Kilab
Hi there guys,
I am having some annoying BSOD problems that I was hoping to get a little help with.Seems to happen randomly and looking at Blue screen viewer it seems to be mainly System_Service_Exception 0x0000003b /0x1000007e or Memory_Management.
So far I have
-Re installed windows -7 64 bit ultimate
- Memtest with prime 95
- Flashed Bios -Gigabyte p55A-UD4 to F15
- Cleared out and reinstalled graphics drivers/ 5850 crossfire <- hoping that last bit is not causing this
Running Kaspersky 6.0 Antivirus/Firewall. Attached are the Dump files since i reinstalled Windows + CPUZ
Thanks in advance for any help.
  • Minidump.rar
    Minidump.rar
Thanks Cybercore.
The answer is sometimes the simplest. Ran Memtest and had a huge amount of errors in the first five minutes.Took out all my ram and reset all and what do you know, No errors. Sigh I feel like a bit of a muppet but at least I wont have the hassles of RMA. Not yet at least.
Thanks to all for your help.
Welcome.
Uninstall VirtualCloneDrive. Replace with PowerISO.
Uninstall UltraMon.
Uninstall your Defragment software which is too old, to get rid of this:
DefragFS DefragFS.SYS Wed Jan 07 08:35:48 2009
Navigate to C:\Windows\System32\drivers and delete:
ElbyCDIO ElbyCDIO.sys Tue Feb 17 12:11:23 2009
Reboot. Then update Realtek lan:
Rt64win7 Rt64win7.sys Thu Feb 26 04:04:13 2009
Thanks for the rapid response. Will implement changes now and the Chocolate fish is in the post.
Thanks again.
I could not find ElbyCDIO ElbyCDIO.sys Tue Feb 17 12:11:23 2009 in the system 32 folder. Hidden maybe.I just had another blue screen too :(
You didn't even do a single thing. From new crash dump:
4: kd> lmvm elbycdio
fffff880`02cdc000 fffff880`02ce6000   ElbyCDIO   (deferred)
    Image path: \SystemRoot\System32\Drivers\ElbyCDIO.sys
    Image name: ElbyCDIO.sys
    Timestamp:        Tue Feb 17 12:11:23 2009 (499AEFBB)
    CheckSum:         00016F74
    ImageSize:        0000A000
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
4: kd> lmvm vclone
fffff880`00e94000 fffff880`00ea3000   VClone     (deferred)
    Image path: \SystemRoot\system32\DRIVERS\VClone.sys
    Image name: VClone.sys
    Timestamp:        Fri May 22 19:08:37 2009 (4A173075)
    CheckSum:         000185FF
    ImageSize:        0000F000
4: kd> lmvm rt64win7
fffff880`056f8000 fffff880`0572a000   Rt64win7   (deferred)
    Image path: \SystemRoot\system32\DRIVERS\Rt64win7.sys
    Image name: Rt64win7.sys
    Timestamp:        Thu Feb 26 04:04:13 2009 (49A65B0D)
    CheckSum:         000361A5
    ImageSize:        00032000
4: kd> lmvm UltraMonUtility
fffff880`02ba7000 fffff880`02bb0000   UltraMonUtility   (deferred)
    Image path: \??\C:\Program Files (x86)\Common Files\Realtime Soft\UltraMonMirrorDrv\x64\UltraMonUtility.sys
    Image name: UltraMonUtility.sys
    Timestamp:        Thu Nov 13 20:10:30 2008 (491CD006)
    CheckSum:         00007FCE
    ImageSize:        00009000
4: kd> lmvm DefragFS
fffff880`08960000 fffff880`0897c000   DefragFS   (deferred)
    Image path: \SystemRoot\System32\Drivers\DefragFS.SYS
    Image name: DefragFS.SYS
    Timestamp:        Wed Jan 07 08:35:48 2009 (4964AFB4)
    CheckSum:         000186D3
    ImageSize:        0001C000
So ya, remove/uninstall/update those as above.
Unfortunately though, it's likely that those things aren't going to help but still should be done for sure. I've already given all my advice necessary here, so with that, hope you do well....
