CLOCK_WATCHDOG_TIMEOUT_4_PROC
Bug Check 0x101: CLOCK_WATCHDOG_TIMEOUT
1. Rename them to .old in C:\Windows\system32:
PxHelp20.sys Tue Oct 28 14:25:49 2003
int15.sys Wed Oct 01 01:29:49 2003
2. Update drivers:
nvlddmkm.sys Sat Oct 31 04:37:52 2009
nvhda32v.sys Fri Aug 21 16:23:35 2009
nvBridge.kmd Sat Oct 31 04:21:51 2009
NVIDIA
HECI.sys Thu Sep 17 15:54:12 2009
Intel(R) Management Engine Interface
DKbFltr.sys Wed Mar 25 23:10:12 2009
Dirtek Keyboard
ewusbmdm.sys Fri Dec 12 22:27:48 2008
USB Modem/Serial Device Driver - or disable it in the device manager
ATSwpWDF.sys Fri Jun 26 16:08:41 2009
Beta Swipe Fingerprint Sensor WDF USB Driver
AuthenTec, Inc. - or disable it in the device manager
3. Make sure the players you mention are also up to date, 2010 version.
4. First be sure to go thro 1-3 above, if it still crashes then test the CPU and RAM:
CPU - Stress Test with Prime95 - Windows 7 Forums
RAM - Test with Memtest86+ - Windows 7 Forums
All clocks must be optimised defaults as meant by the manufacturer.
Loading Dump File [F:\a\Minidump\D M P\120110-15865-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x86 compatible
Built by: 7600.16385.x86fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0x83009000 PsLoadedModuleList = 0x83148570
Debug session time: Tue Nov 30 12:13:51.890 2010 (UTC - 5:00)
System Uptime: 0 days 0:22:32.123
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
0: kd> !analyze -v
* Bugcheck Analysis *
CLOCK_WATCHDOG_TIMEOUT (101)
An expected clock interrupt was not received on a secondary processor in an
MP system within the allocated interval. This indicates that the specified
processor is hung and not processing interrupts.
Arguments:
Arg1: 00000031, Clock interrupt time out interval in nominal clock ticks.
Arg2: 00000000, 0.
Arg3: 80e02120, The PRCB address of the hung processor.
Arg4: 00000002, 0.
Debugging Details:
BUGCHECK_STR: CLOCK_WATCHDOG_TIMEOUT_4_PROC
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: SplashPro.exe
CURRENT_IRQL: 1c
STACK_TEXT:
83127bc4 830384fa 00000101 00000031 00000000 nt!KeBugCheckEx+0x1e
83127c00 83061b6e 00002711 00000000 00015200 nt!KeAccumulateTicks+0x242
83127c40 83061a1b 8305df46 855d4030 00000000 nt!KeUpdateRunTime+0x145
83127c9c 830663e3 83423a02 83423a02 000000d1 nt!KeUpdateSystemTime+0x613
83127c9c 8305df46 83423a02 83423a02 000000d1 nt!KeUpdateSystemTimeAssist+0x13
83127d20 8305e52e 00000000 0000000e 00000000 nt!SwapContext+0x6
83127d24 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0xce
STACK_COMMAND: kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: CLOCK_WATCHDOG_TIMEOUT_4_PROC_ANALYSIS_INCONCLUSIVE
Followup: MachineOwner
0: kd> lmsmtn
start end module name
83e08000 83e50000 ACPI ACPI.sys Mon Jul 13 19:11:11 2009 (4A5BBF0F)
89fa0000 89ffa000 afd afd.sys Mon Jul 13 19:12:34 2009 (4A5BBF62)
8fe18000 8fe2a000 AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
83f6f000 83f78000 amdxata amdxata.sys Tue May 19 13:57:35 2009 (4A12F30F)
