Jun 02 04:55:21 2009 (4A24E8F9)
fffff880`02cf9000 fffff880`02d1e000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`015cd000 fffff880`015dd000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00fc6000 fffff880`00fdb000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`018a3000 fffff880`018ef000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`03f54000 fffff880`03f6f000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02d1e000 fffff880`02d2e000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e54000 fffff880`00ef8000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ef8000 fffff880`00f07000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03ef9000 fffff880`03f02000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000c0000 fffff960`003d0000   win32k   win32k.sys   unavailable (00000000)
fffff880`04f9d000 fffff880`04fa6000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f5e000 fffff880`00f67000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`015dd000 fffff880`015fe000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`019d4000 fffff880`019e2000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`019e2000 fffff880`019ee000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`019ee000 fffff880`019f7000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01800000 fffff880`01813000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Just received another BSOD after doing what you stated above ill attache this DMP files aswell
hopefully you can pinpoint the issue this time aswell thank you
  • 031611-25849-01.rar
BugCheck 23, {e00e6, fffff8800318c7e8, fffff8800318c050, fffff80002a92982}
FAT_FILE_SYSTEM (23)
EXCEPTION_RECORD: fffff8800318c7e8 -- (.exr 0xfffff8800318c7e8)
ExceptionAddress: fffff80002a92982 (nt!ExpInterlockedPushEntrySList+0x0000000000000022)
NumberParameters: 2
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
Probably caused by : fastfat.SYS ( fastfat!FatDeleteFcb+d6 )
1. You haven't updated a single driver of those I listed, update them.
2. CMD > chkdsk /f
3. HDDScan
PassMark DiskCheckup - SMART hard drive monitoring utility
HD Tune website
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\031611-25849-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a1f000 PsLoadedModuleList = 0xfffff800`02c5ce50
Debug session time: Wed Mar 16 01:04:37.386 2011 (UTC - 4:00)
System Uptime: 0 days 3:51:06.087
2: kd> !analyze -v
    If you see FatExceptionFilter on the stack then the 2nd and 3rd
    parameters are the exception record and context record. Do a .cxr
    on the 3rd parameter and then kb to obtain a more informative stack
    trace.
Arguments:
Arg1: 00000000000e00e6
Arg2: fffff8800318c7e8
Arg3: fffff8800318c050
Arg4: fffff80002a92982
Debugging Details:
NumberParameters: 2
CONTEXT:  fffff8800318c050 -- (.cxr 0xfffff8800318c050)
rax=00000003c54a0014 rbx=fffff8a00bf4b0f0 rcx=fff7f8a00bd5cab1
rdx=fffff8a00bd57531 rsi=fffff8800318cbd8 rdi=fffff8800318cb10
rip=fffff80002a92982 rsp=fffff8800318ca20 rbp=0000000000000000
 r8=fffff8a00bd57530  r9=0000000000000050 r10=fffff80002c13280
r11=fff7f8a00bd5cab0 r12=0000000000000504 r13=0000000000000000
r14=0000000000000503 r15=fffff8a00963b8e0
iopl=0         nv up ei pl nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00210206
nt!ExpInterlockedPushEntrySList+0x22:
fffff800`02a92982 4d8903          mov     qword ptr [r11],r8 ds:002b:fff7f8a0`0bd5cab0=????????????????
CURRENT_IRQL:  0
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cc70e0
 ffffffffffffffff
FOLLOWUP_IP:
fffff880`05f6ff4e 66443923        cmp     word ptr [rbx],r12w
FAULTING_IP:
nt!ExpInterlockedPushEntrySList+22
BUGCHECK_STR:  0x23
LAST_CONTROL_TRANSFER:  from fffff80002a65c0a to fffff80002a92982
STACK_TEXT:
fffff880`0318ca20 fffff800`02a65c0a : 00000000`00000504 fffff800`02d7c5a6 00000000`6d665346 fffff8a0`0963b8e0 : nt!ExpInterlockedPushEntrySList+0x22
fffff880`0318ca30 fffff800`02a66e36 : 00000000`00000501 fffff880`0318cb10 00000000`00000503 00000000`00000504 : nt!FsRtlUninitializeBaseMcb+0x52
fffff880`0318ca60 fffff880`05f6ff4e : fffff8a0`0bf4b010 fffffa80`039fe1a0 fffff8a0`0bf4b010 fffff880`0318cbd8 : nt!FsRtlUninitializeLargeMcb+0x2a
fffff880`0318ca90 fffff880`05f56599 : 00000000`00000002 fffff800`02c345a0 fffff8a0`0963b8f0 fffffa80`057eab10 : fastfat!FatDeleteFcb+0xd6
fffff880`0318cad0 fffff880`05f5623b : fffffa80`057eab10 fffff8a0`0bf4b010 00000000`00000000 00000000`00000000 : fastfat!FatCommonClose+0x2e1
fffff880`0318cbd0 fffff880`05f55e83 : 00000000`00000000 00000000`0000000c fffff8a0`0963b8f0 fffffa80`057eab10 : fastfat!FatFspClose+0x3a3
fffff880`0318cc50 fffff800`02d89943 : 00000000`00000000 fffffa80`04eb26a0 fffffa80`04eb26a0 fffffa80`039fe1a0 : fastfat!FatCloseWorker+0x17
fffff880`0318cc80 fffff800`02a9c961 : fffff800`02c34500 fffff800`02d89920 fffffa80`039fe1a0 00000000`00000002 : nt!IopProcessWorkItem+0x23
fffff880`0318ccb0 fffff800`02d327c6 : 00000500`00000000 fffffa80`039fe1a0 00000000`00000080 fffffa80`039d4040 : nt!ExpWorkerThread+0x111
fffff880`0318cd40 fffff800`02a6dc26 : fffff880`02f63180 fffffa80`039fe1a0 fffff880`02f6dfc0 00000500`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`0318cd80 00000000`00000000 : fffff880`0318d000 fffff880`03187000 fffff880`0318c840 00000000`00000000 : nt!KxStartSystemThread+0x16
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  fastfat!FatDeleteFcb+d6
MODULE_NAME: fastfat
IMAGE_NAME:  fastfat.SYS
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc1f0
STACK_COMMAND:  .cxr 0xfffff8800318c050 ; kb
FAILURE_BUCKET_ID:  X64_0x23_fastfat!FatDeleteFcb+d6
Drivers:
fffff880`03fbe000 fffff880`03ffc000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f62000 fffff880`00fb9000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02ce4000 fffff880`02d6e000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`00dd9000 fffff880`00def000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`03f3c000 fffff880`03f51000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0105f000 fffff880`0106a000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`04811000 fffff880`04819000   ASACPI   ASACPI.sys   Wed May 13 21:25:17 2009 (4A0B72FD)