Your memory is likely defective and you will have to replace it entirely with a brand new matching set for best stability, reliability and performance, if the software issues do not fix it.
Enjoy the new hardware when you obtain it, if it's necessary.
Of course, anyone else is perfectly welcome to respond here, so anyone please do so if you wish.
Good luck.
I think it must be hardware related as I have followed all steps and it is still happening.However I am not sure why some of those apps were showing in that dump file as I had already uninstalled them and updated realtec.The only left over drivers in the System32 driver folder were Rt64win7.sys which has to stay for Realtec Lan and Vclone.sys which i deleted.Anyway thanks for the help, I will reinstall windows one more time and test before The Ram is RMA'd
I'm 97% certain that you need to replace the memory, but I can not give you the TorrentG guarantee without seeing a "clean" crash dump, which means that you've taken care of all the software issues stated.
So it is in your best interest to make sure you have, and then post a new crash dump after.
Once I see this "clean" crash dump, then I can give you the certain word to go ahead and replace RAM.
Ok just had latest BS. I believe I have dealt to all of the issues on the software list so I will be surprised if they show up. Fingers crossed .
Cheers
Run memtest overnight:
RAM - Test with Memtest86+ - Windows 7 Forums
Mind you need to run it 10 passes overnight. Better if you isolate sticks to test them separately and in different slots.
122710-23072-01.dmp
BugCheck 1A, {41790, fffffa80033aeb70, ffff, 0}
MEMORY_MANAGEMENT (1a)
PROCESS_NAME: dwm.exe
Probably caused by : ntkrnlmp.exe
STACK_TEXT:
fffff880`0bac5828 fffff800`02cf9f9e : 00000000`0000001a 00000000`00041790 fffffa80`033aeb70 00000000`0000ffff : nt!KeBugCheckEx
fffff880`0bac5830 fffff800`02cb9df9 : 00000000`00000000 00000000`0b238fff 00000000`00000001 00000000`0000001e : nt! ?? ::FNODOBFM::`string'+0x33906
fffff880`0bac59f0 fffff800`02f9f1d0 : fffffa80`07b79250 0007ffff`00000000 fffffa80`0a2a6a20 fffffa80`0a2a6a20 : nt!MiRemoveMappedView+0xd9
fffff880`0bac5b10 fffff800`02f9f5db : 00000980`00000000 00000000`0b040000 fffffa80`00000001 00000000`0270f201 : nt!MiUnmapViewOfSection+0x1b0
fffff880`0bac5bd0 fffff800`02c85993 : 00000000`00000000 00000000`77483650 fffffa80`0775f670 00000000`00000000 : nt!NtUnmapViewOfSection+0x5f
fffff880`0bac5c20 00000000`7739fffa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0270f078 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7739fffa
Unisnstall Kaspersky with the use of its official uninstaller:
Removal tool for Kaspersky Lab products
Link Removed due to 404 Error
Kaspersky was not involved in your crashes but it is rather notorious and yours is outdated - Sep. 2009. So uninstall it to get a "cleaner" list. If despite all you keep getting BSOD's, it's your RAM. --> MEMORY_MANAGEMENT (1a).
[Crash Dump
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Loading Dump File [C:\Documents and Settings\XPMUser\My Documents\122710-23072-01.dmp]
Symbol search path is: SRV*C:\Documents and Settings\XPMUser\My Documents\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02c16000 PsLoadedModuleList = 0xfffff800`02e53e50
Debug session time: Mon Dec 27 21:59:51.834 2010 (UTC - 5:00)
System Uptime: 0 days 2:42:22.833
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+33906 )
Followup: MachineOwner
6: kd> !analyze -v
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041790, The subtype of the bugcheck.