9c5e0000 9c5e9000 asyncmac asyncmac.sys Mon Jul 13 19:54:46 2009 (4A5BC946)
83f2b000 83f34000 atapi atapi.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
83f34000 83f57000 ataport ataport.SYS Mon Jul 13 19:11:18 2009 (4A5BBF16)
8fce4000 8fe18000 athr athr.sys Thu Sep 02 05:05:36 2010 (4C7F68E0)
96614000 966b3500 ATSwpWDF ATSwpWDF.sys Fri Jun 26 16:08:41 2009 (4A452AC9)
83eaf000 83eba000 BATTC BATTC.SYS Mon Jul 13 19:19:15 2009 (4A5BC0F3)
89f0c000 89f13000 Beep Beep.SYS Mon Jul 13 19:45:00 2009 (4A5BC6FC)
8fcb5000 8fcc3000 blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
83c94000 83c9c000 BOOTVID BOOTVID.dll Mon Jul 13 21:04:34 2009 (4A5BD9A2)
96400000 96419000 bowser bowser.sys Mon Jul 13 19:14:21 2009 (4A5BBFCD)
94000000 9401e000 cdd cdd.dll unavailable (00000000)
9c5a9000 9c5bf000 cdfs cdfs.sys Mon Jul 13 19:11:14 2009 (4A5BBF12)
89ee6000 89f05000 cdrom cdrom.sys Mon Jul 13 19:11:24 2009 (4A5BBF1C)
83cde000 83d89000 CI CI.dll Mon Jul 13 21:09:28 2009 (4A5BDAC8)
89e8e000 89eb3000 CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
83c9c000 83cde000 CLFS CLFS.SYS Mon Jul 13 19:11:10 2009 (4A5BBF0E)
91f72000 91f75700 CmBatt CmBatt.sys Mon Jul 13 19:19:18 2009 (4A5BC0F6)
8998b000 899e8000 cng cng.sys Mon Jul 13 19:32:55 2009 (4A5BC427)
83ea7000 83eaf000 compbatt compbatt.sys Mon Jul 13 19:19:18 2009 (4A5BC0F6)
91412000 9141f000 CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
9671f000 9672c000 crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
8fc39000 8fc9d000 csc csc.sys Mon Jul 13 19:15:08 2009 (4A5BBFFC)
8fc9d000 8fcb5000 dfsc dfsc.sys Mon Jul 13 19:14:16 2009 (4A5BBFC8)
89bcf000 89bdb000 discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
89e7d000 89e8e000 disk disk.sys Mon Jul 13 19:11:28 2009 (4A5BBF20)
91f8e000 91f98000 DKbFltr DKbFltr.sys Wed Mar 25 23:10:12 2009 (49CAF214)
8ff8d000 8ffa6000 drmk drmk.sys Mon Jul 13 20:36:05 2009 (4A5BD2F5)
9672c000 96737000 dump_dumpata dump_dumpata.sys Mon Jul 13 19:11:16 2009 (4A5BBF14)
96741000 96752000 dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
96737000 96741000 dump_msahci dump_msahci.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
965e5000 965ef000 Dxapi Dxapi.sys Mon Jul 13 19:25:25 2009 (4A5BC265)
91d9e000 91e55000 dxgkrnl dxgkrnl.sys Mon Jul 13 19:26:15 2009 (4A5BC297)
91e55000 91e8e000 dxgmms1 dxgmms1.sys Mon Jul 13 19:25:25 2009 (4A5BC265)
965ef000 96608280 ewusbfake ewusbfake.sys Mon Dec 29 22:57:53 2008 (49599C41)
9c578000 9c591180 ewusbmdm ewusbmdm.sys Fri Dec 12 22:27:48 2008 (49432BB4)
83fac000 83fbd000 fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
83f78000 83fac000 fltmgr fltmgr.sys Mon Jul 13 19:11:13 2009 (4A5BBF11)
899f6000 899ff000 Fs_Rec Fs_Rec.sys Mon Jul 13 19:11:14 2009 (4A5BBF12)
89e4b000 89e7d000 fvevol fvevol.sys Mon Jul 13 19:13:01 2009 (4A5BBF7D)
89d85000 89db6000 fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
83409000 83440000 hal halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
91e8e000 91ead000 HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
