Hi.
i just want to ask for help on how to solve random blue screen of deaths on my newly purchased netbook.
if i'm not mistaken it is caused by these drivers: ntoskrnl.exe and ntfs.sys ; i don't know how to fix the problem.
i've already brought it back where i purchased it and they sent it on repair but when i start it up again, it crashed again as soon as i finished the set up so i tried to solve the problem by installing RegClean Pro and on 1st scan it fixed almost 180 errors. i thought i finally solved the problem because i was able to use my netbook for almost 2 hours without
the BSOD but when i start it up after more than 24hrs of being shut down, it crashed again. i hope you can help me solve this problem, it's very annoying and frustrating!!!!
I have attached the dump files and other things as instructed..
hope to hear from you soon!! Thanks in advance!!!