fffff880`03f0f000 fffff880`03f16000   AsIO     AsIO.sys     Mon Dec 17 04:11:49 2007 (47663D55)
fffff880`00d60000 fffff880`00d69000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00d69000 fffff880`00d93000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`04200000 fffff880`04222000   AtiHdmi  AtiHdmi.sys  Thu Jan 28 20:03:36 2010 (4B6233E8)
fffff880`03f51000 fffff880`03f85000   atikmpag atikmpag.sys Tue Mar 02 22:07:33 2010 (4B8DD275)
fffff880`0196c000 fffff880`01974000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff880`04822000 fffff880`04e91000   atipmdag atipmdag.sys Tue Mar 02 22:47:08 2010 (4B8DDBBC)
fffff960`00980000 fffff960`009e1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`0183a000 fffff880`01841000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03efe000 fffff880`03f0f000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`054f2000 fffff880`05510000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00600000 fffff960`00627000   cdd      cdd.dll      unavailable (00000000)
fffff880`019aa000 fffff880`019d4000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`0193c000 fffff880`0196c000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d02000 fffff880`00d60000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01134000 fffff880`011a7000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`015ee000 fffff880`015fe000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`061e0000 fffff880`061ee000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03e5d000 fffff880`03ee0000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03ee0000 fffff880`03efe000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02cbf000 fffff880`02cce000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01926000 fffff880`0193c000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05edd000 fffff880`05eff000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06000000 fffff880`06009000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`061ee000 fffff880`061fa000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06009000 fffff880`0601c000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0601c000 fffff880`06028000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04e91000 fffff880`04f85000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`04f85000 fffff880`04fcb000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`02cb4000 fffff880`02cbf000   ElbyCDIO ElbyCDIO.sys Thu Dec 17 17:25:16 2009 (4B2AAFCC)
fffff880`05f47000 fffff880`05f7d000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`010b6000 fffff880`010ca000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0106a000 fffff880`010b6000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`018ec000 fffff880`01926000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0148b000 fffff880`014d5000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02ffc000 fffff800`03045000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04fcb000 fffff880`04fef000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`05f13000 fffff880`05f2c000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`06045000 fffff880`0604d080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`05f05000 fffff880`05f13000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0542a000 fffff880`054f2000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`018e3000 fffff880`018ec000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`01000000 fffff880`0101e000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`055d6000 fffff880`055de000   iPodDrv  iPodDrv.sys  Fri Apr 10 00:07:40 2009 (49DEC60C)
fffff880`02df1000 fffff880`02e00000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00bc8000 fffff800`00bd2000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0431f000 fffff880`04362000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`05eff000 fffff880`05f04200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`05fc1000 fffff880`05fd6000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05f7d000 fffff880`05fa0000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00ce1000 fffff880`00cee000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`05f39000 fffff880`05f47000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`042ff000 fffff880`0430e000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05f2c000 fffff880`05f39000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00cc0000 fffff880`00cda000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`01800000 fffff880`01831000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`055c6000 fffff880`055d6000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`05510000 fffff880`05528000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`05528000 fffff880`05555000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`05555000 fffff880`055a3000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`055a3000 fffff880`055c6000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`019dd000 fffff880`019e8000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fc2000 fffff880`00fcc000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010d6000 fffff880`01134000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02ca9000 fffff880`02cb4000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`018d1000 fffff880`018e3000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`00d93000 fffff880`00dd9000   mv61xx   mv61xx.sys   Thu Mar 19 23:48:21 2009 (49C31205)