91ead000 91eb7080 HECI HECI.sys Thu Sep 17 15:54:12 2009 (4AB293E4)
966bf000 966d2000 HIDCLASS HIDCLASS.SYS Mon Jul 13 19:51:01 2009 (4A5BC865)
966d2000 966d8480 HIDPARSE HIDPARSE.SYS Mon Jul 13 19:50:59 2009 (4A5BC863)
966b4000 966bf000 hidusb hidusb.sys Mon Jul 13 19:51:04 2009 (4A5BC868)
96523000 965d8000 HSX_CNXT HSX_CNXT.sys Fri Feb 13 15:57:25 2009 (4995DEB5)
96421000 96523000 HSX_DPV HSX_DPV.sys Fri Feb 13 16:00:17 2009 (4995DF61)
962dc000 96319000 HSXHWAZL HSXHWAZL.sys Fri Feb 13 15:58:15 2009 (4995DEE7)
96319000 9639e000 HTTP HTTP.sys Mon Jul 13 19:12:53 2009 (4A5BBF75)
89e43000 89e4b000 hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
91f76000 91f8e000 i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B)
96018000 9602f000 idmwfp idmwfp.sys Wed Nov 03 08:42:38 2010 (4CD158BE)
963ee000 963ff000 int15 int15.sys Wed Oct 01 01:29:49 2003 (3F7A664D)
91400000 91412000 intelppm intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07)
91f12000 91f68000 k57nd60x k57nd60x.sys Tue Jun 08 07:40:36 2010 (4C0E2C34)
91f98000 91fa5000 kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
80bb7000 80bbf000 kdcom kdcom.dll Mon Jul 13 21:08:58 2009 (4A5BDAAA)
8feb4000 8fee8000 ks ks.sys Mon Jul 13 19:45:13 2009 (4A5BC709)
89978000 8998b000 ksecdd ksecdd.sys Mon Jul 13 19:11:56 2009 (4A5BBF3C)
89af4000 89b19000 ksecpkg ksecpkg.sys Mon Jul 13 19:34:00 2009 (4A5BC468)
96787000 96797000 lltdio lltdio.sys Mon Jul 13 19:53:18 2009 (4A5BC8EE)
96752000 9676d000 luafv luafv.sys Mon Jul 13 19:15:44 2009 (4A5BC020)
83c0b000 83c83000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:06:41 2009 (4A5BDA21)
96419000 9641c180 mdmxsdk mdmxsdk.sys Mon Jun 19 17:26:59 2006 (449716A3)
965d8000 965e5000 modem modem.sys Mon Jul 13 19:55:24 2009 (4A5BC96C)
96609000 96614000 monitor monitor.sys Mon Jul 13 19:25:58 2009 (4A5BC286)
91fde000 91feb000 mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
966f0000 966fb000 mouhid mouhid.sys Mon Jul 13 19:45:08 2009 (4A5BC704)
83f15000 83f2b000 mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
9639e000 963b0000 mpsdrv mpsdrv.sys Mon Jul 13 19:52:52 2009 (4A5BC8D4)
963b0000 963d3000 mrxsmb mrxsmb.sys Mon Jul 13 19:14:24 2009 (4A5BBFD0)
8ffa6000 8ffe1000 mrxsmb10 mrxsmb10.sys Mon Jul 13 19:14:34 2009 (4A5BBFDA)
963d3000 963ee000 mrxsmb20 mrxsmb20.sys Mon Jul 13 19:14:29 2009 (4A5BBFD5)
83f57000 83f61000 msahci msahci.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
89f65000 89f70000 Msfs Msfs.SYS Mon Jul 13 19:11:26 2009 (4A5BBF1E)
83e59000 83e61000 msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
8994d000 89978000 msrpc msrpc.sys Mon Jul 13 19:11:59 2009 (4A5BBF3F)
89bc5000 89bcf000 mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
89e33000 89e43000 mup mup.sys Mon Jul 13 19:14:14 2009 (4A5BBFC6)
899ff000 89ab6000 ndis ndis.sys Mon Jul 13 19:12:24 2009 (4A5BBF58)
91ff4000 91fff000 ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
