Windows 7 BSOD crashes please help! mini dumps attached
haz
hey everyone,
My computer has been playing up lately and giving me blue screens, I have attached some mini dumps and if someone could analise them that would be muchly appreciated :)
The computer is used fot mainly gaming and specs are -
fx-8150 - h80 liquid cooled
8gb ram
gtx 580
1000w power supply
if anymore info is needed please say so :)
cheers, haz
The XBox controller is known to cause BSOD's and isn't able to be updated (there are no newer drivers).
Un-install it to test if it's the cause of BSOD's - if it's not, you can easily reinstall it.
Please provide this information to assist us further: Link Removed
FNETURPX.SYS Fri Oct 3 22:27:02 2008 (48E6D476)
FNet Turbo HDD USB Driver - Also part of AsRock XFastUSB package - Please just un-install this one as it's a known problem
MBfilt64.sys Thu Jul 30 23:40:32 2009 (4A7267B0)
Realtek HiDefinition Audio driver (file labelled as Creative Audio Driver)
xusb21.sys Thu Aug 13 18:10:17 2009 (4A848F49)
XBox USB wireless controller - A known cause of BSOD's in Win7, and no updates are available. Please un-install this one.
usbfilter.sys Wed Oct 7 03:44:08 2009 (4ACC46C8)
AMD USB Filter Driver (likely part of the chipset drivers)
Link Removed - Invalid URL
If you can't locate this one, post back with the exact make and model of your motherboard
Please uninstall your Apple charger as they have been known to cause BSOD's recently.
Razer Synapse driver dates from 2010 - some issues have been seen in the past. Check the Razer site for updates
Analysis:
[font=lucida console]**************************Sun Aug 26 00:44:35.154 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082612-27471-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 4:22:31.295[/B]
BugCheck Code: [B]BugCheck 3B, {c0000005, 0, fffff88006fc5730, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiSystemServiceHandler+7c )[/B]
BugCheck Info: [B]SYSTEM_SERVICE_EXCEPTION (3b)[/B]
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]explorer.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!KiSystemServiceHandler+7c[/B]
  Manufacturer                  To Be Filled By O.E.M.
  Product Name                  To Be Filled By O.E.M.
  BIOS Version                  P1.50
  BIOS Release Date             11/17/2011
**************************Sat Aug 25 03:22:12.247 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082512-23992-01.dmp]
System Uptime:[B]0 days 0:22:35.386[/B]
BugCheck Code: [B]BugCheck 3B, {c0000005, fffff80003457284, fffff88006e2bbd0, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+15b82 )[/B]
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!_??_::FNODOBFM::_string_+15b82[/B]
  BIOS Version                  P1.50
[/font]
3rd Party Drivers:
The following is for information purposes only. Any drivers in red should be updated.
[B]FNETURPX.SYS                Fri Oct  3 22:27:02 2008 (48E6D476)[/B]
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
AsrAppCharger.sys           Fri Jun 11 02:37:12 2010 (4C11D998)
tmtdi.sys                   Tue Jul 20 04:58:07 2010 (4C45651F)
tmevtmgr.sys                Wed Jul 21 03:31:15 2010 (4C46A243)
tmcomm.sys                  Wed Jul 21 03:31:15 2010 (4C46A243)
tmactmon.sys                Wed Jul 21 03:31:24 2010 (4C46A24C)
FNETTBOH_305.SYS            Wed Nov  3 02:24:26 2010 (4CD1001A)
RzSynapse.sys               Wed Dec 15 05:32:19 2010 (4D089933)
EtronXHCI.sys               Fri Jan 28 16:46:43 2011 (4D433943)
EtronHub3.sys               Fri Jan 28 16:46:45 2011 (4D433945)
k57nd60a.sys                Tue May 10 00:42:30 2011 (4DC8C236)
RTKVHD64.sys                Tue May 24 08:32:39 2011 (4DDBA567)
nvhda64v.sys                Wed Apr 18 13:07:54 2012 (4F8EF4EA)
nvlddmkm.sys                Tue May 15 03:35:36 2012 (4FB20748)
[/font]
thankyou for your reply, sorry about not posting properly and I will do so in the future.
I have unistalled that xfast turbo usb program thing and hopefully that will make the difference, I dont really want to uninstall the xbox wireless reciever as I use it alot. Anyways I've attached some additional information if there is anymore suggestions.
Cheers haz, :)
  • DriverList.txt
    DriverList.txt
  • Systeminfo.txt
    Systeminfo.txt