Arg2: fffffa80033aeb70
Arg3: 000000000000ffff
Arg4: 0000000000000000
Debugging Details:
BUGCHECK_STR:  0x1a_41790
CUSTOMER_CRASH_COUNT:  1
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002cf9f9e to fffff80002c86740
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02cf9f9e cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+33906
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
FAILURE_BUCKET_ID:  X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+33906
Drivers
fffff880`049a6000 fffff880`049e4000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00ec3000 fffff880`00f1a000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02caa000 fffff880`02d34000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0482d000 fffff880`04843000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`010ae000 fffff880`010b9000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`00fdd000 fffff880`00fe6000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01084000 fffff880`010ae000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`05db2000 fffff880`05dd2000   AtihdW76 AtihdW76.sys Wed Nov 17 07:02:04 2010 (4CE3C43C)
fffff880`04a5e000 fffff880`0526f000   atikmdag atikmdag.sys Thu Nov 25 21:46:44 2010 (4CEF1F94)
fffff880`04874000 fffff880`048c0000   atikmpag atikmpag.sys Thu Nov 25 21:16:47 2010 (4CEF188F)
fffff960`00940000 fffff960`009a1000   ATMFD    ATMFD.DLL    Tue Oct 19 23:05:45 2010 (4CBE5C89)
fffff880`00f8b000 fffff880`00f97000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`018e1000 fffff880`018e8000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`0401e000 fffff880`0402f000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`02b91000 fffff880`02baf000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00610000 fffff960`00637000   cdd      cdd.dll      Wed May 19 15:48:26 2010 (4BF4408A)
fffff880`07da3000 fffff880`07dc0000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
fffff880`01866000 fffff880`01890000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01800000 fffff880`01830000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d2a000 fffff880`00d88000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05613000 fffff880`057d8000   cmudaxp  cmudaxp.sys  Wed Sep 15 23:41:13 2010 (4C9191D9)
fffff880`01177000 fffff880`011ea000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`00f82000 fffff880`00f8b000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`0481d000 fffff880`0482d000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03cf2000 fffff880`03cfb000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`05c68000 fffff880`05c76000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04577000 fffff880`045fa000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`04000000 fffff880`0401e000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02c96000 fffff880`02ca5000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`019ce000 fffff880`019e4000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`057d8000 fffff880`057fa000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`05dde000 fffff880`05de7000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`05dd2000 fffff880`05dde000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`05de7000 fffff880`05dfa000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`05c5c000 fffff880`05c68000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0526f000 fffff880`05363000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`05363000 fffff880`053a9000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`02b5b000 fffff880`02b91000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`01105000 fffff880`01119000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010b9000 fffff880`01105000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01200000 fffff880`0120a000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01994000 fffff880`019ce000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01000000 fffff880`0104a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`031f2000 fffff800`0323b000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`053a9000 fffff880`053cd000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`05c00000 fffff880`05c5c000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`00fe6000 fffff880`00fff000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`05c76000 fffff880`05c7e080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0184d000 fffff880`0185b000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`02a00000 fffff880`02ac8000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`0198b000 fffff880`01994000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`0402f000 fffff880`04045000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`05d11000 fffff880`05d20000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`01070000 fffff880`0107e000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bb1000 fffff800`00bbb000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0404e000 fffff880`04577000   kl1      kl1.sys      Wed Nov 11 06:30:15 2009 (4AFAA047)
fffff880`053da000 fffff880`053e5000   klfltdev klfltdev.sys Thu Sep 03 08:23:27 2009 (4A9FB53F)
fffff880`01890000 fffff880`018d8000   klif     klif.sys     Mon Aug 02 11:21:26 2010 (4C56E276)
fffff880`02da8000 fffff880`02db2000   klim6    klim6.sys    Fri Apr 09 09:41:31 2010 (4BBF2E8B)
fffff880`048fd000 fffff880`04940000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013d1000 fffff880`013eb000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`057fa000 fffff880`057ff200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`02b2e000 fffff880`02b43000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`02aea000 fffff880`02b0d000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00cd2000 fffff880`00d16000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`011ea000 fffff880`011f8000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`05d20000 fffff880`05d2f000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`00e00000 fffff880`00e0d000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00fc3000 fffff880`00fdd000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02baf000 fffff880`02bc7000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`02bc7000 fffff880`02bf4000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`03c81000 fffff880`03ccf000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`03ccf000 fffff880`03cf2000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`015d6000 fffff880`015e1000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f23000 fffff880`00f2d000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01119000 fffff880`01177000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02c8b000 fffff880`02c96000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01979000 fffff880`0198b000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014d2000 fffff880`015c4000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04867000 