967dd000 967ed000 ndisuio ndisuio.sys Mon Jul 13 19:53:51 2009 (4A5BC90F)
8fe42000 8fe64000 ndiswan ndiswan.sys Mon Jul 13 19:54:34 2009 (4A5BC93A)
8ff3a000 8ff4b000 NDProxy NDProxy.SYS Mon Jul 13 19:54:27 2009 (4A5BC933)
89b49000 89b57000 netbios netbios.sys Mon Jul 13 19:53:54 2009 (4A5BC912)
89c00000 89c32000 netbt netbt.sys Mon Jul 13 19:12:18 2009 (4A5BBF52)
89ab6000 89af4000 NETIO NETIO.SYS Mon Jul 13 19:12:35 2009 (4A5BBF63)
89f70000 89f7e000 Npfs Npfs.SYS Mon Jul 13 19:11:31 2009 (4A5BBF23)
89bbb000 89bc5000 nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
83009000 83409000 nt ntkrnlmp.exe Mon Jul 13 19:15:08 2009 (4A5BBFFC)
8981e000 8994d000 Ntfs Ntfs.sys Mon Jul 13 19:12:05 2009 (4A5BBF45)
89f05000 89f0c000 Null Null.SYS Mon Jul 13 19:11:12 2009 (4A5BBF10)
91d9c000 91d9d080 nvBridge nvBridge.kmd Sat Oct 31 04:21:51 2009 (4AEBF39F)
8ff4b000 8ff5e000 nvhda32v nvhda32v.sys Fri Aug 21 16:23:35 2009 (4A8F0247)
91427000 91d9b300 nvlddmkm nvlddmkm.sys Sat Oct 31 04:37:52 2009 (4AEBF760)
96797000 967dd000 nwifi nwifi.sys Mon Jul 13 19:51:59 2009 (4A5BC89F)
89b19000 89b38000 pacer pacer.sys Mon Jul 13 19:53:58 2009 (4A5BC916)
83e96000 83ea7000 partmgr partmgr.sys Mon Jul 13 19:11:35 2009 (4A5BBF27)
83e61000 83e8b000 pci pci.sys Mon Jul 13 19:11:16 2009 (4A5BBF14)
83f61000 83f6f000 PCIIDEX PCIIDEX.SYS Mon Jul 13 19:11:15 2009 (4A5BBF13)
899e8000 899f6000 pcw pcw.sys Mon Jul 13 19:11:10 2009 (4A5BBF0E)
9c401000 9c498000 peauth peauth.sys Mon Jul 13 20:35:44 2009 (4A5BD2E0)
8ff5e000 8ff8d000 portcls portcls.sys Mon Jul 13 19:51:00 2009 (4A5BC864)
83c83000 83c94000 PSHED PSHED.dll Mon Jul 13 21:09:36 2009 (4A5BDAD0)
83fbd000 83fc1bc0 PxHelp20 PxHelp20.sys Tue Oct 28 14:25:49 2003 (3F9EB4AD)
8fe2a000 8fe42000 rasl2tp rasl2tp.sys Mon Jul 13 19:54:33 2009 (4A5BC939)
8fe64000 8fe7c000 raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
8fe7c000 8fe93000 raspptp raspptp.sys Mon Jul 13 19:54:47 2009 (4A5BC947)
8fe93000 8feaa000 rassstp rassstp.sys Mon Jul 13 19:54:57 2009 (4A5BC951)
89b7a000 89bbb000 rdbss rdbss.sys Mon Jul 13 19:14:26 2009 (4A5BBFD2)
8feaa000 8feb4000 rdpbus rdpbus.sys Mon Jul 13 20:02:40 2009 (4A5BCB20)
89f4d000 89f55000 RDPCDD RDPCDD.sys Mon Jul 13 20:01:40 2009 (4A5BCAE4)
89f55000 89f5d000 rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
89f5d000 89f65000 rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
89e06000 89e33000 rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
967ed000 96800000 rspndr rspndr.sys Mon Jul 13 19:53:20 2009 (4A5BC8F0)
96035000 962db740 RTKVHDA RTKVHDA.sys Tue Oct 13 05:38:46 2009 (4AD44AA6)
9c498000 9c4a2000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
89dfe000 89e06000 spldr spldr.sys Mon May 11 12:13:47 2009 (4A084EBB)
9c527000 9c578000 srv srv.sys Mon Jul 13 19:15:10 2009 (4A5BBFFE)
9c4d8000 9c527000 srv2 srv2.sys Mon Jul 13 19:14:52 2009 (4A5BBFEC)
9c4a2000 9c4c3000 srvnet srvnet.sys Mon Jul 13 19:14:45 2009 (4A5BBFE5)
9141f000 91420380 swenum swenum.sys Mon Jul 13 19:45:08 2009 (4A5BC704)