fffff880`014fc000 fffff880`015ee000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04263000 fffff880`0426f000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0426f000 fffff880`0429e000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`043ce000 fffff880`043e3000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02de2000 fffff880`02df1000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d6e000 fffff880`02db3000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`055de000 fffff880`055f3000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`019e8000 fffff880`019f9000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02c9d000 fffff880`02ca9000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a1f000 fffff800`02ffc000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`01259000 fffff880`013fc000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01831000 fffff880`0183a000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02dbc000 fffff880`02de2000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e0d000 fffff880`00e22000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00fcc000 fffff880`00fff000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e93000 fffff880`00e9a000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e9a000 fffff880`00eaa000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`06e96000 fffff880`06f3c000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05ea0000 fffff880`05edd000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cee000 fffff880`00d02000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`010ca000 fffff880`010d5e00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
fffff880`0423f000 fffff880`04263000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0429e000 fffff880`042b9000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`042b9000 fffff880`042da000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`042da000 fffff880`042f4000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02c4c000 fffff880`02c9d000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`042f4000 fffff880`042ff000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01884000 fffff880`0188d000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`05e00000 fffff880`05e2e000   rdpdr    rdpdr.sys    Mon Jul 13 20:18:02 2009 (4A5BCEBA)
fffff880`0188d000 fffff880`01896000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019d4000 fffff880`019dd000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`05e2e000 fffff880`05e66000   RDPWD    RDPWD.SYS    Mon Jul 13 20:16:47 2009 (4A5BCE6F)
fffff880`01897000 fffff880`018d1000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`05fd6000 fffff880`05fee000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`03f85000 fffff880`03fbe000   Rt64win7 Rt64win7.sys Fri May 22 10:52:30 2009 (4A16BC2E)
fffff880`01030000 fffff880`0105f000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`06f3c000 fffff880`06f47000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`02cce000 fffff880`02cda000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02c00000 fffff880`02c1d000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`014e5000 fffff880`014ed000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06e00000 fffff880`06e96000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`06f86000 fffff880`06fed000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`06f47000 fffff880`06f74000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`0431d000 fffff880`0431e480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`06f74000 fffff880`06f86000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`014ed000 fffff880`014fa000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`06fed000 fffff880`06ff8000   tdtcp    tdtcp.sys    Mon Jul 13 20:16:32 2009 (4A5BCE60)
fffff880`01235000 fffff880`01253000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02c38000 fffff880`02c4c000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00580000 fffff960`0058a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`05400000 fffff880`0540f000   tssecsrv tssecsrv.sys Mon Jul 13 20:16:41 2009 (4A5BCE69)
fffff880`03f16000 fffff880`03f3c000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04362000 fffff880`04374000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`06043000 fffff880`06044f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04800000 fffff880`04811000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04374000 fffff880`043ce000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04fef000 fffff880`04ffa000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`03e00000 fffff880`03e56000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`06028000 fffff880`06043000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`0430e000 fffff880`0431d000   VClone   VClone.sys   Sun Aug 09 17:25:45 2009 (4A7F3ED9)
fffff880`00e00000 fffff880`00e0d000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01841000 fffff880`0184f000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`0604f000 fffff880`061e0000   viahduaa viahduaa.sys Tue Jun 02 04:55:21 2009 (4A24E8F9)
fffff880`0184f000 fffff880`01874000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`014d5000 fffff880`014e5000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e22000 fffff880`00e37000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e37000 fffff880`00e93000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`011a7000 fffff880`011f3000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02c1d000 fffff880`02c38000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01874000 fffff880`01884000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00eaf000 fffff880`00f53000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f53000 fffff880`00f62000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02db3000 fffff880`02dbc000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000b0000 fffff960`003c0000   win32k   win32k.sys   unavailable (00000000)
fffff880`04819000 fffff880`04822000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fb9000 fffff880`00fc2000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`05fa0000 fffff880`05fc1000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`01974000 fffff880`01982000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01982000 fffff880`0198e000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0198e000 fffff880`01997000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01997000 fffff880`019aa000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