fffff880`04873000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`05c81000 fffff880`05cb0000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`05d9d000 fffff880`05db2000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02db2000 fffff880`02dc1000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d34000 fffff880`02d79000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`015e1000 fffff880`015f2000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02c7f000 fffff880`02c8b000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c16000 fffff800`031f2000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`0122e000 fffff880`013d1000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`018d8000 fffff880`018e1000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02d82000 fffff880`02da8000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`04800000 fffff880`0481d000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00f6d000 fffff880`00f82000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f2d000 fffff880`00f60000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fac000 fffff880`00fb3000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fb3000 fffff880`00fc3000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013eb000 fffff880`013fc000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`03cfb000 fffff880`03da1000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`048c0000 fffff880`048fd000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00d16000 fffff880`00d2a000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04843000 fffff880`04867000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`05cb0000 fffff880`05ccb000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`05ccb000 fffff880`05cec000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`05cec000 fffff880`05d06000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02c2e000 fffff880`02c7f000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`05d06000 fffff880`05d11000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`019f2000 fffff880`019fb000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`015c4000 fffff880`015cd000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`015cd000 fffff880`015d6000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0193f000 fffff880`01979000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02b43000 fffff880`02b5b000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04940000 fffff880`049a6000   Rt64win7 Rt64win7.sys Tue Nov 30 01:01:28 2010 (4CF49338)
fffff880`02c14000 fffff880`02c2e000   SCDEmu   SCDEmu.SYS   Mon Apr 12 04:52:25 2010 (4BC2DF49)
fffff880`03da1000 fffff880`03dac000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`05600000 fffff880`0560c000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02dc1000 fffff880`02dde000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01937000 fffff880`0193f000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`07cdc000 fffff880`07d72000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`03c00000 fffff880`03c67000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`03dac000 fffff880`03dd9000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`05d2f000 fffff880`05d30480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01600000 fffff880`017fd000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`03dd9000 fffff880`03deb000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`015f2000 fffff880`015ff000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`0120a000 fffff880`01228000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02c00000 fffff880`02c14000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00530000 fffff960`0053a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`0104a000 fffff880`01070000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`05d31000 fffff880`05d43000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`00de4000 fffff880`00dfec00   usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`01830000 fffff880`0184d000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`05dfa000 fffff880`05dfbf00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`053e5000 fffff880`053f6000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`05d43000 fffff880`05d9d000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04a00000 fffff880`04a56000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`049e4000 fffff880`049ff000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`053cd000 fffff880`053da000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00f60000 fffff880`00f6d000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`019e4000 fffff880`019f2000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`0149b000 fffff880`014c0000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`0148b000 fffff880`0149b000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00f97000 fffff880`00fac000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d88000 fffff880`00de4000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`018eb000 fffff880`01937000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02dde000 fffff880`02df9000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`014c0000 fffff880`014d0000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e10000 fffff880`00eb4000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00eb4000 fffff880`00ec3000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d79000 fffff880`02d82000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`00370000   win32k   win32k.sys   Tue Oct 19 23:08:46 2010 (4CBE5D3E)
fffff880`053f6000 fffff880`053ff000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f1a000 fffff880`00f23000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02b0d000 fffff880`02b2e000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`07c00000 fffff880`07c31000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`07dc0000 fffff880`07df1000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`07d72000 fffff880`07da3000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`01830000 fffff880`0183e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0183e000 fffff880`0184a000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0184a000 fffff880`01853000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01853000 fffff880`01866000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Thanks Cybercore.
Unfortunately I spoke way to soon it seems. Although I have tested my Ram for ten plus hours with no errors I am still getting BSOD. I am fairly convinced it is hardware related but I have attached the latest dump files to see if any light can be shed on the problem. These blue screens seemed to start happening around about the time I bought a second 5850 for crossfiring (not exactly sure on this though).My first card is a slightly overclocked Gigabyte card while the second is a stock standard Saphirre model.Could the difference in the clocks of the two cards be causing these problems? Just a thought?