91fa5000 91fdb400 SynTP SynTP.sys Thu Sep 03 20:32:25 2009 (4AA06019)
89c3c000 89d85000 tcpip tcpip.sys Mon Jul 13 19:13:18 2009 (4A5BBF8E)
9c4c3000 9c4d0000 tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
89f95000 89fa0000 TDI TDI.SYS Mon Jul 13 19:12:12 2009 (4A5BBF4C)
89f7e000 89f95000 tdx tdx.sys Mon Jul 13 19:12:10 2009 (4A5BBF4A)
89b6a000 89b7a000 termdd termdd.sys Mon Jul 13 20:01:35 2009 (4A5BCADF)
943d0000 943d9000 TSDDD TSDDD.dll unavailable (00000000)
8fcc3000 8fce4000 tunnel tunnel.sys Mon Jul 13 19:54:03 2009 (4A5BC91B)
8fee8000 8fef6000 umbus umbus.sys Mon Jul 13 19:51:38 2009 (4A5BC88A)
966d9000 966f0000 usbccgp usbccgp.sys Mon Jul 13 19:51:31 2009 (4A5BC883)
91fdc000 91fdd700 USBD USBD.SYS Mon Jul 13 19:51:05 2009 (4A5BC869)
91eb8000 91ec7000 usbehci usbehci.sys Mon Jul 13 19:51:14 2009 (4A5BC872)
8fef6000 8ff3a000 usbhub usbhub.sys Mon Jul 13 19:52:06 2009 (4A5BC8A6)
91ec7000 91f12000 USBPORT USBPORT.SYS Mon Jul 13 19:51:13 2009 (4A5BC871)
9c592000 9c5a9000 USBSTOR USBSTOR.SYS Mon Jul 13 19:51:19 2009 (4A5BC877)
966fb000 9671eb00 usbvideo usbvideo.sys Mon Jul 13 19:51:51 2009 (4A5BC897)
83e8b000 83e96000 vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
89f13000 89f1f000 vga vga.sys Mon Jul 13 19:25:50 2009 (4A5BC27E)
89f1f000 89f40000 VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
89db6000 89dbe380 vmstorfl vmstorfl.sys Mon Jul 13 19:28:44 2009 (4A5BC32C)
83eba000 83eca000 volmgr volmgr.sys Mon Jul 13 19:11:25 2009 (4A5BBF1D)
83eca000 83f15000 volmgrx volmgrx.sys Mon Jul 13 19:11:41 2009 (4A5BBF2D)
89dbf000 89dfe000 volsnap volsnap.sys Mon Jul 13 19:11:34 2009 (4A5BBF26)
91f68000 91f72000 vwifibus vwifibus.sys Mon Jul 13 19:52:02 2009 (4A5BC8A2)
89b38000 89b49000 vwififlt vwififlt.sys Mon Jul 13 19:52:03 2009 (4A5BC8A3)
89b57000 89b6a000 wanarp wanarp.sys Mon Jul 13 19:55:02 2009 (4A5BC956)
89f40000 89f4d000 watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
83d89000 83dfa000 Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
83dfa000 83e08000 WDFLDR WDFLDR.SYS Mon Jul 13 19:11:25 2009 (4A5BBF1D)
89c32000 89c39000 wfplwf wfplwf.sys Mon Jul 13 19:53:51 2009 (4A5BC90F)
94170000 943ba000 win32k win32k.sys unavailable (00000000)
91feb000 91ff4000 wmiacpi wmiacpi.sys Mon Jul 13 19:19:16 2009 (4A5BC0F4)
83e50000 83e59000 WMILIB WMILIB.SYS Mon Jul 13 19:11:22 2009 (4A5BBF1A)
9676d000 96787000 WudfPf WudfPf.sys Mon Jul 13 19:50:13 2009 (4A5BC835)
9c5bf000 9c5df480 WUDFRd WUDFRd.sys Mon Jul 13 19:50:44 2009 (4A5BC854)
9c4d0000 9c4d8000 XAudio32 XAudio32.sys Wed Apr 29 14:20:55 2009 (49F89A87)
Unloaded modules:
9c5e9000 9c653000 spsys.sys
Checksum: 00000000
ImageSize: 0006A000
96000000 96018000 parport.sys
Checksum: 00000000
ImageSize: 00018000
89eb3000 89ec0000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000D000
89ec0000 89ecb000 dump_pciidex
Checksum: 00000000
ImageSize: 0000B000
89ecb000 89ed5000 dump_msahci.
Checksum: 00000000
ImageSize: 0000A000
89ed5000 89ee6000 dump_dumpfve
Checksum: 00000000
ImageSize: 00011000
