BSOD due to HAL
I have changed nothing I got this BSOOD at o401 AM on 08-01-2010 I know it concerns thw hardware application Layer (HAL) but that is all I can figure out. I have added no new equipment nor software View attachment 080110-48032-01.zip Any and all help is appreciated
Ouch, a 0x124 hardware error:
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Loading Dump File [E:\Temp\Rar$DI00.092\080110-48032-01.dmp]
Symbol search path is: SRV*C:\SymCache*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16539.amd64fre.win7_gdr.100226-1909
Machine Name:
Kernel base = 0xfffff800`0364c000 PsLoadedModuleList = 0xfffff800`03889e50
Debug session time: Sun Aug  1 05:01:23.539 2010 (UTC - 4:00)
System Uptime: 3 days 16:24:39.844
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 124, {0, fffffa800ce3c028, fe000000, 300152}
Probably caused by : hardware
Followup: MachineOwner
4: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800ce3c028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000fe000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000300152, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
Here's the best resource available about 0x124 stops:
Stop 0x124 - what it means and what to try - Windows 7 Forums
Please pay special attention to the first thing listed:
"1) Ensure that none of the hardware components are overclocked. Hardware that is driven beyond its design specifications - by overclocking - can malfunction in unpredictable ways."