If the dumps dont show anything glaringly obvious my next course of action is to remove all drives bar C:/second graphics card/Audio card and reinstall WIn7 and wait to see if it continues.
Thanks for your help once again.
BugCheck 3B, {c0000005, fffff80002cda905, fffff8800cdd51d0, 0}
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine
PROCESS_NAME:  firefox.exe
Probably caused by : dxgkrnl.sys ( dxgkrnl!DXGDEVICE::CreateAllocationObjects+be )
1. Uninstall Avast:
2. Update:
DefragFS.SYS Tue Dec 15 05:18:19 2009
Raxco PerfectDisk
3. Reinstall the Catalyst with an earlier more stable release, one before 10.11:
Also,
VERIFY THE RAM SETTINGS - frequency, timings, voltage.
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\011111-20451-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02c67000 PsLoadedModuleList = 0xfffff800`02ea4e50
Debug session time: Tue Jan 11 09:03:40.412 2011 (UTC - 5:00)
System Uptime: 0 days 0:27:22.411
4: kd> !analyze -v
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002cda905, Address of the instruction which caused the bugcheck
Arg3: fffff8800cdd51d0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
nt!ExpInterlockedPopEntrySListFault16+0
fffff800`02cda905 498b08          mov     rcx,qword ptr [r8]
CONTEXT:  fffff8800cdd51d0 -- (.cxr 0xfffff8800cdd51d0)
rax=00000005570e00c8 rbx=0000000000000009 rcx=fffff880009b3840
rdx=006c007500610067 rsi=fffff880009b3840 rdi=0000000000000009
rip=fffff80002cda905 rsp=fffff8800cdd5ba0 rbp=fffffa8006995000
 r8=006c007500610066  r9=fffff80002c67000 r10=fffff880009b3840
r11=fffff8800cdd5d10 r12=0000000000000007 r13=0000000000000000
r14=0000000000000002 r15=000000004b677844
iopl=0         nv up ei pl nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010206
nt!ExpInterlockedPopEntrySListFault16:
fffff800`02cda905 498b08          mov     rcx,qword ptr [r8] ds:002b:006c0075`00610066=????????????????
Resetting default scope
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002e0b646 to fffff80002cda905
STACK_TEXT:
fffff880`0cdd5ba0 fffff800`02e0b646 : 00000000`00000000 00000000`00000801 fffff8a0`02c764e0 fffff880`6d4d6956 : nt!ExpInterlockedPopEntrySListFault16
fffff880`0cdd5bb0 fffff800`02cf8536 : fffff8a0`0b3f0010 00000000`00000009 fffff8a0`0b3f0010 fffff880`050ce3a1 : nt!ExAllocatePoolWithTag+0x276
fffff880`0cdd5ca0 fffff880`050cf0de : 00000000`00000000 fffff880`0cdd5db8 fffff880`0cdd63b0 00000000`00000000 : nt!ExAllocatePoolWithQuotaTag+0x56
fffff880`0cdd5cf0 fffff880`050d0313 : fffff880`0cdd60f0 fffff880`0cdd60f0 fffff880`0cdd6520 00000000`00000000 : dxgkrnl!DXGDEVICE::CreateAllocationObjects+0xbe
fffff880`0cdd5d40 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : dxgkrnl!DXGDEVICE::CreateAllocation+0xa67
FOLLOWUP_IP:
fffff880`050cf0de 488bd8          mov     rbx,rax
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  dxgkrnl!DXGDEVICE::CreateAllocationObjects+be
MODULE_NAME: dxgkrnl
IMAGE_NAME:  dxgkrnl.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ac5509e
STACK_COMMAND:  .cxr 0xfffff8800cdd51d0 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_dxgkrnl!DXGDEVICE::CreateAllocationObjects+be
Drivers:
fffff880`0453d000 fffff880`0457b000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00eee000 fffff880`00f45000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02cac000 fffff880`02d36000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`045bd000 fffff880`045d3000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`01042000 fffff880`0104d000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`02b36000 fffff880`02b3f000   aswFsBlk aswFsBlk.SYS Tue Sep 07 10:47:09 2010 (4C86506D)
fffff880`02afc000 fffff880`02b36000   aswMonFlt aswMonFlt.sys Tue Sep 07 10:47:32 2010 (4C865084)
fffff880`02d36000 fffff880`02d40000   aswRdr   aswRdr.SYS   Tue Sep 07 10:47:47 2010 (4C865093)
fffff880`04104000 fffff880`04127000   aswSP    aswSP.SYS    Tue Sep 07 10:52:07 2010 (4C865197)
fffff880`019eb000 fffff880`019fb000   aswTdi   aswTdi.SYS   Tue Sep 07 10:52:27 2010 (4C8651AB)
fffff880`00e1a000 fffff880`00e23000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01018000 fffff880`01042000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`058da000 fffff880`058fa000   AtihdW76 AtihdW76.sys Wed Nov 17 07:02:04 2010 (4CE3C43C)
fffff880`04885000 fffff880`05096000   atikmdag atikmdag.sys Thu Nov 25 21:46:44 2010 (4CEF1F94)
fffff880`04163000 fffff880`041af000   atikmpag atikmpag.sys Thu Nov 25 21:16:47 2010 (4CEF188F)
fffff960`00920000 fffff960`00981000   ATMFD    ATMFD.DLL    Tue Oct 19 23:05:45 2010 (4CBE5C89)
fffff880`00fb6000 fffff880`00fc2000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`0193f000 fffff880`01946000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`040f3000 fffff880`04104000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`02ac8000 fffff880`02ae6000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00690000 fffff960`006b7000   cdd      cdd.dll      Wed May 19 15:48:26 2010 (4BF4408A)
fffff880`05800000 fffff880`0581d000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
fffff880`0190c000 fffff880`01936000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cde000 fffff880`00d9e000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`018a6000 fffff880`018d6000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c80000 fffff880`00cde000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04217000 fffff880`043dc000   cmudaxp  cmudaxp.sys  Wed Sep 15 23:41:13 2010 (4C9191D9)
fffff880`0110b000 fffff880`0117e000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`00fad000 fffff880`00fb6000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`045ad000 fffff880`045bd000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03d48000 fffff880`03d51000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`05846000 fffff880`05854000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04052000 fffff880`040d5000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`02b60000 fffff880`02b85000   DefragFS DefragFS.SYS Tue Dec 15 05:18:19 2009 (4B27626B)
fffff880`040d5000 fffff880`040f3000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`01890000 fffff880`018a6000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`043dc000 fffff880`043fe000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`05860000 fffff880`05869000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`05854000 fffff880`05860000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`059e7000 fffff880`059fa000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`05990000 fffff880`0599c000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`05096000 fffff880`0518a000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`0518a000 fffff880`051d0000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`02bb2000 fffff880`02be8000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`01099000 fffff880`010ad000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0104d000 fffff880`01099000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01856000 fffff880`01890000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`015ad000 fffff880`015f7000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02c1e000 fffff800`02c67000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`051d0000 fffff880`051f4000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`058fa000 fffff880`05956000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`059c5000 fffff880`059de000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`059de000 fffff880`059e6080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`059b7000 fffff880`059c5000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0184d000 fffff880`01856000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`0414d000 fffff880`04163000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0449c000 fffff880`044ab000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0582a000 fffff880`05838000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00b99000 fffff800`00ba3000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04000000 fffff880`04043000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013de000 fffff880`013f8000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`04200000 fffff880`04205200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`02b85000 fffff880`02b9a000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`018d6000 fffff880`018f9000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c28000 fffff880`00c6c000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`05838000 fffff880`05846000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`044ab000 fffff880`044ba000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0581d000 fffff880`0582a000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e00000 fffff880`00e1a000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02be8000 fffff880`02c00000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`011ca000 fffff880`011f7000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`03cd7000 fffff880`03d25000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`03d25000 fffff880`03d48000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`019a4000 fffff880`019af000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f4e000 fffff880`00f58000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010ad000 fffff880`0110b000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`0183b000 fffff880`0184d000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014bb000 fffff880`015ad000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04400000 fffff880`0440c000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0440c000 fffff880`0443b000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`058c5000 fffff880`058da000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02db4000 fffff880`02dc3000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d40000 fffff880`02d85000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`019af000 fffff880`019c0000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff800`02c67000 fffff800`03243000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`0123b000 fffff880`013de000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01936000 fffff880`0193f000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02d8e000 fffff880`02db4000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`04587000 fffff880`045a4000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00f98000 fffff880`00fad000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f58000 fffff880`00f8b000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fd7000 fffff880`00fde000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fde000 fffff880`00fee000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`03d51000 fffff880`03df7000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`041af000 fffff880`041ec000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c6c000 fffff880`00c80000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`045d3000 fffff880`045f7000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0443b000 fffff880`04456000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04456000 fffff880`04477000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04477000 fffff880`04491000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04491000 fffff880`0449c000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01989000 fffff880`01992000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01992000 fffff880`0199b000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0199b000 fffff880`019a4000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01801000 fffff880`0183b000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02b9a000 fffff880`02bb2000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`044d7000 fffff880`0453d000   Rt64win7 Rt64win7.sys Tue Nov 30 01:01:28 2010 (4CF49338)
fffff880`03c00000 fffff880`03c0b000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`0457b000 fffff880`04587000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02dc3000 fffff880`02de0000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`0149b000 fffff880`014a3000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`05441000 fffff880`054d7000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`03c4a000 fffff880`03cb1000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`03c0b000 fffff880`03c38000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`044ba000 fffff880`044bb480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01603000 fffff880`01800000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`03c38000 fffff880`03c4a000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`019de000 fffff880`019eb000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`019c0000 fffff880`019de000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff960`00570000 fffff960`0057a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`04127000 fffff880`0414d000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`044bc000 fffff880`044ce000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`05975000 fffff880`0598fc00   usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`05956000 fffff880`05973000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`05973000 fffff880`05974f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04863000 fffff880`04874000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0586b000 fffff880`058c5000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`0480d000 fffff880`04863000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0599c000 fffff880`059b7000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`04800000 fffff880`0480d000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00f8b000 fffff880`00f98000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01946000 fffff880`01954000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01954000 fffff880`01979000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00fc2000 fffff880`00fd7000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d9e000 fffff880`00dfa000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0117e000 fffff880`011ca000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02de0000 fffff880`02dfb000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01979000 fffff880`01989000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e3b000 fffff880`00edf000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00edf000 fffff880`00eee000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d85000 fffff880`02d8e000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00050000 fffff960`00360000   win32k   win32k.sys   Tue Oct 19 23:08:46 2010 (4CBE5D3E)
fffff880`045a4000 fffff880`045ad000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f45000 fffff880`00f4e000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02b3f000 fffff880`02b60000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`018d6000 fffff880`018e4000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`018e4000 fffff880`018f0000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`018f0000 fffff880`018f9000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`018f9000 fffff880`0190c000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Hi and thanks Cybercore,
Did all of the above including nuking Perfectdisc completely.Was Ok for a while but got another blue this morning. Continued with testing Ram today and I can't seem to get my machine to post with any of the sticks in Dimm slot 1.Seems dead slot on Mobo is the culprit. I have never had a mobo die on my before is there any other reason it would not post from slot 1.I tried all sticks in the other slots and it posts fine.
Cheers
Kilab
That's the culprit. And you were lucky enough that the memtest showed errors. It doesn't always do why it's a good idea to test sticks per one and in different slots.
Taking the board for RMA today.
Just want to say again thanks for all your help Cybercore and Torrentg. Great that you give up your time to help people though their issues.
Hopefully I should have a shiny new mobo soon and be on my merry way.
Cheers
Kila
Cheers
Kila
OKey, thanks for keeping us updated and wish you have no problems with the new motherboard.
Good luck. : )
